Like Tree11Likes
 Old 05-10-2010, 09:45 AM   #321
[MSF STIG]
FORZDA 1's Avatar
Posts: 1,206   (View Stats)
FORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the worldFORZDA 1 is the leader of the world
Also note that KR goes to 0 abruptly at 5700 RPM while a sweet knock point for the car is 5500 RPM.....
And the recent event I had with severe KR at WOT kinda proved that out. The owner saw 5.8 KR as the engine rev'ed past the "sweet spot" and none after. The engine was >/= 6k rpm when the BIG detonation event happened and I'm "almost" sure at least one rod is bent to the point of knocking.
`07 Speed6 Sport Tit Gray Sleeper Express... SOLD
`11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG
`12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan
`12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket
`17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy
FORZDA 1 is offline   Reply With Quote
 Old 05-10-2010, 10:49 AM   #322
There's more than 1 reason the stock calibration closes the throttle past 5500 RPM. One of them is that the knock sensor goes deaf shortly after.
MPSdriver (05-10-2010)
 Old 05-10-2010, 11:15 AM   #323
Ziggo's Avatar
Posts: 3,843   (View Stats)
Well despite what click says I do get it and I will be paying special attention to timing at low rpm.
FYI 06speed6 diesels don't generally premix unless it is just for reducing charge temp. Diesels inject during the power stroke, and thus have a very flat cylinder pressure curve.
 Old 05-10-2010, 11:22 AM   #324
starscream's Avatar
Posts: 630   (View Stats)
starscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the world
Groans: 44
So with this, does this mean that Flashes/Tunes that allow the stock throttle plates remain wide open past 5500 RPM (think CPE Throttle Flash and Piasini Flash) put those cars more at risk because the knock sensor has a harder time distinguishing knock?
Or is there another element to this I am not seeing based on what you said?
Just curious to know if those flashes are actually doing more harm.
starscream is offline   Reply With Quote
 Old 05-10-2010, 11:27 AM   #325
[MSF STIG]
FORZDA 1's Avatar
Originally Posted by starscream View Post
.....Just curious to know if those flashes are actually doing more harm.
Not really "doing harm", just making more power and as such, definitely increases the odds for a failure somewhere along the line. As all who mod for more power must know, that NOTHING comes without any risk.
 Old 05-10-2010, 11:33 AM   #326
The knock sensor does not work past 5700 RPM. So if you have high KR up to that point, the knock will be worse past that point since KR goes to 0.
 Old 05-10-2010, 11:46 AM   #327
[MSF STIG]
FORZDA 1's Avatar
Yep, the way I understand it, the motor is making so much noise, the sensor is really ineffective. Therefore when we see KR at WOT high rpms, LIFT for safety, OR stay with it for the WIN!
The Following User Says Thank You to FORZDA 1 For This Useful Post:
Lex (05-10-2010)
 Old 05-10-2010, 12:13 PM   #328
SRTie4k's Avatar
Posts: 1,715   (View Stats)
I could rev to 6800RPM in my SRT-4 with the BS chain removed and full solid mounts all around and my knock sensor would still pick up knock all the way to redline. Full stock motor at about 420WHP, I never had a single problem.
So either the DISI is an insanely noisy engine with bad vibration problems, or our knock sensor just plain sucks. Which is it?
 Old 05-10-2010, 12:16 PM   #329
Always FTW!!
kgb (05-10-2010), leadf00t (05-10-2010)
 Old 05-10-2010, 12:17 PM   #330
starscream's Avatar
Groans: 44
I am figuring that its noisy. I mean who knows how it sounds on the inside, but fuck even on the outside shit is all diesel crazy/tick tick/clack clack/whoosh sounding. LOL
The Following User Says Thank You to starscream For This Useful Post:
Swearingen (05-12-2010)
 Old 05-10-2010, 12:18 PM   #331
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
It could be that the frequency of knock on this motor (it all depends on the characteristics of the block etc), and the injector firing (or a harmonic thereof) is misconstrued as knock, thus the ECU ignores it.
