![]() | | #1 | ![]() |
| Banned ![]() Join Date: Aug 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
Groaned at 7 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score im about to buy a m2 downpipe for my speed6 and ive heard a few bad things. 1. ill need a new o2 sensor for the upstream cuz getting the old one out without breaking it is a miracle. 2. I have to run a tune with the DP because neither the stage 1 or stage 2 tune in my AP will make it work. boost will spike and I will go boom boom zoom with about a custom tune. 3. it wont add that much power to a relatively stock ms6 anyway Last edited by redneckspeed; 08-29-2013 at 02:48 PM. |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
2. It sounds like your car has other issues. You should be able to run a Stage 2 map with a stock downpipe. Either gut the midpipe cat or get a test pipe. Personally I would leave the Stock downpipe in for now. 3. Once again, you are an faggot. You can make decent power with minimal mods and a good tune. If you want to know more, learn how to search and read.
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
(Thread Starter) | Not Ranked : 0 score I haven't done it yet. my installer predicted this would happen and preferred I had a extra sensor on standby |
![]() | | #4 | ![]() |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score why you no work on your own car? fuck it, throw your money away.
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
![]() | | #5 | ![]() |
Groans: 128
| Not Ranked : 0 score atleast watch them so you know they don't f something up
![]() | | #6 | ![]() |
(Thread Starter) | Not Ranked : 0 score im disabled, and used to working on old fords with lots of room. that's an excuse I know but it is the truth as well. I don't want some one to do it for me, I just want some one to help me so I don't jack my car up and not be able to fix it. |
![]() | | #7 | ![]() |
Groans: 128
| Not Ranked : 0 score cool, good luck with your upgrades
![]() | | #8 | ![]() |
![]() Join Date: Nov 2010 Location: Murrieta, CA
Rep Power: 1393 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,136
Groans: 52
Groaned at 54 Times in 39 Posts
Sent from my HTCONE using Tapatalk 2
__________________ 2009 CWP Speed3 | |
![]() | | #9 | ![]() |
Groans: 128
| Not Ranked : 0 score any pics of the ride?
![]() | | #10 | ![]() |
just a sec | |
![]() | | #11 | ![]() |
![]() Join Date: Feb 2009 Location: Dupont wa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,527
| Not Ranked : 0 score I have my m2 downpipe for 6 months now awaiting on growing some balls for the install, because I heard is a pita.g/l op and if you going the buy a new o2 sensor try this: NTK Part # 24354 More Info NTK OE Type Wideband Upstream; NTK is way cheaper than oem and work in our cars!!
__________________ |
![]() | | #12 | ![]() |
![]() | | #13 | ![]() |
![]() Join Date: Jun 2010 Location: Howell, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,749
Groans: 124
| Not Ranked : 0 score Did my dp in 6 hours.make sure you have a pry bar to pull the oem dp out
__________________ 1995 Miata 1.8 2006 MS6 Sold |
![]() | | #14 | ![]() |
Groans: 255
Second, if you have no idea what you are doing, leave the fucking downpipe alone and install a racepipe or remove the secondary cat from your midpipe. Heavily modding the Speed 6 usually leads to EPIC fail. Keep It Simple Stupid.
| The Following User Says Thank You to himurax13 For This Useful Post: | GTFD_Tony (09-11-2013) |
![]() | | #15 | ![]() |
![]() Join Date: Oct 2012 Location: Owatonna, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 437
| Not Ranked : 0 score Good luck. The OTS tune should work okay. You'll definitely notice a power gain. When I did my DP I ruined my down stream O2. There was no amount of PB blaster or heat that would help. |
![]() | | #16 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score 40% disability just like himurax 13. OP if you still got hands and able to stand you got no excuse. Dad is also disabled. Like broke his back, injured his spinal cord, never should have walked again disabled, took 3 years to walk (not exactly the most smooth walking you've ever seen in your life), and he still gets out and works his ass off. Point in case unless your seriously fucked up, stop being a pussy and do it yourself. Its really not that hard. They make a specialty O2 sensors socket that works amazingly, use it.
__________________ 06 speed 6 Current: CPE dp, CS tip, CS rmm, CS rdm, JBR side mounts (70a) Cobb sri, Toyota seals, Autotech internals, CS tmic. In progress: Rich Tuned Future: JBR OCC, lowering, BT and 5th port (maybe) |
| replacing the ECU | olcho | MazdaSpeed 3/6 - ECU Computer Tuning | 7 | 11-16-2018 09:10 PM |
