![]() | | #1 | ![]() |
(Thread Starter) | Neutral : +1 score The pictures below tell an interesting story - sorry about the large size but it is needed. The small end bearing is lined up with the web of the rod that supports the loads that run along from the front to back axis of the motor. However, the flanges of the rod (that support side to side load) are NOT lined up with the web and the bearing itself. Look through the pictures and you should see the imperfections. They are about 0.5mm off. This is what happens when you don't machine the entire surface of the rod. I can only imagine how many of these types of tolerances can stack up. EDIT: This is something I saw in all the rods I have. It is likely a result of the forging process. |
| The Following 60 Users Say Thank You to Lex For This Useful Post: | 06Speed6 (11-11-2009), AmillieMS6 (11-11-2009), ATAZ (01-05-2010), aviator79 (11-14-2009), bioevolve (11-11-2009), BoostIsBetter (11-11-2009), Chief_Wiggum (11-11-2009), cudaman (01-04-2010), D-Rick21 (11-16-2009), DaleNixon (11-12-2009), Darksun280 (11-11-2009), Demi (11-11-2009), djthom (11-16-2009), djuosnteisn (11-11-2009), doubleflusher (11-12-2009), E4Performance (11-11-2009), Fagwagon (11-11-2009), FearUndersteer (11-11-2009), fhaze (11-12-2009), Fobio (11-11-2009), glocK23 (11-11-2009), gsrtype1 (11-13-2009), hyun (11-11-2009), IshiKage (11-10-2009), jrp (01-02-2010), kgb (11-11-2009), kore2000 (11-11-2009), KoukiS14 (11-11-2009), madvillain (11-11-2009), MarkyMark (11-11-2009), mazda.speed3 (11-11-2009), mazdarati (11-12-2009), meatball18 (11-14-2009), mexicant (11-11-2009), MicaBlackMS6 (11-11-2009), MS3Zoom24 (11-11-2009), Murse (11-11-2009), NJSPEED3 (11-11-2009), Nliiitend1 (11-15-2009), NRSpeed (11-12-2009), nyghtryder (11-11-2009), phantom3 (11-11-2009), psychophyr (11-11-2009), QuickSpool (11-12-2009), RacingToaster (11-10-2009), s-retire (11-11-2009), SharkDiver (11-11-2009), speed23 (11-11-2009), SpeedSixxx (11-11-2009), spnkr21 (11-12-2009), superskaterxes (11-11-2009), Superstretch18 (11-13-2009), Thestaplegunkid (11-11-2009), the_caruch (11-12-2009), tmtbiker (11-11-2009), toprock (11-11-2009), ungrave (11-12-2009), wakeboarddude (11-11-2009), wcm250f (01-10-2010), xcoldricex (11-13-2009) |
| Banned ![]() Join Date: Feb 2009 Location: Inland Empire
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 937
Groans: 701
| Not Ranked : 0 score I hope only a small percentage of MS3/MS6 motors have these forging imperfections. |
![]() Join Date: Apr 2009 Location: Bethpage, New York
Rep Power: 4481 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,850
Groans: 778
If you think about it, most of the bent rod motors have gone at a pretty early age (low mileage) some of us are higher then others me being 50k in a week or so. really I guess the only way to tell is to take our motors apart and take a look but hell, if you do that then I guess you should just replace everything with new parts. Lex, can you fit one of those tiny micro scope cameras down in the crank case and check out the rods and bearings?.... is it even poss to tell from a scopes eye view if the imperfection is there? or you need a digital caliper? again, hope it's only a small percent with these imperfections and I assume so cause it's not like you hear of everyone motors dropping like flies here on Msf.org... One thing I think we should do is go back into the blown motor thread and ask all the members with blown motors to check their VIN and see what factory in Japan their car was built at. I know the speed 3 and 6 were built in two different cities factories in Japan. Maybe it could be poss for the cars with the imperfections to have come from only one single factory. or I could be all wrong---meaning I would now assume that all the pistons and rods crank ect...are forged and manufatured in one plant and then sent to both factories. In that case I would assume that there are imperfected rods in cars from both factories. maybe....the factories got their internals from different factories?.... there are so many variables but if we could pin point where the defective rods come from then we would have a better idea of who could potentially blow. ![]()
__________________ 2003 SilverStone Grey Honduh S2000 ![]() ![]() | |
![]() | | #4 | ![]() |
| Must Have Teh 10's! ![]() ![]() Join Date: Mar 2008 Location: Columbia, MD
