Like Tree2Likes
  • 1 Post By Lex
  • 1 Post By smoogs12
 Old 04-18-2012, 05:37 PM   #1
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
Default Smoogs12's blown boost tube
PROBLEM SOLVED. Was simply a blown boost tube that caused all the problems. I=fail
To summarize for anyone that didn't see that thread:
-08 Speed 3
-33k on odo, 2k ish on bt
-350hp/360tq
-@Lex Tuned
-Boom, couch fucked.
What we know so far:
-Timing chain is very slack
-No oil loss
-Hot side boost coupler on the turbo did pop off. This could account for part or all of the pop noise that I heard (good call @atvfreek)
-car will turn over (at least it did once) but runs pretty shitty.
The plan:
-First take off valve cover and drop oil pan just to get a better understanding of what is wrong
-Talked to @JP@edgeautosport.com and he is putting together a parts list for me. but atm im thinking as follows.
K1 rods
Wiseco pistons (stock bore)
ARP Main/Head Studs
Cometic head gasket
JBR TIGs (why not)
Also might try the toyota fuel seals
-Profit
Hopefully will have pics around Saturday ish or as soon as I can get my friends with the engine hoist to my place.
Thats all for now. I will try to keep the OP updated.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
The Following User Says Thank You to smoogs12 For This Useful Post:
Broxer (04-18-2012)
 Old 04-18-2012, 06:29 PM   #2
What does shitty mean when it's turned on? Bad mechanical noise? Because with that coupler off it will run really rough. I know - crazy - but maybe it's not blown
atvfreek likes this.
atvfreek (04-18-2012)
 Old 04-18-2012, 06:46 PM   #3
smoogs12's Avatar
Groans: 423
I dont recall any terribly harsh engine noises. I could get everything buttoned up and give it another try if you think thats the best thing to do.
Pulled the plugs too and had a look. Seems fairly normal to me. Looking for opinions though as most of you guys would probably know better. Attached pics, cellphone quality but its something.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 04-18-2012, 07:01 PM   #4
atvfreek's Avatar
Posts: 7,787   (View Stats)
Ya with that coupler off, I bet that's what the issue was. I would try reassembling and turning it over. It may take a sec for the car to smooth out, cause it went really rich when it shut off. Possibly set a few codes too.
Reassemble, clear codes and recheck. If there is damage it's already done, so it's worth a shot.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following User Says Thank You to atvfreek For This Useful Post:
Lex (04-18-2012)
 Old 04-18-2012, 07:05 PM   #5
smoogs12's Avatar
Groans: 423
So what do you guys think about the slack in the timing chain? There has to be like an inch of play.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 04-18-2012, 07:18 PM   #6
atvfreek's Avatar
There will be some slack in the chain depending on where the engine stopped. If you turn the motor over by hand (socket on crank pully bolt) does the chain slack go away?
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 04-18-2012, 07:29 PM   #7
smoogs12's Avatar
Groans: 423
i cant belive im saying this...but i think its fine..hooked everything up car turned over and ran! checked chain tension and it was back to normal as well!
I feel like an idiot for not noticing something so simple. But hey, at least im an idiot who is 1k$ richer than he would have been if you guys hadnt helped me out. Damn. Good shit.
@Lex
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
The Following 2 Users Say Thank You to smoogs12 For This Useful Post:
atvfreek (04-18-2012), Lex (04-18-2012)
 Old 04-18-2012, 07:33 PM   #8
TRSpeed's Avatar
Posts: 1,537   (View Stats)
TRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the world
Haha nice!
Sent from my DROID4 using Tapatalk 2
2008.05 True Red Mazdaspeed3
Lex Tuned
GTX3071r | 38mm Tial WG | Hallman MBC
Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod |
Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM |
Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs
TRSpeed is offline   Reply With Quote
The Following User Says Thank You to TRSpeed For This Useful Post:
smoogs12 (04-18-2012)
 Old 04-18-2012, 07:33 PM   #9
atvfreek's Avatar
Glad you got it sorted! That pop you mentioned was what led us there.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 04-18-2012, 07:39 PM   #10
smoogs12's Avatar
Groans: 423
I really cant thank you guys enough. Sometimes you just get caught up in the simplest stuff while fearing the worst.
And Lex now i guess we can ger started on my e85 tune. Ill be sending you money for that very soon
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 04-18-2012, 07:43 PM   #11
Lol, this here is winning Charlie Sheen style! Went from blown motor to shit's running again in a matter of $0! Awesome!
I will now take 50% of that $1k we saved you
J/K - really happy this got sorted out.
atvfreek (04-18-2012), smoogs12 (04-18-2012), TRSpeed (04-18-2012)
 Old 04-18-2012, 07:46 PM   #12
smoogs12's Avatar
Groans: 423
lol. Im really am gonna go throw another donation at the site though. Worth every penny.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 04-18-2012, 07:46 PM   #13
Broxer's Avatar
Posts: 875   (View Stats)
Broxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the world
Groans: 90
GL with the build man. This must be the season to blow motors. Everytime i get on here someone else has a blown motor thread lol. Wonder if I should just get some rods to put in.
2012 Triumph Street Triple
SOLD -- 2010 Velocity Mica Red MS3
ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM
Broxer is offline   Reply With Quote
The Following User Says Thank You to Broxer For This Useful Post:
 Old 04-18-2012, 07:47 PM   #14
Reading fail.
 Old 04-18-2012, 07:49 PM   #15
atvfreek's Avatar
Lol
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 04-18-2012, 07:53 PM   #16
smoogs12's Avatar
Groans: 423
haha
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 04-18-2012, 08:00 PM   #17
Broxer's Avatar
Groans: 90
Reading fail.
lol I just didn't read far enough down.
But srsly though, Bent rod/blown threads have been popping up a lot recently.
The Following 3 Users Say Thank You to Broxer For This Useful Post:
atvfreek (04-18-2012), Lex (04-18-2012), smoogs12 (04-18-2012)
 Old 04-18-2012, 08:23 PM   #18
smoogs12's Avatar
Groans: 423
lol i like the new thread title
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
Broxer (04-19-2012)
Boost Tube Size 07-09 MS3 feldm4n MazdaSpeed 3 - Engine, Transmission & Driveline 15 02-17-2013 10:19 PM
Boost Tube Replacement Airman3454 Gen2 MS3 General Discussion 3 11-11-2011 03:43 PM
How to cap a boost gauge tap on boost tube?? emag remrofni MazdaSpeed 3/6 - Turbo Induction 5 09-04-2011 11:17 AM
Nozzle in boost tube? Bigbody250 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 18 12-13-2009 02:25 PM
Page generated in 0.38535 seconds with 25 queries
