 Old 11-08-2009, 10:11 PM   #41
MZRDISI4's Avatar
Posts: 1,430   (View Stats)
MZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the world
Groans: 94
Groaned at 38 Times in 19 Posts
The passenger side mount has the possibility of busting and leaking its fluids, so replacing it with the topspeed mount is a good idea.
"We already have the Speed6 replacement" "It's just called the CX-7 now"
back at http://www.mcx7.com bitches, spam free
MZRDISI4 is offline   Reply With Quote
The Following User Says Thank You to MZRDISI4 For This Useful Post:
bioevolve (11-09-2009)
 Old 11-09-2009, 06:03 AM   #42
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
Originally Posted by nyghtryder View Post
Any issues or complaints about the topspeed mounts? Im torn between these and the trz mounts but I know Im going to get alot more vibs from the trz combo.
i'd get the trz combo first and then the top speed pmm if you're worried about the stocker going poop. as far as the trz combo, vibes aren't bad and actually less harsh when you add the tranny mount. i normally buy from su (quicker), but pg had good customer service.
i have the top speed pmm (afraid of poop) and like it. stiffer than the stocker, but didn't notice any vibe difference. my only reservation recommending top speed is dealing with darksun. i had no problem getting the pmm from myke but got burned on a subsequent buy from him. luckily paypal gives you most of your money back. i'd just make sure darksun has the pmm in stock before you buy. wonder why pg or su doesn't carry top speed.
The Following 2 Users Say Thank You to karl-hungus For This Useful Post:
bioevolve (11-09-2009), nyghtryder (11-09-2009)
 Old 11-09-2009, 09:16 AM   #43
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
what stiffness did you go with on the trz mounts.
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline   Reply With Quote
The Following User Says Thank You to nyghtryder For This Useful Post:
 Old 11-09-2009, 10:46 AM   #44
patrick failman
Groans: 74
i have the trz polyurethane rear mount, but probably wouldn't mind the delrin (stiffer of the two). one of the mods has delrin and likes it iirc.
the tranny mount doesn't have a stiffness option.
hard to beat $180 for both mounts.
The Following User Says Thank You to karl-hungus For This Useful Post:
motor mounts LiEast MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-13-2009 06:34 AM
cpe motor mounts marcusdigi MazdaSpeed 3 - Engine, Transmission & Driveline 9 04-24-2009 08:57 AM
Page generated in 0.25347 seconds with 22 queries