A knock sensor is nothing more than a microphone, i find it hard to believe that it just plain sucks.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
FreeFlyFreak (05-12-2010)
 Old 05-10-2010, 12:29 PM   #332
[MSF STIG]
FORZDA 1's Avatar
*Sigh* Direct Injection fires the injectors at ~100 VDC under a fuel pressure of ~1800+psi directly into the CC at max compression, so yeah, it makes a bit of noise too close to the frequency associated with "knock". It has nothing to do with "sucking" or overall engine vibration.
djuosnteisn (05-10-2010)
 Old 05-10-2010, 12:30 PM   #333
Sucking FTW!
DaleNixon (05-11-2010), djuosnteisn (05-10-2010), kgb (05-10-2010)
 Old 05-10-2010, 12:34 PM   #334
SRTie4k's Avatar
What does the injection cycle have to do with the frequency associated with knock?
 Old 05-10-2010, 12:49 PM   #335
[MSF STIG]
FORZDA 1's Avatar
The injection "cycle" requires that the injector must be just a bit more "robust" than the puny little port injectors operating at maybe 60 psi. If you still don't understand the why/how an injector firing 60 psi into a vacuum/low-pressure intake runner vs an injector firing 2k psi into a cylinder under max compression pressure, then I can't explain it to you in a post. Maybe try a web search and read for a while then come back to discuss.
The Following 2 Users Say Thank You to FORZDA 1 For This Useful Post:
djuosnteisn (05-10-2010), FreeFlyFreak (05-12-2010)
 Old 05-10-2010, 01:19 PM   #336
leadf00t's Avatar
Posts: 100   (View Stats)
leadf00t has much to be proud ofleadf00t has much to be proud ofleadf00t has much to be proud ofleadf00t has much to be proud ofleadf00t has much to be proud ofleadf00t has much to be proud ofleadf00t has much to be proud ofleadf00t has much to be proud ofleadf00t has much to be proud ofleadf00t has much to be proud of
I just wanted to say thanks to everyone for their input, and trying to help the community better understand these engines !!
On a side note does anyone else think that mazda engineers are reading this thread, and saying 日本語教師がしっかり日本語教えます ただ今、1ヵ月間の無料体験授業受付中 While laughing - These idiots dont have a fucking clue !!
2010 Mazda 6 GT
2008 Speed 3 - Traded
leadf00t is offline   Reply With Quote
 Old 05-10-2010, 01:22 PM   #337
SRTie4k's Avatar
I understand that a high pressure injection of gasoline into a high compression chamber is more volatile than injecting low pressure gas into a low pressure chamber, and therefore has a higher chance of detonating without spark, but I fail to see how that has anything to do with interfering with the knock sensor's ability to pick up knock at high RPM's.
Also, if its as easy as "reading the results of a web search", please provide links to these glaringly obvious technical documents that you have access to. Otherwise, drop the patronizing routine.
 Old 05-10-2010, 01:42 PM   #338
[MSF STIG]
FORZDA 1's Avatar
I can tell you're missing my point entirely. Here's an analogy that might put it into perspective.
Port injection is like hitting a tiny fiinishing nail with a 1 oz hammer into a 1/8" thick trim panel. Direct Injection is like driving a 10 penny nail with a 2lb claw hammer through a 4x4. It takes a bit more force and makes a bit more noise.
Sorry, I know it's tough having to read and research a topic. Hey, if you have a USB port on your forehead, I'll just download and email you my brain memory files and you won't need to expend ANY effort.
Start here and follow all the links......
Search: direct injection gasoline engine basics - MetaCrawler
Ok, so I'm a bit tense today.....
 Old 05-10-2010, 01:50 PM   #339
SRTie4k's Avatar
I understand your point but I don't believe its valid at all. You're trying to tell me that direct injection by itself makes more noise than an engine with no balance shaft chain and full solid engine mounts?
By your own logic, you're telling me that any DI engine in the world cannot detect knock above 5500RPM because DI causes too much interference into the frequency of the knock sensor. What about Porsches that inject at up to 2400PSI? Hell, what about all of the Cobalt SS/TC's that are modded to 400WHP+ and push over 2100PSI? Are you telling me that their knock sensors go "deaf" at 5500RPM? Also by your logic, the more PSI you're pushing, the lower RPM your knock sensor becomes worthless?
