Like Tree4Likes
  • 2 Post By Thor Hammer
  • 1 Post By g00s3y
  • 1 Post By Fstrnyou
 Old 04-06-2018, 12:01 AM   #1
KooshaS's Avatar
Posts: 24   (View Stats)
KooshaS is on a distinguished road
Groaned at 6 Times in 3 Posts
Default Second thoughts on downpipe
I recently purchased a Cobb catted downpipe and now I'm having second thought on installing it. I hear all these people saying how their cars started smoking after installing a downpipe and im afraid mine will too. I took out both my resonators and my 2nd cat and I haven't had any smoking issues so far. I do puff out a little bit of black smoke when revving it to higher rpms but no white smoke but thats fine because my car runs a little rich. Do you think i should install it? I have 98k miles and I checked my turbo when i recently installed my TIP and it seemed really healthy but that probably doesnt mean much. Any replies are appreciated!
KooshaS is offline   Reply With Quote
 Old 04-06-2018, 05:58 AM   #2
shamie's Avatar
Posts: 863   (View Stats)
You already own it and don't want to install it? What are you going to do with it - hang it on your wall? Stop being a pussy and just put it on. If you start smoking fix that issue. DPs don't make your car smoke, they just stop the masking of it.
2009 MGM MS3 - / HTP 3"/ COBB AP V3, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM PS Cooler & OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, 51R Battery Box & Raider's AD / StopTech Brakes
 Old 04-06-2018, 06:21 AM   #3
GroceryGtr's Avatar
Posts: 402   (View Stats)
shamie hit the nail on the head. The DP doesnt cause the smoking...it just brings it to your attention that its already happening(1st cat usually filters it out). Install the damn thing already.
If you are smoking its likely the seals on your K04. Options are to buy the restrictor banjo bolt or upgrade to a s3/cs and be done with it. Some have also had good luck with running a 5/40 oil to keep it from seeping past the seals. But if you are already less 2nd cat and resonators with little to no smoke I doubt you will see much of a change in smoke output. Most guys that see a big difference go from full emissions to nada.
 Old 04-06-2018, 08:22 AM   #4
Bertospeed3's Avatar
Posts: 8   (View Stats)
Bertospeed3 is an unknown quantity at this point
Hope you already have HPFP installed.
2010 Black Mica Mazdaspeed3
Autotech Fuel Pump Internals | Cobb 3" SS Downpipe | OBX R Catback Exhaust | Cobb SF Intake | Cobb Turbo Inlet Hose | CP-e TMIC | Corksport Dual VTA BPV
 Old 04-06-2018, 09:04 AM   #5
Police - Grammarhead
Vansquish's Avatar
Groans: 1,791
Groaned at 44 Times in 25 Posts
^^^ This ^^^
You also actually need a custom tune at this point as well.
 Old 04-06-2018, 09:47 AM   #6
Jeff23spl's Avatar
Posts: 1,216   (View Stats)
like other said cats mask a problem but doesn't create one....
Sometimes you install a dp to add power and tune it to a point that makes the k04 overspeed and decrease it's lifespan.
If your engine blow-by, reducing the backpressure on the discharge side of the turbo with a DP may let more oil pass thru the turbo seals....Again it isn't because of the DP but because you already have a problem....
1993 Ford Probe KLZE
2012 Mazda3 Gs-sky to save fuel and when the speed is broken
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
2007 speed3 burned
...Because French Canadian...
 Old 04-06-2018, 01:18 PM   #7
Thor Hammer's Avatar
Posts: 1,390   (View Stats)
Groans: 125
Step 1: Buy HPFP internals and AP or VT.
Step 2: Send E-Tuner of choice mod list for first base tune.
Step3: Install DP
Step 4: Take data logs and tune.
Step 5: Win
Jeff23spl and Carskick like this.
Waiting for Install: BNR S3/HTP 3.5 Intake/Damond OCC/ CS Injector Seals/ WMI/MAPerformance Rev3 Intake Manifold
 Old 04-09-2018, 04:38 PM   #8
KooshaS's Avatar
Thanks for the replies. My current mods are a Cobb intake, TIP, HPFP, AP, and just the res and 2nd cat delete so yeah im all set with the HPFP. Sadly, I pulled out of the parkway today and noticed a puff of white smoke and same again when i stopped at a stop sign but it went away after driving for a bit and didn't notice anymore smoke at a long ass red light. Im due for an oil change so ill go 5w-40, install a bnoon bolt soon and hopefully install the DP later next week. Also some people say they've had success with a ptp pill but i cant find one anywhere.
 Old 04-10-2018, 08:41 PM   #9
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,771   (View Stats)
Groans: 534
Groaned at 178 Times in 115 Posts
sooo was it cold out?
06 MS6
 Old 04-10-2018, 08:48 PM   #10
KooshaS's Avatar
Nope. Phoenix weather. Hot as hell outside
 Old 04-11-2018, 12:36 PM   #11
Dennisms3's Avatar
Posts: 187   (View Stats)
Dennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant future
I heard going catless solves the smoking problems.
