Like Tree6Likes
 Old 10-25-2014, 03:44 PM   #1
rockshoxtora's Avatar
Posts: 76   (View Stats)
rockshoxtora is a splendid one to beholdrockshoxtora is a splendid one to beholdrockshoxtora is a splendid one to beholdrockshoxtora is a splendid one to beholdrockshoxtora is a splendid one to beholdrockshoxtora is a splendid one to beholdrockshoxtora is a splendid one to behold
Default Stealership WAY Overfilled My Oil
Let me first start off by saying this is the first oil change I have not done myself. For something so crucial to the life of the vehicle, I like knowing it's done right.
That being said, I took my car into Camelback Mazda here in Phoenix 3k miles ago to have the VVT replaced. They did a great job under warranty and filled up my oil after finishing.
This being the first time I haven't done my own oil, the thought didn't occur to me to check the level until today. I've heard my engine make an occasional misfire/clunk type noise under heavy WOT. Only happened a handful of times. First time I thought something got caught up in my wheel well. Well today I checked my oil level being it's around the mid point to the next change.
To my dismay, I found the level way over max. About a few mm below the first crimp on the dip stick.
I'm no stranger to what an overfilled engine can do. I've heard plenty of horror stories.
Long story short, I'm at the dealership now. They are checking and refilling to appropriate height. I'm also demanding a compression test and rod length test. Any other ideas what I should have the dealership do to ensure my engine is in good standing? I'm guessing I also need to obtain some material in writing assuming they fess up to the fault.
The car is I only 73k miles young.
rockshoxtora is offline   Reply With Quote
 Old 10-25-2014, 04:17 PM   #2
They just finished filling it. I checked again and it was even more overfilled than before!!
I'm seriously raged. I grabbed a tech and showed him and he agreed. They are doing it again...
Monday when the service manager is in, we will be talking next steps.
 Old 10-25-2014, 04:27 PM   #3
Here it is before I brought it in. Remember, this reading was on a hot engine that sat for about an hour:
 Old 10-25-2014, 04:35 PM   #4
Darth_Nuruodo's Avatar
Posts: 2,775   (View Stats)
Groans: 88
Damn. Yeah try and get them to admit in writing that they're fucking up. Good luck.
Sent from my SCH-I605 using Tapatalk
Bone stock so far
The Following 2 Users Say Thank You to Darth_Nuruodo For This Useful Post:
Raider (10-27-2014), roguemazda (11-23-2014)
 Old 10-25-2014, 05:04 PM   #5
btstarcher's Avatar
Posts: 4,852   (View Stats)
Groans: 112
Hopefully everything is still fine.....
SnailTune in progress
 Old 10-25-2014, 05:45 PM   #6
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
your faggot ass tech's should know it takes 5.5 qrts MAX if it drips for an hour..... any less time... it'll be overfilled. The pan holds almost 3/4 of a qrt even when left to drip
the way THAT stick is reading, all they are doing is draining some and filling IF they over drained.
The Following User Says Thank You to pzr2874 For This Useful Post:
rockshoxtora (10-27-2014)
 Old 10-25-2014, 05:46 PM   #7
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
I get some free oil change coupons in the mail from my local dealer all the time.
I went in once.
Then they did this exact same thing.
They also used some KIA bulk oil.
Its just best to change it yourself.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 10-25-2014, 06:56 PM   #8
div2's Avatar
Posts: 273   (View Stats)
div2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the worlddiv2 is the leader of the world
Groans: 57
My dealer gives free oil changes for as long as you own the car. I bring my own synthetic and I've never had a problem. And yes, the UOAs indicate that the techs aren't swiping my oil and pouring in some rotgut...
Cosmic Blue Mica 2007 MS3 GT- MSCAI, HT, E-Focus RMM, FSDs, JBR Rear ARB and billet mounts
Hellrot 1995 318ti Club Sport- Turner/Conforti chip, Turner SS clutch line, UUC Motorwerks pedal bushings, clutch stop, and RK II
Desert Sand Pearl 1999 Wrangler Sahara- Banks SS Exhaust manifold, Hella H4 E-Codes, Bilstein HDs
Fireball Orange 1996 Speed Triple 900- Alcon six-pot front calipers, Sebring 3 into 1 "Off Road" exhaust
div2 is offline   Reply With Quote
 Old 10-25-2014, 08:01 PM   #9
Any other things I should demand up front aside from a compression test and rod length test? I feel like those two tests are pretty conclusive of any damage it could have caused.
Thoughts?