Sorry, but the logic you're trying to use is completely flawed.
 Old 05-10-2010, 01:56 PM   #340
Captain
Groans: 79
I don't think it's flawed at all. Rather than the DI injection event itself being the "noise", it could instead be harmonics of those events that correlate to the knock frequency of our motors. So say at 5700rpm to 6300rpm or something like that, the injectors are opening and closing at a frequency where harmonics would readily register as knock if the sensor was actually active.
www.permtuning.com
FORZDA 1 (05-10-2010)
 Old 05-10-2010, 02:01 PM   #341
[MSF STIG]
FORZDA 1's Avatar
Yep, in the frequency of concern.
Okie Dokie. Suit yourself on whatever you want to believe.
 Old 05-10-2010, 02:02 PM   #342
Captain
Groans: 79
Let me just expand a bit more....
A motor will typically "knock" at a very narrow frequency, and there is a lot of filtering on the ECU's side of the "knock sensor" that filters out all the other engine noise. So, while motor mounts and balance shaft deletes make the ride much more "noisy" to you as a driver, it's all filtered out by the ecu... unless of course, it put sufficient energy into the "knock frequency" that the ecu is looking at (which can definitely happen, but is generally quite rare).
But (and this is pure speculation), if the natural frequency of knock on our blocks falls into a multiple of the injector events (say at 5700rpm for instance), then they would put sufficient energy into that frequency, and register as knock. Thus from a design perspective, would be sufficient reason to simply ignore the sensor at that rpm(s).
www.permtuning.com
 Old 05-10-2010, 02:08 PM   #343
SRTie4k's Avatar
With the explanation he gave, the logic does not compute. If he had thrown in that extra information it would have made sense, but just saying "DI makes lots of noise" does absolutely nothing to bring good factual information into consideration.
But now begs the question: how many of you actually know what the frequency of the injectors or injection process is? I have a feeling none of you do, and that you're all merely trying to make a guess, whether educated or pure speculation, as to why the knock sensors goes "dead" after 5500RPM.
I full understand what you're saying, and I'm not disputing the idea. What I am disputing is the factual information behind it, of which there is none from what I can see.
Last edited by SRTie4k; 05-10-2010 at 02:08 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-10-2010, 02:11 PM   #344
Captain
Groans: 79
Welp, if it means anything to you... once i get my car running, investigation of the knock sensor and knock on this motor is top of my list.
And i have a few tricks up my sleeve. Until then, we can only speculate
You can buy (or build your own) amplifier with head phones, and actually listen to your knock sensor. Just an FYI.
www.permtuning.com
Lex (05-10-2010)
 Old 05-10-2010, 02:32 PM   #345
It is speculation that they turn off the knock sensor due to noise although many OEMs employ this strategy. They could also turn it off in part due to the way the stock calibration drops power/boost past that point. I am fairly certain there is a parameter in the ECU that can be modified indicating until what RPM the sensor is listened to.
Until that parameter is discovered and exploited the next best thing is to devise your own amplifier as DJ stated or keep an eye on knock up to 5500RPM and tune conservatively thereafter.
djuosnteisn (05-10-2010), FORZDA 1 (05-10-2010), rfinkle2 (04-29-2011)
 Old 05-10-2010, 02:47 PM   #346
Captain
Groans: 79
And when you do decide to dial in timing beyond 5700rpm, do it on a dyno and keep an eye on your torque.
www.permtuning.com
Abilor (06-09-2011), Lex (05-10-2010), rfinkle2 (04-29-2011)
 Old 05-10-2010, 02:48 PM   #347
Ziggo's Avatar
Good luck, vibration analysis is tough. Isolating why the motor would experience enough noise to KO the knock sensor would by quite the undertaking. It's probably why Mazda didn't do it in the first place.
 Old 05-10-2010, 03:27 PM   #348
darth vader's Avatar
Posts: 665   (View Stats)
I am sure 5400 is mega safe but, since I flat-shift at the track, I need to leave headroom for that flare. I *maybe* lose a touch not revving it out a little further but, I think I gain more back by keeping it on boost all the way down the track instead of lifting to shift. Stock turbos nosing over hard after 5500 anyway so, why rev it to 6800?
