Like Tree2Likes
 Old 01-17-2013, 04:28 PM   #1
steelknight7d's Avatar
Posts: 78   (View Stats)
steelknight7d has much to be proud ofsteelknight7d has much to be proud ofsteelknight7d has much to be proud ofsteelknight7d has much to be proud ofsteelknight7d has much to be proud ofsteelknight7d has much to be proud ofsteelknight7d has much to be proud ofsteelknight7d has much to be proud ofsteelknight7d has much to be proud ofsteelknight7d has much to be proud of
Groaned at 31 Times in 12 Posts
Default smell clutch all the time
Ok before ppl start to go crazy just here me out . I drive my car normal don't really get on it unless I have to anyways yesterday opened the hood to for vehicle inspection at my unit was looking around and smelled a lil hint of clutch and yes I know what clutch smells like so I guessed I slipped it alil today I checked and again smelled it and now coming home opened the hood again and smelled it again Wtf is this clutch bout to go any input would be much appreciated oh and its not driver mod been driving manual for years and I've searched a lot before posting
Corksport core/cx piping, HTP 3" intake, Grimmspeed EBCS, Autotech internals, Turbo Smart 50/50, CNT CBE, Sure PMM, Perm knob, Cobb AP, Matt Damond occ, JBR SSP, JBR TMM, JBR rmm, JBR Shifter bushings, ATP catted dp, NGK Plugs 1 step colder,H&R springs,hotchkis rsb, 5mm spacers, moog endlinks, Corksport strut bar, CP-e tow plate, Stratified by LEX
steelknight7d is offline   Reply With Quote
The Following User Says NO Thank You to steelknight7d For This Un-useful Post:
Manny (01-17-2013)
 Old 01-17-2013, 04:29 PM   #2
boostdmazda3's Avatar
Posts: 1,177   (View Stats)
boostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the world
Groans: 28
maybe you suck at driving.
Bnr s3/Act 6 puck/sure full 3inch intake/cobb fmic/cobb downpipe/grimmspeed ebc/3 bar map/hks catback/autotech hpfp internals/turbosmart bpv/bc coilovers/jbr trilogy mounts/ngk one step colder plugs/ms6 rims on nt-01 tires. 24 psi E85 freektuned.
Freektuned e85 Focus st as the daily.
boostdmazda3 is offline   Reply With Quote
The Following 4 Users Say Thank You to boostdmazda3 For This Useful Post:
IshiKage (01-17-2013), taf0422 (01-17-2013), Vansquish (01-17-2013), warlord (01-17-2013)
 Old 01-17-2013, 04:46 PM   #3
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
Is it an OEM clutch?
Past Mazdas & Speeds
 Old 01-17-2013, 05:50 PM   #4
Maybe u suck so shut up if u don't any thing useful to say
The Following 6 Users Say NO Thank You to steelknight7d For This Un-useful Post:
ANITIX87 (01-18-2013), Easter Bunny (01-17-2013), jeopardy98 (01-18-2013), Manny (01-17-2013), rherold9 (01-17-2013), Vansquish (01-17-2013)
 Old 01-17-2013, 06:00 PM   #5
chuckms6's Avatar
Posts: 1,618   (View Stats)
Tapatalking
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
 Old 01-17-2013, 06:03 PM   #6
Speed3in215's Avatar
Posts: 459   (View Stats)
Speed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond reputeSpeed3in215 has a reputation beyond repute
How many miles ?
2012 Mazdaspeed3~~Cobb AP~Corksport SRI+Tip~CNT cbe~JBR Red Spherical Knob~JBR SSP w/bushings~Autotech Internals ~ JBR 88 duro RMM~ Ultimate Racing Race Pipe ~Ultimate racing catless downpipe ~ forge v1 BPV~ denso ivt22 one step colder plugs~Rokblokz mud flaps
Freek tuned on 93 pump gas
Virtual Dyno - 3rd gear 285whp 326tq
4th gear 270whp 352tq
Speed3in215 is offline   Reply With Quote
 Old 01-17-2013, 06:10 PM   #7
22k
The Following 2 Users Say NO Thank You to steelknight7d For This Un-useful Post:
Manny (01-17-2013), Vansquish (01-17-2013)
 Old 01-17-2013, 06:26 PM   #8
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
Making a manual transmission car move for years does not mean you know how to drive one.
