Socket sensor size? I'm just preparing all the tools I need to do the cp-e DP install. I have everything I need except for the socket sensor. What size do I need? Any help would be welcome. Thanks in advance. |
I'm assuming you are talking about the O2 sensor socket? it's a 22mm |
Thanks! Thats what I needed. |
I got my O2 Sensor Wrench at Parts Source, just the socket one, you don't need the offset. Make sure you get some anti-sieze for the bolts too. You'll also need an opened ended wrench to get off some of the DP from the turbo. Don't forget to plug the sensors back in either. He he. |
Thanks for the help guys. |
You read the procedure of screwing the sensor in and out a tiny bit at a time with alot of pb plaster or liquid wrench on it right? You also need a special O2 sensor socket to get to the sensor with the heat shield on it. An open end wrench will not work so hot on the front O2 sensor. |
| All times are GMT -7. The time now is 07:12 AM. |