 Old 05-10-2010, 06:06 PM   #349
[MSF STIG]
FORZDA 1's Avatar
Here's some tech-line quotes concerning knock sensors. I'm still looking for additional detail to confirm, but I'm pretty sure our DISI utilizes the resonance type piezeoelectric sensor....
......There are two different styles of piezoelectric sensors -- mass and resonance. The mass sensor has its "ears" up to all vibrations. It produces a voltage at all vibration frequencies, creating its highest voltage at around 7,000Hz. This sensor forces the PCM to filter out the voltages above and below those generated at the 7,000Hz level.
The resonance sensor is much smarter. It sends a significant voltage to the PCM only when it detects vibration in the 7,000Hz range. At all other times it is quiet as a mouse.....
 Old 05-10-2010, 06:09 PM   #350
BrianZX10R's Avatar
Posts: 1,163   (View Stats)
BrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the world
Groans: 88
Groaned at 121 Times in 75 Posts
Lot of good information in here
1995 honda civic. 1.6L slow
2007 Kawasaki ZX10r
BrianZX10R is offline   Reply With Quote
 Old 05-10-2010, 06:39 PM   #351
SRTie4k's Avatar
I can't say one way or another whether the knock sensor "cuts out" after a certain RPM, but what I can say is the definitive way to find out is to run some extra wires off of the sensor to a logger that can take aux inputs.
Log that voltage against actual Knock Retard and we'll know for sure whether the knock sensor is registering anything past 5500RPM.
 Old 05-10-2010, 07:09 PM   #352
[MSF STIG]
FORZDA 1's Avatar
Sounds like you already have a good test plan. All we need now is for you to execute it and report back! lol
kgb (05-10-2010)
 Old 05-10-2010, 09:48 PM   #353
The sensor is a transducer - a microphone. It's the ECU that decides to no longer listen to it. The sensor looks like a standard bosch unit:
FreeFlyFreak (05-12-2010), kgb (05-10-2010)
 Old 05-10-2010, 11:24 PM   #354
SRTie4k's Avatar
The knock sensor converts the frequency it picks up from a certain range into a voltage. The ECU then reads that voltage, determines and spits out level of knock. Like I said before, the only way to determine whether the ECU is actually ignoring that voltage input is to datalog both parameters at the same time and compare them.
If the knock sensor registers voltage above 5500RPM and knock retard is null, then you are correct in assuming the ECU ignores the sensor. If neither registers anything, then the whole "DI frequency interference" is a bunch of poorly conceived BS.
There is no other way to verify that. Everything else is still just speculation.
 Old 05-11-2010, 08:51 AM   #355
Captain
Groans: 79
If you guys are patient enough, i'll do a full blown investigation. I already have all the right tools at my disposal. I just need a car.
www.permtuning.com
FORZDA 1 (05-11-2010), kgb (05-11-2010)
 Old 05-11-2010, 09:00 AM   #356
^ I need to get me a portable scope
djuosnteisn (05-11-2010)
 Old 05-11-2010, 09:26 AM   #357
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
that there is a nissan knock sensor looks just like the one from my se-r. see the nissan emblem around the bolt hole(actually i think that is the one in my se-r)
"Go find your own enterprise, and get the fuck off my bridge!"
2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard"
1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action"
skeeter149 is offline   Reply With Quote
 Old 05-11-2010, 09:40 AM   #358
[MSF STIG]
FORZDA 1's Avatar
.....If the knock sensor registers voltage above 5500RPM and knock retard is null, then you are correct in assuming the ECU ignores the sensor. If neither registers anything, then the whole "DI frequency interference" is a bunch of poorly conceived BS.
You're correct in your test method and I understand your skepticism. It may even be warranted as far as whether the sensor stops outputting or the ECU stops listening, but a simple(?) fact(AFAIK) remains that the ECU doesn't output any KR after ~5500 rpms in ANY log or real-time AP or DH display. Based on this bit of empirical information, the deduction is made that EITHER the ECU stops listening, or the sensor output is attenuated.