I hugged rfinkle2
The Following 4 Users Say Thank You to Easter Bunny For This Useful Post:
ANITIX87 (01-18-2013), Dash08 (01-18-2013), Neverlift (01-18-2013), Vansquish (01-17-2013)
 Old 01-17-2013, 06:34 PM   #9
Well regardless what u say I know how to drive so instead of trying to talk shit why don't u give some input bout what I'm saying
 Old 01-17-2013, 06:36 PM   #10
Raider is mah Homie
Groans: 2,978
You haven't demonstrated an ability to speak English so why would we assume you know how to drive.
I hugged rfinkle2
johnredding (01-17-2013)
 Old 01-17-2013, 06:40 PM   #11
Neutral  -1 score
Well all u have demonstrated is that your an ass so anyways can anyone let me know what u think about what I wrote if not then thanks anyways
The Following 4 Users Say NO Thank You to steelknight7d For This Un-useful Post:
ANITIX87 (01-18-2013), Easter Bunny (01-17-2013), Manny (01-17-2013), rherold9 (01-17-2013)
 Old 01-17-2013, 06:41 PM   #12
chuckms6's Avatar
You have not used a period once in this thread. That is amazing.
Tapatalking
johnredding likes this.
The Following 2 Users Say Thank You to chuckms6 For This Useful Post:
h0ckeyman (01-17-2013), johnredding (01-17-2013)
 Old 01-17-2013, 06:41 PM   #13
Police - Grammarhead
Vansquish's Avatar
Groans: 1,911
Why don't you give us some more info instead of getting pissy?
Does it happen all the time, every time you drive the car?
Have you noticed whether it feels like it's slipping? In other words, if you put your foot in it in a higher gear (say 4th or 5th) do the revs rise sporadically while the car doesn't accelerate during those sporadic rev-bursts?
Where does the clutch begin to engage? Do you have to press it down until it's near the floor? Do you only have to barely brush it to find the bite-point?
If there's no "dead space" at the top of the clutch pedal's travel, then it may just be poorly adjusted.
The Following 2 Users Say Thank You to Vansquish For This Useful Post:
chuckms6 (01-17-2013), Easter Bunny (01-17-2013)
 Old 01-17-2013, 06:42 PM   #14
Cause I don't want to if u need me to so u can follow I will
The Following 5 Users Say NO Thank You to steelknight7d For This Un-useful Post:
 Old 01-17-2013, 06:43 PM   #15
Keko's Avatar
Posts: 1,455   (View Stats)
Groans: 107
Tapatalking
I laughed.. but then I spotted one in the OP Still pretty funny though
2012 MS3
Stratified 91
The Following User Says Thank You to Keko For This Useful Post:
 Old 01-17-2013, 06:44 PM   #16
Raider is mah Homie
Groans: 2,978
No one here gives a shit if your car explodes. However you do if you would like help don't be a whiny bitch and use proper grammar and punctuation. Otherwise we will just make fun of you.
@Tokay444;
I hugged rfinkle2
 Old 01-17-2013, 06:45 PM   #17
Well thankst for finally asking me something no it has not slipped in high gears or any gear and yes the smell is always there also bout the car with 19k so I haven't had it that long
Manny (01-17-2013)
 Old 01-17-2013, 06:49 PM   #18
makjur's Avatar
Posts: 1,313   (View Stats)
When my ms3 was not yet mine (gf baught it and wanted to learn to drive manual after the following events occured we traded in my vduhb gti and got her an automatix)
A week of her trying to learn to drive the car and me crying many times ended up making the car stink like clutch for a month. I thought the smell would never go away.
derpatapped
°(ಠೆಒಠಿ)°
 Old 01-17-2013, 06:50 PM   #19
Vansquish's Avatar
Groans: 1,911
What about the rest of my questions? If you want e-help trying to figure this out, they're important to answer too.
