 Old 11-16-2011, 07:36 PM   #1
ckurth's Avatar
Posts: 10   (View Stats)
ckurth will become famous soon enough
Default RMM Intall?
Does anyone have a link they could share that shows how to install an RMM? I can't find anyone in my area that can do it so I think I'm going to see if a buddy of mine can help me change it out. I just haven't seen any how-to's on here (or any other site) that are clear and detailed.
ckurth is offline   Reply With Quote
 Old 11-16-2011, 07:38 PM   #2
TexasSpeed3's Avatar
Posts: 1,996   (View Stats)
TexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the world
Groans: 273
try the search bar
2011 Black Mica - Daily
JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp
TexasSpeed3 is offline   Reply With Quote
 Old 11-16-2011, 07:40 PM   #3
magicka's Avatar
Posts: 520   (View Stats)
magicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the world
http://jamesbaroneracing.com/support...structions.pdf
HOW-TO DATABASE MS3
2009 CWP MS3 GT
Rally Armor Flaps | Gen Pu Wheels | JBR 80d v1 RMM/RSB/TIGs/Boost & Bypass Tubes
TWM Full Replacement Shifter | CS SRI/TIP/Skid Plate | Koni FSD 4045 | Matt Damon OCC | Cobb DP/AP | CP-e TMIC/HPFP
PTP VVT Actuator/Injector Seals & Studs | Samco Rad Hoses | Redline Leather Shift & E-Brake Boot
BNR S3 | Stratified Boost Dial
magicka is offline   Reply With Quote
The Following 2 Users Say Thank You to magicka For This Useful Post:
blu (11-16-2011), TexasSpeed3 (11-16-2011)
 Old 11-16-2011, 07:46 PM   #4
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
AtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the world
I would recommend using the scissor jack that comes with the car to place it under the motor when it comes time to swap the mount. It makes it easier to maneuver the engine and line up the bolt holes. Be careful not to strip them. Many have screwed up like that.
AtTheDriveIn is offline   Reply With Quote
 Old 11-16-2011, 08:07 PM   #5
ScarMS3's Avatar
Posts: 2,088   (View Stats)
ScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the world
Groans: 97
Groaned at 31 Times in 25 Posts
I didn't secure the engine at all, no problems, the hardest thing about this install is literally jacking the car up or driving it on ramps. It's that simple.
ScarMS3 is offline   Reply With Quote
 Old 11-17-2011, 05:37 PM   #6
ckurth's Avatar
That pdf is exactly what I was looking for. Thanks for your help! I am going to order this weekend, just till not sure on which one to get. There are a lot of reviews out there and a lot of opinions floating around on this site. I was thinking the RRM by Torque Solutions but there seems to be others that work just as well that are cheaper. I know I am not going with the cp-e. Any suggestions based on personal experience would be helpful. Thanks again!
 Old 11-17-2011, 08:41 PM   #7
ScarMS3's Avatar
Groans: 97
Sent you a pm, perhaps you will be able to respond...
 Old 11-17-2011, 08:45 PM   #8
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
James Barone Racing mounts are king.
Do it and don't look back.
this forum serves 2 purposes
JBR (11-18-2011)
 Old 11-17-2011, 08:50 PM   #9
Jake5713's Avatar
Posts: 1,775   (View Stats)
JBR FTW
@jbarone
Jake5713 is offline   Reply With Quote
The Following User Says Thank You to Jake5713 For This Useful Post:
JBR (11-18-2011)
 Old 11-17-2011, 08:54 PM   #10
jimmy's Avatar
Posts: 234   (View Stats)
jimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond repute
JBR. Great customer service.
2010 LSM MS3 w/ Tech: Cobb AP, CorkSport SRI/TIP, JBR 80d RMM, JBR SSP, JBR SSB, JBR heavy knob, RallyArmor mudflaps, DDM 5k HIDs, Lamin-X fogs.
jimmy is offline   Reply With Quote
The Following User Says Thank You to jimmy For This Useful Post:
JBR (11-23-2011)
 Old 11-19-2011, 08:45 AM   #11
ckurth's Avatar
Okay, I have one done some research and JBR is my choice. I'm not sure if I should get the billet or chrome? This is my daily driver but I'm lke every other MS3 owner, I love to drive fast. The chrome is cheaper but I suppose you get more cabin noise and vibration compared to the billet. Which one do most people get? I'd like to get it ordered today so hopefully it will be here for the holiday weekend.
The Following User Says Thank You to ckurth For This Useful Post:
JBR (11-23-2011)
 Old 11-19-2011, 09:04 AM   #12
Boost Addict's Avatar
Posts: 1,327   (View Stats)
Rear Motor Mount 88 durometer [MZ3MS3MollyRMM] - $90.00 : James Barone Racing, Custom Fabrication
Get it, you wont be disappointed.
FREEKTUNE
The Following User Says Thank You to Boost Addict For This Useful Post:
JBR (11-23-2011)
 Old 11-19-2011, 09:17 AM   #13
jimmy's Avatar
I got the 80 durometer billet. At first there was a noticeable increase in vibration and noise, but after a couple weeks of breaking in, I can't even tell if it's worse than stock. And there has been no decrease in performance.
JBR (11-23-2011)
 Old 11-23-2011, 08:04 AM   #14
JBR
JBR's Avatar
Posts: 6,629   (View Stats)
Groans: 28
JBR FTMFW!
JBR is offline   Reply With Quote
Fuel pump internals intall in progress rghispanic88 Gen2 MS3 General Discussion 9 03-29-2011 11:18 AM
Page generated in 0.36884 seconds with 29 queries
