| wanabe_batman | 04-09-2015 06:25 PM | Slave cylinder leak I have 2008.5 speed3 and am having problems with the connection between clutch line going into slave cylinder. Slave cylinder is pumping just fine and clutch line is not bent at all. I had this problem about 3 months after i got the car back in august 2014 just disconnected the line and put it back, bled the cylinder and i had no problem afterwards. Until last friday when it happened again and just now again. It appears i have a act 6 puck clutch according to a buddy who is a ms3 expert, i have not done any work to the car besides and intake and ots map from stratified. Its almost as if the cone at the end of the line is worn or the little rubber grommet looking thing just doesnt stay in place or maybe the clutch/pressure plate is too strong and forcing too much liquid for the line and slave cylinder to worm properly so it leaks. I've read many other forums and questions similar to this one and have tried everything but to no avail. Any suggestions, ideas, comments would be awesome. Thanks |
