-   -   Starting funny? (http://www.mazdaspeedforums.org/forum/f10/starting-funny-175224/)
wonderish 08-08-2014 11:13 AM
Starting funny?
Hi all!
I have a 2007 Mazda 6, 140,000km, in the last 3 weeks or so it has started rough 3 times. It will kinda hesitate to start and then idle rough. I'll give it some gas and it goes away immediately. It seems to happen during short shut off times, last night I ran into the store and then came out 5 mins later...
The first 2 I had a quarter of a tank of gas or less so I thought it was crappy gas, then this time, yesterday, I had almost a full tank of gas.
I have no error codes or warning lights. Car runs fine other than that.
What should I do? Bringing it to the dealership will cost a lot, and any other repairs i've ever had done this car have been up to $1200.
Thank you for your help!!
[R]usty 08-08-2014 11:34 AM
@wonderish;
This is the Mazdaspeed forum and Mazdaspeed3 section but I'll help you out.
Clean MAF sensor, clean throttle body, check intake valves, check spark plugs and plug gap. It's most likely a dirty MAF sensor if you haven't cleaned it before. I've also seen throttle bodies getting stuck on start up because of oil and dirt buildup around the butterfly valve. My girlfirend's 3 had the same thing happening and it ended up being the throttle body from build up. Went away after I cleaned it.
wonderish 08-08-2014 11:43 AM
Originally Posted by rustysurfsa (Post 2671938)
@wonderish;
Sorry, the whole layout of this forum is a bit confusing.
Is there other threats that show how to clean the sensors, check for the other things?
[R]usty 08-08-2014 11:46 AM
Google the stuff I told you to check there's tons of information available. Oh and no need to check the intake valves since you're not driving a speed. Just clean the MAF sensor, clean your thorttle body, change the plugs if needed, check for a clogged air filter.
wonderish 08-08-2014 11:48 AM
I googled, found a step by step site for a Mazda 6 for the MAF thing. I'll get a new air filter tonight, i've had the one in there now for a long, long long time.
Thank you!!
mituc 08-08-2014 01:47 PM
If you don't keep up with the maintenance then when problems arise don't even ask on forums what the problem may be.
wonderish 08-08-2014 01:49 PM
Thanks for making me feel welcome! :)
Raider 08-08-2014 02:09 PM
@mituc;, you are in trouble now!
09Speed3Z 08-08-2014 03:40 PM
3 Attachment(s)
Attachment 169951
Attachment 169952
Attachment 169953
[R]usty 08-08-2014 03:45 PM
What a little vagina...
wonderish 08-08-2014 03:52 PM
Attachment 169955
nilashish 08-08-2014 03:56 PM
nudes??
wonderish 08-08-2014 03:58 PM
Attachment 169956
pzr2874 08-08-2014 05:46 PM
LMFAO.... Raider got a PM from a brownie for a member being "rude"?
Chickadee, you are being treated like a queen..... trust me.
Page generated in 0.17897 seconds with 11 queries
