![]() | | #81 | ![]() |
![]() Join Date: May 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score
![]() | | #82 | ![]() |
| Must Have Teh 10's! ![]() ![]() Join Date: Mar 2008 Location: Columbia, MD
Rep Power: 10779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,334
| Not Ranked : 0 score the point of a "plenum" is to gather air in one large area and then it gets evenly distributed into each of the runner. the velocity stacks help smooth out and speed up the air entering each runner. i wish i knew what whoosh's intake mani looked like when he was designing it.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner |
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | phantom3 (09-04-2009), xcoldricex (09-04-2009) |
![]() | | #83 | ![]() |
Groans: 79
| Not Ranked : 0 score Yup, it's not like all the valves are open at once.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
![]() | | #84 | ![]() |
Rep Power: 7491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG | |
![]() | | #85 | ![]() |
![]() Join Date: Oct 2008 Location: Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 761
Groans: 190
Groaned at 53 Times in 32 Posts
__________________ My mission is to go fast. ![]() Currently Designing: The golden girdle of the gods The CF "fuck your face" IM | |||
| The Following User Says Thank You to phantom3 For This Useful Post: | djuosnteisn (09-04-2009) |
![]() | | #86 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
So if the manifold is to big, the stock turbo will loose HP because of it. If it is to small, the larger turbos will have sonic resonance in the manifold and cause the manifold air flow to "stall" inside the manifold. There is an amazing amount of work that goes into making a manifold that makes power and is proven to work on both stock turbo and larger turbo applications. This is why we abandonded our manifold project with the Speed's, to many motors go boom before people can spend some serious money on making them go fast. Last edited by ptperformance; 09-06-2009 at 07:53 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #87 | ![]() |
| Not Ranked : 0 score Speaking of sonic resonance... damn yeah I nearly forgot, phantom... you cant have a design that exceeds ~10900in/sec because that is the sound barrier. As completely ripped off of another site: "The Mach Index is a mathematical expression of the speed, in this case, of the inlet velocity, relative to the speed of sound. Volumetric efficiency will start to fall off sharply past six tenths the speed of sound (Mach .6) so the engine designer will not want to exceed this .6 mach value at peak rpms. In as much as the speed of sound is temperature dependent and the exhaust valve has different requirements, these calculations do not apply to the exhaust valve." I think we might still be in the green though, we need to determine the CFM requirements of say 700 crank hp, and then run a flow model with that CFM and see what the velocity is. EDIT: 700 crank hp is about 1050CFM on a 2.3l engine, and it is also a calculated 44psi but I have no idea how they determined that.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG Last edited by 06Speed6; 09-06-2009 at 11:14 PM. |
![]() | | #88 | ![]() |
Groans: 190
I'm heading back to the drawing board with these new figures in mind. Last week was a write off as I was helping a friend with his business. I should have a new model later today as its a long weekend here in Canada-land.
| The Following User Says Thank You to phantom3 For This Useful Post: | 06Speed6 (09-08-2009) |
![]() | | #89 | ![]() |
![]() Join Date: Jul 2008
Rep Power: 1791 ![]() Thanks: 2,239
Groans: 62
Groaned at 156 Times in 148 Posts
![]() what program are you using btw? | |
| The Following User Says Thank You to MarkyMark For This Useful Post: | phantom3 (09-07-2009) |
![]() | | #90 | ![]() |
![]() Join Date: Apr 2008 Location: NoVA
Rep Power: 998 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 167
Groans: 31
Groaned at 86 Times in 65 Posts
| Not Ranked : 0 score I am guessing its solid works.