 Old 10-25-2014, 08:05 PM   #10
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
Leak down test
I hugged rfinkle2
Raider (10-27-2014), rockshoxtora (10-27-2014)
 Old 10-25-2014, 08:33 PM   #11
Are you suggesting a leak down as opposed to a compression test?
 Old 10-25-2014, 10:01 PM   #12
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Agent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the world
Groans: 665
Groaned at 76 Times in 40 Posts
Make them do all three. Compression, leakdown, and piston height.
Ensure they are performed by someone more competent than the moron that filled the oil. Also make sure it's documented as to why the tests are being performed. So in the event something does happen, liability is clearly demonstrated.
If/when your engine gets a clean bill of health, NEVER take it to that dealership again.
Agent_Orange is offline   Reply With Quote
The Following 5 Users Say Thank You to Agent_Orange For This Useful Post:
calizoomzoom (10-26-2014), chaser27 (10-27-2014), JgamB (11-25-2014), Raider (10-27-2014), rockshoxtora (10-27-2014)
 Old 10-27-2014, 01:26 PM   #13
Service rep just called and said they are going to get in touch with Mazda before making a decision and then let me know. They want to determine "safe margins" for overfill which is bullshit. They are going to try and find some way to weasel out by claiming their overfill fell within the "safe" margin.
I'll be fighting this one tooth and nail. I'm not going to be satisfied unless I have an engine diagnostic ran.
 Old 10-27-2014, 02:13 PM   #14
LatinKraze's Avatar
Posts: 804   (View Stats)
LatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the worldLatinKraze is the leader of the world
Safe margin is the Max/Min on the dip stick. Fuck them
2007 MS3: BNRs3 PPT Tuned 350hp/360tq Stocked out and SOLD
2016 CX-5 GT AWD
LatinKraze is offline   Reply With Quote
The Following 3 Users Say Thank You to LatinKraze For This Useful Post:
mr.speedy3 (10-27-2014), Raider (10-27-2014), rockshoxtora (10-27-2014)
 Old 10-27-2014, 02:20 PM   #15
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
How hard is to put in exactly 6 quarts or 5.7l of oil in an engine? Are they retarded? The engine may be fine with 5.8-5.85l of oil in it, as well as with only 5 (at this point it's at the minimum on the dipstick) if all you want is to get your kids to the school and back. But not ok even by far in a performance car driven accordingly. If there's any damage found to your engine get it replaced under warranty.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
The Following 2 Users Say Thank You to mituc For This Useful Post:
rfinkle2 (11-22-2014), rockshoxtora (10-27-2014)
 Old 10-27-2014, 02:38 PM   #16
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
mr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the world
Which Mazda is this (the one on the 51 and camelback)? What part of AZ are you in? Nator out here is very active, we can always help diagnose the issue if Mazda is giving you the run around. Make sure to be present during the compression/leak down/rod height test. I'd want picture of all the numbers they come up with.
Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet!
mr.speedy3 is offline   Reply With Quote
The Following 2 Users Say Thank You to mr.speedy3 For This Useful Post:
Easter Bunny (10-27-2014), rockshoxtora (10-27-2014)
 Old 10-27-2014, 03:03 PM   #17
Correct! I live in North Valley (Scottsdale and Shea). Camelback Mazda was said to be "mod friendly" which is why I took the Speed there for warranty work.
I'm going to shoot you a PM. Glad to know there's such awesome support behind these cars. Almost feels like a union but less gay.
 Old 10-27-2014, 03:21 PM   #18
mr.speedy3's Avatar
Who said they're mod friendly? I know 2 mod friendly dealers, and only trust 1 lol.
The Following User Says Thank You to mr.speedy3 For This Useful Post:
mxlplx71 (10-28-2014)
 Old 10-27-2014, 03:31 PM   #19
Yatta's Avatar
Posts: 1,862   (View Stats)
If you have catalysts on the car this can royally f them as well, as others have said, get it in writing, you might even insist they clean your damned valves, check your turbo, intercooler etc.. anything that has PCV flow to it might be coated in OIL (more so than usual); some people have given me crap for this but I use a vacuum draw through the oil/dipstick tube, I know exactly how much comes out and exactly how much should go in each time. take/scan copies of your service documents for these ‘visits’ as the originals can fade but twice in a row? never go there again.
 Old 10-27-2014, 03:42 PM   #20
Google
 Old 10-27-2014, 03:54 PM   #21
Turbo_Steve's Avatar
Posts: 944   (View Stats)
Turbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the worldTurbo_Steve is the leader of the world
Google
mr.speedy3 likes this.
The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS
Soon to come.
WHO KNOWS? A.D.D. FTW!
