-   -   Short Block Is Done (http://www.mazdaspeedforums.org/forum/f10/short-block-done-58360/)
qtrmile beast 06-01-2011 04:15 PM
Nice i can't wait to see what you pull out!! how much psi?
SilverDemon 06-01-2011 05:21 PM
23-24psi...and a stupid amount out timing.....hehehehe
I found the max flow of the stock catback...bigger pipes are needed before I go any farther
turd burglar 06-01-2011 05:49 PM
Hey silver, wanna trade the stock catback and some $ for my txs catback?
SilverDemon 06-01-2011 05:51 PM
Thanks man... just bought the CP-E cat back
turd burglar 06-01-2011 05:56 PM
Poop dick
SilverDemon 06-01-2011 05:59 PM
ZERO issues out of the SB...logging or other wise...it performed flawless...
djuosnteisn 06-01-2011 06:00 PM
Hope the good luck continues man!
SilverDemon 06-01-2011 08:26 PM
3 Attachment(s)
pic 1 is the 1st stable run of the day at 15 psi
pic 2 is final run about 23 -24 psi
pic 3 is just an overlay of the two graphs
Sorry for the video, I thought I caught a full run, but this was a short 3rd gear pull to test boost control at 23 psi.
This is where we stopped, nothing more could be done to make more power, the stock cat back starts to choke things up at this point, there was no need to beat on it anymore.
I believe the stock exhaust is really good to this point, I am only about 40 whp from the highest recorded speed 3 on this dyno. Would have I liked to see 400 - 450? Absolutely, I will soon get there....
qtrmile beast 06-01-2011 09:30 PM
you were at cpe today???????? the 2 highest hp speed3s that i know of that used this dyno was when we had the shop it and that was robbie with 380hp and socks with 395... when we did the 409 on the dyno jet we dynoed it that morning on the mustang and made 356 about two weeks later we made 380!! good job silver!!
socks 06-01-2011 09:46 PM
allo for highest speed 3 on that dyno!
is my 394whp on that dyno still good?
SilverDemon 06-01-2011 10:11 PM
yes, I was at Cp-E for the dyno. (the fucking ego killer of a dyno... hahahaha)
Socks, we looked through all of the runs that were saved on the computer, and could only find the highest of something like 370 or so. I had thought that you had made more power, but could not find the run saved in the dyno computer. But don't worry, your record is still safe.....at least for now..hahaha :)
qtrmile beast 06-01-2011 10:33 PM
I believe that was robbies!!! but i was there when socks did his number though.. i have robbies 380hp pull but i am having problem converting it to something that photobucket can upload as it will not do pdf files...
Ckmazdaspeed3 06-01-2011 10:39 PM
That's good info regarding the stock catback because I'm on stock catback and running your old 2871. So, being that the genpoo exhaust is more restrictive than gen 1, I wonder if it will be a restriction for me? Granted, I won't be making the power u are, but hopefully 350-380 whp (not on the heartbreaker of course).
I can't wait to see the power you put down when you get shit all lined up!
cpolly69 06-02-2011 01:52 AM
that's why i asked philly if he knew your last name yesterday - just trying to find your run to compare hp/tq curves
(just in case you were wondering)
socks 06-02-2011 06:05 AM
why you sweatin me dog?
Big Power Is HERE! | Custom Performance Engineering
cpolly69 06-02-2011 06:21 AM
Originally Posted by socks (Post 877373)
Because your run would appear to not be on that hard drive. Sander looked for a few min...
NJSPEED3 06-02-2011 06:40 AM
WTF 200 cocks in one night? Amazazing
Its portuguese thought
socks 06-02-2011 06:43 AM
im pretty sure that 370 you saw was it. i think it was 394whp uncorrected, but... it was january.
cpolly69 06-02-2011 06:45 AM
Omg oatmeal that shits been in my sig like 2 weeks and it's amazing, so I guess we both fail
cpolly69 06-02-2011 06:48 AM
Idk man we were just comparing curves and discussing different styles of tuning - it was nice to overlay other bt mzrs
NJSPEED3 06-02-2011 06:50 AM
I dont really read sigs, plus that shit is so tiny.
djuosnteisn 06-02-2011 09:01 AM
Scott, the torque falls off pretty abruptly at 5700 rpm, did you guys spend much time on timing? Just seems weird that the torque would take a sudden dive at a specific rpm when a flow restriction is the cause. Typically you just see the torque gradually drop faster and faster, not like a specific elbow.
Just curious. Also, are you using any water injection or race gas?
SilverDemon 06-02-2011 11:43 AM
Most of the day focused around timing.
I do not have meth injection....at all
Pump gas and 19 psi and insane amount of timing (I do not know exact timing until I look at the BBX logs, but I think it was somewhere near 23-25*) The car made good power, with out a hint of knock. Made many repeatable runs at that level, BAS was set up at 25%, no misfires.
5 gallons of Sunoco VP 110 was put in with less than half a gallon of 93. Raised the boost to about 23 and added 1* of timing, this is where we saw a detonation event on #1 cylinder. Kind of scary to pull the plug and see that for the first time hahaha! Pulled the 1* back out and it would repeat the runs like with out further mishap. What seems to be a little strange is on the drive home I am back on 93 octane (several tanks of pump gas cycled through the car) with the 23 psi race gas tune and the car shows no sign of knock, and I stabbed the throttle several times, it just fucking hauls like I have never seen before.
