![]() | | #1 | ![]() |
![]() Join Date: Jun 2008 Location: NW Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 361
Groaned at 7 Times in 6 Posts
(Thread Starter) | Not Ranked : 0 score So I get home and have a look in my engine bay to see if there is any fluid coming from the slave and I see alot of fluid all over my under body pan. I then jack the car up and take the belly pan cover thing off and see that oil is coming from my slave cylinder. I push on the slave boot and oil just sprays out like crazy, Im like wtf. I take off the 2 11mm bolts holding the slave on and put my oil drain pan down to catch some of the oil so it dont get all over my floor. So I pull back on the slave boot and bam the boot goes flying off and the internals of the slave go shooting down into my oil drain pan. It apears my slave came completely apart and the spring and the plunger and some plastic O-ring that holds it all in just all came apart and out. I never had a slave go out and come apart like this before but I never had a slave that all the internals were plastic. Im wondering if I could just put it back together and try it again or just order a new slave.. Im thinking I should order a new slave since I hear they came out with a stronger slave then the stocker that came in my 07 MS3. I also have about 55k miles on the stock slave so maybe its time to say goodbuy and Im sure my ACT clutch is putting a bit of a hurting on it anyways. Hear are a few photos of the internals incase you guys want to have a look at the weak sauce slave internals we have on our cars. Im lucky I made it home since the slave was only held together because of the rubber boot and I have a 32 mile drive each way for work so I went over 20 miles with it like this.
__________________ Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more http://videos.streetfire.net/profile/SharkDiver.htm http://www.youtube.com/user/sharkdiverjohn Last edited by SharkDiver; 11-13-2009 at 11:16 PM. |
![]() Join Date: Apr 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score I've gone through 3 slaves. The third one is a new revision and the parts guy said its internals are stronger. I also have an ACT clutch. Oh, one point to look at. The pipe connecting to the slave, it has some rubber gaskets/grommets. Make sure that they are there. If not replace that pipe too. Otherwise it will fail in another 10-15k mi. |
| The Following User Says Thank You to QuickSpool For This Useful Post: | SharkDiver (11-17-2009) |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
Groans: 105
| Not Ranked : 0 score wtf, our cars have the same problems sharkdiver - when i went under my car to change the starter - i discovered my slave is leaking crap too.. is that covered under powertrain or do i have to order it? $96.42 B37F-41-920B Auto Town Parts , $120 at the dealer. |
| The Following User Says Thank You to xcoldricex For This Useful Post: | SharkDiver (11-19-2009) |
![]() | | #4 | ![]() |
![]() Join Date: Mar 2009 Location: Oceanside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 925
| Not Ranked : 0 score The slave cylinder should be covered under powertrain warrantee and the starter should be covered as well. Powertrain warrantee covers everything involved with moving the car pretty much, except for brakes and clutch.
__________________ Murdered out 2007 speed3 GT with navi. |
![]() | | #5 | ![]() |
Groans: 105
| Not Ranked : 0 score the starter is not covered under powertrain, at least that's what one of the stealerships said. |
![]() | | #6 | ![]() |
![]() Join Date: May 2009 Location: Browns Mills/NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 739
| Not Ranked : 0 score Why doesnt anyone make heavy duty slaves, every car ived owned the slave has been the weakest link.
__________________ A Kabar is just a paper weight until it's in the hand of a Marine. If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground. COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS NATOR PA |
![]() | | #7 | ![]() |
| Not Ranked : 0 score I dont doubt that the "stealership" would try to not cover a starter but thats why i stated it should be covered under warrantee. If it was worth your time and energy you could probably get them to do it. I understand some things just are not worth fighting.
