 Old 02-22-2017, 06:27 PM   #1
LordNikko's Avatar
Posts: 9   (View Stats)
LordNikko will become famous soon enoughLordNikko will become famous soon enough
Default Retaining clip on shifter assembly part #
Whilst driving today I noticed excessive side to side slop in the shifter that wasn't there before. I pulled apart the console and noticed the retaining clip on the passenger side of the shifter assembly was broken. One of the teeth is missing from the clip, and is preventing it from staying in place. I installed a zip tie around it to hold it in place for the time being. In searching for a replacement clip, I am only finding the entire shifter assembly as one part. If anyone knows where these can be acquired, I would appreciate that information.
2008 MS3 GT - CPE TMIC, Forge V1 BPV(blue spring & two shims), CS Stage II Power Series SRI & TIP, CS Injector Seals, MSD Ignition Spark Plugs, JBR Boost Tubes, JBR Recirculation Tube, JBR EGR Block Off, JBR TB TIG, JBR Shifter Bushings, JBR Short Shifter, JBR Reverse Lockout, JBR Shifter Counterweight, JBR Weighted Shift Knob, Adapted Performance Intake Manifold TIG, DM EGR Delete, DM OCC, DM RMM, TRZ TMM, HARDRACE PMM, Autotech Internals, eBay Long Catless DP, Koni STR.T Shocks/Struts, MOOG Endlinks, Prothane Swaybar Bushings, StopTech Slotted Rotors + Pads, South Bend Stage 3 Endurance Clutch Kit w/ Flywheel, Bronze RX-8 Rims + Michelin Pilot Super Sport Tires, SWAS Disabled, Cobb AP V2, Stratified Tuned
LordNikko is offline   Reply With Quote
 Old 02-22-2017, 06:29 PM   #2
sharksinspace's Avatar
Posts: 763   (View Stats)
Groans: 126
Could be wrong, but I believe I've read that that is not a part that can be purchased separately.
2007 MS3
PD by Will
The Following User Says Thank You to sharksinspace For This Useful Post:
LordNikko (02-22-2017)
Sideskirt clip/fastener part number thems3driver Exterior 5 05-06-2014 09:11 AM
halfshaft retaining clip? btstarcher MazdaSpeed 3 - Engine, Transmission & Driveline 20 02-12-2013 07:15 AM
08 Shifter Assembly Part #? D08SPEED3 MazdaSpeed 3 - Engine, Transmission & Driveline 1 12-20-2012 04:07 AM
09 Shifter assembly tom9293 Mazdaspeed3/6 General Discussion 1 06-01-2012 05:26 PM
Custom CBE part 2 Video and sound clip Greyspeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 12 04-13-2009 09:05 AM
Page generated in 0.23400 seconds with 22 queries
