![]() | | #41 | ![]() |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,963
Groans: 47
| Not Ranked : 0 score E85 can help, but the problem is that aftermarket cats only get rid of 2 of the 3 contaminants that the sniffer is looking for. So, even brand new, you may not pass on 1 out of the 3 areas tested. There are corvette guys who claim to have passed the sniffer completely catless with a few gallons of E85, but who knows if that's bullshit or not. You do need to tune for ethanol, but keep in mind that the ECU has the ability to add or pull about 25% fuel, so if you stay within that range with an ethanol mix, you will be fine if you only plan to run one tank. Is that enough help for you? Now go buy some god damn fuel pump internals.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
![]() | | #42 | ![]() |
![]() Join Date: Nov 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score I'm never going to put a DP on my car, simply because of the CARB rules...it's too much pain to swap in and out every two years. Yes, it means I'll never have the fastest Speed around, but I can live with that. If you have a CARB number on an intake they have to pass you...I'm waiting to see if that's actually true with my intake.OP, instead of being upset, you could say "thanks for the advice, I know about it but I'm being careful" instead of being grumpy. That's all people are doing, trying to help you out. The rest of you, it's his car to do with as he pleases...even if you think it's stupid and he'll blow up any day now, you just gotta shrug, because you can't make anyone do what you think they should, even if it's good for them. Oh, almost forgot...do your emissions testing in the morning, there is less crap in the air which means you are pulling cleaner air into the car. The one time I had a bad test with my old car (passed but barely) was when I went in the afternoon, every other time the car was at the bottom of the scale. Also, try to drive there on the freeway, that helps to burn some crud out before testing.
__________________ 2007 Mazdaspeed 6 GT |
| The Following User Says Thank You to keymaster For This Useful Post: | sidekick (03-27-2013) |
![]() | | #43 | ![]() |
![]() Join Date: Apr 2009 Location: Monterey Park, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
Groaned at 8 Times in 7 Posts
will do fuel pump next on list ..
__________________ ///KW V2 Coilovers///AWR F&R///HyperTech-Tune///HKS Intake Black Edtion///Bilstein Sport///Eibach Pro-Kit///CP-E Rear Mount///CP-E Passenger Mount 75///CP-E Driver Mount 75///Act Stage 1 Streetlite///Hawks HPS F&R///Goodridge SS Brake Line///Hotchkis F&R///Corksport Front Endlinks///Turbo Smart Dual Port BOV///SPC Rear Camber Arms///Cobb Short Shifter///Cobb Red Knob///Cobb AP V3. Stg-1+Cobb SF+TIH+91///Cobb Downpipe///Cobb Exhaust///Cobb SF///Corksport Cobb SF Cold Air Box///IVT-22,0.028///Corksprort LED///Sure Turbo Inlet///Silicone Boost Hose///J-Speed SSP///Rally Armor Mud Flaps///JDM Window Visor///IR30 Tint///Yellow Fog Light Overlay///CPE-TowPlate///PTP Baffle Plate///MF Magnetic Tans & Oil Bolt///ProClip,GPS,AP,I5/// | |
![]() | | #44 | ![]() |
![]() | | #45 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
You should fail visual unless you have stock downpipe. You might be able to pass the sniffer with 4 gallons of e85 in your tank but you should drive the car around for 30 minutes and leave it running until after the test is over. Putting the stock downpipe and midpipe back on will pretty much ensure that you will pass and it will probably eliminate the need for hpfp internals for now. Sent via smokey turbo.
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
![]() | | #46 | ![]() |
![]() | | #47 | ![]() |
Groans: 47
| Not Ranked : 0 score It will work. Look at it this way. We know that 85% ethanol requires about 30% more fuel for a given amount of airflow/power. A 4 gallon mix in a MS3 will put you at about 30% ethanol content, so that will require about 9% more fuel than 91. The ECU will have no problem adding 9% fuel via LTFTs and STFTs. I would suggest tuning for it if you plan to run an ethanol mix, but 1 tank should not fuck your couch.
| The Following User Says Thank You to sidekick For This Useful Post: | jseams (03-27-2013) |
![]() | | #48 | ![]() |
Groans: 255
| The Following User Says Thank You to himurax13 For This Useful Post: | jseams (03-27-2013) |
| CA Smog | poisonouschimp | Gen2 MS3 General Discussion | 63 | 02-23-2013 02:03 PM |
| Smog w/ Hi-Flow Cat | razorscs | Mazdaspeed3/6 General Discussion | 1 | 05-15-2012 03:32 PM |
| Check engine light delete with cobb ap? | I gotthatzumzum | Cobb ATR Support | 12 | 07-14-2010 08:46 PM |
