![]() | | #41 | ![]() |
![]() Join Date: Jan 2009 Location: Bangor PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,426
Groans: 88
Groaned at 121 Times in 75 Posts
| Not Ranked : 0 score
__________________ 1995 honda civic. 1.6L slow 2007 Kawasaki ZX10r |
| The Following 2 Users Say Thank You to BrianZX10R For This Useful Post: | djuosnteisn (03-08-2011), SilverDemon (03-07-2011) |
![]() | | #42 | ![]() |
![]() Join Date: May 2009 Location: Clw/ NPR Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,516
Groans: 89
| Not Ranked : 0 score did they use a deck plate when they bored it ??
__________________ [SIGPIC][/SIGPIC] 2013 EVO X GSR Wicked White w/Areo H&R springs/H&R 15mm spacers MAP modified 3" Magna Flow cat back MAP catless testpipe MAP UICP Grimmspeed 3 port Cosworth filter SSP relay kit TWM Desert Eagle shift knob AEM wideband gauge Prosport boost gauge EvoX piller pod 30%Tint Slowpoke Tuned 339hp/336tq **** SOLD ***** 2006 speed6 " A woman's asshole is like a 9-volt battery..U know its wrong, but sooner or later ur gonna put ur tongue on it !! " |
![]() | | #43 | ![]() |
Groans: 79
You'll get it fixed Scott. And don't worry, your not alone lol. I'm still confident my fail outweighs yours.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
| The Following User Says Thank You to djuosnteisn For This Useful Post: | SilverDemon (03-08-2011) |
![]() | | #44 | ![]() |
![]() Join Date: Jul 2009 Location: Sardinia, Ohio
Rep Power: 4726 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,721
(Thread Starter) | Not Ranked : 0 score I am going to let the cat out of the bag on my little excursion of fail. I have the stock motor sitting on the stand, the flywheel is already unbolted, and I am ready to remove the crank pulley...(keep in mind that I have read the service manual) Now, since the flywheel is unbolted from the engine I have no way of holding the crank while loosening the crank pulley bolt. This is where it went horribly wrong, I looked at the threaded timing hole that orients the crank pulley on the 20th tooth with the crank position sensor. I thought I would try to thread an M6x1 bolt in and try to give it a little tug on the ratchet. Well, the cast timing cover did not hold up....it broke the boss off of the cover, now I have no way to set the timing pin in the crank pulley. The only thing left of the boss was a dimple where the tap stopped when the hole was threaded after it was cast. I finished removing the cover, and picked everything up. The next day I took it to work and set the cover up on the mill, picked up center on the dimple and plunged a 3/8" cutter into the cover. I took the depth to about .130" from breaking through. I then center drilled and tapped a piece of 3/8" round stock to 10 - 24 . I made the new boss about 3/8" long. I then cut a 10 - 24 clearance hole in the timing cover (the center of the old boss), counter sunk a flat head into the back of the cover. I used loc-tite 680 (high strength retaining compound) to hold the new boss and the flat head 10 -24 into the cover. Next I threaded the flat head screw through the cover and into the new boss. Now I have a new hole to center the crank pulley by using a 1/4" shoulder bolt. After all of that, I am now starting to assemble the accessories on the built block....
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. |
| The Following 8 Users Say Thank You to SilverDemon For This Useful Post: | 06Speed6 (03-08-2011), cld12pk2go (03-09-2011), djuosnteisn (03-09-2011), I Love Brownies (03-30-2011), jracer (03-08-2011), mayer (04-16-2011), MPSdriver (03-14-2011), rigor (03-09-2011) |
![]() | | #45 | ![]() |
Rep Power: 7491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
| Not Ranked : 0 score ^^^ Gheeeeetttttoooooo... I didnt know you were mexican!
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG |
| The Following User Says Thank You to 06Speed6 For This Useful Post: | SilverDemon (03-09-2011) |
![]() | | #46 | ![]() |
(Thread Starter) | Not Ranked : 0 score SI.... hahaha
![]() | | #47 | ![]() |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
Groans: 105
| Not Ranked : 0 score If this had happened to any other person it would've taken weeks to fix or the part would need replacing.