Rep Power: 10779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,334
| Not Ranked : 0 score lol can we get lex his own section? lol like NATOR LEX haha. atleast someway to get all his findings and threads together in one place
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner |
| The Following 10 Users Say Thank You to superskaterxes For This Useful Post: | ATAZ (01-05-2010), djthom (11-16-2009), doubleflusher (11-12-2009), FearUndersteer (11-11-2009), MS3Zoom24 (11-11-2009), phantom3 (11-11-2009), predapio (11-11-2009), SpeedNess (11-11-2009), SpeedSixxx (11-12-2009), xcoldricex (11-13-2009) |
![]() | | #5 | ![]() |
![]() Join Date: Feb 2009 Location: All Over
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 284
Groans: 32
Groaned at 31 Times in 18 Posts
| Not Ranked : 0 score lex, props to you for all your help to the community. maybe you should start your own company like RaceRoots and not charge up the ass for secrets but help the world instead, haha. |
| The Following 4 Users Say Thank You to BoostIsBetter For This Useful Post: |
| The Following User Says NO Thank You to BoostIsBetter For This Un-useful Post: |
![]() | | #6 | ![]() |
![]() Join Date: Jul 2009 Location: Vancouver, BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score Interesting so, if I understand you correctly, the top of the rod is bent towards 4, thus the bottom is pushed towards the pass side of the vehicle, engine in. This may explain why we don't see rashes of blown CX-7 mills. Aside from the obvious fact that CX-7 owners aren't rev-happy punk-asses trying to squeeze 5000 hp out of the stock tune , there's a big mechanical difference: the auto trans. The auto has a big ass torque converter bolted to the flexplate and it doesn't impart hundreds of pounds of compressive side force to the crank, like happens when the clutch is used. The force is momentary but, large. I wonder what is an acceptable amount of crank float on these engines and whether the tolerance stack-up is leading some to be extreme in this regard? Are there indications of excessive movement at the other end of the crank like spalling on the inner side of the block or whatever kind of thrust plate limits this movement? |
![]() | | #7 | ![]() |
![]() Join Date: May 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 50
Groaned at 30 Times in 15 Posts
| Not Ranked : 0 score To me FORD has a hand in this. When I stopped buying US made cars in 83 this is exactly why. Had a 460 FORD motor go bad at 2,000 miles for just this reason. Will they ever learn. Quality Job 1.....right up your ass. |
| The Following 3 Users Say NO Thank You to Doc-1 For This Un-useful Post: |
![]() | | #8 | ![]() |
![]() Join Date: Jan 2009 Location: Columbus Ohio
Rep Power: 1087 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,958
Groans: 27
| Not Ranked : 0 score Did these still have the rings on them? How did they look?
__________________ 08 CB MS3 Sport Sold 01 MX-5 (Project) 03 P5 (DD) |
| The Following User Says Thank You to cpolly69 For This Useful Post: | SpeedSixxx (11-12-2009) |
![]() | | #9 | ![]() |
![]() Join Date: Mar 2008 Location: abc
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,081
Groans: 147
Groaned at 34 Times in 29 Posts
__________________ "08, I hate to break it to you, but if it gives kevin a boner, its porn" ![]() NATOR PERFORMANCE Nylon washer sponsered | |
| The Following User Says Thank You to mexicant For This Useful Post: | speed3 (11-17-2009) |
| The Following 3 Users Say NO Thank You to mexicant For This Un-useful Post: |
![]() | | #10 | ![]() |
![]() Join Date: Sep 2009 Location: CREVE COUER, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 263
Groans: 75
Groaned at 57 Times in 37 Posts
| Not Ranked : 0 score You should break this down barney style for ppl that dont understand. Good work! |
| The Following 3 Users Say Thank You to Fagwagon For This Useful Post: |
![]() | | #11 | ![]() |
| WOT @1k RPM! ![]() Join Date: Jul 2009 Location: SoCal
Rep Power: 7299 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24,432
Groans: 47
Groaned at 50 Times in 33 Posts
| Not Ranked : 0 score I cant be bothered to search for the info, but wasnt TrickyTwelve inch going to blow the whole thing wide open and teach us all what was really the problem? Lex, are these from the same year engine?
