 Old 09-16-2009, 02:57 PM   #1
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Default Redline MT90 Thoughts?
I picked up some Redline MT90 gear oil from summit racing for $9.95 a quart. Should be getting it by friday. Gonna hit up vato zone or pep boys for the fill tube.
Just curious on your thoughts on it after some use.
Is it a pain to change out or as easy as a regular oil change?
Noticeable difference in shifting?
TIA
this forum serves 2 purposes
 Old 09-16-2009, 03:02 PM   #2
DaleNixon's Avatar
Posts: 2,079   (View Stats)
Groans: 91
It's much smoother when warmed up. Before it warms up (especially when it's cold out), shifting is pretty rough. It's worth the tradeoff if you ask me.
The Following User Says Thank You to DaleNixon For This Useful Post:
Dash08 (09-16-2009)
 Old 09-16-2009, 03:06 PM   #3
RayRayBauder's Avatar
Posts: 1,999   (View Stats)
RayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the worldRayRayBauder is the leader of the world
Groans: 234
Groaned at 154 Times in 122 Posts
dale nixon pretty much summed it up. and honestly, i think it's easier than an oil change. took no time at all to do.
'08 MazdaSpeed3 - sold
RayRayBauder is offline   Reply With Quote
The Following User Says Thank You to RayRayBauder For This Useful Post:
Dash08 (09-16-2009)
The Following User Says NO Thank You to RayRayBauder For This Un-useful Post:
 Old 09-16-2009, 03:09 PM   #4
I <3 your mom
Dash08's Avatar
Groans: 293
Luckily I live in southern California, it doesn't get too cold here.
 Old 09-16-2009, 03:12 PM   #5
Groans: 234
even on a warm day and a cold start it can be a little rough. but not that bad. it's worth it IMO
 Old 09-16-2009, 03:16 PM   #6
I <3 your mom
Dash08's Avatar
Groans: 293
I think I can handle it. *hint of sarcasm* lol
 Old 09-16-2009, 04:19 PM   #7
SpdFreak's Avatar
Posts: 364   (View Stats)
SpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the worldSpdFreak is the leader of the world
For the north east (15*f winters), does it make sense to use MT-90, or use OEM spec tranny fluid?
DIY: Sea Foam
SpdFreak is offline   Reply With Quote
 Old 09-17-2009, 06:22 AM   #8
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
you're fine to use mt-90 in a cold climate. just let the tranny warm up before romping as previously stated.
get a 24mm socket and don't touch the angled bolt of death!
 Old 09-17-2009, 08:03 AM   #9
SpdFreak's Avatar
What are the benefits of MT-90 over OEM transmission fluid?
DIY: Sea Foam
 Old 09-17-2009, 09:56 AM   #10
Miembro
nighthawk358's Avatar
Posts: 725   (View Stats)
nighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the world
Groans: 27
Groaned at 6 Times in 6 Posts
large amounts of women and glory...seriously, it is supposed to make shifting smoother if i recall correctly
2008.5 MS3 Metro Gray...slow
nighthawk358 is offline   Reply With Quote
 Old 09-17-2009, 10:00 AM   #11
I <3 your mom
Dash08's Avatar
Groans: 293
From my understanding and what people have told me is that the shifting is super smooth because it's a synthetic gear oil.
Either way, I 've heard nothing but great things and I know a lot of people are running this in their Mazdas.
 Old 09-17-2009, 10:01 AM   #12
Vin
Vin's Avatar
Posts: 21   (View Stats)
Vin is on a distinguished road
It feels about the same to me when cold, but there definitely is a difference once it's warmed up.
Vin is offline   Reply With Quote
 Old 09-17-2009, 10:33 AM   #13
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
I've been using it for about a year now and it's been fine for me. I did notice a little more, "wah wah wah wah wah" sound when I turn the wheel sharply and I'm going slow. Don't know what that's about, but I heard it's normal. Shifting is smooth when warm, but a little knotchy in the winter time until you've driven a little while.
 Old 09-17-2009, 10:44 AM   #14
I <3 your mom
Dash08's Avatar
Groans: 293
I'm pretty sure the wah wah's from turning the wheel to lock is normal. My car does it too.
 Old 09-17-2009, 11:08 AM   #15
Zeya's Avatar
Posts: 992   (View Stats)
Zeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the worldZeya is the leader of the world
I'll second a more pronounced "wah wah wah" sound when you downshift into first (low speed, parking lot obviously). I think I even turn some heads because of it I think. I don't think that has anything to do with turning the wheel to lock, just the synchro noises at low gear / highish rpm coasting.
I remember right after I swapped the fluid, it did seem to shift a bit more nicely. It felt a little bit smoother. It wasn't a night-and-day thing, and the OEM fluid is almost as good, honestly. But it's such an easy thing to do, why not do it? Just make sure to buy a $3 tranny fill tube (funnel with plastic tube attached) or you can go to the trouble of making your own thing.
I live near San Jose and I guess it's a little rougher to shift for the first 2-3 stop lights, then it warms up. (Someone mentioned california.)
2008 MS3 GT ~ Cobb SRI, Cobb turbo inlet, CPE rear motor mount, Koni FSD shocks
Zeya is offline   Reply With Quote
 Old 09-17-2009, 11:25 AM   #16
I <3 your mom
Dash08's Avatar
Groans: 293
Hmmm. The wah wah noises I'm hearing when I turn the wheel to lock and move must just be the power steering pump then. I don't downshift into first so, I can't elaborate on the tranny sounds.
If the shifting is a bit rough at first, that's fine. I don't even touch boost until the engine is at operating temps anyway.
Thanks again everyone for the input.
 Old 09-17-2009, 12:21 PM   #17
eddelgado's Avatar
Posts: 84   (View Stats)
eddelgado will become famous soon enougheddelgado will become famous soon enough
The MT90 is an improvement over the factory fluid and a no-brainer to do. I put mine in within a couple of thousand miles of buying the car. When I get to about 20K or so I will swap out for the synthetic Ford fluid that is supposed to be really good.
Ed
eddelgado is offline   Reply With Quote
 Old 09-17-2009, 03:31 PM   #18
Zeya's Avatar
Yeah that's probably just the power steering. The engine revs up too by a couple hundred RPM when you turn the wheel at a stop as well.
 Old 09-17-2009, 03:37 PM   #19
MazMusic's Avatar
Posts: 120   (View Stats)
MazMusic is a name known to allMazMusic is a name known to allMazMusic is a name known to allMazMusic is a name known to allMazMusic is a name known to allMazMusic is a name known to all
ilttle more noise, better shifting I recomend it
MazMusic is offline   Reply With Quote
thoughts (tsw) ispypsi MazdaSpeed 3/6 - Wheels & Tires 0 03-24-2009 10:51 PM
BS assembly thoughts 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 2 03-08-2009 04:24 PM
May buy MS6 This weekend. Thoughts? Godofelru Mazdaspeed3/6 General Discussion 11 10-30-2008 07:22 PM
Concerned with MT90 bacarl MazdaSpeed 3 - Engine, Transmission & Driveline 55 09-30-2008 09:43 PM
Page generated in 0.38116 seconds with 30 queries
