 Old 08-30-2009, 12:34 PM   #41
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Originally Posted by phantom3 View Post
I looked more into this velocity stack (VS) issue and this is what I have found so far.
VS's are used on N/A motors in order to produce more torque. VS's essentially do the same thing on a turbo motor untill boost kicks in. This is when the air flow dynamics change. The engine is no longer sucking the air in, its more being forced in by the turbo (Duh).
In an N/A application the air speeds up as it travels down the VS due to vacuum. The point where it speeds up is the taper to the VS. Any obstructions (minor) pre VS don't have much effect.
In a turbo application we are dealing with compressed air (more molecules). As the air is crammed in and small disruptions have a more profound effect on flow paths and velocity. The turbo is creating the pressure but the design of the manifold (IC, piping, TB, ect) is providing the CFM to the engine through smooth and even flow.
When I ran the simulation the VS raised up 2.250" from the bottom, them flow was really good under no pressure. Once I added 30psi of boost, a lot of interference occurred around the bottoms the the VS....
Now I lost my train of thought.... fuck.
Actually, the flange that I'm using will be interchangeable with the Vivid motorsports one. I'll just send it out sans flange and you get the Vivid one Tig'd on... PI done.
Nice, I am liking this more and more.
2006 Mazdaspeed 6
phantom3 (08-31-2009)
 Old 08-30-2009, 01:32 PM   #42
phantom3's Avatar
Posts: 1,223   (View Stats)
phantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the world
Groans: 190
Groaned at 53 Times in 32 Posts
Originally Posted by devils10 View Post
do u plan of making alot fo these or just one€?
I'm going to see how it pans out.
If the cost, time ect. is too much then I'll just release the drawings the the community. That way you can submit the drawings to a shop, get the parts made, and build it yourself. Kind of a DIY kit manifold.
More playing around.
So far the MZR-R design has yielded the best flow characteristics so far (Big suprise)
I have played around with the diffuser height and angle, and while I can get a more direct flow to the Velocity Stacks, the flow in the Velocity Stacks is not as nice.
At this point I'm going to stick with the MZR-R design and tweek it a bit.
David
Edit: First post updated
My mission is to go fast.
Currently Designing:
The golden girdle of the gods
The CF "fuck your face" IM
Last edited by phantom3; 08-30-2009 at 09:13 PM. Reason: MSF Database - Automerged Doublepost
phantom3 is offline   Reply With Quote
The Following 3 Users Say Thank You to phantom3 For This Useful Post:
Fobio (08-31-2009), miguelbates (09-03-2009), QuickSpool (08-31-2009)
 Old 08-31-2009, 02:41 PM   #43
QuickSpool's Avatar
Posts: 235   (View Stats)
QuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to beholdQuickSpool is a splendid one to behold
Groaned at 9 Times in 5 Posts
Would approaching a company that already makes CF parts be easier and cheaper to mass produce theses? I would guess they could take your rendering and have it rapid prototyped and then a mold created.
Looks great, thanks for the time and effort.
QuickSpool is offline   Reply With Quote
 Old 08-31-2009, 03:10 PM   #44
ATE BALLER's Avatar
Posts: 3,227   (View Stats)
ATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the world
Me likes! Alot!
Originally Posted by StreetUnitMark View Post
I don't think I could go one day without some sort of meat in my mouth.
ATE BALLER is offline   Reply With Quote
The Following User Says Thank You to ATE BALLER For This Useful Post:
 Old 08-31-2009, 03:13 PM   #45
Miembro
nighthawk358's Avatar
Posts: 725   (View Stats)
nighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the world
Groans: 27
Groaned at 6 Times in 6 Posts
2 weeks for this sexy piece to be made?
2008.5 MS3 Metro Gray...slow
nighthawk358 is offline   Reply With Quote
The Following User Says Thank You to nighthawk358 For This Useful Post:
 Old 08-31-2009, 03:36 PM   #46
if u guys notice on the reg 2.3L the intake design is the same as the MZR-R. im loving this ish please get this done!!!!
 Old 08-31-2009, 04:30 PM   #47
Speeeeeed
06Speed6's Avatar
Flow of a 3.2"sq port is:
441CFM @ 28"H2O
453HP @ 28"H2O
8.39FPS @ 28"H2O
1,697CFM @ 15PSI
1170HP @ 15PSI
2,147CFM @ 24PSI
1480HP @ 24PSI
2,401CFM @ 30PSI
1655HP @ 30PSI
EDIT #1 Mind you this is calculated without factoring in humidity, temp, altitude, port shape, port angle, volumetric efficiency, friction coeficient, or anything else that would restrict flow. These calculations are from a world where unicorns roam freely and all women are naked, horny, and hot.
