 Old 02-23-2015, 05:53 PM   #1
bdm665's Avatar
Posts: 101   (View Stats)
bdm665 is a splendid one to beholdbdm665 is a splendid one to beholdbdm665 is a splendid one to beholdbdm665 is a splendid one to beholdbdm665 is a splendid one to beholdbdm665 is a splendid one to beholdbdm665 is a splendid one to behold
Default shifting issues
when im in park, its smooth shifting but when im driving, it gets held up on something then goes into gear. Also when im moving and try to shift, especially into first, it sounds like something is winding up. My foot is all the way to the ground on the clutch too. I have no idea whats going on. The guy who i bought it from said he put new forks and syncros in it. There is a whining sound when im in park and when i step on the clutch, it goes away. It doesnt get any easyer when it warms up either. I just changed to xt-m5-qs. The problem is still there.
bdm665 is offline   Reply With Quote
 Old 02-23-2015, 06:16 PM   #2
frothy's Avatar
Posts: 1,067   (View Stats)
Are you implying that you're downshifting into first gear?
The Following User Says NO Thank You to frothy For This Un-useful Post:
license2ill (02-24-2015)
 Old 02-23-2015, 06:25 PM   #3
bdm665's Avatar
Yep, and i dont have to engage 1st for it to happen. The winding happens before im even in gear.
 Old 02-23-2015, 06:45 PM   #4
mxlplx71's Avatar
Posts: 3,265   (View Stats)
Groans: 128
Speeds don't have "park"
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following 2 Users Say Thank You to mxlplx71 For This Useful Post:
btstarcher (02-24-2015), Cujo (02-24-2015)
The Following User Says NO Thank You to mxlplx71 For This Un-useful Post:
 Old 02-23-2015, 06:51 PM   #5
CFI2008's Avatar
Posts: 259   (View Stats)
CFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the world
Why are you downshifting into first?
CFI2008 is offline   Reply With Quote
The Following User Says Thank You to CFI2008 For This Useful Post:
The Following User Says NO Thank You to CFI2008 For This Un-useful Post:
 Old 02-23-2015, 07:00 PM   #6
mxlplx71's Avatar
Groans: 128
Im usually in second by 15/20 mph on the street.
Off the line shift...
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 02-23-2015, 07:02 PM   #7
bdm665's Avatar
Sorry i ment neutral. It doesnt just do it going into first. The winding sound is worse going into 1st. And the clutch is in the whole time. Im not downshifting into 1st. I heard the sound downshifting into 2nd. And i just wanted to see if it did it in any other gear.
 Old 02-23-2015, 07:11 PM   #8
frothy's Avatar
Don't downshift into first unless you're at a complete stop or a REALLY slow crawl.
As for the other gears, are you rev-matching when you downshift?
How long have you been driving cars with a manual transmission?
EDIT:
In what gear(s) does the shifter "get held up by something"? Is it when downshifting? Upshifting? Both?
 Old 02-23-2015, 08:53 PM   #9
danosrk's Avatar
Posts: 130   (View Stats)
danosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the worlddanosrk is the leader of the world
What mods do you have as far as trans mount or clutch?
Go catch a headlight
Things learned from 2014 deployment:
