Like Tree7Likes
 Old 03-07-2011, 08:10 PM   #41
BrianZX10R's Avatar
Posts: 1,163   (View Stats)
BrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the world
Groans: 88
Groaned at 121 Times in 75 Posts
Originally Posted by SilverDemon View Post
I knew better, but I went ahead and did it any way, and now I am paying for the mistake
sounds familiar, dustin!
1995 honda civic. 1.6L slow
2007 Kawasaki ZX10r
BrianZX10R is offline   Reply With Quote
The Following 2 Users Say Thank You to BrianZX10R For This Useful Post:
djuosnteisn (03-08-2011), SilverDemon (03-07-2011)
 Old 03-08-2011, 09:59 AM   #42
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
did they use a deck plate when they bored it ??
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 03-08-2011, 10:57 AM   #43
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
It went OK.... well, not that great.. I spent about 70 hours at work last week, I had to work on Saturday, and then I had a meeting on Sunday. So, most of my time was spent running around. I think I had a total of 10 hours invested in removing motor and the accessories from the motor. I have the block to the point of removing the head and oil pump.. I also encountered a small bit of fail... I will elaborate after I fix it, but lets just say I knew better, but I went ahead and did it any way, and now I am paying for the mistake by needing to fix the screw up....
Hahahahahahahahaahha, read my mind.
You'll get it fixed Scott. And don't worry, your not alone lol. I'm still confident my fail outweighs yours.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
SilverDemon (03-08-2011)
 Old 03-08-2011, 07:49 PM   #44
SilverDemon's Avatar
Posts: 3,034   (View Stats)
I am going to let the cat out of the bag on my little excursion of fail.
I have the stock motor sitting on the stand, the flywheel is already unbolted, and I am ready to remove the crank pulley...(keep in mind that I have read the service manual) Now, since the flywheel is unbolted from the engine I have no way of holding the crank while loosening the crank pulley bolt. This is where it went horribly wrong, I looked at the threaded timing hole that orients the crank pulley on the 20th tooth with the crank position sensor. I thought I would try to thread an M6x1 bolt in and try to give it a little tug on the ratchet. Well, the cast timing cover did not hold up....it broke the boss off of the cover, now I have no way to set the timing pin in the crank pulley. The only thing left of the boss was a dimple where the tap stopped when the hole was threaded after it was cast.
I finished removing the cover, and picked everything up. The next day I took it to work and set the cover up on the mill, picked up center on the dimple and plunged a 3/8" cutter into the cover. I took the depth to about .130" from breaking through. I then center drilled and tapped a piece of 3/8" round stock to 10 - 24 . I made the new boss about 3/8" long. I then cut a 10 - 24 clearance hole in the timing cover (the center of the old boss), counter sunk a flat head into the back of the cover. I used loc-tite 680 (high strength retaining compound) to hold the new boss and the flat head 10 -24 into the cover. Next I threaded the flat head screw through the cover and into the new boss. Now I have a new hole to center the crank pulley by using a 1/4" shoulder bolt.
After all of that, I am now starting to assemble the accessories on the built block....
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 8 Users Say Thank You to SilverDemon For This Useful Post:
06Speed6 (03-08-2011), cld12pk2go (03-09-2011), djuosnteisn (03-09-2011), I Love Brownies (03-30-2011), jracer (03-08-2011), mayer (04-16-2011), MPSdriver (03-14-2011), rigor (03-09-2011)
 Old 03-08-2011, 11:10 PM   #45
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
^^^ Gheeeeetttttoooooo... I didnt know you were mexican!
2006 Mazdaspeed 6
SilverDemon (03-09-2011)
 Old 03-09-2011, 02:57 AM   #46
SI....
hahaha
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 03-09-2011, 03:37 AM   #47
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
If this had happened to any other person it would've taken weeks to fix or the part would need replacing.