EDIT #2 This is calculated for an ideal round port.
EDIT #3 The CFM is also calculated with the port flowing to the open atmosphere and not to a engine.
EDIT #4 The HP calculation is a generic CFM to HP equation that assumes stoich conditions and 100% efficiency.
2006 Mazdaspeed 6
 Old 08-31-2009, 05:28 PM   #48
phantom3's Avatar
Groans: 190
Thanks.
I'm going to get a rapid prototype done (3D printer) and create a silicon mold from that. I'm going to pour plaster into the mold and let it dry. Extract the plaster positive and wrap in CF. Once dry, wash out the plaster.
I approached a shop here in Edmonton that does composites but they wanted a 1,000 piece commitment.. F that noise. They did say they would help with the prototype and mold though.
Originally Posted by ATE BALLER View Post
Me likes! Alot!
Good. How would you like a 3.25" MAF, TB, and BAT spacer?
That was a joke. Cobb used to say that. I'm trying my best (I'm only one man). I think I've made huge progress in the past 3 days. I'm making no dead lines, but I will keep this thread updated.
Hopefully this will fit the reg 3's as well. I can test it on my wife car.
441CFM @ 28"H2O
453HP @ 28"H2O
8.39FPS @ 28"H2O
1,697CFM @ 15PSI
1170HP @ 15PSI
2,147CFM @ 24PSI
1480HP @ 24PSI
2,401CFM @ 30PSI
1655HP @ 30PSI
Well shit. I'm not that far off. I got 1229.86111111111111 CFM for one runner.
Thanks man
I had to Mock up the rest of the intake in order to see the projected flow better. Thought you guys would like a sneak peak.
The entire ID is 3.25".
Included in the pics are:
MZR-R manifold
BAT relocation spacer
3.25" DBW Throttle body
3.25" MAF relocation
Last edited by phantom3; 08-31-2009 at 05:37 PM. Reason: MSF Database - Automerged Doublepost
The Following 8 Users Say Thank You to phantom3 For This Useful Post:
802MS3 (09-02-2009), bioevolve (09-02-2009), DingoDave (07-10-2012), MarkyMark (08-31-2009), mexicant (09-02-2009), miguelbates (09-03-2009), Smoker6 (09-06-2009), vasaribm (09-02-2009)
 Old 08-31-2009, 05:54 PM   #49
MarkyMark's Avatar
Posts: 1,624   (View Stats)
MarkyMark has disabled reputation
Groans: 62
Groaned at 156 Times in 148 Posts
If you come up dry I have the perfect guy in Canada to do that for us. He just visited too and he's ready to take on some projects.
MarkyMark is offline   Reply With Quote
The Following User Says Thank You to MarkyMark For This Useful Post:
 Old 08-31-2009, 06:18 PM   #50
Speeeeeed
06Speed6's Avatar
Thanks man
Your numbers are probably more accurate than mine, but in the real world I can assure you that both of our numbers are very very very very far off. At least we can be fairly certain that this new IM will not be a restriction for anyone and the flow loss appears to be minimal compaired to the stock one.
2006 Mazdaspeed 6
 Old 08-31-2009, 06:19 PM   #51
wassup61's Avatar
Posts: 1,232   (View Stats)
Groans: 29
How are you going to shield the MAF so it lasts longer than a few K miles. (blowthrough induces MAF failure quickly)
All wagon, No traction
 Old 08-31-2009, 06:29 PM   #52
thats not the MAF thats the MAP.
and BTW from my understanding the MAP should go AFTER the TB cause you arent measuring vacuum pre TB. just update your dwg to reflect that.
EDIT: ok maby that is the MAF im seeing sorry i misunderstood cause u diddent actually have a MAP drawn in. i wouldent do a blow through. its too hard to tune and will never run as well as pull through setup.
 Old 08-31-2009, 06:33 PM   #53
Speeeeeed
06Speed6's Avatar
You can make a blow through MAF function quite well, especially since this is to be used with the Vivid system which is speed density.
2006 Mazdaspeed 6
 Old 08-31-2009, 07:28 PM   #54
phantom3's Avatar
Groans: 190
Thanks Mark!