Turbo_Steve is offline   Reply With Quote
The Following 2 Users Say Thank You to Turbo_Steve For This Useful Post:
mxlplx71 (10-28-2014), pzr2874 (10-27-2014)
 Old 10-28-2014, 05:19 PM   #22
Camelback Mazda refused to budge. The rep claimed that MazdaUSA says ".5 quarts above max will not damage the engine."
I said that would be great in the case that my car was only overfilled .5 quarts. The evidence suggests it was probably overfilled 1-2 quarts.
Still refused to budge. I will be contacting MazdaUSA to escalate the case. I'm getting my damn tests, a new engine, or both - whatever Mazda would prefer to accommodate me with due to their incompetence.
 Old 10-28-2014, 05:37 PM   #23
DaUberSchwebel's Avatar
Posts: 233   (View Stats)
DaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the worldDaUberSchwebel is the leader of the world
Groans: 28
Sorry to say MazdaUSA won't do shit. The dealership didn't put my fucking oil cap on all the way, after one of my "free" oil changes. Pulled up in my driveway and my car smelled horrible. Shut it off before it got to the point of smoking. Oil was all over the passenger side engine bay and on my hood.
Luckily it was less than a quart lost, it must have just fell off after going up my driveway. Needless to say I was pissed. The dealership basically said prove it, and gave me the "well what do you want me to do" attitude. I should have called my roadside assistance and had the car towed thinking back. Instead I drained the horse piss oil and replaced it with Rotella t6 and cleaned the shit out of the engine bay. MazdaUSA sent me some fucking coupons and a half-ass sorry letter.
My advice is to leave a negative review about the service on yelp...etc. And steer your friends/family away from there. "Free" oil changes, you really get what you pay for. I also should have known better since the dealership has such a shitty rating, unfortunately they were the only speed dealer within 100 miles.
2013 VRM with Cobb AP V3/ CS SRI/TIP/SS/TP/ CP-E RMM CP-E TMIC Autotechs JBR TIG/IMG/EGR delete Stratified OTS tune
DaUberSchwebel is offline   Reply With Quote
 Old 10-28-2014, 06:27 PM   #24
Raider is mah Homie
Groans: 2,978
the rule is that no matter where you go or what the work performed was you inspect it before you leave.
kilo101 likes this.
I hugged rfinkle2
DaUberSchwebel (10-28-2014)
 Old 10-28-2014, 07:21 PM   #25
As I've learned! And never trust somebody else to do your oil change.
Looking over the itemized parts from the VVT warranty work, they charged me for 6 qts worth of oil and did not replace the filter. According to the manual, that would put me .4 quarts over full. Mazda also claims a full engine is 6.0 quarts when in all reality we know it's closer to 5.5. So let's say that puts me at .9 quarts over full.
It's reasonable to believe they probably overfilled by at least a quart with that evidence. Assuming you never fully drain all your engine oil. Plus the dip stick readings are pretty high. I'm still going to push forward with my case. At least I have evidence they overfilled it, just not to the amount my picture claims.
BUT according to the manual, any amount over or under max/min is too much and can cause engine damage. So theoretically, that .4 qts could cause engine damage according to Mazda.
 Old 10-28-2014, 07:24 PM   #26
doctavus's Avatar
Posts: 1,728   (View Stats)
doctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the worlddoctavus is the leader of the world
Groaned at 29 Times in 23 Posts
If you HAVE to take it somewhere, make sure you bring your own oil and filter and watch them.
I have had a few issues with shops and don't trust a single one. It's a shitty way of living life but hey.
doctavus is offline   Reply With Quote
 Old 10-28-2014, 08:17 PM   #27
Raider is mah Homie
Groans: 2,978
Don't know if you are Juan or PU but my 2010 takes 6.0 with a filter change.
I hugged rfinkle2
 Old 10-28-2014, 09:18 PM   #28
Yatta's Avatar
6.0 here as well (2012) I fill my filter before putting in on but its nearly always 6 when it is all said and done.
 Old 10-28-2014, 10:19 PM   #29
doctavus's Avatar
I just changed mine on Sunday. Took about 5.5 Quarts and I let the pan drip for several minutes, car sat for about 1 1/2 hours before change. Car was not level obviously as it was on ramps.
2012.
 Old 10-29-2014, 04:41 AM   #30
btstarcher's Avatar
Groans: 112
Honestly, that only looks like maybe a quart overfilled to me. Just playing devil's advocate. Next time I change my oil (probably this week sometime) I'll fill it and add incrementally until my level is similar.