![]() | | #8 | ![]() |
![]() Join Date: May 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
| Not Ranked : 0 score anybody know if the slave cylinder is in the same spot on a speed 6? |
![]() | | #9 | ![]() |
| Not Ranked : 0 score They new revision of the part is stronger and it feels WAY better that the previous 2. It is very noticeable w/ the ACT heavy duty PP |
| The Following User Says Thank You to QuickSpool For This Useful Post: | SharkDiver (11-18-2009) |
![]() | | #10 | ![]() |
Groans: 105
| Not Ranked : 0 score apparently there's a 4th revision that my dealer just ordered. they said it wasn't covered under powertrain either - since it's clutch related. i think he said it was part number B4S41920D ? i'll check again when i get it in on friday. after replacing it - do we need to bleed the clutch since a good amt of fluid came out? |
![]() | | #11 | ![]() |
| Not Ranked : 0 score yeah and the breaks a little bit, same reseviour. not a full flush just a bit. |
![]() | | #12 | ![]() |
| Fux Wit It ![]() ![]() Join Date: Mar 2008 Location: Li
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,795
Groans: 175
| Not Ranked : 0 score ive been through 3 over the past 2 years. first two felt like trash newest one feels good. So far........
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous |
| The Following User Says Thank You to Darksun280 For This Useful Post: | SharkDiver (11-18-2009) |
![]() | | #13 | ![]() |
(Thread Starter) | Not Ranked : 0 score I would think so... Also Im hoping I get the newest revision.They were suppose to have the part today but I went to pick it up and they oredered the master cylinder instead. They say they will have the right part tomorrow (Turs.) now.
__________________ Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more http://videos.streetfire.net/profile/SharkDiver.htm http://www.youtube.com/user/sharkdiverjohn |
![]() | | #14 | ![]() |
![]() Join Date: Jun 2008 Location: Edinburg, Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 669
Groans: 31
Groaned at 12 Times in 5 Posts
| Not Ranked : 0 score same here, im on my third one. the 2nd one didn't last a month before that POS broke. Luckly it broke as soon as got into my gargage. as soon as the car slowed down, the clutch peddle hit the floor and i turned the car off. popped the hood open and looked down and saw fluids all on the undertray. this third one does feel better than the previous two.
2009 Rally Yellow Cobalt SS/TC K&N Intake, Badmab Catless Downpipe, ZZP FMIC Kit, Forge BPV, Mpx Exhaust, Dual Aeroforce Gauges, R1 Concept Drilled and Slotted Rotors, E85 Tune 310 WHP 330 WTQ 93 Octane 347 WHP 386 WTQ E85 | |
![]() | | #15 | ![]() |
(Thread Starter) | Not Ranked : 0 score Does any of you have the part # of the third one that you say works the best? i want to check it with mine tomorrow when I get it. Im pretty sure that when they come out with a new part they junk all the old stock but I could be wrong.
![]() | | #16 | ![]() |
Groans: 105
| Not Ranked : 0 score let me know what part number you get. how much did you end up paying? for some reason i only got charged $108 for the new part. i hope they didn't order the wrong thing for me, i kept asking him to make sure. |
![]() | | #17 | ![]() |
(Thread Starter) | Not Ranked : 0 score Mine should be around the same price..I think he said it was $130 but I get a 10% discount. The other day I called about 5 dealers to see if any of them had this part in stock and I got 5 diffrent prices ranging from $120-$230. Ill post the part # when I get a chance tomorrow..
![]() | | #18 | ![]() |
| Not Ranked : 0 score Call Josh at AutoTown Mazda. Tell him Sterling sent ya. He will hook you up Part # B37F-41-920B Toll Free: 1.866.537.6959 Local: 503.652.9101 |
| The Following User Says Thank You to QuickSpool For This Useful Post: | SharkDiver (11-19-2009) |
![]() | | #19 | ![]() |
![]() Join Date: Aug 2008 Location: Kahaluu, HI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 37
| Not Ranked : 0 score Heh rocking my third Slave cylinder also, just replaced last week.