__________________ -JEWBERT |
| The Following User Says Thank You to jhershorin For This Useful Post: | phantom3 (09-07-2009) |
![]() | | #91 | ![]() |
Groans: 190
(Thread Starter) | Not Ranked : 0 score I'm using solid works 2009 Premium. It's good all around program though it does lack in the area of complex surfaces through (think car body design). It's not impossible to do, but there are better programs out there like Pro engineering that can do it easier.
| The Following User Says Thank You to phantom3 For This Useful Post: | MarkyMark (09-07-2009) |
![]() | | #92 | ![]() |
| Fuck sushi rolls ![]() Join Date: May 2008 Location: Los Angeles
Rep Power: 12764 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,168
Groans: 356
| Not Ranked : 0 score impressive work ninja
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE |
| The Following User Says Thank You to rodrigo For This Useful Post: | phantom3 (09-07-2009) |
![]() | | #93 | ![]() |
| Not Ranked : 0 score Not a problem, I would have to say if your going to build it built it around bigger turbo applications or make it so you can swap plenum size, lets say for a stock turbo to big turbo application. I really like the design, keep up the good work. |
| The Following User Says Thank You to ptperformance For This Useful Post: | JMEngineer (12-20-2009) |
![]() | | #94 | ![]() |
Groans: 190
I've already geared it towards the big turbo crowd with the 3.25" inlet. The plenum will be interchangeable eventually but not at first. There is a ring that sandwiches the plenum between the velocity stack flange and a bolt ring on the inside. Changing it will be as easy as unbolting the ring and bolting the new plenum on. Just to be clear, for the time being I'm just going to start with one plenum until I get some real flow numbers and fitment sorted out. I'm going to make the first one out of fiberglass just to keep the prototyping costs down. One of my CNC machinist friends has a lot of down time at his shop right now and said that if I can get the material, he will make up the metal parts for me. Another friend offered to TIG it for free as well. So far, for the prototype, the cost is going to be minimal which will help if I end up doing multiple revisions. At the same time I can get a good estimate on the actual cost for full production.
![]() | | #95 | ![]() |
Groans: 62
![]() | | #96 | ![]() |
Groans: 190
(Thread Starter) | Not Ranked : 0 score Will do.
![]() | | #97 | ![]() |
Groans: 190
(Thread Starter) | Not Ranked : 0 score UPDATE in original post.
![]() | | #98 | ![]() |
| Not Ranked : 0 score hey as for the flow moving left. after a bend in piping you ALWAYS need and air straightener. put one just before the inlet of the mani and see what happens.
![]() | | #99 | ![]() |
Groans: 190
(Thread Starter) | Not Ranked : 0 score lol... That's what I said I was going to do...
![]() | | #100 | ![]() |
| Eatin' Your Tuna ![]() Join Date: Feb 2008 Location: Nator HQ - San Diego, CA
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,602
Groans: 244
| If you need other software, let me know. I can get anything.
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | |
| The Following User Says Thank You to Haltech For This Useful Post: | phantom3 (09-11-2009) |
![]() | | #101 | ![]() |
| Team Überfrazn ![]() Join Date: Apr 2008 Location: Plymouth, MN
Rep Power: 324 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 661
| Not Ranked : 0 score update looks good. although i don't see provisions for this. 3" TORNADO INTAKE TURBONATOR SINGLE FAN GAS/FUEL SAVER:eBay Motors (item 370248709511 end time Sep-20-09 17 15 PDT) it's JDM!i am kidding. i was thinking that it may be more real world if you ran two separate study's one with the two inside runners plugged at the outlet and another study with the two outside runners plugged at the outlet. this may simulate the real running engine better. please keep in mind i may be totally off base though.
__________________ "My car won't start!" "Well, maybe there's a killer after you."-Mitch Hedberg I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming. - Mitch Hedberg |
![]() | | #102 | ![]() |
![]() Join Date: Apr 2009 Location: Cincinnati
Rep Power: 2046 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
Groans: 32
Groaned at 19 Times in 15 Posts
| Not Ranked : 0 score My SolidWorks license expires in about 2 months I'm looking forward to seeing some prototype numbers on this.