Easter Bunny (10-29-2014)
 Old 10-29-2014, 08:42 AM   #31
Awesome! I hope your right. My fills always take 5.5 on the dot. Genjuan.
I wonder if a quart overfilled could still cause misfires? I cleaned out my intake a few nights ago and their was some oil build up but not much. The sounds I heard under load are what worries me. Unfortunately I can't recreate (but of a mixed blessing).
The car noticeably ran different (in a good way) after removing the extra oil.
 Old 10-29-2014, 11:28 AM   #32
btstarcher's Avatar
Groans: 112
I had a friend overfill her (LOL) Maxima; her car wouldn't even run. It was a little low so she added a few quarts. It was about 4 inches past the full mark on the dipstick. I've checked my oil before and it was barely registering, like just a drop; it only took 2 quarts to get it to the full mark. That was when it was using a quart every 200 miles.
 Old 10-29-2014, 01:47 PM   #33
Just got off the phone with Todd (Manager over at Camelback Mazda).
Real nice guy who took some more time to explain to me what they are going to do.
They wrote up an RO (Repair Order) stating the dealership overfilled the oil which caused no noticeable damage to engine at the time.
In the event something were to rise in the future due to the dealership's negligence, they will cover any repairs assuming the culprit was the engine oil. Now I find it hard to believe they would ever be able to pinpoint engine nuking to an overfill that occurred in the past.
At least I have acknowledgement in writing on a legally bound document stating they fucked up my oil levels. Better than nothing I suppose.
I'm going to pull my plugs this weekend and maybe do a Seafoam treatment.
I'll probably pursue my own compression test just to give me peace of mind.
The Following 2 Users Say Thank You to rockshoxtora For This Useful Post:
btstarcher (10-29-2014), Easter Bunny (10-29-2014)
 Old 10-29-2014, 02:33 PM   #34
mr.speedy3's Avatar
Skip the seafoam, lets get them nasty ass valves cleaned instead. With all the issues I've had recently, I can remove the intake manifold in 20 minutes lol.
 Old 10-29-2014, 02:59 PM   #35
Need to find someone with a sand blaster! I'm scared to see what my valves look like...
 Old 10-29-2014, 06:11 PM   #36
mr.speedy3's Avatar
They will look terrible. There is only one car i've seen that does not run meth with clean valves... and he ran Lucas fuel injector cleaner through his car since its conception at each fill up. Almost blew my mind.
We have a sand blaster in Nator AZ, we even had a valve cleaning party a few months back.
 Old 11-20-2014, 05:09 PM   #37
mr.speedy3's Avatar
Update?
tapatalkin
 Old 11-22-2014, 11:25 AM   #38
fasteddie128's Avatar
Posts: 348   (View Stats)
fasteddie128 is the leader of the worldfasteddie128 is the leader of the worldfasteddie128 is the leader of the worldfasteddie128 is the leader of the worldfasteddie128 is the leader of the worldfasteddie128 is the leader of the worldfasteddie128 is the leader of the worldfasteddie128 is the leader of the worldfasteddie128 is the leader of the worldfasteddie128 is the leader of the worldfasteddie128 is the leader of the world
I am also interested in a update. I took my car in for my free change on friday and after checking it mine to was overfilled by the same margin. Level on the dipstick looks the same as yours. I am thinking I will jack it up this weekend and drain a little but I am curious how much over you were.
fasteddie128 is offline   Reply With Quote
 Old 11-22-2014, 11:36 AM   #39
mituc's Avatar
Groans: 111
Check the dipstick on both sides. It's usually the motor side of the dipstick that shows the correct level for oil.
Also make sure the car was used for at least 15 minutes and then was stopped for 10-15 minutes before checking the oil.
 Old 11-22-2014, 11:46 AM   #40
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
HawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the world
@LynzeC; had this happen...and they used 0w-20 oil. Never trust these idiots.
Silver 2007 Speed3 GT
Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power.
Titanium Grey Mazdaspeed6 GTX3071, DD
HawkeyeGeoff is offline   Reply With Quote
Overfilled oil from fuel dillution?? blkspd3 Mazdaspeed3/6 General Discussion 4 12-29-2013 01:46 AM
Could my transmission be overfilled from the factory? J.Dy 2010 MS3 - Engine, Transmission & Driveline 1 10-21-2012 06:16 AM
overfilled oil snOhio Gen2 MS3 General Discussion 20 10-10-2011 06:15 PM
somewhere besides the stealership.. JAGspeed6 Mazdaspeed3/6 General Discussion 9 08-04-2011 11:09 AM
Page generated in 0.55057 seconds with 37 queries