__________________ MazdaSPEED3 2009 - Mica Black http://www.mazdaspeedforums.org/forum/f8/setting-avatar-new-users-other-noobs-43712/ http://www.mazdaspeedforums.org/forum/f8/uploading-adding-images-your-post-43704/ No BB URL code = sux |
![]() | | #12 | ![]() |
![]() Join Date: May 2009 Location: Little Neck, NY
Rep Power: 3771 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,108
Groans: 326
http://www.mazdaspeedforums.org/foru...engines-41236/ | |
| The Following User Says Thank You to 8.5MS3 For This Useful Post: | NRSpeed (11-12-2009) |
![]() | | #13 | ![]() |
Based on people's observations and my own, yes, the rod has some side to side movement and yes during a shift it would be offset towards the passenger side. This may be even more significant than the imperfect construction of the rod itself. These rods seem to mainly bend along the left-right axis of the motor. This can very well be because the cylinder pressure is not centered on the load axis of the rod and the tolerances are not tight enough. This is part of the motor design - no motors are perfect - we are just seeing a combination of cylinder pressure (for various reasons) and enough tolerance deviation (it is mass produced after all) to overwhelm the ultimate tensile strength of the rod along that axis. Also note that ALL the rods I have are constructed this way. They range from an MS6 to an 08.5 MS3. So there is no point in checking this inside your motor. | |
![]() | | #14 | ![]() |
![]() Join Date: Oct 2008 Location: New Brunswick, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 37
| Not Ranked : 0 score Lex, I just checked my 3 remaining Rods. They all show the exact thing you've measured. A 0.5mm difference in the small rod end centering. And they all correspond to the uneven bearing wear on the large rod end. And #4's bend is also in the direction of the off center force caused by this. Excellent find. |
| The Following 8 Users Say Thank You to Thestaplegunkid For This Useful Post: | 06Speed6 (11-11-2009), DaleNixon (11-12-2009), djuosnteisn (11-11-2009), FearUndersteer (11-11-2009), Lex (11-11-2009), SpeedSixxx (11-12-2009), superskaterxes (11-11-2009), xcoldricex (11-13-2009) |
![]() | | #15 | ![]() |
![]() Join Date: Sep 2009 Location: Austin, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 289
Groans: 40
| Not Ranked : 0 score Does that mean that the crank is shifting to one side causing this? |
![]() | | #16 | ![]() |
More of a reason to limit torque, low RPM load, detonation, and flat foot shifting on the stock bottom end. EDIT: Some cars will have poorer tolerance stack up (not just the rods, but all tolerances) than others and those are more susceptible to this problem. | |
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
![]() | | #17 | ![]() |
![]() Join Date: Nov 2008 Location: Alexandria, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 413
Groans: 40
| Not Ranked : 0 score Lex should have his own forum section for all his observations. My .02cents.
__________________ CP-E SRI / Forge BPV / Corksport TP / Corksport CBE |
| The Following 2 Users Say Thank You to toprock For This Useful Post: | SpeedSixxx (11-12-2009), xcoldricex (11-13-2009) |
![]() | | #18 | ![]() |
![]() Join Date: Jul 2009 Location: Baltimore, MD
Rep Power: 253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 157
| Not Ranked : 0 score I applaud your efforts! So are quality aftermarket rods the answer, atleast to abate this issue?
__________________ 2009 MazdaSpeed3 | True Red 35% Tint CP-E Engine Mount - CP-E XCel Intake - COBB AP - CP-E TMIC |
![]() | | #19 | ![]() |
![]() | | #20 | ![]() |
![]() Join Date: May 2009 Location: Tallmadge, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 208
Groaned at 8 Times in 5 Posts
| Not Ranked : 0 score So basically this is like a mini crankwalk? That's apparently a strain on already improperly manufactured rods? FML
__________________ ![]() ::: Cobb AP ::: HTP 3" Full Intake ::: Ebay DP ::: CNT CBE ::: JBR Triology ::: JBR SSP ::: JBR RSB ::: CS TMIC ::: MSD Dashhawk ::: White PC RX-8 Wheels wrapped in Continental DWS 225-40-18 ::: ::: DIZZY TUNED by Boost_creep ::: |
![]() | | #21 | ![]() |
| Lurkers
Posts: n/a
| i got the good set of 09 mazda rods as well as samsel450r |
| The Following User Says Thank You to For This Useful Post: | SpeedSixxx (11-12-2009) |
![]() | | #22 | ![]() |
![]() Join Date: Sep 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 145
Groans: 29
| Not Ranked : 0 score I gawt me some pauterz?? Seriously though, the side loading of these rods is worrisome, but there was a correction in 08.5 with a diamond cut thrust washer (more precise tolerance) that was designed to prevent lateral deflection in the crankshaft.