2012 WRX HB w/mudflaps yo!
The Following 3 Users Say Thank You to spnkr21 For This Useful Post:
06Speed6 (03-09-2011), MPSdriver (03-14-2011), SilverDemon (03-09-2011)
 Old 03-09-2011, 05:25 AM   #48
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
I did that EXACT same thing when i had my motor on a stand..... you're not alone.
luckily with mine they were still able to time the engine without repairing/replacing the timing cover. it was broken just enough to tick me off but still able to snug a bolt on for the timing
The Following 3 Users Say Thank You to socks For This Useful Post:
djuosnteisn (03-09-2011), jracer (03-09-2011), SilverDemon (03-09-2011)
 Old 03-09-2011, 06:19 AM   #49
yes...my machinest made his own deck plate
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following User Says Thank You to SilverDemon For This Useful Post:
jracer (03-09-2011)
 Old 03-09-2011, 09:21 AM   #50
Captain
Groans: 79
Ugh... haha you should have phoned a friend man. I would have sent you a timing cover to save you some trouble.
When i had to pull the crank bolt on the last motor, i took a piece of flat stock, and drilled 2 holes in it spaced such that i could bolt it to the flywheel hole and bell housing. It worked perfect. I can take a pic for you if you wanna know more what i mean.
Nice save Scott.
www.permtuning.com
SilverDemon (03-12-2011)
 Old 03-09-2011, 09:52 AM   #51
I had ya on speed dial if this little fix would not have worked. hahaha It really only took me 45mins to fix, and I did it at work, so I got paid for fixing it...
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 03-09-2011, 10:09 AM   #52
Captain
Groans: 79
Lolol. Can't really argue with that shit. Almost an incentive to break stuff.
www.permtuning.com
 Old 03-09-2011, 04:27 PM   #53
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
SI....
hahaha
If only you had the skills of the real Mexican......
This whole project would have be so much easier for you
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
The Following 2 Users Say Thank You to cpolly69 For This Useful Post:
djuosnteisn (03-09-2011), SilverDemon (03-09-2011)
 Old 03-12-2011, 04:07 PM   #54
Default Jiggen' up the down pipe location!!!
I bolted everything to my stock motor so I can locate the position on the exhaust with out the engine being the car. Once all the go fast goodies start to show up I can fab the new down pipe and dump tube for the waste gate.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 3 Users Say Thank You to SilverDemon For This Useful Post:
djuosnteisn (03-14-2011), MPSdriver (03-14-2011), Spoolme (03-25-2011)
 Old 03-12-2011, 07:43 PM   #55
smitty5788's Avatar
Posts: 1,065   (View Stats)
smitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the world
Groans: 215
Looks great scott. Are you sticking with the 2871 or is something else in the works?
2011 DGM STI Sedan - Fully Bolted FP Green Setup
368WHP / 335WTQ
SOLD: Black Mica 2010 MS3 - Tech Package -CPE Catless DP - CS CBE - SURE Aeros - SURE Sidewinder - TS BPV - CPE HPFP - JBarone Shifter Bushings - TRZ RMM - MD OCC - Progress RSB - DashDAQ - 18x8.5 +45 Rays Gram Light 57F - 235/40 Potenza RE760
smitty5788 is offline   Reply With Quote
The Following User Says Thank You to smitty5788 For This Useful Post:
 Old 03-12-2011, 07:54 PM   #56
Thanks...
I had to go with something bigger than the 2871. I am going with steedspeed's manifold with a 35R T3 set up.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 10 Users Say Thank You to SilverDemon For This Useful Post:
djuosnteisn (03-14-2011), Docnox (03-30-2011), manelscout4life (03-17-2011), smitty5788 (03-12-2011), socks (03-17-2011), Speed3eak (03-12-2011), spiker98 (04-14-2011), Spoolme (03-25-2011), turd burglar (04-07-2011), xcoldricex (03-20-2011)
 Old 03-12-2011, 08:16 PM   #57
smitty5788's Avatar
Groans: 215
Thats going to be nasty. Are you having Automotion tune it?