The first one I'm going to hand make myself, and then I'll base future efforts off of that. I'm pretty sure I can build a mani in 2 days including waiting for the CF to dry and TIG welding. While my buddy is welding I can be starting the next one. I'm guessing I can do 5/week with 1 mold.. more molds, more parts.
 Old 08-31-2009, 07:35 PM   #55
Speeeeeed
06Speed6's Avatar
While we are talking construction, I wonder if there is any info on the net on sizing the thickness of carbon fiber for boosted intake parts. Ill take a look around and see if I see anything.
2006 Mazdaspeed 6
 Old 08-31-2009, 07:46 PM   #56
phantom3's Avatar
Groans: 190
I don't see any reason why it would degrade faster. It's seeing the same amount of air in blow through as in suck mode. The only thing might be that it will need cleaning slightly more often do to possible oil coming from the turbo. We'll have to wait and see what happens to ATEBALLER's blow thru MAF.
EDIT: LOL @ the MAF being backwards in the pic.
Sorry I haven't mocked up the MAP sensor yet. The spacer is similar to the racing roots one except mine has a connection for a silicon tube (for the intake mani). It's in the pic after the TB
Thanks!
Keep in mind that you don't have to use a blow through MAF to use this setup. You can keep your existing intake (SRI, Cold air ect), and IC.
What you will need is a BAT spacer and 3.25" TB. I'm going to put these in as a kit.
I'm choosing to do a blow through as I'm doing a custom intake with the Battery and ECU relocated. This should allow for some nice real estate for some big smooth tubing. I'm also using a L/A IC and a big turbo (yet to be decided). These are long term plans. First thing I'm doing is the intake manifold.
That would be awesome, Thanks! I just used 0.025" thickness as a nominal value for now. Anything thicker will not change the internal dimensions.
EDIT: LOL@ the MAF being backwards in the pic. (DOH!)
Last edited by phantom3; 08-31-2009 at 07:49 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-31-2009, 08:42 PM   #57
MarkyMark's Avatar
Groans: 62
Thanks Mark!
Once you physically make one, see what your time is worth. If the results are favorable, I have no problem making it worth while for you to knock a few out a week or so in your spare time.
Downmented (07-10-2012)
 Old 08-31-2009, 08:49 PM   #58
Speeeeeed
06Speed6's Avatar
Found a couple links with some really good home brew carbon fiber info:
http://www.rotaryeng.net/carbon-intake.txt
www.racingcomposites.net:
You have to register for the racingcomposits forum, but it really has alot of good info.
It seems that you can make this stuff to be really really thin and hold alot of boost.
2006 Mazdaspeed 6
 Old 08-31-2009, 08:50 PM   #59
also what are you gona do about the few vacuum lines we do need like brake booster and BOV/meth? is that what you were talking about with the tubing in the BAT spacer?
 Old 08-31-2009, 11:08 PM   #60
phantom3's Avatar
Groans: 190
Thanks mang... I'll keep it in mind and let you know.
Wow thanks man. I've done a lot of fiberglass stuff so I figured it wouldn't be too different. Looks like I have some reading to do!
I have a plate drawn up that's tapped for vac sources just like this.
Meth can go in the BAT spacer behind the TB, in the post IC piping, or in each runner of the mani.
The Following User Says Thank You to phantom3 For This Useful Post:
 Old 09-01-2009, 10:51 AM   #61
ATE BALLER's Avatar
Not true at all. Take it out and clean it every few months or so and it'll be fine. I wish you would stop going into every thread that says blow-thru in it somewhere and tell everyone how bad it is when it isn't. Just saying.
Also not true. When I had the stock size housing in there it ran perfect, other than blowing the cheap couplers apart at 10psi. If anything, I'd say it ran alot better. It didn't have any choppiness or oscillation that it does in the stock airbox. Hell, when the couplers would blow off, it would still run fine, minus boost. It would get some weird cut if I tried to hammer the gas pedal, but I'd expect that without the turbo hooked up to the intake. I was deffinately able to make it home from work though on a few occations with no boost and it drove and felt fine. The only reason I took it off is cause I switch the housing with a 3" one when I got it all welded together and I have no way to tune it. I dumped money into a Tactrix cable and ECU Edit which turned out to be utter fail, so I have to hold off for now. I'm still in the process of unpacking since I moved into my house a few weeks ago, plus I'm getting married this Sunday and will be in Mexico all next week. After that, maybe I can put some much-needed attention back into my car.