1. Tomahawks will kill you
2. Remember that one time you didn't suck at your job? Yeah, neither do I.
3. I work with enough retards on my ship that we should qualify for extra money from the government
Purple Drank Tuned
Wiseco Pistons/Manley H-beams/JBR BSD/JBR Oil Pan Baffle/ACT 6 Puck/Streetlite Flywheel/CP-E Exhaust Mani/GTX2867R/CP-E Catless DP/Electronic Exhaust Cutout/HTP 4" Intake/PERM PCV Plate/Damond Dual OCCs/Kozmic EGR Deletes/Coolant Bypass/CP-E Safe Seals/CP-E HPFP/Grimspeed 3 Port EBCS/3.5 Bar MAP/CX FMIC w/ TR8 Core/Devil's Own Stage 2 Meth Kit/NGK Iridium IX/HKS SSQV 4 VTA/JBR 88D Trilogy Mounts/JBR Small Battery Box/Optima Yellow Top/Gram Lights 57F/Dunlop Direzza ZII's/Yellowspeed Coils/DK Rear Camber Arms/CorkSport RSB/GT Spec Rear Tie Brace/GT Spec Link Reinforcement Panel/TWM Short Throw/CP-E Triple Gauge Pod/ProSport EVO Gauges
danosrk is offline   Reply With Quote
 Old 02-24-2015, 05:07 AM   #10
bdm665's Avatar
I only down shift to 4 3 or 2. It does it if im just moving and i step on the clutch, and go to engage another gear, it makes that sound. Especially if i just put little pressure on it instead of fully engaging. I will try to get it on video.
The Following User Says Thank You to bdm665 For This Useful Post:
mxlplx71 (02-24-2015)
 Old 02-24-2015, 08:49 AM   #11
license2ill's Avatar
Posts: 313   (View Stats)
license2ill is infamous around these partslicense2ill is infamous around these parts
Groans: 30
Groaned at 132 Times in 57 Posts
wow, no help from these turds. I think you're hearing some normal synchro noise, but nt sure why you are having trouble getting into gears, but it is probably related to those synchros, but could be clutch maybe. I haven't had mine long enough to know yet.
license2ill is offline   Reply With Quote
The Following 6 Users Say NO Thank You to license2ill For This Un-useful Post:
ASHMS3 (02-24-2015), btstarcher (02-24-2015), Easter Bunny (02-24-2015), frothy (02-24-2015), mxlplx71 (02-24-2015), RalliartRsX (02-25-2015)
 Old 02-24-2015, 09:05 AM   #12
frothy's Avatar
WTF? I'm trying to understand what OP is experiencing/doing and asking questions to help troubleshoot and you mass-groan everyone in here??
The Following 4 Users Say Thank You to frothy For This Useful Post:
ASHMS3 (02-24-2015), Drive By Fire (02-24-2015), Easter Bunny (02-24-2015), mxlplx71 (02-24-2015)
 Old 02-24-2015, 09:07 AM   #13
bdm665's Avatar
Well lets talk about the function of syncros. What do they do and y? I know tht gears arn't grinding and its not from fluid. All signs point to syncros. Could be..
 Old 02-24-2015, 09:15 AM   #14
Whistlefist's Avatar
Posts: 35   (View Stats)
Whistlefist has a brilliant futureWhistlefist has a brilliant futureWhistlefist has a brilliant futureWhistlefist has a brilliant futureWhistlefist has a brilliant futureWhistlefist has a brilliant futureWhistlefist has a brilliant futureWhistlefist has a brilliant futureWhistlefist has a brilliant futureWhistlefist has a brilliant futureWhistlefist has a brilliant future
Manual transmission - Wikipedia, the free encyclopedia
Whistlefist is offline   Reply With Quote
 Old 02-24-2015, 09:19 AM   #15
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
what clutch do you have, are you certain the clutch is fully disengaging?
I hugged rfinkle2
 Old 02-24-2015, 10:47 AM   #16
bdm665's Avatar
It has a new luk clutch with 1000 miles on it. When im not moving and i push the clutch in, the sound goes away. Its hard to explain. Im gonna post a video today.
frothy (02-24-2015)
 Old 02-24-2015, 10:52 AM   #17
btstarcher's Avatar
Posts: 4,850   (View Stats)
Groans: 112
Do you have a SSP?
SnailTune in progress
 Old 02-24-2015, 10:57 AM   #18
mxlplx71's Avatar
Groans: 128
did you replace the throwout bearing along with the clutch?
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 02-24-2015, 11:00 AM   #19
frothy's Avatar
Offtopic, but are you sure your car doesn't have HPFP internals?
I find it strange (also worrisome) that your car is modded as much as it is and doesn't have 'em.