368WHP / 335WTQ
 Old 03-12-2011, 08:19 PM   #58
I have been thinking about letting them do the tune.
Did you go there to get yours dyno'ed?
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 03-12-2011, 08:27 PM   #59
smitty5788's Avatar
Groans: 215
Ya, stock was 212HP 222TQ, stage 1 was 250HP 262TQ on a mustang.
I have a Big MAF Intake, 3" inlet, ATP 3071, DP, CBE, EWG, Up Pipe, Header all sitting in my apartment ready to go on. Just waiting on some injectors and a fuel pump and some P&P work on the intake manifold, TB and TGV deletes.
368WHP / 335WTQ
 Old 03-12-2011, 08:37 PM   #60
Good numbers on that dyno....my car hated that dyno, but I believe he put the best tune on the car
Your going to need something bigger than the 3071 to keep up man...hahahaha
Edit: is Charles still at Automotion ?
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 03-17-2011, 05:44 PM   #61
A few more pics...Assembly of the top end, timed, and all accessories are installed. Valve cover and intake manifold powder coated.....The last pic still has a few items missing.
Bucker likes this.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 18 Users Say Thank You to SilverDemon For This Useful Post:
ak_spray (03-20-2012), alien_sporez (03-30-2011), bova (03-17-2011), Ckmazdaspeed3 (03-17-2011), cld12pk2go (03-18-2011), cpolly69 (03-17-2011), djuosnteisn (03-17-2011), Docnox (03-30-2011), doubleflusher (03-17-2011), gerry@ardesign (03-17-2011), mayer (04-16-2011), mazda.speed3 (03-30-2011), MPSdriver (04-10-2011), smitty5788 (03-19-2011), spiker98 (04-14-2011), super_pablo_ (03-28-2011), turd burglar (04-07-2011), xcoldricex (03-20-2011)
 Old 03-17-2011, 05:49 PM   #62
Captain
Groans: 79
Fuuuuuuck, this is getting me excited man.
Good job, and i hope to not be toooo far behind you.
www.permtuning.com
SilverDemon (03-17-2011)
 Old 03-17-2011, 05:49 PM   #63
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
looks awesome
 Old 03-17-2011, 06:22 PM   #64
manelscout4life's Avatar
Posts: 1,781   (View Stats)
manelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the world
Groans: 661
Groaned at 45 Times in 33 Posts
This is going to be sick.
manelscout4life is offline   Reply With Quote
The Following User Says Thank You to manelscout4life For This Useful Post:
 Old 03-17-2011, 06:25 PM   #65
spnkr21's Avatar
Groans: 105
What!
Scott you need to clean up my engine bay.
Let's see pics of the new turbo!!!!
The Following User Says Thank You to spnkr21 For This Useful Post:
 Old 03-17-2011, 06:43 PM   #66
Originally Posted by spnkr21 View Post
What!
I wish I could show pics of the turbo...but I have not received it yet (come on Mark!!!) The exhaust manifold shipped today...hope to have it in a few days.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 03-17-2011, 06:46 PM   #67
spnkr21's Avatar
Groans: 105
Haha. I didn't know you got one. What size? The intake mani looks so amazing. I can't get over that thing.
 Old 03-17-2011, 06:47 PM   #68
Hahaha..thanks man!! T3 GT35r .63 A/R and the steedspeed exhaust mani, and tial 38mm exg
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 03-17-2011, 06:50 PM   #69
spnkr21's Avatar
Groans: 105
Awesome
Zex
I mean sex
Zex
 Old 03-17-2011, 06:56 PM   #70
never fear...I am looking into something along those lines.....hehehehehe
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 03-17-2011, 07:03 PM   #71
spnkr21's Avatar
Groans: 105
Coitus?
 Old 03-17-2011, 07:07 PM   #72
That word does not exist for me, I have been married for too long ......but a Zex N2O system might become a reality in the near future....