I just recently experienced the situation where there was no KR shown on the AP >5500 and had an obviously severe detonation event near redline.
djuosnteisn (05-11-2010), FreeFlyFreak (05-12-2010)
 Old 05-11-2010, 12:34 PM   #359
SRTie4k's Avatar
The other alternative is that the sensor just doesn't register knock in high RPM situations. Who is to say knock at a higher RPM doesn't generate a frequency outside of the "listening" range of the OEM sensor?
Mazda designed or selected all of the OEM parts to function properly in a stock environment. It would make sense that Mazda designed the engine to taper power from 5500RPM to redline since the turbo is simply blowing hot air and increasing the chance of knock in that range. It sounds stupid, but Mazda may not have cared about knock above 5500RPM for that specific reason - since power is tapered down on the stock tune, anyways - and decided that this specific knock sensor is "good enough".
Whatever the situation, nothing is proven until tested. I still don't believe the DI system interferes with the knock sensor, I'm more apt to believe one of the above scenarios before believing the DI conjecture.
 Old 05-11-2010, 01:00 PM   #360
Captain
Groans: 79
knock frequency depends on structural characteristics of the block, not rpm.
www.permtuning.com
BrianZX10R (05-26-2010), FORZDA 1 (05-11-2010)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/real-reason-people-breaking-rods-33010/
Big Torque at Low RPMs This thread Refback 07-08-2015 11:03 AM
Latvijas Mazda Klubs ? Apskat?t tematu - DISI 2.3 turbo v?j?s vietas This thread Refback 08-05-2014 11:38 PM
When did these get so cheap?: Grassroots Motorsports forum: Grassroots Motorsports Magazine Mobile This thread Refback 04-12-2014 10:48 PM
When did these get so cheap?: Grassroots Motorsports forum: Classic Motorsports This thread Refback 04-08-2014 03:00 PM
When did these get so cheap?: Grassroots Motorsports forum: Grassroots Motorsports This thread Refback 04-08-2014 02:36 PM
Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum - Reply to Topic This thread Refback 11-18-2013 08:22 PM
Turbo pulse @ full throttle??? - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum Post #1 Pingback 11-18-2013 08:05 PM
RS TUNING GRAPHS+PHOTOS ? Mazda MPS Owners Club This thread Refback 11-05-2013 12:05 PM
Is the 3 capable in 6th gear at low speeds? ? Mazda MPS Owners Club This thread Refback 06-03-2013 09:47 AM
Mazda MPS Owners Club • View topic - RS TUNING GRAPHS+PHOTOS This thread Refback 08-17-2012 04:35 AM
Went to Chicago for milk, found this on the way v.MS3 - ClubSi This thread Refback 07-25-2011 07:56 AM
civic si with bolt ons or a ms3 - Page 3 - 8th Generation Honda Civic Forum This thread Pingback 07-26-2010 04:11 PM
Subaru/Mazda reliability? - Page 2 - 8th Generation Honda Civic Forum This thread Pingback 02-25-2010 06:00 PM
[Engine] Engine Swaps? - Page 2 - MX-5 Miata Forum This thread Refback 07-30-2009 07:55 AM
albuquerque nm mazda 6 owners - Mazda6 / Atenza This thread Refback 07-28-2009 06:11 AM
Day of 7/21/2009: Top 50 of 264 Referring Pages This thread Refback 07-22-2009 08:06 AM
2.3disi Turbo Engine Blow - Club Mazda This thread Refback 07-20-2009 01:38 AM
FYI: Carrillo Rods vs. Factory Rods JimmyMac MazdaSpeed 3 - Engine, Transmission & Driveline 45 02-20-2009 10:07 AM
Chicago 2009: SHO History - The real reason Ford had Yamaha's V6 lying around Haltech Automotive News 1 02-12-2009 12:27 PM
The CPe Store is for real... Its GO TIME people. phailerider Custom Performance Engineering (cp-e.com) 14 10-20-2008 10:56 AM
Real photo of the real Volt powertrain mule Haltech Automotive News 0 04-17-2008 01:40 PM
Page generated in 0.62733 seconds with 30 queries