__________________ 2006 MS6 GT - Built engine, twin scroll GT3076R, dual MV-S wastegates dumped to atmosphere, TR1035 FMIC, too many parts to list... ![]() 2009 MS3 GT - Built engine, JBR intake/TIP and short shifter, all engine mounts, Autotech HPFP internals, ETS TMIC, Custom AP tune, Pauter rods, CP pistons, and 6-puck ACT clutch -GTX2867R Coming Soon |
![]() | | #103 | ![]() |
Groans: 190
(Thread Starter) | Not Ranked : 0 score use a keygen and a crack... that's what I did.
| The Following User Says Thank You to phantom3 For This Useful Post: | MATT DAMOND (09-14-2009) |
![]() | | #104 | ![]() |
Groans: 32
| Not Ranked : 0 score More info please - I haven't done anything like that in years since I've had free access to just about everything up until last Friday. Are there any possible issues with information hidden in part files that get sent to a client?
![]() | | #105 | ![]() |
| I have candy in my van ![]() Join Date: Apr 2009 Location: Chicago, IL
Rep Power: 2810 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,091
| Not Ranked : 0 score I'm gonna give that a try. As of right now I just have SolidWorks Student Edition 09, which feels like SW 08. I actually just started my SW 09 training today, so I'm just starting up and making simple models. Nothing like this yet:
__________________ Current Fail: 2008 Mazda5 DD/Mazdaspeed5 BT project |
![]() | | #106 | ![]() |
Groans: 32
__________________ 2006 MS6 GT - Built engine, twin scroll GT3076R, dual MV-S wastegates dumped to atmosphere, TR1035 FMIC, too many parts to list... ![]() 2009 MS3 GT - Built engine, JBR intake/TIP and short shifter, all engine mounts, Autotech HPFP internals, ETS TMIC, Custom AP tune, Pauter rods, CP pistons, and 6-puck ACT clutch -GTX2867R Coming Soon | |
| The Following User Says Thank You to JMEngineer For This Useful Post: | MATT DAMOND (09-14-2009) |
![]() | | #107 | ![]() |
| Not Ranked : 0 score LOL The guy who made that, is actually making the R8 build into a tutorial. SolidWorks Car Tutorial: Master SolidWorks Surfacing and Complex Shape Modeling with this Step-by-Step Video Tutorial.
![]() | | #108 | ![]() |
Groans: 190
![]() | | #109 | ![]() |
Groans: 32
| Not Ranked : 0 score ^^ I actually did have a job offer to do that stuff for Honda interiors in Marysville, Ohio but I had already accepted another position... Search 40.305209,-83.545547 in google maps and check out the test tracks they have. You have to zoom out a few times to see the whole 7 mile oval.
![]() | | #110 | ![]() |
Groans: 190
(Thread Starter) | Not Ranked : 0 score UPDATE: I'm broke.. lol. what else is new? I'm currently looking for a second job, but the repo man commeth and taketh away... my wife's car that is (2004 mazda 3 sedan, orange). Needless to say the manifold has been put on the back burner. I've finalized the design and I'm very happy with it. I have a shop in town that is going to print the plenum in 3D for me so I can make a mold to wrap the CF around. I've also scored some machine time at a friends shop. So once we get back on our feet and have some disposable income I can get this thing done. I'm going to machine a mandrel up to press the runners on. The pipe will be heated up and pressed onto the mandrel shaping it perfectly to the port. Once the runners are welded to the flanges the rest just bolts together. I should be able to make different runner lengths quite easily. So that's where I'm at. It will get done, just not before Christmas. David
| The Following User Says Thank You to phantom3 For This Useful Post: | MarkyMark (09-29-2009) |
![]() | | #111 | ![]() |
![]() Join Date: Jan 2009 Location: Lehigh Acres, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 824
| Not Ranked : 0 score wow bro srry to hear about the repo :\ good luck with second job
__________________ [SIGPIC][/SIGPIC] |
![]() | | #112 | ![]() |
![]() Join Date: Mar 2008 Location: Jacksonville, NC
Rep Power: 2469 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 810
Groans: 60
| Not Ranked : 0 score Shit, that sucks dude. Hope you get back on your feet soon. It's just a car, the manifold can wait...