Just my $0.02.
phantom3 (09-01-2009)
 Old 09-01-2009, 12:24 PM   #62
stealthspeed6's Avatar
Posts: 136   (View Stats)
stealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant future
this looks pretty awesome now.
stealthspeed6 is offline   Reply With Quote
 Old 09-01-2009, 02:08 PM   #63
ALL-IN.
AndyMS3's Avatar
Posts: 671   (View Stats)
AndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the world
Groans: 30
Good progress so far, very curious to see the results of this.
If you need a hand let me know.
AndyMS3 is offline   Reply With Quote
The Following User Says Thank You to AndyMS3 For This Useful Post:
 Old 09-01-2009, 02:54 PM   #64
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
I would cut off my own hand and lend it to you if you needed it. I really like your manifold, thanks!
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 09-01-2009, 06:42 PM   #65
sleeperstang1994's Avatar
Posts: 569   (View Stats)
sleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the world
Groaned at 7 Times in 5 Posts
this mock up looks great! would love to see a working piece. keep up the good work. way to look out for the community we need more people like you...im just to busy haha
sleeperstang1994 is offline   Reply With Quote
The Following User Says Thank You to sleeperstang1994 For This Useful Post:
 Old 09-01-2009, 07:10 PM   #66
GQ_WhiteMS3's Avatar
Posts: 658   (View Stats)
GQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the world
Ditto on the help / resources ... if you need something post it up, if I can help I'm 100% in to help ... this is great work
GQ_WhiteMS3 is offline   Reply With Quote
The Following User Says Thank You to GQ_WhiteMS3 For This Useful Post:
phantom3 (09-02-2009)
 Old 09-02-2009, 08:35 AM   #67
phantom3's Avatar
Groans: 190
[/B]
Just my $0.02.
Thanks for the info and support ATE.
Thanks man.
Will do Champ.
lol... I think that custom might have a problem with that.
Thanks.
Thanks!
 Old 09-02-2009, 01:55 PM   #68
Arrowpoint's Avatar
Posts: 364   (View Stats)
Arrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the world
Man, that is a beautiful thing! Please don't let this fall through the cracks! I'm salivating in anticipation. I hope you get this on your car soooon!
Arrowpoint is offline   Reply With Quote
 Old 09-02-2009, 02:03 PM   #69
Phantom's Avatar
Posts: 313   (View Stats)
Phantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud ofPhantom has much to be proud of
Very nice piece!
CPE CAI|TRZ Motor Mount (Poly)|Hoen Xenonmatch Fogs/Highs |Hotchkis Rear Sway Bar|Prosport Boost Gauge|Buddy Club Condenser|18x8 OZ Ultraleggera Matte Black|Gorilla Black Lugs|G2 Red Calipers|Autoexe Stainless Steel Brake Lines|Chromium Signals|Hella Supertone|sk07 Accel Pedal|CPE DP|Cobb Shift Weight|Evo Turbo Timer|Dual AeroForce|TurboSmart BOV|Denso ITV22 Plugs|CPE HPFP|H&R Springs|Koni Yellows (Struts/Shocks)|Autoexe Street Pads|Rotora Slotted Rotors|SPC Camber Kit|CPE PNP|CPE Standback|CPE Pro Fuel Controller|Labonte Stage 1 Water/Meth Injection Kit|Tribute Oil Filter Converstion
Phantom is offline   Reply With Quote
 Old 09-02-2009, 02:22 PM   #70
spiker98's Avatar
Posts: 427   (View Stats)
spiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the world
This is coming along waayy better than I imagined. I thought u were just some dude with a cool computer program. This shit looks awesome, great work!
spiker98 is offline   Reply With Quote
 Old 09-02-2009, 02:26 PM   #71
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Groans: 166
i would have sex with that manifold...violating each and every velocity stack
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
Originally Posted by Say Chi Sin Lo View Post
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
 Old 09-02-2009, 02:42 PM   #72
7mileshome's Avatar
Posts: 350   (View Stats)
7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world
Subbing here.... this looks good.
2012 Mazdaspeed3 LSM
Should have gotten a speed6
2008 Mazdaspeed3 GT Black Mica [sold]
Built motor, Etc.