Also, do you have a short shift plate? When I had one, it added just enough height that it would make contact with the bottom of my intake. I had no problems shifting at a standstill, but in motion I would have difficulty or wouldn't be able to engage certain gears. Probably not your issue -- just throwing it out there...
The Following User Says Thank You to frothy For This Useful Post:
 Old 02-24-2015, 11:16 AM   #20
Cujo's Avatar
Posts: 1,192   (View Stats)
Cujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the world
Groaned at 6 Times in 4 Posts
Not sure if troll or not....
1. Never shift into first when rolling
2. Rev match or kiss you tranny gbye
3. The cake is a lie.
4. ?????
5. Profit.
6. when you think you should downshift into first just go to second instead.
2012 Mazdaspeed3 Black Mica
Cobb AP // Stratified S-OTS+ Stage 2 Tune // Autotech Internals // CorkSport 3" Intake // CX Racing FMIC // NGK Iridium One Step Colder Plugs // JBR Throttle Body Gasket Kit & Coolant Bypass // SURE Return (w/ Dremel mod) // GFB Respons BOV // UR V2 Metal Catted DP // SURE Flow M3 // UR Catback Exhaust // StopTech Front Slotted Rotors + Performance Brake Pads // TWM Phantom Shift Knob // TWM Leather Shift Boot // CorkSport Adjustable Shortshifter // SURE Anchors // Tanabe NF210 Springs // JBR Tru-Torsion.125 Rear Sway Bar // Tanabe Sustec Tower Strut Bar // Tanabe Sustec Front Under Brace // JBR 88a RMM // Rally Armor Mudflaps // CorkSport Hood Scoop // CorkSport Battery Box // CorkSport LED Light Kit // CorkSport LED Fogs // GTA Car Kits iPod Adapter // Weathertech Floor Mats // Motorcraft Unicorn Tranny Juice // Pentosin Super DOT 4 Brake Fluid // Purple Effect Stock Rims // Falken Ziex ZE 329 // Plastidip'd Fog Light Bezels
Waiting for install: StopTech Rear Slotted Rotors + Performance Brake Pads, StopTech SS Brake Lines
Soon: Custom Tune by Stratified // Guardian Angel // BT, CorkSport Puppy or BNRs3???
Cujo is offline   Reply With Quote
The Following User Says Thank You to Cujo For This Useful Post:
AZST (02-24-2015)
 Old 02-24-2015, 11:19 AM   #21
AZST's Avatar
Posts: 64   (View Stats)
AZST is a splendid one to beholdAZST is a splendid one to beholdAZST is a splendid one to beholdAZST is a splendid one to beholdAZST is a splendid one to beholdAZST is a splendid one to beholdAZST is a splendid one to behold
I have the exact same issue on my 09. I like to fully clear the gearbox at each stoplight, you know like shift 1 2 3 4 5 6 back to 1 with the clutch in, and it helps temporarily, but my gears do the same thing where it feels like you have to push it through something and then it goes into gear, and its kinda crunchy. I have a whine that goes away with the clutch in as well, and I am running the XT as well. Either both of our cars have the exact same tranny issue, or its just the nature of the car.
AZST is offline   Reply With Quote
The Following User Says Thank You to AZST For This Useful Post:
 Old 02-24-2015, 11:24 AM   #22
Raider is mah Homie
Groans: 2,978
1. False
2. False
I hugged rfinkle2
 Old 02-24-2015, 11:46 AM   #23
bdm665's Avatar
Sorry, i forgot to mention it but like a week after my hpfp thread, i got the internals in. Then about a week later, i did the trans fluid. I only drove the car w/o the hpfp for a couple weeks without boosting at all. I ALWAYS rev match. I only drive 10 mi. To work and 90% is highway. I dont down shift to 1st unless im moving 10 or less. And when i do, i match revs. And trolling is for faggets.
 Old 02-24-2015, 11:49 AM   #24
btstarcher's Avatar
Groans: 112
So, no SSP?