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks |
![]() | | #113 | ![]() |
![]() Join Date: Mar 2009 Location: Greenville, SC
Rep Power: 388 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 445
| Not Ranked : 0 score Damn dude. Understand completely on the lack of funds situation.. |
![]() | | #114 | ![]() |
Groans: 79
| Not Ranked : 0 score at least they took the right car. GL on getting everything squared away.
![]() | | #115 | ![]() |
![]() Join Date: Aug 2008 Location: Red Deer, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,362
| Not Ranked : 0 score sorry to hear that dude. when all else fails, join the oilfeild. its looking to be a busy winter for the right service lines.
__________________ |
![]() | | #116 | ![]() |
| Not Ranked : 0 score so uhhhhh just how much money are we talking here to get this done? is this something we could start a donation for?
![]() | | #117 | ![]() |
Groans: 190
(Thread Starter) | Not Ranked : 0 score I hope I can find one soon... else the speed is next.
Thanks man.
I'd say less than $600, but I do not want to take donations. Reason being, if something goes wrong, I don't want to be accused of taking money and running. Any cost I incur making this thing can be recouped in sales... That and I hate being a charity case... I won't even let my friends buy me a coffee.
![]() | | #118 | ![]() |
![]() Join Date: Sep 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score oh how i love sw |
![]() | | #119 | ![]() |
| Not Ranked : 0 score *puts on salesman voice* if you can handle +12hr days, being gone for weeks on end, endless repetitive physical labor (ie. swing 8lb sledgehammer more times than you can count), all while some asshole supervisor screams at you to do it faster, then the patch is the right place for you. thats a worst case scenario. i work 15 days on, 6 off, 80-100hrs a week, and make roughly $75k/year as a senior equipment operator. i'm not sure what companies operate out of nisku, or if your willing to drive to red deer a lot, but you want to apply to a well servicing company. stay away from drilling/service rigs and well testing. just drop off lots of resumes with companies like BJ, Trican, Calfrac, Sanjel, Weatherford, Slumberger or Halliburton for their wireline, coil tubing, or pumping services divisions. PM me if you want more info
![]() | | #120 | ![]() |
![]() Join Date: Dec 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 134
as for the mani...what type of school is required for this type of thing... like designing cars, car parts and such... Drafting? or is it something else.
__________________ PURPLE VOLK TE37's Cp-e FMIC, Cp-e Fuel Pump, Cp-e Catless Downpipe, Cobb AP v103l BETA map, Injen CAI, TRZ Rear Motor Mount, TRZ Transmission Mount, Weapon R Engine Torque Dampner, N2MB Wot Box w/ 2 Step | |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/sex-carbon-fiber-intake-manifold-36704/ | ||||
| If you could make your own intake manifold - Page 3 | This thread | Refback | 02-24-2013 05:18 AM | |
| If you could make your own intake manifold - Page 5 - SR20 Community Forum - The Dash | This thread | Refback | 06-20-2012 08:01 AM | |
| sr20 intake manifold build - 502StreetScene | This thread | Refback | 01-10-2012 09:08 PM | |
| If you could make your own intake manifold - Page 6 - SR20 Community Forum - The Dash | This thread | Pingback | 12-24-2011 10:06 AM | |
| What is the difference between wet and dry carbon fiber? | marcusdigi | MazdaSpeed 3/6 - Appearance | 4 | 06-04-2009 01:18 AM |
| carbon fiber mirrors | marcusdigi | MazdaSpeed 3/6 - Appearance | 0 | 04-20-2009 03:26 AM |
| Carbon fiber to be replaced by Buckypaper? | Haltech | Automotive News | 0 | 10-21-2008 01:40 PM |