__________________ 2012 WRX HB w/mudflaps yo! |
| The Following 3 Users Say Thank You to spnkr21 For This Useful Post: |
![]() | | #48 | ![]() |
![]() ![]() Join Date: Jun 2008 Location: Greenville, SC
Rep Power: 2562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,586
Groans: 125
luckily with mine they were still able to time the engine without repairing/replacing the timing cover. it was broken just enough to tick me off but still able to snug a bolt on for the timing
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 | |
| The Following 3 Users Say Thank You to socks For This Useful Post: |
![]() | | #49 | ![]() |
(Thread Starter) | Not Ranked : 0 score yes...my machinest made his own deck plate
| The Following User Says Thank You to SilverDemon For This Useful Post: | jracer (03-09-2011) |
![]() | | #50 | ![]() |
Groans: 79
When i had to pull the crank bolt on the last motor, i took a piece of flat stock, and drilled 2 holes in it spaced such that i could bolt it to the flywheel hole and bell housing. It worked perfect. I can take a pic for you if you wanna know more what i mean. Nice save Scott.
| The Following User Says Thank You to djuosnteisn For This Useful Post: | SilverDemon (03-12-2011) |
![]() | | #51 | ![]() |
(Thread Starter) | Not Ranked : 0 score I had ya on speed dial if this little fix would not have worked. hahaha It really only took me 45mins to fix, and I did it at work, so I got paid for fixing it...
| The Following User Says Thank You to SilverDemon For This Useful Post: | djuosnteisn (03-09-2011) |
![]() | | #52 | ![]() |
Groans: 79
| Not Ranked : 0 score Lolol. Can't really argue with that shit. Almost an incentive to break stuff.
| The Following User Says Thank You to djuosnteisn For This Useful Post: | SilverDemon (03-09-2011) |
![]() | | #53 | ![]() |
![]() Join Date: Jan 2009 Location: Columbus Ohio
Rep Power: 1087 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,958
Groans: 27
| Not Ranked : 0 score If only you had the skills of the real Mexican...... This whole project would have be so much easier for you
__________________ 08 CB MS3 Sport Sold 01 MX-5 (Project) 03 P5 (DD) |
| The Following 2 Users Say Thank You to cpolly69 For This Useful Post: | djuosnteisn (03-09-2011), SilverDemon (03-09-2011) |
![]() | | #54 | ![]() |
(Thread Starter) | Not Ranked : 0 score I bolted everything to my stock motor so I can locate the position on the exhaust with out the engine being the car. Once all the go fast goodies start to show up I can fab the new down pipe and dump tube for the waste gate.
| The Following 3 Users Say Thank You to SilverDemon For This Useful Post: |
![]() | | #55 | ![]() |
![]() Join Date: Dec 2009 Location: Cincinnati, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,608
Groans: 215
| Not Ranked : 0 score Looks great scott. Are you sticking with the 2871 or is something else in the works?
__________________ 2011 DGM STI Sedan - Fully Bolted FP Green Setup 368WHP / 335WTQ SOLD: Black Mica 2010 MS3 - Tech Package -CPE Catless DP - CS CBE - SURE Aeros - SURE Sidewinder - TS BPV - CPE HPFP - JBarone Shifter Bushings - TRZ RMM - MD OCC - Progress RSB - DashDAQ - 18x8.5 +45 Rays Gram Light 57F - 235/40 Potenza RE760 |
| The Following User Says Thank You to smitty5788 For This Useful Post: | SilverDemon (03-12-2011) |
![]() | | #56 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks... I had to go with something bigger than the 2871. I am going with steedspeed's manifold with a 35R T3 set up.
| The Following 10 Users Say Thank You to SilverDemon For This Useful Post: | djuosnteisn (03-14-2011), Docnox (03-30-2011), manelscout4life (03-17-2011), smitty5788 (03-12-2011), socks (03-17-2011), Speed3eak (03-12-2011), spiker98 (04-14-2011), Spoolme (03-25-2011), turd burglar (04-07-2011), xcoldricex (03-20-2011) |
![]() | | #57 | ![]() |
Groans: 215
| Not Ranked : 0 score Thats going to be nasty. Are you having Automotion tune it?
![]() | | #58 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have been thinking about letting them do the tune. Did you go there to get yours dyno'ed?
