 Old 11-17-2009, 06:30 PM   #121
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
scientific test > feelings, thoughts, hopes and dreams and day of the week
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
The Following 2 Users Say Thank You to cpolly69 For This Useful Post:
djuosnteisn (11-18-2009), SpeedSixxx (01-02-2010)
 Old 01-02-2010, 06:45 AM   #122
ungrave's Avatar
Posts: 30   (View Stats)
ungrave has a spectacular aura aboutungrave has a spectacular aura aboutungrave has a spectacular aura about
If you haven't blown, is it possible to swap out the stock rods for aftermarket ones without pulling the motor?
2006 Mazdaspeed6 33k miles - stock
ungrave is offline   Reply With Quote
 Old 01-02-2010, 08:08 AM   #123
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Doesn't seem to be. The timing cover and components seem to be the biggest difficulty. There's a fair amount of stuff that needs to come off the block and as i'm learning (i used to want to do it in the car like you too), it's best to just do it right, and pull the block. You should really send it to a machine shop to at least check the deck and cylinder bores and crank and stuff. Esp if your going to put in the money for upgraded internals.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
ungrave (01-05-2010)
 Old 01-03-2010, 12:22 AM   #124
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
You can swap pistons and rods with the engine in the car, if you have very many miles it wont run worth a shit because it wont hold a good compression and unless your very lucky it will probably vibrate very badly, but it is definitely possible if you want to do things absolutely the hardest way possible.
2006 Mazdaspeed 6
SpeedSixxx (01-04-2010), ungrave (01-05-2010)
 Old 01-03-2010, 05:30 PM   #125
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
You need your block machined prior to installing new parts.
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline   Reply With Quote
The Following User Says Thank You to nyghtryder For This Useful Post:
 Old 01-04-2010, 08:06 PM   #126
cudaman's Avatar
Posts: 155   (View Stats)
cudaman has a reputation beyond reputecudaman has a reputation beyond reputecudaman has a reputation beyond reputecudaman has a reputation beyond reputecudaman has a reputation beyond reputecudaman has a reputation beyond reputecudaman has a reputation beyond reputecudaman has a reputation beyond reputecudaman has a reputation beyond reputecudaman has a reputation beyond reputecudaman has a reputation beyond repute
Thanks for looking into this. This is probably a large reason as to why we're bending rods all the time and say an Evo or SRT4 are not when the rod dimensions and forging are quite similar. The fact that we have a pretty long stroke really doesn't help as it amplifies the effects of the poor geometry.
More of a reason to limit torque, low RPM load, detonation, and flat foot shifting on the stock bottom end.
EDIT: Some cars will have poorer tolerance stack up (not just the rods, but all tolerances) than others and those are more susceptible to this problem.
I agree. I have a stage3 Neon SRT-4 and an '09 MS3. Stock for stock, the MS3 is a much better car overall, BUT, the Neon SRT-4 internals and the bottom end seem to hold up much better when modded..... I may not be doing much to the MS3... don't have to...
cudaman is offline   Reply With Quote
 Old 01-04-2010, 08:40 PM   #127
BoostIsBetter's Avatar
Posts: 582   (View Stats)
BoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the worldBoostIsBetter is the leader of the world
Groans: 32
Groaned at 31 Times in 18 Posts
that's cause your your SRT-4 bottom end is build by dodge in the same fashion they make their diesel trucks. that block is invincible! you got stage 3, what goodies on it?
BoostIsBetter is offline   Reply With Quote
 Old 01-05-2010, 10:25 AM   #128
clos561's Avatar
Posts: 1,172   (View Stats)
clos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the world
its probably because its port vs di
7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance
clos561 is offline   Reply With Quote
 Old 01-10-2010, 07:17 AM   #129
nyghtryder's Avatar
especially since dodge has never built their own diesels
NATOR PA
 Old 01-11-2010, 04:25 PM   #130
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
can we has get this thread back on track please././
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/rod-bending-observations-42105/
Ok mod stage advice.. This thread Refback 01-07-2013 01:16 AM
Forge BPV for the 2010 - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 02-22-2010 09:41 PM
Ok mod stage advice.. - Mazda CX-7 Forums This thread Refback 12-22-2009 07:05 AM
A2SportCompacts :: View topic - AFCadet's engine This thread Refback 11-20-2009 08:17 AM
Vague Observations on Boost and Load Tables fjames
Cobb ATR Support
5 09-02-2009 08:48 AM
Intake vs. boost observations Hectik1 MazdaSpeed 3/6 - Turbo Induction 12 05-16-2009 05:07 PM
Open/Closed Loop Transition, Some New Observations superskaterxes MazdaSpeed 3/6 - ECU Computer Tuning 1 07-18-2008 11:35 AM
Page generated in 0.32447 seconds with 29 queries
