![]() | | #1 | ![]() |
![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 2506 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,527
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
| Raider is mah Homie ![]() Join Date: Jan 2011 Location: Towson, Maryland
Rep Power: 7524 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54,831
Groans: 2,978
| Not Ranked : 0 score Have you pulled the console and inspected the shifter?
__________________ ![]() I hugged rfinkle2 Last edited by MS3Shadow; 07-05-2016 at 07:00 PM. |
| Bob Ross Fanclub ![]() Join Date: Jan 2009 Location: SEFL
Rep Power: 4333 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,534
| Not Ranked : 0 score When did this start? Out of nowhere? Have you adjusted your shifted cables?
__________________ ![]() |
| The Following User Says Thank You to Tomas For This Useful Post: | Domino81 (07-05-2016) |
![]() | | #4 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yes, I've adjusted it a few times. I've checked for obstructions inside the engine bay. It started out of the blue a few weeks back. And yes, totally out of the blue.
![]() | | #5 | ![]() |
| Not Ranked : 0 score Since all your other gears are working fine I would rule out the slave cylinder. If you can't find anything wrong with the linkages the next suspect would be the plastic tabs on the shift fork that engages reverse. When that pad is gone the fork won't be able to fully push the gear. Replacement requires opening up the gear box. I wold try hard to rule out everything else possible before you take down the transmission to check the pads or wait till you have to replace your clutch and at that time change the fork.
| The Following User Says Thank You to Tomas For This Useful Post: | Nliiitend1 (07-07-2016) |
![]() | | #6 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well.. I have to pull the motor because I believe the 2 middle cylinders have cracked ring lands and have pretty excessive blow by.
![]() | | #7 | ![]() |
Groans: 2,978
| Not Ranked : 0 score Need to find a wrecked car and steal the motor and transmission.
__________________ ![]() I hugged rfinkle2 |
| The Following User Says Thank You to Easter Bunny For This Useful Post: | Domino81 (07-06-2016) |
| Alarm doesnt engage but door locks | macromind | CX-7 > Issues & Troubleshooting | 1 | 09-25-2015 06:23 PM |
| Transmission Grind / No engage (2nd) | zumzum | MazdaSpeed 3 - Engine, Transmission & Driveline | 12 | 05-27-2015 11:24 AM |
| Luk fidenza combo wont engage | whenning232323 | MazdaSpeed 6 - Engine, Transmission & Driveline | 22 | 08-13-2013 04:21 PM |
| Shifter Issue - Really difficult to engage reverse, then back to 1st | vtak07 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 3 | 01-21-2011 01:00 PM |