__________________ All wagon, No traction |
![]() | | #23 | ![]() |
![]() Join Date: Mar 2009 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
Groaned at 34 Times in 12 Posts
| Not Ranked : 0 score Makes me feel a little better with my 08.5 but i drive like an old lady now just because im soo no trying to pay for another engine :/
__________________ 2008.5 Red Mazdaspeed 3 Performance Mods: OBX RP | SURE Intake | SU-TMIC | Cobb TIH | Turbosmart Hybrid BOV | JBR 80 Duro RMM | Hypertech Appearance Mods: 15% tint | Blacked-out Emblems, Side Markers and Side Reflectors Monitoring: Dashhawk |
![]() | | #25 | ![]() |
![]() Join Date: Apr 2008 Location: Utah
Rep Power: 573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 120
| Not Ranked : 0 score If i got a new thrust washer for my engine build, it would be the updated one right? |
![]() | | #26 | ![]() |
| The Following 2 Users Say Thank You to Thestaplegunkid For This Useful Post: | djuosnteisn (11-11-2009), SpeedSixxx (11-12-2009) |
![]() | | #27 | ![]() |
Groans: 79
| Not Ranked : 0 score Thanks for taking away all my worries.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
![]() | | #28 | ![]() |
![]() Join Date: Jun 2008 Location: New Port Richey, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,984
Groans: 88
| Not Ranked : 0 score So....Mazda designed our Mission Impossible ECU to target high loads, at low RPM on incorrectly sized rods with a long stroke? FOL (Fck Our Life) Do you think they knew about the rod size problem.... I'm sure they will now...
__________________ FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute JAM SESSION........US Amps (in Series w/ Stock Amp) using OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back) RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors - Acne Rear Bumper LED Reflectors |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score Is there a way to check a part number for this? Thestaplegun's motor looked really bad in terms of side loading the rods and it was an 08.5 |
![]() | | #30 | ![]() |
Groans: 778
| Not Ranked : 0 score just saying...lex did mention that his bent rods came from Ms6 to a 08.5 ms3....
![]() | | #31 | ![]() |
![]() Join Date: Jun 2008 Location: Raleigh NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
Groaned at 37 Times in 23 Posts
| Not Ranked : 0 score I wonder if its possible to take it to a lawsuit if mazda denies your warranty claim due to mods. If you have a pre 08.5, this type of evidence plus the new diamond cut bearings they added in points to them trying to cover up a problem. |
![]() | | #32 | ![]() |
| Not Ranked : 0 score they arent going to warranty shit if they claim you werent stock.
![]() | | #33 | ![]() |
Groans: 47
| Not Ranked : 0 score So I googled up Crank walking and found this. Very good info. Also found another and they are all about DSMs. So, it may be wearing on the thrust bearings in combination with possibly uneven rods? These two powers combined form Captain Capow!
![]() | | #34 | ![]() |
Groans: 79
| Not Ranked : 0 score It's funny, forzda on 6club was talking about the thrust bearing a long time ago. He even mentioned how to check for it with a 2x4, and what amount of movement was "ok". HERE was forzda's thread.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com Last edited by djuosnteisn; 11-12-2009 at 10:29 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #35 | ![]() |
Groans: 47
| Not Ranked : 0 score Yea, seems that Forda says the same thing in one of the links I posted about how important it is to jumper the clutch safety. Ill be reading up on all this during lunch. Learnin is fun!
![]() | | #36 | ![]() |
![]() | | #37 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score I forsee more intrest in PTP's crank straps and 06Speed6's possible billet main. |
| The Following User Says Thank You to QuickSpool For This Useful Post: | ptperformance (11-20-2009) |
![]() | | #38 | ![]() |
![]() Join Date: Oct 2008 Location: Western Hemisphere
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
Groans: 91
| Not Ranked : 0 score So the diamond thrust washer in the 08.5+ should prevent this but plenty of 08.5's have blown?
__________________ Gay car #1: 2001 Miata (Gay White) Gay car #2: 2011 Mazda 2 (Gay Blue) |
![]() | | #39 | ![]() |
Groans: 47
| Not Ranked : 0 score Still hear-say till we get a part number or someone finds the part breakdown.
![]() | | #40 | ![]() |
![]() Join Date: Mar 2008 Location: orange county
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,807
Groans: 137
| Not Ranked : 0 score this has something to do with some people reporting clutch vibrations leading to a rod exiting the block?
__________________ 2008 STi Intake Turboback AP |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/rod-bending-observations-42105/ | ||||
| Ok mod stage advice.. | This thread | Refback | 01-07-2013 01:16 AM | |
| Forge BPV for the 2010 - 2010 Mazda 3/Mazdaspeed 3 Forums | This thread | Pingback | 02-22-2010 09:41 PM | |
| Ok mod stage advice.. - Mazda CX-7 Forums | This thread | Refback | 12-22-2009 07:05 AM | |
| A2SportCompacts :: View topic - AFCadet's engine | This thread | Refback | 11-20-2009 08:17 AM | |
| Vague Observations on Boost and Load Tables | fjames | Cobb ATR Support | 5 | 09-02-2009 08:48 AM |
| Intake vs. boost observations | Hectik1 | MazdaSpeed 3/6 - Turbo Induction | 12 | 05-16-2009 05:07 PM |
| Open/Closed Loop Transition, Some New Observations | superskaterxes | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 07-18-2008 11:35 AM |
