Like Tree3Likes
 Old 10-26-2014, 05:51 PM   #81
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Originally Posted by TRQ STEER FTL View Post
Is SURE honestly that bad? They hadnt fixed the problems by now? I noticed the HTP 3.0 intake is only a ID of 2.87. Was hopinh for a full 3in ID.
I also replaced the stock pcv plate with a stock one. Would that really be the leak? Is so I'm ready to shoot myself. Really didn't want to pull the IM off again. I have a boost leak tester on the way so ill be able to hopefully pin point the leak with a bike pump cause i don't have a air compressor.
Don't shoot yourself please.
You'll get it with a leak tester.
 Old 10-26-2014, 06:31 PM   #82
TRQ STEER FTL's Avatar
Posts: 189   (View Stats)
TRQ STEER FTL has much to be proud ofTRQ STEER FTL has much to be proud ofTRQ STEER FTL has much to be proud ofTRQ STEER FTL has much to be proud ofTRQ STEER FTL has much to be proud ofTRQ STEER FTL has much to be proud ofTRQ STEER FTL has much to be proud ofTRQ STEER FTL has much to be proud ofTRQ STEER FTL has much to be proud ofTRQ STEER FTL has much to be proud of
Can I ask how youre so sure about that being the leak?
TRQ STEER FTL is offline   Reply With Quote
 Old 10-26-2014, 06:55 PM   #83
btstarcher's Avatar
Posts: 4,852   (View Stats)
Groans: 112
@Raider; is Sure really that bad? LOL
SnailTune in progress
The Following 2 Users Say Thank You to btstarcher For This Useful Post:
Raider (10-26-2014), rfinkle2 (10-26-2014)
 Old 10-26-2014, 07:00 PM   #84
rfinkle2's Avatar
Groans: 298
If you replaced that pcv box with a stocker, I cannot be sure.
What does the remainder of the fuel curve look like? The remainder of your trims?
Sure sucks btw.
Some of their parts are fine, just don't use any that are suspension or fuel related and don't count on any of their instructions being correct.
Their wiper plug and lanyards are no joke.
 Old 10-26-2014, 07:10 PM   #85
Sure sucks btw.
Ill take some logs and post them up soon.
I already planned on staying away from SURE's major components. Was thinking a simple intake could be safe aside from the glue somehow being stuck inside the vacuum breather.
The Following 2 Users Say Thank You to TRQ STEER FTL For This Useful Post:
btstarcher (10-26-2014), rfinkle2 (10-26-2014)
 Old 10-26-2014, 07:14 PM   #86
rfinkle2's Avatar
Groans: 298
Don't get me wrong, the marketing, the packaging and the initial look of the parts is all very nice.. Just, imo, they pay more attn: to cosmetics than engineering and the owner is a total douchehat.
Raider (10-26-2014)
 Old 10-26-2014, 07:22 PM   #87
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
mr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the world
Go read the sure fail thread and you decide if they are that bad...
Did you silicone the PCV plate?
Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet!
mr.speedy3 is offline   Reply With Quote
The Following User Says Thank You to mr.speedy3 For This Useful Post:
Raider (10-26-2014)
 Old 10-26-2014, 07:27 PM   #88
btstarcher's Avatar
Groans: 112
Whether they're bad or not is irrelevant; the fact that a company would hang its customers out to dry as bad as they did should be enough for anyone here not to do business with them.
rfinkle2 (10-27-2014)
 Old 10-26-2014, 07:28 PM   #89
I did read the fail thread and figured as long as i check over the intake thoroughly i should be safe. Wouldnt exactly trust a suspension or major engine part though.
I did not silicone the PCV plate. I slightly oiled the seal and crisscrossed the bolts as i tightened them.
 Old 10-27-2014, 09:23 AM   #90
Lets say it turns out the PCV plate is the problem. Does anyone have any opinions on this block off plate? Or another brand? I dont want to run more than one catch can.
Ford Duratec & Mazda MZR PCV Block-Off Plate
I would like the pcv being brass rather than a cheap plastic. I read another thread talking about how it doesnt need the bafflinr and that its somehow in the highest position possible. Anyone here run one of these things?
 Old 10-27-2014, 09:32 AM   #91
radbrad's Avatar
Posts: 538   (View Stats)
radbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the worldradbrad is the leader of the world
I think some have used that one, but I believe most people will use this plate:
http://www.edgeautosport.com/manufac...focus-st-2013/
This one was developed by one of own mazdaspeed drivers and forum members. You can plug one of the holes, and if you ever need to add a second can, you have the ability.
