Smog Check Cobb DP i just got a smog check epic fail with cobb DP !!! the numbers it was producing was like double and some instance were triple of what values i should be in. |
I thought they got rid of the sniffer test in cali ... i guess not |
Well it should have failed visual anyways. Sent via smokey turbo. |
Run 2-3 gallons of e85 - should help with the sniffer test... .. and what is up with that mod list, half of what you have on there makes no sense (ie, the tune you are running with those mods... hypertech or Cobb OTS stage 1, Corksport and Cobb cold air box, etc) and unless I missed it no HPFP internals/pump? |
im running 3 gallons of e85 in my bitch with the cobb dp and it didnt pass the sniffer test. Luckily I still managed to pass though :bigok: |
Good for you that you don't have to worry about a visual but have you performed a compression and leakdown test to confirm the health of your motor? That seems like a lot of miles for the Dixie Cups that Mazda used for pistons on the Gen Ones. Some people on here have passed visual with a catted downpipe or a second cat delete so I don't know what to tell you. Sent via smokey turbo. |
himurax13 i don't know why ur all getting pissed off for if u look closely at my mods like a good amount of them don't do anything much to the engine. so why would the stuff i install damage anything? no i haven't done a compression & leakdown test, and all that does is tell u how good ur rings seal i believe, i think u have to crack the engine open to really determine the health of the engine. but i can tell u i have no smoke coming out of my exhaust, runs strong. Quote:
Out of curiosity, are you at least monitoring fuel pressure regularly? |
You realize you have more than a few flow mods... They might not do much to your engine with an OTS stage 1 tune - but you have almost all of them to include a downpipe... Sent from my iPhone using Tapatalk |
Maybe he is new and dosent realized you should have fuel pump internals for a DP.....oh wait, join date "Apr 2009" And who keeps parts they dont have any more on their mod list? It looks like you have things on the list to just try and make it longer. |
A properly performed compression and leakdown test can reveal the status of your rings, valves, if you have a blown head gasket, and if it is time to rebuild your motor. If you have to crack your engine open, you might as well rebuild. My engine was running strong and had no smoking but it had massive blowby and crank pressure and it took only a few months to finally die. What I am trying to say is that it may be your motor and not your catted downpipe is the reason you are not passing smog. Also, did you let your car cool off before they started the smog test? |
post some wot logs so we can check the pressure. |
blow by u say.. hmm if the gasket or head is bad i should get oil in my fluids but none yet. well can't hurt to do a compression test, i've been wanting to have someone crack the engine open to clean the valves. |
and how are you hitting 1745+ on stock internals on a map that only commands 1669? ... stock internals will not hit 1800 on wot unless you are counting the few cells that spike after you let off the throttle completely. People are just generally puzzled that you have been on this site for so long - have spent a ton of money on suspension and flow mods (which ARE power mods, btw) to include downpipe and an expensive cbe and more than a couple of appearance mods but haven't upgraded your internals yet. It's your car, after all, and you can do what you want with it... although I do question your overall knowledge considering the above comments. |
Dude you have no idea what the fuck you are doing. Try reading a little about your car before modding it? Damn. |
just cause you like modding your car like that don't me i like to mod my car like that. and i don't have a problem modding my car. if you read the post it says SMOG not how do i mod my car. why do people what to give u their 2 cents on how u mod ur car when my post has nothing to do with that. and i am not asking for anyone's help on how to mod my car i am ask for smog check. so if you want to talk about how ur mod kicks more ass then other peoples mods then go to another topic plz. |
It kills me when some people upgrade the suspension and stereo (in this case a downpipe) before they instal HPFP internals. The stock suspension is pretty good. It is even better with a decent RSB. The stock brakes are also very good, but even better with S/S braided lines. In your case, if you keep it, get the Fuel pump internals before getting the intercooler but with the mileage on the car, it might make more sense to stock out, part out, and trade in. |
All I'm saying is you are a dumbass. You installed a DP and only checked the HPFP at 80% throttle when you first got it which was last year. That is pretty stupid. |
LOL @ OP getting butthurt simply becuase we are telling him he needs HPFP to avoid ZZB. Dude gets angry cuz people trying to help him. Oh well. Also...is Cobb DP catted or non-catted? I'm assuming catted, otherwise not sure why OP is surprised it failed. |
if dude wants to blow up his bitch let him. I look forward to a new thread "why did my car blow up?" |
save up 150 to 250 and just pay to pass lol problem solved. Sent from your Anus |
the answer is no you wont i tried a few days ago. |
PROBLEM SOLVED, please close thread. ;) |
there are no legal aftermarket cats as far as CARB is concerned. YOU WILL NOT PASS. EVER. unless you know someone. or the guy just does not care. but if you want to do it "right", then take it off. there is no EO# on an aftermarket cat. it's just that simple. to pass CARB smog test legally (as you say you want to do it), then you can't have an illegal downpipe on. and all aftermarket downpipes are illegal. correct me if i'm wrong, but this is what i have gathered. |
shit some places wont even pass you with an intake let alone downpipe catted or not. This entire thread was stupid. |
The only reason people are giving you advice about HPFP is because you have bigger issues at hand than passing some Emissions test. No point in passing an emissions test just to have your motor blow because you did not have enough fuel pressure. HPFP > emissions. |
| All times are GMT -7. The time now is 06:39 AM. |
