Notices
 Old 07-31-2012, 01:09 PM   #1
CU_Slik's Avatar
Posts: 109   (View Stats)
CU_Slik has disabled reputation
Default Squeaking/Creaking after RMM Install
Hello All,
Recently installed the SURE RMM on my 06 MS6. Feels great and I'm loving the results, but I started noticing that there is some audible squeaking/creaking during weight shifts (accel/decel). It only happens for the first few minutes of driving, after that it goes away.
Could this be due to the RMM? And if so, is it expected? Aka does it just need some time to settle? When I searched I saw a lot of posts that referenced the suspension, but I'm hesitant to think anything changed with that since I didn't touch it.
I tried to get a video of it but it was difficult to hear the sound. Any help/insight is greatly appreciated!
CU_Slik is offline   Reply With Quote
 Old 07-31-2012, 01:12 PM   #2
EdgeAutosport.com's Avatar
Posts: 4,533   (View Stats)
Groaned at 9 Times in 7 Posts
Make sure the bolts are tight and not bound up. Did you torque them to the correct values?
Auto Tech Fuel pump internals #1 Source!
PM Me for Details or call me 303-268-2140
EdgeAutosport.com is online now   Reply With Quote
The Following User Says Thank You to EdgeAutosport.com For This Useful Post:
CU_Slik (07-31-2012)
 Old 07-31-2012, 03:20 PM   #3
CU_Slik's Avatar
I thought I did! Well... I torqued them to 65 after making a judgement call of reading various threads with different numbers. I'll check it again and see if that helps. Thanks!
 Old 07-31-2012, 03:24 PM   #4
All the cpe mounts Ive done here at the shop say 90 ft/lbs. The directions didnt say anything?
 Old 08-01-2012, 05:50 PM   #5
Stealth01's Avatar
Posts: 6,804   (View Stats)
Stealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the world
Groans: 199
Groaned at 163 Times in 102 Posts
Yeah, I think 90 ft lbs is what I read, but I've also seen 70....
Where does the creak come from? Could it be one of the other motor mounts creaking now that the RMM is secure?
Stealth01
2006 Mazdaspeed6 GT
Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose
SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG
Read my stories: https://www.smashwords.com/books/view/55318
Stealth01 is offline   Reply With Quote
The Following User Says Thank You to Stealth01 For This Useful Post:
CU_Slik (08-27-2012)
 Old 08-01-2012, 06:18 PM   #6
emag remrofni's Avatar
Posts: 1,462   (View Stats)
emag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the world
Groans: 179
Groaned at 89 Times in 36 Posts
I think 85 ft lbs is the number from the shop manual IIRC. Generally creaking noises happen when the RMM is loose, so the point is, torque those fuckers down...
// 09 CWP // Cobb SRI // SURE Race RMM // eBay DP // Street Unit Test Pipe // SU BPV // ITV22's // PERM'd // JBR SSP // KMD Internals // VTAK GAUGE // Cobb FMIC V.1 //
Originally Posted by Monotonous ONE View Post
it was a mexican
whoever said they are lazy is a stupid dumb fucking idiot
and they can do ANYTHING...they prolly got the wheels off with a branch and some hedge clippers
Originally Posted by FreeFlyFreak View Post
The dick bone is not connected to the asshole... Mind over matter, learn to control them both.
emag remrofni is offline   Reply With Quote
 Old 08-01-2012, 07:14 PM   #7
kingbird72's Avatar
Posts: 80   (View Stats)
kingbird72 is just really nicekingbird72 is just really nicekingbird72 is just really nicekingbird72 is just really nice
I installed my SURE RMM about a month ago with track urethane, so far no noise or any issues, I tighten it to 85lbs
kingbird72 is offline   Reply With Quote
 Old 08-01-2012, 10:56 PM   #8
Jh8909's Avatar
Posts: 1,017   (View Stats)
Jh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the world
Groans: 106
Groaned at 7 Times in 6 Posts
thats what I was thinking. Check your pmm (passenger motor mount) its probably done.
06 Black Cherry Mica MS6 GT: Cobb AP, Cobb SRI, CP-E TIP, CP-E FMIC
CP-E Tow Plate, JBR RMM, MD OCC, Step Colder Plugs, AT FP Internals, HKS BPV
Ceramic Coated ex. mani & turbo, Ceramic Coated M2 DP, Custom 3" catback, EGR Delete
H&R springs, Morimoto clear projector retrofit, 18x8 TD HS 1.2's
GT3076r/Brand New Motor build coming soon
Jh8909 is offline   Reply With Quote
The Following User Says Thank You to Jh8909 For This Useful Post:
 Old 08-26-2012, 07:14 PM   #9
falcon's Avatar
Posts: 83   (View Stats)
falcon has much to be proud offalcon has much to be proud offalcon has much to be proud offalcon has much to be proud offalcon has much to be proud offalcon has much to be proud offalcon has much to be proud offalcon has much to be proud offalcon has much to be proud of
I am about to put a Sure RMM on, and it does say 65ft\lbs in Sure's instructions. Is that not enough?
CS SRI - Sure RMM - VG Shark Fin - Auto Goody LED Kit - Sure Shortcut - Sure CounterShift -
falcon is online now   Reply With Quote
 Old 08-26-2012, 07:17 PM   #10
Dmurray06's Avatar
Posts: 2,591   (View Stats)
Groans: 122
Groaned at 49 Times in 15 Posts
JBR calls for all being torqued to 60 ft/lbs but that long blot that goes through the tranny bracket. Torque that birc down to 120 ft/lbs. I know this because I had some clunking issues. That bolt was the problem.
2010 Mazdaspeed 3 Black Mica w/ Tech Package
Insalled: Corksport SRI/TIP // Cobb AccessPort// Autotech Internals // Corksport LED Kit // Corksport Stubby Antenna // Forge v2 BPV // JBR SSP// JBR 80a RMM // JBR Weighted Shift Knob // ETS TMIC // Corksport Catless Downpipe // Corksport RacePipe // Denso itv22 // Stratified Guardian Angel // block8head Defrost Pod // Prosport Boost Gauge // Zoom Boom Box
Awaiting Install: HTP 3" TIP // HTP Battery Tray // Sure 3" MAF // Stratified Boost Dial
Dmurray06 is online now   Reply With Quote
 Old 08-27-2012, 10:18 AM   #11
CU_Slik's Avatar
Thanks, yeah I'll check those too.
06 LPM MS6 GT ~ COBB AP (OTS Stage 1) ~ SURE SRI ~ Corksport TIP ~ CPE TMIC ~ Autotech Fuel Pump Internals ~ SU Test Pipe ~ SURE RMM ~ SURE SSP ~ SURE Counterweight ~ NGK Plugs
07 Kawasaki Ninja 650R ~ Yoshimura Exhaust
**Sold** 04 Mazda 6s
Center console squeaking GCL_speeder08 Mazdaspeed3/6 General Discussion 5 06-29-2012 03:31 PM
Front left squeaking like an old taxi... Ski82 MazdaSpeed 3/6 - Suspension & Brakes 0 03-12-2012 04:42 AM
squeaking/creaking noise when cold mrkdspd MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 03-10-2010 11:41 AM
Squeaking noise when going over small bumps dread MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 01-12-2010 03:57 AM
Turboback is squeaking KeysMS3 MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-16-2009 11:19 AM
Page generated in 0.43720 seconds with 27 queries
