 Old 04-29-2012, 04:37 PM   #1
contreras's Avatar
Posts: 72   (View Stats)
contreras has a spectacular aura aboutcontreras has a spectacular aura about
Groaned at 39 Times in 12 Posts
Default Spark plug fail?
Not even 3 months with the new set of densos ITV 22 a enginelight and got to auto zone and its a miss fire on #2. I go home and check it out and a chunk of metal at the tip of the spark plug is melted off. They were gap at .030. Replaced them all with some from auto zone temporary. Do i need to go two step colder. Im hitting 19 psi.
contreras is offline   Reply With Quote
 Old 04-29-2012, 04:44 PM   #2
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
.028 is the gap you need.
What a lovable bunch we are!!
 Old 04-29-2012, 04:49 PM   #3
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
@Darksun280 knows all about losing the spark plug armature.
NATOR PA
 Old 04-29-2012, 05:04 PM   #4
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
Mine was cause first by over boosting and detonating. Once the ring land was damaged it started to wear away. Once oil started to blow passed the rings that cyl was constantly running hot and detonating cause oil lowers the octane in that cyl. Vicious cycle. The Leg is soft enough where I don't think it would cause much damage. the ceramic on the other hand can fuck shit up.
Carry on citizens....
10.7 @ 133 auto 1G DSM
 Old 04-29-2012, 05:12 PM   #5
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
you should be fine on stock heat range plugs with the k04
Blue Pu.
Spark plug gap? blue_train MazdaSpeed 3 - Engine, Transmission & Driveline 7 02-07-2012 11:40 PM
spark plug blackwidow Custom Performance Engineering (cp-e.com) 12 03-07-2011 04:08 PM
best spark plug? soulefx 2010 MS3 - Engine, Transmission & Driveline 12 12-22-2009 10:35 PM
Spark Plug Gap khaydin
Cobb Access Port/Maps
5 12-01-2008 10:17 PM
Spark plug gap Jesse MS3GT MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-16-2008 04:53 PM
Page generated in 0.25688 seconds with 24 queries