 Old 02-24-2015, 11:54 AM   #25
danosrk's Avatar
When you did the trans fluid did you accidentally loosen any other bolts besides the drain plug? Also do you have an upgraded trans mount?
Purple Drank Tuned
 Old 02-24-2015, 12:03 PM   #26
bdm665's Avatar
If i have an upgraded trans mount, i wouldnt know about it. No short shift plate. I only touched the two bolts on the trans. Drain and fill. The two bolts look exactly the same.
 Old 02-24-2015, 06:01 PM   #27
Raider is mah Homie
Groans: 2,978
Have you tried adjusting your shift linkage?
I hugged rfinkle2
frothy (02-24-2015)
 Old 02-24-2015, 06:21 PM   #28
bdm665's Avatar
I didnt know you could do that.
2007 ms3 gt w/ 23000mi. New timing assembly and Rebuilt trans. With brass pads and new syncros and luk clutch at 22000. Mazdaspeed intake, ported intake manifold, vtcs delete, egr delete, fmic, ported and rebuilt k04 turbo, forge bpv w/ yellow spring, corksport hpfp, jbr 88 duro rmm, jbr balance shaft delete, oil pan baffle, catless dp, xt-m5-qs trans oil, mobile 1 full synthetic motor oil. Coming soon: cs injector seals, manley h beam connecting rods, a/c delete, alternator relocation, main egr delete, forged pistons...
 Old 02-24-2015, 06:25 PM   #29
frothy's Avatar
 Old 02-24-2015, 06:36 PM   #30
bdm665's Avatar
The shifting is flawless when im not moving. And the faster i go the harder it gets. I don't think it should be doing that if i got my foot on the clutch. I mean in theory, it should be like butter no mater how fast or what gear i engage as long as my foot is on the clutch. Am i right. Are there guys out there that can engage a gear perfectly without any force?
 Old 02-24-2015, 06:39 PM   #31
Raider is mah Homie
Groans: 2,978
Mine is pretty effortless once it is warm.
I hugged rfinkle2
 Old 02-24-2015, 06:53 PM   #32
frothy's Avatar
The shifting's always been effortless for me as well with this car. I definitely don't need to force anything into gear.
Edit:
Just came across this thread -- still reading it. May not apply to your situation, but I suggest you read it:
How To: Clutch Pedal Adjustment
bdm665 (02-24-2015)
 Old 02-24-2015, 07:15 PM   #33
bdm665's Avatar
Thanks frothy its definitely worth a try.
 Old 02-24-2015, 08:16 PM   #34
frothy's Avatar
No luck. As mentioned in the thread linked above, unlike the MS6, the MS3 has a non-adjustable clutch pedal.
I read through the FSM for both cars and confirmed this.
Oddly, the MS3 manual still has a procedure for checking the pedal disengagement point:
Not sure what the point of this is if you can't alter it...
 Old 02-25-2015, 06:03 AM   #35
frothy's Avatar
As far as the shifter getting caught up, another thing to consider is the reverse lock-out gate.
Over time it can become grooved or notched out, as it's made of plastic. That could possibly explain bad shifting in first/second gear. The other gears, not so much...
JBR makes a plate that addresses this.
Grooved stock lock-out:
w/ JBR plate:
Edit:
...aaand your shifter works flawlessly at a standstill. So this post won't help.
Ford issues six recalls covering 101,000 vehicles for multiple issues Haltech Automotive News 0 07-08-2014 12:50 PM
Help with my shifting Y.U. M.A.D? Mazdaspeed3/6 General Discussion 6 06-24-2012 02:56 PM
shifting issues Eric_Williams 2010 MS3 - Engine, Transmission & Driveline 9 06-22-2012 08:13 PM
MS3 Shifting curlyface Mazdaspeed3/6 General Discussion 17 05-12-2012 12:24 PM
(down) shifting (toao)fallen MazdaSpeed 3 - Engine, Transmission & Driveline 10 01-21-2010 04:47 PM
Page generated in 0.50993 seconds with 30 queries
