the point of a "plenum" is to gather air in one large area and then it gets evenly distributed into each of the runner. the velocity stacks help smooth out and speed up the air entering each runner. i wish i knew what whoosh's intake mani looked like when he was designing it. |
Yup, it's not like all the valves are open at once. |
So if the manifold is to big, the stock turbo will loose HP because of it. If it is to small, the larger turbos will have sonic resonance in the manifold and cause the manifold air flow to "stall" inside the manifold. There is an amazing amount of work that goes into making a manifold that makes power and is proven to work on both stock turbo and larger turbo applications. This is why we abandonded our manifold project with the Speed's, to many motors go boom before people can spend some serious money on making them go fast. |
Speaking of sonic resonance... damn yeah I nearly forgot, phantom... you cant have a design that exceeds ~10900in/sec because that is the sound barrier. As completely ripped off of another site: "The Mach Index is a mathematical expression of the speed, in this case, of the inlet velocity, relative to the speed of sound. Volumetric efficiency will start to fall off sharply past six tenths the speed of sound (Mach .6) so the engine designer will not want to exceed this .6 mach value at peak rpms. In as much as the speed of sound is temperature dependent and the exhaust valve has different requirements, these calculations do not apply to the exhaust valve." I think we might still be in the green though, we need to determine the CFM requirements of say 700 crank hp, and then run a flow model with that CFM and see what the velocity is. EDIT: 700 crank hp is about 1050CFM on a 2.3l engine, and it is also a calculated 44psi but I have no idea how they determined that. |
I'm heading back to the drawing board with these new figures in mind. Last week was a write off as I was helping a friend with his business. I should have a new model later today as its a long weekend here in Canada-land. |
what program are you using btw? |
I am guessing its solid works. |
I'm using solid works 2009 Premium. It's good all around program though it does lack in the area of complex surfaces through (think car body design). It's not impossible to do, but there are better programs out there like Pro engineering that can do it easier. |
impressive work ninja |
I've already geared it towards the big turbo crowd with the 3.25" inlet. The plenum will be interchangeable eventually but not at first. There is a ring that sandwiches the plenum between the velocity stack flange and a bolt ring on the inside. Changing it will be as easy as unbolting the ring and bolting the new plenum on. Just to be clear, for the time being I'm just going to start with one plenum until I get some real flow numbers and fitment sorted out. I'm going to make the first one out of fiberglass just to keep the prototyping costs down. One of my CNC machinist friends has a lot of down time at his shop right now and said that if I can get the material, he will make up the metal parts for me. Another friend offered to TIG it for free as well. So far, for the prototype, the cost is going to be minimal which will help if I end up doing multiple revisions. At the same time I can get a good estimate on the actual cost for full production. |
UPDATE in original post. |
hey as for the flow moving left. after a bend in piping you ALWAYS need and air straightener. put one just before the inlet of the mani and see what happens. |
If you need other software, let me know. I can get anything. |
update looks good. although i don't see provisions for this. 3" TORNADO INTAKE TURBONATOR SINGLE FAN GAS/FUEL SAVER:eBay Motors (item 370248709511 end time Sep-20-09 17:12:15 PDT) it's JDM! i am kidding. i was thinking that it may be more real world if you ran two separate study's one with the two inside runners plugged at the outlet and another study with the two outside runners plugged at the outlet. this may simulate the real running engine better. please keep in mind i may be totally off base though. |
I'm looking forward to seeing some prototype numbers on this. |
Are there any possible issues with information hidden in part files that get sent to a client? |
I actually just started my SW 09 training today, so I'm just starting up and making simple models. Nothing like this yet: |
^^ I actually did have a job offer to do that stuff for Honda interiors in Marysville, Ohio but I had already accepted another position... Search 40.305209,-83.545547 in google maps and check out the test tracks they have. You have to zoom out a few times to see the whole 7 mile oval. |
UPDATE: I'm broke.. lol. what else is new? I'm currently looking for a second job, but the repo man commeth and taketh away... my wife's car that is (2004 mazda 3 sedan, orange). Needless to say the manifold has been put on the back burner. I've finalized the design and I'm very happy with it. I have a shop in town that is going to print the plenum in 3D for me so I can make a mold to wrap the CF around. I've also scored some machine time at a friends shop. So once we get back on our feet and have some disposable income I can get this thing done. I'm going to machine a mandrel up to press the runners on. The pipe will be heated up and pressed onto the mandrel shaping it perfectly to the port. Once the runners are welded to the flanges the rest just bolts together. I should be able to make different runner lengths quite easily. So that's where I'm at. It will get done, just not before Christmas. David |
wow bro srry to hear about the repo :\ good luck with second job |
Shit, that sucks dude. Hope you get back on your feet soon. It's just a car, the manifold can wait... |
Damn dude. Understand completely on the lack of funds situation.. |
at least they took the right car. GL on getting everything squared away. |
sorry to hear that dude. when all else fails, join the oilfeild. its looking to be a busy winter for the right service lines. |
so uhhhhh just how much money are we talking here to get this done? is this something we could start a donation for? |
oh how i love sw |
if you can handle +12hr days, being gone for weeks on end, endless repetitive physical labor (ie. swing 8lb sledgehammer more times than you can count), all while some asshole supervisor screams at you to do it faster, then the patch is the right place for you. thats a worst case scenario. i work 15 days on, 6 off, 80-100hrs a week, and make roughly $75k/year as a senior equipment operator. i'm not sure what companies operate out of nisku, or if your willing to drive to red deer a lot, but you want to apply to a well servicing company. stay away from drilling/service rigs and well testing. just drop off lots of resumes with companies like BJ, Trican, Calfrac, Sanjel, Weatherford, Slumberger or Halliburton for their wireline, coil tubing, or pumping services divisions. PM me if you want more info |
as for the mani...what type of school is required for this type of thing... like designing cars, car parts and such... Drafting? or is it something else. |
| All times are GMT -7. The time now is 06:41 AM. |