383 hp 401 tq GTX2867R @ 25 psi
7mileshome is offline   Reply With Quote
 Old 09-02-2009, 10:38 PM   #73
phantom3's Avatar
Groans: 190
Don't come into my thread a fucking write "subing" to subscribe. That's my biggest pet peve ever! There's a subscription button at the top of the Page!.
That being said, Thanks! and stay tuned.
The Following 2 Users Say Thank You to phantom3 For This Useful Post:
06Speed6 (09-03-2009), AndyMS3 (09-03-2009)
 Old 09-03-2009, 05:54 AM   #74
miguelbates's Avatar
Posts: 689   (View Stats)
miguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the world
damn scientists...lol
miguelbates is offline   Reply With Quote
 Old 09-03-2009, 06:42 AM   #75
Arrowpoint's Avatar
I don't have any experience with carbon fiber other than gun barrels where the bore is a steel sleeve inside of CF. How is it with heat retention/dissipation? I'm sure that whatever it is, it's right for this application since it's used on the MZR-R. Just curious.
 Old 09-03-2009, 07:28 AM   #76
7mileshome's Avatar
Alright, wheres the noob stamp I did not know that...
Built motor, Etc.
The Following 2 Users Say Thank You to 7mileshome For This Useful Post:
AndyMS3 (09-03-2009), phantom3 (09-03-2009)
 Old 09-03-2009, 08:13 AM   #77
Buildabong's Avatar
Posts: 3,034   (View Stats)
Buildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the world
Groans: 213
Groaned at 274 Times in 187 Posts
lol owned
beautiful work phantom, keep the work up, make this car a monster!
Buildabong is offline   Reply With Quote
The Following User Says Thank You to Buildabong For This Useful Post:
 Old 09-03-2009, 09:44 AM   #78
Team Überfrazn
labikesrcool's Avatar
Posts: 782   (View Stats)
labikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the worldlabikesrcool is the leader of the world
have you considered making the intake runners out of carbon also? the flange may have to be more complicated but you could use adhesive to attach the carbon to the flange. the manufacturablity would be harder if you included the intake runners in the carbon piece i would imagine though. perhaps your flow would be better? i would check myself but i only have access to flowworks xpress and can't specify surfaces and other variables. i'm assuming you use solidworks if you gave me your model i could model the part i am thinking of so you could test it. totally understand if you don't want your hard work floating around to people you don't know though. put me on the list if you need any help with anything else.
from what you have though it looks good keep it up!
"My car won't start!"
"Well, maybe there's a killer after you."-Mitch Hedberg
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming.
- Mitch Hedberg
labikesrcool is offline   Reply With Quote
The Following User Says Thank You to labikesrcool For This Useful Post:
phantom3 (09-04-2009)
 Old 09-03-2009, 11:54 AM   #79
Captain
Groans: 79
Phantom's giving out free thanks for complimenting his manifold
Phantom, i just love what you've done with this manifold!
www.permtuning.com
 Old 09-03-2009, 04:05 PM   #80
spiker98's Avatar
Ok, maybe I'm just out there. But what if you took some of the bulging off the sides and front of the manifold? (Do you see what I'm saying?..on the bulging away from the airflow)..none of that is really being used but is still going to be filled up with excess air. I would think if you kinda shaved off those bulges and it would be more of a direct flow. I think that would help some of your velocity through the stacks.
I dunno but here is a shitty paint drawing for what I'm talking about. If I don't know shit and that is completely wrong then just say so.. I'm just throwing this out there.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/sex-carbon-fiber-intake-manifold-36704/
If you could make your own intake manifold - Page 3 This thread Refback 02-24-2013 05:18 AM
If you could make your own intake manifold - Page 5 - SR20 Community Forum - The Dash This thread Refback 06-20-2012 08:01 AM
sr20 intake manifold build - 502StreetScene This thread Refback 01-10-2012 09:08 PM
If you could make your own intake manifold - Page 6 - SR20 Community Forum - The Dash This thread Pingback 12-24-2011 10:06 AM
What is the difference between wet and dry carbon fiber? marcusdigi MazdaSpeed 3/6 - Appearance 4 06-04-2009 01:18 AM
carbon fiber mirrors marcusdigi MazdaSpeed 3/6 - Appearance 0 04-20-2009 03:26 AM
Carbon fiber to be replaced by Buckypaper? Haltech Automotive News 0 10-21-2008 01:40 PM
Page generated in 0.61079 seconds with 41 queries