![]() | | #59 | ![]() |
Groans: 215
| Not Ranked : 0 score Ya, stock was 212HP 222TQ, stage 1 was 250HP 262TQ on a mustang. I have a Big MAF Intake, 3" inlet, ATP 3071, DP, CBE, EWG, Up Pipe, Header all sitting in my apartment ready to go on. Just waiting on some injectors and a fuel pump and some P&P work on the intake manifold, TB and TGV deletes.
![]() | | #60 | ![]() |
(Thread Starter) | Not Ranked : 0 score Good numbers on that dyno....my car hated that dyno, but I believe he put the best tune on the car Your going to need something bigger than the 3071 to keep up man...hahahaha Edit: is Charles still at Automotion ?
![]() | | #61 | ![]() |
(Thread Starter) | Not Ranked : 0 score A few more pics...Assembly of the top end, timed, and all accessories are installed. Valve cover and intake manifold powder coated.....The last pic still has a few items missing.
| The Following 18 Users Say Thank You to SilverDemon For This Useful Post: | ak_spray (03-20-2012), alien_sporez (03-30-2011), bova (03-17-2011), Ckmazdaspeed3 (03-17-2011), cld12pk2go (03-18-2011), cpolly69 (03-17-2011), djuosnteisn (03-17-2011), Docnox (03-30-2011), doubleflusher (03-17-2011), gerry@ardesign (03-17-2011), mayer (04-16-2011), mazda.speed3 (03-30-2011), MPSdriver (04-10-2011), smitty5788 (03-19-2011), spiker98 (04-14-2011), super_pablo_ (03-28-2011), turd burglar (04-07-2011), xcoldricex (03-20-2011) |
![]() | | #62 | ![]() |
Groans: 79
| Not Ranked : 0 score Fuuuuuuck, this is getting me excited man. Good job, and i hope to not be toooo far behind you.
| The Following User Says Thank You to djuosnteisn For This Useful Post: | SilverDemon (03-17-2011) |
![]() | | #63 | ![]() |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| Not Ranked : 0 score looks awesome |
| The Following User Says Thank You to bova For This Useful Post: | SilverDemon (03-17-2011) |
![]() | | #64 | ![]() |
![]() Join Date: Jan 2009 Location: Newark, NJ
Rep Power: 1040 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,110
Groans: 661
Groaned at 45 Times in 33 Posts
| Not Ranked : 0 score This is going to be sick. |
| The Following User Says Thank You to manelscout4life For This Useful Post: | SilverDemon (03-17-2011) |
![]() | | #65 | ![]() |
Groans: 105
| Not Ranked : 0 score What! Scott you need to clean up my engine bay. Let's see pics of the new turbo!!!!
| The Following User Says Thank You to spnkr21 For This Useful Post: | SilverDemon (03-17-2011) |
![]() | | #66 | ![]() |
(Thread Starter) | Not Ranked : 0 score I wish I could show pics of the turbo...but I have not received it yet (come on Mark!!!) The exhaust manifold shipped today...hope to have it in a few days.
| The Following User Says Thank You to SilverDemon For This Useful Post: | djuosnteisn (03-17-2011) |
![]() | | #67 | ![]() |
Groans: 105
| Not Ranked : 0 score Haha. I didn't know you got one. What size? The intake mani looks so amazing. I can't get over that thing.
![]() | | #68 | ![]() |
(Thread Starter) | Not Ranked : 0 score Hahaha..thanks man!! T3 GT35r .63 A/R and the steedspeed exhaust mani, and tial 38mm exg
![]() | | #69 | ![]() |
Groans: 105
| Not Ranked : 0 score Awesome Zex I mean sex Zex
| The Following User Says Thank You to spnkr21 For This Useful Post: | djuosnteisn (03-17-2011) |
![]() | | #70 | ![]() |
(Thread Starter) | Not Ranked : 0 score never fear...I am looking into something along those lines.....hehehehehe
![]() | | #71 | ![]() |
Groans: 105
| Not Ranked : 0 score Coitus?
![]() | | #72 | ![]() |
(Thread Starter) | Not Ranked : 0 score That word does not exist for me, I have been married for too long ......but a Zex N2O system might become a reality in the near future....