__________________ 07 Black Mica with Sunroof" 11/17/11 ZZ-SB (Spun #4 Rod Bearing @97,643 miles) "I'm back Baby" says the almighty Bender CURRENT MODS: Cobb ATR self tune+JBR WP+FMIC+BNR S3+MI+IM+CP-e EXMAN: VDyno 351hp and 331tq BEST 1320: COBB AP S2+MSCAI2+FMIC-v1.03i Best ET on 2Nov08 13.6@98mph (yeah I missed 5th gear) |
![]() | | #20 | ![]() |
Groans: 105
| Not Ranked : 0 score |
![]() | | #21 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks for the replys... My part should be here today tho but if there is a problem I will call autoTown.. Im just hoping they have the right part this time..
![]() | | #22 | ![]() |
| The Truth Hurts ![]() Join Date: Mar 2009
Rep Power: 206 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 73
Groans: 286
Groaned at 339 Times in 226 Posts
| Not Ranked : 0 score Just because it failed it doesn't mean it's weak.
__________________ Trickytwelveinch has elite car skillz - opt_ms3. Last edited by trickytwelveinch; 11-19-2009 at 12:11 PM. |
![]() | | #23 | ![]() |
Groans: 105
| Not Ranked : 0 score got mine today - part BP4S41920c (they ordered D but it says C on the package) - boot is black abd seems to look smaller. i paid 108.29 which is the listed retail price... hope i didnt get the wrong part - the guy insisted on using my vin and would not use the parrt no i gave him... so i hope this is the newest rev.. |
![]() | | #24 | ![]() |
__________________ A Kabar is just a paper weight until it's in the hand of a Marine. If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground. COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS NATOR PA | |
| The Following User Says Thank You to nyghtryder For This Useful Post: | xcoldricex (11-21-2009) |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score I changed out my slave yesterday. I bleed the slave 2 times and it still dont feel right, It will go into gears but not as good as it did before. It feels like it still has alot of air in the system but now it seems my clutch is slipping. A bad slave or alittle air in the system should not cause the clutch to slip should it..? Im going to bleed it again tomorrow but Im really hoping its not my new clutch that is messed up. I have about 9k miles on my ACT street disk with no problems so far.
![]() | | #26 | ![]() |
Groans: 175
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous | |
![]() | | #27 | ![]() |
Groans: 105
| Not Ranked : 0 score haha looks like it might be a mazda 5 slave wtf. edit: haha he admits he was wrong- so at least he's express ordering it for me. stupid guy should have listened to me when i was like - well i have the part number that i want... are you sure? this isn't the same part number i have... new part number is the same as the one from autotownparts. Last edited by xcoldricex; 11-21-2009 at 07:30 AM. |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score So after bleeding over and over and never getting all the air out I took my car to my mechanic to have a look. So we bleed the system with a mityvac type and it never stops with the air bubbles,We try to gravity bleed and it still dont get all the air out. You can even push the slave rod in by hand and you can hear the air bubbles in the slave and lines. The slave is not leaking any fluid out so we think that is ok and I did just replace it so we now think its the master cylinder that may have gone out at the same time OR the master went out and caused the slave to go bad somehow. Either way Im ordering a new master and will install that and see what happens. If thats not it then it must be the throwout bearing or just a clutch plate malfunction or bent clutch fork thing. My clutch is also kinda slipping now but my mechanic thinks that fluid from my bad slave may have sprayed into the tranny and got some on the clutch but that sounds like a long shot to me. He also thinks that having a bad master could cause the clutch to slip but I dont see how. I think my ACT street disk or bearing is fucked up somehow and Im sure I will be taking off the tranny soon. What a joy that will be......
![]() | | #29 | ![]() |
Groans: 175
| Not Ranked : 0 score I think you just got to bleed the fuck out of it like I had too. Anyway if your master was out your brakes would suck and if you let your car sit for a while and the clutch gets soft but when you start the car it pressurizes that means your master and brae booster is fine no? Some one correct me if im wrong.