07Speed3
TWM STS || Forge BPVv1 || Sure RMM || Cobb SRI || CNT DP || AP || Autotech || ITV22 || COBB/TR8L FMIC || JBR TB&IM TIG || HTP TIP || JBR PMM&TMM || JBR EGR DELETE || Cobb CBE || SONIC COs || Perm Plate & OCC || JBR OCC || PnP IM || DO Meth Inj. ||
radbrad is offline   Reply With Quote
 Old 10-27-2014, 09:44 AM   #92
PERM Tuning PCV Plate Mazdaspeed 3 Mazdaspeed 6 2006 - 2013
Thats the other one I was looking at but for some reason my mind didnt think about plugging one of the ports and just running it like a normal pcv. Ill keep that one in mind if my boost leak teat shows thats where my leak is coming from.
 Old 10-29-2014, 10:32 PM   #93
I dont believe that pcv block off plate has an actual pcv valve. Would it be okay just running a check valve with the MD occ kit?
 Old 10-31-2014, 07:33 AM   #94
mr.speedy3's Avatar
I've never seen that plate... I would have preferred it to stock plastic but I run a dual catch can setup. Did you not check the pcv valve when you had it out?
tapatalkin
 Old 11-01-2014, 07:12 PM   #95
I did check the pcv but I noticed I was able to slightly blow air one way and not at all through the other way. I though it was only suppose to be a one way valve but it was brand new ao I stuck it on amyways. Recently though I had a second injector go out on me so im just saying screw it and replacing the 3 that are still on from the factory.
Im also going with the CPE seals and was curious about how the studs that are included go on in place of the T40 torx bolts.
Also just want to get the whole pcv block off plate routing right. I only want to run one catch can and need to know if you have to run a inline pcv after the block off plate or am I safe with a check valve on the catch can line?
This car sure is more expensive than my cheap honda. Lol.
 Old 11-01-2014, 07:51 PM   #96
mr.speedy3's Avatar
More expensive because not all Japanese sushi parts lol.
I run the pcv and check valve... Think of it as double protection lol. Make sure you get a quality, low crack pressure check valve for the occ, a local melted a cheap check valve. You can buy a decent check valve from Matt Damond, or go to ace and assemble your own.
Do you have replacement injectors? I have a spare set I could sell for a good price. As for the studs, definitely do it.
These were cleaned with meth and work just fine. I used them for testing.
And for eye candy... Seen this guy today
tapatalkin
 Old 11-01-2014, 10:06 PM   #97
Attachment 180458
Attachment 180457
Attachment 180456
Attachment 180459
tapatalkin
I was going to use a MD catch can that uses the check valve on the IM side. Would that alone be safe? This is my daily and would love for it to make it through winter without having to take it apart all the time.
I don't have injectors yet. Been putting off ordering them from an online dealership. I know i need to sooner rather than later. I would love to purchase those injectors but a part of me is worried that used ones would fail soon as well but the cheap ass in me is saying to go that route. Decisions, decisions...
 Old 11-01-2014, 10:30 PM   #98
mr.speedy3's Avatar
Ask MD about the check valve lol
As for injectors, they have 30k on em from a pu. If that helps any lol
Also say you buy my injectors, you can have them cleaned for $100 at 2k psi. That'll basically make them new. That'd still be 1/4 the price of new lol
tapatalkin
 Old 11-02-2014, 08:22 AM   #99
mr.speedy3's Avatar
Gaskets, FYI.
tapatalkin
 Old 11-02-2014, 03:03 PM   #100
mr.speedy3's Avatar
Woops, disregard, wrong thread.
 Old 11-29-2014, 01:56 PM   #101
Well, got the injectors cleaned and installed. Cpe seals also and replaced all the o rings and everyhing. Get it all bundled and no start... I swear I can never win with this car. I crank it and it makes a squealing sound and then after I stop cranking it makes a clicking sound. Inj pulse width is about 10-11 ms and hpfp psi is in he 1800s.
I wish it'd atleast start and run to throw a cel to give me a clue.
 Old 11-29-2014, 07:28 PM   #102
mr.speedy3's Avatar
Double check you reconnected everything. And that you didn't nudge the ground on the starter (white clip points up towards the bottom of the intake Mani).
Is it clicking?
