squeaky clutch. What to do? Hey all. When i press in my clutch it makes a loud squeak. its not coming from the pedal but actually in the engine bay. there is a red boot near at the end. is there a way to oil this to get rid of the squeak? Thanks. |
I don't have any help for you, but I thought I'd add my squeaky clutch story. Around 30k mine started squeaking, sounds / feels like the PP or throw-out bearing or something. I'm now over 110k and it still squeaks. Stock clutch (lots of highway miles). I figure once it stops squeaking, then I'll really have a problem. |
Grease up the linkage? |
Ya ill see if i can take off that boot and shoot some oil or grease into there. Car has 85k.. |
it's the slave cylinder arm usually. For me, the boot slipped off a little, causing an elbow to dry out. I sprayed it with all sorts of lubricants and grease to clean it, and then slipped the boot back on tight. havent had the squeak since. |
I think I'm having this issue as well. It only seems to be at start up then goes away. The sqeal even increases slightly when I increase rpm to start moving. It's gone shortly after. I'm just confused on if this could be clutch because I hear the noise when clutch peddle is pressed in. Anyone have any ideas? |
I'm starting to have this issue this morning. Nothing wrong with the engagement , the pedal just squeaks under the dash. The last 2-3 miles I didn't hear anymore. I guess something I can deal with as long it's not bad. I just crack 11k miles 2012 speed3. I dealt with this in my 8th gen si, but it was a loud clank noise when pedal goes down. This is just a squeak and I can deal wih it . Wonder if this has a anything dealing with being cold now? It's 40 degrees out here in Philly right now. |
Uhhh yes. Cold can do a number on moving parts like this. Seriously, locate the squeak and lube it up with some grease. This isn't rocket science. |
I installed my AP lastnight and reflashed the CS stage 1 map and took it for a few runs on the highway when i got back as i was backing in it sounded like two pieces of styrofoam rubbing against each other everytime i engaged the clutch but only in gear. i was good this morning as well until i got bored and ran 2/3 pretty hard and i heard it again.. besides the unlubed parts theory anyone have any ideas? |
Turn your radio up:D tappy tap |
Easy to pull undertray. Then you can easily inpect the slave, check for leaks, check clutchline, etc. Rub some high temp grease in contact arm. |
Mine recently started squeaking only when I start from a stand still and shifting, especially if I don't rev match properly. It doesn't squeak when I press it in or let it out. My suspision is the stock RMM but what do you guys think? Car has 54k miles. |
| All times are GMT -7. The time now is 07:27 AM. |