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 03-17-2011, 08:08 PM   #73
tbot's Avatar
Posts: 2,821   (View Stats)
tbot is the leader of the worldtbot is the leader of the worldtbot is the leader of the worldtbot is the leader of the worldtbot is the leader of the worldtbot is the leader of the worldtbot is the leader of the worldtbot is the leader of the worldtbot is the leader of the worldtbot is the leader of the worldtbot is the leader of the world
Groans: 40
Good work man! I hope to have my car up and running soon...but nothing fancy yet...I haz no monies.
Sent from my HTC Glacier using Tapatalk
| Steedspeed Top Mount Mani | Precision BB 5857 | Perm Tuning 3.5" Intake | Perm Tuning 2 Piece DP | Perm Tuning PCV Plate and Vented Catch Can | Mishimoto Catch Can | Weisco Pistons | Pauter Rods | AWR Tranny Mount | CP-e RMM | Turbinetech FMM | Turbinetech FDM | CP-e RDM | CX Racing FMIC | TWR Short Shifter | JBR SSP | AP w/ Base Map | BLOWN MOTOR |
| 1974 Nova | SBC 350 | TH350 | Weiand Team G | Edelbrock 1406 | Aluminum 4 Core Radiator | Pro Comp HEI Distributor |
tbot is offline   Reply With Quote
The Following 2 Users Say Thank You to tbot For This Useful Post:
djuosnteisn (03-17-2011), SilverDemon (03-18-2011)
 Old 03-17-2011, 09:16 PM   #74
Captain
Groans: 79
A fully forged bottom end is fancy man
Scott... thank god your thinking about nitrous.
www.permtuning.com
NJSPEED3 (04-03-2011), SilverDemon (03-18-2011)
 Old 03-17-2011, 09:28 PM   #75
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
AtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the world
Anxious for number!! omg omg omg omg......
AtTheDriveIn is offline   Reply With Quote
The Following User Says Thank You to AtTheDriveIn For This Useful Post:
 Old 03-17-2011, 09:33 PM   #76
Posts: 20,650   (View Stats)
Groans: 1,443
Into which hole do I insert my penis?
Beanfab / Tuned by Nishan
The Following 2 Users Say Thank You to doubleflusher For This Useful Post:
cld12pk2go (03-18-2011), SilverDemon (03-18-2011)
 Old 03-17-2011, 11:26 PM   #77
tbot's Avatar
Groans: 40
Yeah I was thinking more along the lines of big top mount Turbo being fancy.
djuosnteisn (03-18-2011), SilverDemon (03-18-2011)
 Old 03-20-2011, 04:04 PM   #78
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
Groans: 105
NICE!
where's that spark plug cover?
xcoldricex is offline   Reply With Quote
The Following User Says Thank You to xcoldricex For This Useful Post:
SilverDemon (03-20-2011)
 Old 03-25-2011, 07:22 PM   #79
Spoolme's Avatar
Posts: 1,041   (View Stats)
Spoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the world
Groans: 54
amazing man. I cannot wait to see this thing in action.
Parting out!
http://www.mazdaspeedforums.org/forum/f229/spoolme-parting-out-76016/
Spoolme is offline   Reply With Quote
The Following User Says Thank You to Spoolme For This Useful Post:
SilverDemon (03-30-2011)
 Old 03-30-2011, 04:19 AM   #80
Just a little update........
It has been 22 days since the money was sent from my paypal account for the steedspeed exhaust manifold....you think that might be a little excessive?
Then the bullshit with dealing with ATP on the turbo....Them fucksticks need a new kindergarden teacher to help them manage simple orders....The order went through Street Unit, Mark has stepped up and has bent over backwards to make things right with me, even though ATP is fucking him on the backside...
I thought having a hobby was meant to be fun...not a fight everytime an order is placed.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
06Speed6 (03-30-2011), ak_spray (03-20-2012), cld12pk2go (03-30-2011), jracer (03-30-2011), NJSPEED3 (04-03-2011), smitty5788 (03-30-2011), Spoolme (03-30-2011), xcoldricex (03-30-2011)
Page generated in 0.57121 seconds with 36 queries