Or just absolutely nothing?
tapatalkin
 Old 11-30-2014, 09:06 AM   #103
I pulled my plugs abd they had quiet a bit of carbon on them so I replaced them but still no start. It'll just keep on cranking when trying to start. I have my accessport reading fuel injection amount and its reading 15-16 mg/cyl. I checked the ground on the starter as best i could. Im figuring the clicking was from my battery being low. I tried jump starting it but still just cranks away with no start.
Really at a loss here. Last time I took it to a dealer I got royally fucked and the car still had problems so Im having trouble with the idea of taking it somewhere again.
 Old 11-30-2014, 09:16 AM   #104
Scare Dem's Avatar
Posts: 1,505   (View Stats)
Scare Dem is the leader of the worldScare Dem is the leader of the worldScare Dem is the leader of the worldScare Dem is the leader of the worldScare Dem is the leader of the worldScare Dem is the leader of the worldScare Dem is the leader of the worldScare Dem is the leader of the worldScare Dem is the leader of the worldScare Dem is the leader of the worldScare Dem is the leader of the world
Clicking does mean a weak battery and I know you tried jumping it, but can you put it on a charger?
Trickle charge it over night and see if that helps.
I had starting issues a month ago, but when I turned my key there was NOTHING. I just wiggled the wires on both sides of the starter and it's been fine ever since.
Good luck man.
2008 Mazdaspeed3 GT
GTX2867r
Scare Dem is offline   Reply With Quote
 Old 11-30-2014, 10:15 AM   #105
That's what i had to do. Reach under the IM and use my hands as eyes and wiggle everything that i could feel was connected to the starter. Nothing though.
Only CEL I'm getting is ABS U2023.
I need fuel, compression, and spark to start. I just changed the plugs so I'm sure that's good Last i did a compression check everything was gravy. Fuel is the only thing I'm curious about. The HPFP seems good. Anyone wanna check their AP to see the fuel injection amount per cylinder on start up?
Also this car sure is a pain in the ass, lol.
 Old 11-30-2014, 10:47 AM   #106
btstarcher's Avatar
Groans: 112
Ballast resistor maybe?
mr.speedy3 (11-30-2014)
 Old 11-30-2014, 11:02 AM   #107
Honestly I've never even heard of a ballast resistor. Lol. It was starting before i replaced the injectors. Ran like shit but it did run.
 Old 11-30-2014, 11:22 AM   #108
btstarcher's Avatar
Groans: 112
http://www.mazdaspeedforums.org/foru...ml#post2569198 The thread references another thread with similar issues; not sure if it's applicable to your case but worth a try.
 Old 11-30-2014, 10:52 PM   #109
mr.speedy3's Avatar
You can also get a fuel pressure tester for the itfp to ensure the itfp isn't dead. Is your hpfp reading 400 or so with the key on?
tapatalkin
 Old 12-01-2014, 01:44 PM   #110
Hpfp is reading 1800s with key on.
Anyone know of a good auto ahop in the cleveland area? Ive got no more time to figure it out myself and need this car back already.
 Old 12-02-2014, 08:49 AM   #111
mr.speedy3's Avatar
Have you joined your local Nator yet?
tapatalkin
 Old 12-08-2014, 07:43 PM   #112
Its been all worked put thanks to a local guys help. Wiring harness issues for all. Thabks for all the help though. Great community here!
The Following User Says Thank You to TRQ STEER FTL For This Useful Post:
btstarcher (12-08-2014)
 Old 12-08-2014, 09:30 PM   #113
mr.speedy3's Avatar
Where exactly? Was it the intake rubbing the ecu harness?
tapatalkin
 Old 12-12-2014, 08:46 PM   #114
tapatalkin
No but that was an issue when i first took it to the dealership. Had it "fixed" and then had problems with plug pins that connected to the injector harness and had corrosion in the fuse box.
You would think the dealership would have noticed some of these things but that's why i will go back and will warn anyone who even thinks about going that way.
Rough Idle Rizz Nasty Mazdaspeed3/6 General Discussion 45 12-16-2012 02:24 PM
Rough Idle and KR fearturtle03 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 05-27-2011 11:38 AM
sometimes rough idle....?? MSP611 MazdaSpeed 6 - Engine, Transmission & Driveline 12 07-14-2010 04:32 PM
Rough Idle/Acceleration wasntme MazdaSpeed 3/6 - Troubleshoot/Diagnostics 48 07-08-2010 09:05 AM
rough idle? tbone MazdaSpeed 3/6 - Turbo Induction 13 11-11-2008 06:10 AM
Page generated in 0.52236 seconds with 26 queries