Moving on to the torque drop at ~5500 rpm. Both the tunes have the same timing values all the way to red line. I agree that it should drop a little more gradual with a flow restriction, but I know the tune is perfect, and lets face it, a 2.5" exhaust was not meant to flow this much air. The exhaust is 3" to the mid pipe, then squeezes down to 2.5" with the factory silencer and muffler. I thought it did great considering. I will install the 3" straight through exhaust this week end and we will see how it does. If this does not do it, I will run a 4" cut out behind the front wheel....ahahahhaha :D
Just to let everyone know, this is just the end of the first chapter...many more chapters will follow!!!
socks 06-02-2011 11:46 AM
same timing values to redline? can you explain this?
for your power to hold on, you will want it to gradually increase advance towards redline.
SilverDemon 06-02-2011 11:51 AM
I'm sorry... same timing values between the pump gas and race gas tunes to red line.
socks 06-02-2011 12:01 PM
Oh, yea that was something we noticed, is that we were able to run enough timing on pump, that it sorta plateaued and there was no point in running more. race gas or not.
but, at the same time, i was on a 3071, at 24psi, so...
djuosnteisn 06-02-2011 12:24 PM
Did the detonation event occur above or below 5700 rpm? Odd that you detonated with the higher octane, but i guess with the added boost it may be understandable.
Are you certain your not beyond MBT?
Like Sean mentioned, there's a plateau point, where any extra timing doesn't buy you any extra power. And from my experience it's several degrees deep. So if you actually detonated at 24psi and 1* more timing, you may want to pull like 3* back out, or keep pulling it til you see the torque drop, then add 1* back in.
Just food for thought. I know your built, but detonation can still wreak havoc! And i also know i'm not telling you anything you don't already know :240:
SilverDemon 06-02-2011 12:43 PM
No worries man!! thanks for looking out for me :)
I do not know when the event happened, but I know it was in the upper end of the revs, because I was standing right next to the car when it happened.
The power was still increasing with each timing adjustment, until we hit the event, pulled the degree out and left it there. I truly do not think the car surpassed MBT based on the power increase with each adj.
The engine simply does not exhibit KR where it is right now.
spnkr21 06-02-2011 12:52 PM
Yea even with my small 3071 maxed out I wasn't getting knock and my egts were 100-200 higher than your's without meth.
Awesome job Scott. Your car will be much louder with the new cat back haha.
superskaterxes 06-02-2011 02:07 PM
dont fret scott. this dyno is garbage (at least in the hands of CPE) as no one there actually knows how to use it.
Lex 06-02-2011 03:14 PM
I find it odd that you had one extreme deto event (to show up on the plug?) and no other detonation with only 1 deg less timing.
SilverDemon 06-02-2011 03:50 PM
It may be odd, but I was standing there when it happened, and when the plug was pulled out. Inspected it with my own eyes. There was no other adjustments to boost.
djuosnteisn 06-02-2011 03:55 PM
Moar race gas!
SilverDemon 06-02-2011 03:58 PM
hahaha!!! C16 here I come!!
I think once I get the other exhaust on, this is the way the car will stay for a while, I just want to enjoy the car right now. :cool2:
kmac 06-02-2011 07:19 PM
Happy to see u finished the car, love the video, sound nice when It's pulling. Gl with future dyno and add ons . You'll hit those numbers soon enough. How many pulls did u do before u detonated? Possible heat soak high bat's . Too many pulls in a row without spraying down the i/c with co2 or nos to drop the temps could cause detonation.
SilverDemon 06-02-2011 07:54 PM
Thanks!!
It was hotter than a firecracker that day..If I remember the air temp was about 92* with 89% humidity. So, yes, the heat did not help anything , could have played a roll in detonation.
Edit: There were probably a good dozen pulls before the knock event.
SilverDemon 06-03-2011 07:27 PM
Got the CP-E exhaust on this afternoon!! I kind of found out how bad the stock exhaust drones when the cats are removed. My SOTP dyno will have to be used...it is not calibrated very well :D I have not had a chance to run it much, kind of busy tonight, but I did do a few short runs when the boost tube from the turbo popped off...holy shit it was loud!!! hahaha
11cruzito11 06-11-2011 02:57 PM
Now that you have the new CBE on, when are you going to re-dyno?
SilverDemon 06-11-2011 06:05 PM
Well, seeing how CP-E is a 400 mile drive, I might not be able to get there until next year. Going to another dyno, even if it is a Mustang, it will not be accurate comparison.
The next stage of the build is going to begin in a few weeks. I just ordered W/M injection system, with the pro fuel controller for the stand back. I am also going to go about the install in a little bit different way than the standard. I want to do some testing before I release any details of the set up, but, if it works, this should be a plus in the terms of where the water/meth is injected. Don't worry, I will let everyone know what I did, and how to do the install if it all works......and if it does not work, I will share my fail as well....hahaha :D
kmac 06-11-2011 07:45 PM
Awesome, bro happy to see you're trying something new. How did the exhaust help out? Big difference or no? Always interesting to see what u have on the horizon.
Page generated in 0.21283 seconds with 11 queries