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score It doesnt really get anymore pressure after I start it then it did when not running. I left my car at the shop or I would go outside and check it out again to make sure. My brakes have been ok this whole time. If my clutch master cylinder is bad it will make my brakes go bad also?
![]() | | #31 | ![]() |
| Not Ranked : 0 score bleed them both, brakes and clutch. |
![]() | | #32 | ![]() |
Groans: 175
why do I feel like I messed up that statement some where lol.
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score I was just looking at the service manual and it seems to show a clutch master cylinder and a brake master cylinder. The brake master is connected to the reserve tank and the clutch master is connected to the clutch pedal.
![]() | | #34 | ![]() |
Groans: 175
| Not Ranked : 0 score oh snap why'd I never notice it when My motor was out. Or maybe just cause I wasn't looking for it lol. No matter either way if you do have some bubbles but enough fluid in the chamber the system should presurize somewhat with the car turned on and you pumping the pedal I believe.
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score So I changed out the clutch master and it didnt help. It looks like I will be taking my tranny off this friday to check on the clutch plate,cover and throwout bearing. Im getting about 7/16" of movement with the slave but I still cant get the car into Reverse and its hard going into 1-6 gears. It still seems to slip and it just feels like the clutch is not engaging like it should. The service manual doesnt say anything about how much throw out the slave cylinder should be putting out but it seems like its going enough to disengage the clutch. The manual only tells you how to check the throw by measuring your clutch pedal travel. At this point it seems like taking the tranny off is the only next step,Its not something Im looking forward to doing. If any of you out there with a ACT street dish setup want to measure your slave cylinder throwout or distance it moves when you press your clutch pedal in that would really help. Your slave is easy to get to and measure but you will need 2 people to do it.
![]() | | #36 | ![]() |
Groans: 175
| Not Ranked : 0 score I hope for the best but I still would like to think you just have a real pesky air bubble in the line.
| The Following User Says Thank You to Darksun280 For This Useful Post: | SharkDiver (11-25-2009) |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score Even if I did I dont know how that would cause my clutch to slip. Before I take it apart I will try to do another bleed and also try and look inside the clutch fork boot and see how far the clutch plate moves when I push the clutch and see if there is any visible problems.
![]() | | #38 | ![]() |
Groans: 105
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score So I took off my tranny last Friday to see what is wrong with it. As soon as we saw my clutch we seen the problem,The clutch diaphragm fingers on 1 side are bent. Act is sending me out a new clutch plate and a new disk with a new pilot bearing today at no charge. I had to send them photos of my plate and disk and after I get the new parts I will have to send them my old stuff. As soon as they seen my photos they said it was not repairable and I will get new parts instead of waiting for them to repair the old parts. It really suxs to have to go thru all this but its cool that they are replacing the parts at no cost,That helps alot. So it looks like this weekend I will be putting the tranny back into the car and hoping the tranny works as good as it did before all this bs.
| The Following 3 Users Say Thank You to SharkDiver For This Useful Post: |
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here are some photos of my plate and disk. Its clear what fingers are sitting low. The disk is alittle glazed but still ok if you ask me but they are sending a new disk anyways and thats what I wanted since I had it all apart already. I just dont really know why my slave went out at the same time...
| The Following User Says Thank You to SharkDiver For This Useful Post: | xcoldricex (11-30-2009) |
| How to bleed MazdaSpeed 3 clutch slave cylinder | y2kc0wb0y | Mazdaspeed3/6 General Discussion | 4 | 11-27-2017 07:11 PM |
| Clutch slave cylinder issues | socks | MazdaSpeed 3 - Engine, Transmission & Driveline | 13 | 03-31-2009 05:36 PM |
| need help with clutch slave sylinder,with spec stg 3+ | allmotor95pgt | MazdaSpeed 3 - Engine, Transmission & Driveline | 20 | 01-27-2009 04:00 PM |
| Mercedes unveils new range of diesel four-cylinders | Haltech | Automotive News | 0 | 04-10-2008 04:51 PM |