 Old 01-17-2013, 06:52 PM   #20
Look I'm not getting pissy ans I'm not getting mad just want to know waz up cause u guys have had this kind of car longer then I have plus this is the best forum out there I just don't want to spend money on something else if the clutch is bout to go out
Manny (01-17-2013)
 Old 01-17-2013, 06:57 PM   #21
makjur's Avatar
Factory power train warranty for 60k miles
Bring that shit in if your so concerned
Also, learn 2 english
derpatapped
°(ಠೆಒಠಿ)°
The Following 2 Users Say Thank You to makjur For This Useful Post:
2008speed3 (01-17-2013), Easter Bunny (01-17-2013)
 Old 01-17-2013, 07:00 PM   #22
Well I feel the clutch engages high but it drives fine . So idk why that smell is there the revs are normal nothing jumping around and if I put my foot down the car moves no lag I'm not tuned no ap stock tune
Manny (01-17-2013)
 Old 01-17-2013, 07:01 PM   #23
Vansquish's Avatar
Groans: 1,911
My clutch has always engaged "high" as well, but my question wasn't whether it was high, it was whether or not there was any "dead space" at all at the top of the clutch travel.
 Old 01-17-2013, 07:05 PM   #24
Don't know what dead space means.
Manny (01-17-2013)
 Old 01-17-2013, 07:29 PM   #25
Vansquish's Avatar
Groans: 1,911
When you press the clutch, the "dead space" is the bit of clutch travel before you get to the clutch engagement point.
 Old 01-17-2013, 07:37 PM   #26
maxspeed3's Avatar
Posts: 386   (View Stats)
maxspeed3 is the leader of the worldmaxspeed3 is the leader of the worldmaxspeed3 is the leader of the worldmaxspeed3 is the leader of the worldmaxspeed3 is the leader of the worldmaxspeed3 is the leader of the worldmaxspeed3 is the leader of the worldmaxspeed3 is the leader of the worldmaxspeed3 is the leader of the worldmaxspeed3 is the leader of the worldmaxspeed3 is the leader of the world
Do u rest your foot on the clutch pedal while driving? (Cruising) Not pressing it in.....just resting on it instead of the kick plate?
Current ~2013 WRX STI~
2007 Mazdaspeed3 GT Stocked Out and Sold
maxspeed3 is offline   Reply With Quote
The Following User Says Thank You to maxspeed3 For This Useful Post:
 Old 01-17-2013, 07:44 PM   #27
It does feel like it has some space and no I don't rest my foot on the pedal I learned that the hard way
Manny (01-17-2013)
 Old 01-17-2013, 08:28 PM   #28
DuBz's Avatar
Posts: 238   (View Stats)
DuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the worldDuBz is the leader of the world
R u shure yewr not sme11ing brakez?
Sorry just wanted to use your typing style for a sec, but seriously they smell similar......if clutch seems fine, then smell because frozen front caliper?
GenWin Mazdaspeed 3: HTP 3", CP-E RMM: HKS SSQV : masonville knob, JBR SSP, bushings, RSB: COBB AP: STRATIFIED: Saikou Michi OCC: CP-E DP & FMIC: Autotech Internals: Koni FSD's: DO Meth A La WW tank style
DuBz is offline   Reply With Quote
 Old 01-17-2013, 08:39 PM   #29
I was thinking the same thing cause I don't have the under tray on the car.
 Old 01-17-2013, 10:14 PM   #30
DuBz's Avatar
Take it for a drive getting on the brakes a few times then get out and sniff around the wheels, I thought the same thing but my driver's side caliper was seized.....you'll know right away.
 Old 01-18-2013, 08:51 AM   #31
Ok I will do that today I'll post back what I find out thanks .
 Old 01-18-2013, 09:24 AM   #32
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Look dude, nobody else has this problem. This is not some common issue that's related to the car in any way.
I've been in this gig for a long time and the only people who have this problem are people who do not operate the car properly.
I understand you've been driving manual for years, but that doesn't mean shit when you're explaining this type of problem. You may have to succumb to the fact that you're not as good a driver as you fancied.
Happens a lot.
this forum serves 2 purposes
Easter Bunny (01-18-2013)
 Old 01-18-2013, 09:34 AM   #33
ms3rick's Avatar
Posts: 2,959   (View Stats)
Your dad took it out for a joy ride smell will last!
