 Old 04-20-2010, 09:04 AM   #81
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
Groans: 105
why don't engine brake?
xcoldricex is offline   Reply With Quote
 Old 04-20-2010, 09:07 AM   #82
JBR
JBR's Avatar
Posts: 6,629   (View Stats)
Groans: 28
Simple....What's cheaper clutch or brakes?
JBR is offline   Reply With Quote
 Old 04-20-2010, 09:17 AM   #83
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Groans: 166
Why would engine braking wear out the clutch? The only way this would happen is if you never rev match on downshifting.
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
Originally Posted by Say Chi Sin Lo View Post
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
The Following User Says Thank You to Blackspeed For This Useful Post:
FreeFlyFreak (04-20-2010)
 Old 04-20-2010, 09:24 AM   #84
JBR
JBR's Avatar
Groans: 28
Rev matching does not eliminate clutch wear, it reduces it and makes for smoother downshifting. Up shifting through all 6 then downshifting is just double the wear on everything.
 Old 04-20-2010, 11:27 AM   #85
DaleNixon's Avatar
Posts: 2,079   (View Stats)
Groans: 91
So much conflicting information I've read on this subject over the years.
 Old 04-20-2010, 01:54 PM   #86
Oswald's Avatar
Posts: 89   (View Stats)
Oswald is a splendid one to beholdOswald is a splendid one to beholdOswald is a splendid one to beholdOswald is a splendid one to beholdOswald is a splendid one to beholdOswald is a splendid one to beholdOswald is a splendid one to beholdOswald is a splendid one to behold
I rev match on just about every down shift! It is significantly easier on the entire drivetrane than just letting out the clutch and making the revs catch up. I don't really see how anyone could disagree with this. Just try down shifting w/out rev matching and you can hear and feel the clunk from the drivetrane catching up.
Oswald is offline   Reply With Quote
The Following User Says Thank You to Oswald For This Useful Post:
JBR (04-20-2010)
 Old 04-20-2010, 02:02 PM   #87
JS + MS3's Avatar
Posts: 1,794   (View Stats)
JS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the world
Groans: 98
Groaned at 72 Times in 51 Posts
i just tried to rev match for the first time yesterday.... it felt pretty smooooth. i didn't know. lol
i was cruising on hwy @ 70mph or so, went neutral, bliped throttle, then put it in 4th and went WOT. good smooth feelingggg
though i guess i have to practice alot to do this in a matter of split second... it's pretty hard for noobs i think
2010 Mazdaspeed3
Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18)
Last edited by JS + MS3; 04-20-2010 at 02:02 PM. Reason: MSF Database - Automerged Doublepost
JS + MS3 is offline   Reply With Quote
 Old 04-20-2010, 02:13 PM   #88
JBR
JBR's Avatar
Groans: 28
THANK YOU! You have no idea how many PM's and e-mails I get about this very issue. "I hear a clunk when I down shift from 3rd to second at 35 MPH" Do you rev match? NO. Sick!
Those of you that are new to this car or manuals in general Trust us on this one.
Jamie
 Old 04-20-2010, 06:26 PM   #89
Say Chi Sin Lo's Avatar
Posts: 872   (View Stats)
Say Chi Sin Lo has disabled reputation
Groaned at 62 Times in 28 Posts
Man, you got balls considering that was your first attempt at rev-matching.
Say Chi Sin Lo is offline   Reply With Quote
 Old 04-20-2010, 06:33 PM   #90
saitek's Avatar
Posts: 369   (View Stats)
saitek is the leader of the worldsaitek is the leader of the worldsaitek is the leader of the worldsaitek is the leader of the worldsaitek is the leader of the worldsaitek is the leader of the worldsaitek is the leader of the worldsaitek is the leader of the worldsaitek is the leader of the worldsaitek is the leader of the worldsaitek is the leader of the world
Rev match or go home.
http://vimeo.com/mazdaspeed/videos
saitek is offline   Reply With Quote
The Following User Says Thank You to saitek For This Useful Post:
Arrowpoint (04-20-2010)
 Old 04-20-2010, 06:55 PM   #91
Arrowpoint's Avatar
Posts: 364   (View Stats)
Arrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the world
Nice!! I need that car!
Arrowpoint is offline   Reply With Quote
 Old 04-20-2010, 11:32 PM   #92
Speedee3's Avatar
Posts: 105   (View Stats)
Speedee3 has a reputation beyond reputeSpeedee3 has a reputation beyond reputeSpeedee3 has a reputation beyond reputeSpeedee3 has a reputation beyond reputeSpeedee3 has a reputation beyond reputeSpeedee3 has a reputation beyond reputeSpeedee3 has a reputation beyond reputeSpeedee3 has a reputation beyond reputeSpeedee3 has a reputation beyond reputeSpeedee3 has a reputation beyond reputeSpeedee3 has a reputation beyond repute
If you guys are so worried about the dang clutch buy a car with an automatic transmission! Geeezes.
Someone was talking about "clutch or brakes...which costs more"....if I need to stop extremely fast...I have braked AND engine braked with good effect. Its not a habit, but I have to tell you...when I did it I wasnt thinking..."wonder how much my clutch will cost to replace".
I think we are beating a dead clutch!
I wonder how we all survived driving 4 speeds, "three on the tree", and "rock crushers"...before this forum!?? Its ok...breaaaaaathe...your clutch will tell you if you are screwing up...as in..."man this is a herky jerky ride" coming from your passenger! Ha!
Ken
Speedee3 is offline   Reply With Quote
Mix/Matching Downpipe and Testpipe Emoranges MazdaSpeed 3 - Engine, Transmission & Driveline 0 02-15-2010 02:15 PM
lugs matching calipers ZoomByU Wheels & Tires - BLACK 1 10-28-2009 09:38 AM
Price Matching! Meghan@Autogeek.net Mazdaspeed3/6 General Discussion 0 11-14-2008 01:40 PM
Would you like a matching chopper and trailer with that Gallardo? Haltech Automotive News 0 05-15-2008 04:40 PM
Page generated in 0.36003 seconds with 30 queries
