-   -   Shifter adjustment Side to side (http://www.mazdaspeedforums.org/forum/f10/shifter-adjustment-side-side-45412/)
Jarods7920 12-28-2009 10:38 PM
Ok so my shifter has been getting stuck in the 1-2 spots and 5-6 when in neutral. I have to give it a little tap to get it to go over to the 3-4 gates. This is something new since the new engine went in, i had ti once before when i popped off the cable up front to do the tranny mount but it went away after a while. This time it doesnt seem to be going away. Any suggestions on how to fix this?
darth vader 12-29-2009 07:17 AM
I had this happen after I put in a ETD. turned out in trying to get the ETD as tight as possible I tweaked the engine out of position slightly and caused this. I did disassemble the bottom of the shifter and grease everything well but, moving the ETD back a couple mils fixed it. Try loosening all the mounts slightly, letting the engine settle, then tighten it back up.
FreeFlyFreak 12-29-2009 08:06 PM
Originally Posted by Jarods7920 (Post 387883)
Ok so my shifter has been getting stuck in the 1-2 spots and 5-6 when in neutral........ Any suggestions on how to fix this?
Try this:
http://www.mazdaspeedforums.org/foru...shifter-18796/
Jarods7920 12-29-2009 10:48 PM
Originally Posted by FreeFlyFreak (Post 388732)
Tried its not the problem. I think the motor is misaligned so i am going to go back to stock mounts and realign it and go from there.
Page generated in 0.17025 seconds with 11 queries