Sold:
2010 MS3 siLver.
Official 60-100mph Times
Official Video battles
Official Youtube Channels
 Old 01-18-2013, 09:40 AM   #34
I understand what you are saying and let me say the clutch is this car is different then the other cars that I have . But it can't be just driving normal this would happen ill check the brakes and check the way I'm letting of the clutch never know probably driver error thanks for the input
 Old 01-18-2013, 10:05 AM   #35
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Zdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the world
Groans: 145
Groaned at 80 Times in 77 Posts
Or maybe you just suck at driving
Sent from a GenPu
2011 MS3"Princess GRU"
GT2876r
AEM Meth Injection, Cobb AP, HTP 3' Intake, KMD interals, Shitty FMIC, JBR 88d RMM, JBR 88d TMM, JBR TIG's x2, JBR BSD, JBR Short THrow Shifter, JBR shifter bushings, Corksport License Plate Bracket, Forge BPV v1, ATP Downpipe, UR Straightpipe Beast Mod, Progress RSB, Koni Yellows, Eibach Pro Kit, Kosei K1-TS Gold 17x8,
E85 FREEKTUNE
Zdraveca is offline   Reply With Quote
 Old 01-18-2013, 11:34 AM   #36
skiptowncat's Avatar
Posts: 1,592   (View Stats)
skiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the world
Groans: 49
Groaned at 34 Times in 25 Posts
Does it do it only after thrashing it?
Are you a woman?
What colour knickers are you wearing?
Tuned with by
K1 Rods//Wiseco Pistons//CX Racing FMIC//JBR Widepath Intake//Custom 3" TBE//Grimmspeed EBCS//Forge BPV//JBR SSP//JBR RSB//JBR Side Mounts//ISC-N! coilovers//JBR BSD and Baffle//Sure TIG Set//Sure R3 RMM//KMD Internals//XS Power Exhaust Manifold//P&P Intake Manifold//Fidanza Flywheel//EM Organic Compound Clutch//GTX3071//DVC30 Meth Kit//3 Gauge Pod.....415WHP....so far!!
Last edited by skiptowncat; 01-18-2013 at 11:34 AM. Reason: MSF Database - Automerged Doublepost
skiptowncat is offline   Reply With Quote
The Following 2 Users Say Thank You to skiptowncat For This Useful Post:
Easter Bunny (01-18-2013), makjur (01-18-2013)
 Old 01-18-2013, 12:17 PM   #37
Like I said normal driving I don't beat on my cars.
 Old 01-18-2013, 12:23 PM   #38
jeopardy98's Avatar
Posts: 1,920   (View Stats)
Groans: 112
That's the fucking problem. These cars are like high class hookers. They want you to pound the shit out of them and then throw money at them. You drive it like a pussy and it's mad at you. That's not clutch you smell it's the snatch juices you keep dripping in the seat.
richkidone likes this.
jeopardy98 is offline   Reply With Quote
The Following 3 Users Say Thank You to jeopardy98 For This Useful Post:
makjur (01-18-2013), MizzyMS3 (01-18-2013), Ryguy (01-18-2013)
 Old 01-18-2013, 01:02 PM   #39
makjur's Avatar
Thank you for contributing to the many reasons I love msf.org
OP... hopefully you learned by now you need a thick skin around here
Im trying to put myself in your shoes for your clutch situation...
Dont let anyone drive your car, unless they have something similar
Wait a week and see if the smell subsides
Take it to the dealer
Learn to drive it or trade it in
derpatapped
°(ಠೆಒಠಿ)°
 Old 01-18-2013, 04:40 PM   #40
Thanks for all the input and for all the smart ass comments lol
Clutch smell eppopipe 2010 MS3 - Engine, Transmission & Driveline 9 04-02-2013 07:37 PM
Burning clutch smell 07blackms3 MazdaSpeed 3 - Engine, Transmission & Driveline 31 07-25-2011 06:32 PM
Time for a Clutch... please help! ESRnjms3 MazdaSpeed 3 - Engine, Transmission & Driveline 14 05-13-2011 05:59 PM
Weird smell, maybe clutch? Hazgasm MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-20-2011 04:32 PM
Clutch install time PDXImportRacer MazdaSpeed 3 - Engine, Transmission & Driveline 22 03-04-2009 06:39 PM
Page generated in 0.56045 seconds with 35 queries