Dennisms3 is offline   Reply With Quote
 Old 04-11-2018, 02:59 PM   #12
JakeMS3's Avatar
Posts: 1,128   (View Stats)
JakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the world
Groaned at 6 Times in 4 Posts
No cats. Fk all the cats.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
Corksport Catted DP/HPFP Internals
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
JakeMS3 is offline   Reply With Quote
 Old 04-11-2018, 03:36 PM   #13
Db09ms3's Avatar
Posts: 170   (View Stats)
Db09ms3 has much to be proud ofDb09ms3 has much to be proud ofDb09ms3 has much to be proud ofDb09ms3 has much to be proud ofDb09ms3 has much to be proud ofDb09ms3 has much to be proud ofDb09ms3 has much to be proud ofDb09ms3 has much to be proud ofDb09ms3 has much to be proud ofDb09ms3 has much to be proud of
What if it's on your foot? You touch it.
Stockish
 Old 04-15-2018, 04:33 AM   #14
KooshaS's Avatar
I decided to return the downpipe and not risk fucking anything up(for now). Putting money towards some proper coilovers. Thanks for the help!
The Following User Says Thank You to KooshaS For This Useful Post:
Db09ms3 (04-17-2018)
 Old 04-15-2018, 05:31 AM   #15
MSMS3's Avatar
Posts: 2,143   (View Stats)
Groans: 108
You heard that? Must be an attempt at humor.
 Old 04-15-2018, 08:36 AM   #16
Fstrnyou's Avatar
Posts: 1,424   (View Stats)
I heard ZZB solves the smoking problems.
2006 MS6 GT - 152k Miles
Versatuner, 3-bar MAP, ITV22's
Russian Bushings in Back, Magnaflow CBE
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/Stage 2 OCC
Forged build ongoing. Manley H-Tuff & 2618, King Bearings
Other rides:
History:
The Following 2 Users Say Thank You to Fstrnyou For This Useful Post:
Db09ms3 (04-16-2018), Thor Hammer (04-16-2018)
 Old 04-15-2018, 02:02 PM   #17
Hoyoman's Avatar
Posts: 300   (View Stats)
Hoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the world
No balls
2012 black mica MS3 ; 3.5 HTP/ Catless DP/ AT HPFP/ APV2/ FMIC/ GFB BOv/ 3" CBE/ RMM/ XXR 530(18x9 +33)/ NT05 245/40/18/ 3bar map/ 3 port EBCS/ bnrs3/ DO stg2 dvc30/ REAR swaybar/ EBC Yellow/ CS Inj seals/ PNP IM/ Manley H-Beam/ Manley platinum piston 87.5/ soon...... PI+ BNRs6+ 44mm TIAL+ ACT 6 puck
E35 meth d012 26psi 420/451 self tuned/built
Hoyoman is offline   Reply With Quote
 Old 04-16-2018, 11:10 AM   #18
dealerjohn1's Avatar
Posts: 268   (View Stats)
dealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the worlddealerjohn1 is the leader of the world
Fag
dealerjohn1 is offline   Reply With Quote
 Old 04-16-2018, 01:52 PM   #19
Groans: 125
Looks > Performance
Don't you know?
 Old 04-17-2018, 10:16 AM   #20
g00s3y's Avatar
Posts: 2,096   (View Stats)
Groans: 418
You sound like a faggot.
Scared to install a DP, but all for getting some "proper" coils for what? So you can say you have coils on your car. Shocks/Struts/Springs are a much better combo for a daily, but I guess that doesn't sound as cool to your 14 year old friends.
You should sell the car and put the money towards a proper prius.
Hoyoman likes this.
The Following User Says Thank You to g00s3y For This Useful Post:
Thor Hammer (04-17-2018)
 Old 04-17-2018, 10:25 AM   #21
greg08's Avatar
Posts: 457   (View Stats)
greg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond repute
5w40 rotella T6 fully synthetic. Use it. Never look back.
greg08 is offline   Reply With Quote
 Old 04-17-2018, 10:25 AM   #22
Fstrnyou's Avatar
Priorities: Get your stance right yo!
Jeff23spl likes this.
Other rides:
History:
 Old 04-20-2018, 07:32 AM   #23
Enigmaz power's Avatar
Enigmaz power is an unknown quantity at this point
Why do people still troll?
Enigmaz power is offline   Reply With Quote
 Old 04-20-2018, 08:53 PM   #24
Pu Manchu's Avatar
Groans: 534
why do people still have default avatars?
06 MS6
The Following User Says Thank You to Pu Manchu For This Useful Post:
Db09ms3 (04-21-2018)
 Old 04-21-2018, 06:11 AM   #25
Dennisms3's Avatar
Why do people still not have the balls to go catless?
Downpipe post install thoughts, concerns, regrets, questions makjur 2010 MS3 - Engine, Transmission & Driveline 22 05-29-2014 06:45 PM
2010 Catless Downpipe Thoughts John F Custom Performance Engineering (cp-e.com) 0 06-27-2010 11:25 AM
Page generated in 0.39562 seconds with 37 queries
