![]() | | #1 | ![]() |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score Thanks.
__________________ Turbo XS DP // Turbo XS RP // HKS CatBack // Sure RMM // Autotech FPI // Turbo Smart Dual Port BOV Guy on crotch rocket - "Does that car have an STI exhaust?" |
![]() Join Date: Aug 2008 Location: Milwaukee, WI
Rep Power: 90 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
Groaned at 6 Times in 2 Posts
I don't have any help for you, but I thought I'd add my squeaky clutch story. Around 30k mine started squeaking, sounds / feels like the PP or throw-out bearing or something. I'm now over 110k and it still squeaks. Stock clutch (lots of highway miles). I figure once it stops squeaking, then I'll really have a problem. |
![]() Join Date: Jul 2008 Location: Vancouver, BC Canada
Rep Power: 778 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 522
Groaned at 6 Times in 4 Posts
Grease up the linkage?
__________________ 2008 Cosmic Blue Mica Mazdaspeed 3. ETS TMIC, Cobb SRI, Cobb TIP, TWM SS w/Bushings and TypeR knob, Cobb Shift Weight, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb RSB, Autotech HPFP Internals, Denso Iridium ITV-22, Cobb AccessPort, Port and Polished IM, VTCS & EGR Delete, CP-e Safe Seals, SURE TIG IM and TB, JBR Trilogy Mounts 70a Duro, GS EBCS, CP-e Catted Downpipe. Coming Soon: Stratified Tuning Guardian Angel and Lex Tuning. |
![]() | | #4 | ![]() |
Ya ill see if i can take off that boot and shoot some oil or grease into there. Car has 85k..
![]() | | #5 | ![]() |
| thread killer ![]() Join Date: Sep 2009 Location: Oak Pollen Central
Rep Power: 784 ![]() Thanks: 1,896
Groans: 84
it's the slave cylinder arm usually. For me, the boot slipped off a little, causing an elbow to dry out. I sprayed it with all sorts of lubricants and grease to clean it, and then slipped the boot back on tight. havent had the squeak since. |
![]() | | #6 | ![]() |
![]() Join Date: Oct 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
I think I'm having this issue as well. It only seems to be at start up then goes away. The sqeal even increases slightly when I increase rpm to start moving. It's gone shortly after. I'm just confused on if this could be clutch because I hear the noise when clutch peddle is pressed in. Anyone have any ideas?
![]() | | #7 | ![]() |
![]() Join Date: May 2011 Location: Philly Pa
Rep Power: 65 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
I'm starting to have this issue this morning. Nothing wrong with the engagement , the pedal just squeaks under the dash. The last 2-3 miles I didn't hear anymore. I guess something I can deal with as long it's not bad. I just crack 11k miles 2012 speed3. I dealt with this in my 8th gen si, but it was a loud clank noise when pedal goes down. This is just a squeak and I can deal wih it . Wonder if this has a anything dealing with being cold now? It's 40 degrees out here in Philly right now.
__________________ 2012 Mazdaspeed3~~Cobb AP~Corksport SRI+Tip~CNT cbe~JBR Red Spherical Knob~JBR SSP w/bushings~Autotech Internals |
![]() | | #8 | ![]() |
Uhhh yes. Cold can do a number on moving parts like this. Seriously, locate the squeak and lube it up with some grease. This isn't rocket science.
__________________ 2008 Cosmic Blue Mica Mazdaspeed 3. ETS TMIC, Cobb SRI, Cobb TIP, TWM SS w/Bushings and TypeR knob, Cobb Shift Weight, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb RSB, Autotech HPFP Internals, Denso Iridium ITV-22, Cobb AccessPort, Port and Polished IM, VTCS & EGR Delete, CP-e Safe Seals, SURE TIG IM and TB, JBR Trilogy Mounts 70a Duro, GS EBCS, CP-e Catted Downpipe. Coming Soon: Stratified Tuning Guardian Angel and Lex Tuning. | |
![]() | | #9 | ![]() |
![]() Join Date: Nov 2012 Location: Honolulu, HI
Rep Power: 0 ![]() Thanks: 2
I installed my AP lastnight and reflashed the CS stage 1 map and took it for a few runs on the highway when i got back as i was backing in it sounded like two pieces of styrofoam rubbing against each other everytime i engaged the clutch but only in gear. i was good this morning as well until i got bored and ran 2/3 pretty hard and i heard it again.. besides the unlubed parts theory anyone have any ideas?
![]() | | #10 | ![]() |
![]() Join Date: Feb 2012 Location: Westlake, Oh
Rep Power: 35 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
Turn your radio up ![]() tappy tap
__________________ Cobb AP // KMD HPFP Internals // Injen CAI // HTP inlet pipe // CPE Tmic JBR boost tubes // OBX test pipe // Resonator Delete Corksport RMM inserts // E4P Shifter // JBR weight // TS SSP // TWM shifter bushings Crushed 1G DSM bov // Road magnet springs // Rokblokz muflaps // lots of other ricer mods ![]() Richtune in progress |
| Squeaky Clutch | Airman3454 | 2010 MS3 - Engine, Transmission & Driveline | 4 | 08-09-2012 07:15 PM |
| Tight, Loose, & Squeaky....clutch | mczimer | Mazdaspeed3/6 General Discussion | 6 | 05-17-2012 08:54 PM |
| Squeaky squeak!! | skiptowncat | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 23 | 02-15-2012 01:30 PM |
| Squeaky Seat | thebbqbar | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 5 | 06-03-2011 05:23 AM |
| Squeaky brakes | Dino | 2010 MS3 - Suspension & Brakes | 5 | 11-19-2010 08:21 PM |