![]() | | #73 | ![]() |
![]() Join Date: Dec 2009 Location: Denver, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29,434
Groans: 40
| Not Ranked : 0 score Good work man! I hope to have my car up and running soon...but nothing fancy yet...I haz no monies. Sent from my HTC Glacier using Tapatalk
__________________ | Steedspeed Top Mount Mani | Precision BB 5857 | Perm Tuning 3.5" Intake | Perm Tuning 2 Piece DP | Perm Tuning PCV Plate and Vented Catch Can | Mishimoto Catch Can | Weisco Pistons | Pauter Rods | AWR Tranny Mount | CP-e RMM | Turbinetech FMM | Turbinetech FDM | CP-e RDM | CX Racing FMIC | TWR Short Shifter | JBR SSP | AP w/ Base Map | BLOWN MOTOR | | 1974 Nova | SBC 350 | TH350 | Weiand Team G | Edelbrock 1406 | Aluminum 4 Core Radiator | Pro Comp HEI Distributor | |
| The Following 2 Users Say Thank You to tbot For This Useful Post: | djuosnteisn (03-17-2011), SilverDemon (03-18-2011) |
![]() | | #74 | ![]() |
Groans: 79
![]() Scott... thank god your thinking about nitrous.
| The Following 2 Users Say Thank You to djuosnteisn For This Useful Post: | NJSPEED3 (04-03-2011), SilverDemon (03-18-2011) |
![]() | | #75 | ![]() |
| Two nuns and a pack mule ![]() Join Date: Jan 2010 Location: Virginia Beach, VA
Rep Power: 595 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 459
| Not Ranked : 0 score Anxious for number!! omg omg omg omg......
__________________ ![]() |
| The Following User Says Thank You to AtTheDriveIn For This Useful Post: | SilverDemon (03-18-2011) |
![]() | | #76 | ![]() |
![]() Join Date: Feb 2009
Rep Power: 151849 ![]() Thanks: 55,993
Groans: 1,443
| Not Ranked : 0 score Into which hole do I insert my penis?
__________________ Evo VIII - 9.93 @ 150.05 - CAI and LEDs Beanfab / Tuned by Nishan |
| The Following 2 Users Say Thank You to doubleflusher For This Useful Post: | cld12pk2go (03-18-2011), SilverDemon (03-18-2011) |
![]() | | #77 | ![]() |
Groans: 40
| Not Ranked : 0 score Yeah I was thinking more along the lines of big top mount Turbo being fancy. Sent from my HTC Glacier using Tapatalk
| The Following 2 Users Say Thank You to tbot For This Useful Post: | djuosnteisn (03-18-2011), SilverDemon (03-18-2011) |
![]() | | #78 | ![]() |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
Groans: 105
| Not Ranked : 0 score NICE! where's that spark plug cover? |
| The Following User Says Thank You to xcoldricex For This Useful Post: | SilverDemon (03-20-2011) |
![]() | | #79 | ![]() |
![]() Join Date: Dec 2009 Location: Dublin, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 443
Groans: 54
| Not Ranked : 0 score amazing man. I cannot wait to see this thing in action.
__________________ Parting out! http://www.mazdaspeedforums.org/forum/f229/spoolme-parting-out-76016/ |
| The Following User Says Thank You to Spoolme For This Useful Post: | SilverDemon (03-30-2011) |
![]() | | #80 | ![]() |
(Thread Starter) | Not Ranked : 0 score Just a little update........ It has been 22 days since the money was sent from my paypal account for the steedspeed exhaust manifold....you think that might be a little excessive? Then the bullshit with dealing with ATP on the turbo....Them fucksticks need a new kindergarden teacher to help them manage simple orders....The order went through Street Unit, Mark has stepped up and has bent over backwards to make things right with me, even though ATP is fucking him on the backside... I thought having a hobby was meant to be fun...not a fight everytime an order is placed.
| The Following 8 Users Say Thank You to SilverDemon For This Useful Post: | 06Speed6 (03-30-2011), ak_spray (03-20-2012), cld12pk2go (03-30-2011), jracer (03-30-2011), NJSPEED3 (04-03-2011), smitty5788 (03-30-2011), Spoolme (03-30-2011), xcoldricex (03-30-2011) |
