Like Tree6Likes
 Old 11-22-2014, 11:50 AM   #41
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
This is exactly why I changed the oil in our cx5 myself this week.
At 9:00 at night
After working all day
In the dark
While it was 35 degrees outside
On a gravel driveway
It was less work than making sure they didn't fuck it up. Though it takes 0-w20 so at least they couldn't have put something too thin in.
mr.speedy3 and fasteddie128 like this.
I hugged rfinkle2
The Following 4 Users Say Thank You to Easter Bunny For This Useful Post:
HawkeyeGeoff (11-22-2014), Nliiitend1 (11-26-2014), predapio (11-23-2014), pzr2874 (11-22-2014)
 Old 11-22-2014, 12:02 PM   #42
I Sparkle
LynzeC's Avatar
Posts: 3,216   (View Stats)
LynzeC is the leader of the worldLynzeC is the leader of the worldLynzeC is the leader of the worldLynzeC is the leader of the worldLynzeC is the leader of the worldLynzeC is the leader of the worldLynzeC is the leader of the worldLynzeC is the leader of the worldLynzeC is the leader of the worldLynzeC is the leader of the worldLynzeC is the leader of the world
Originally Posted by HawkeyeGeoff View Post
@LynzeC; had this happen...and they used 0w-20 oil. Never trust these idiots.
They not only overfilled it, they didn't drain the old oil first. Tear them a new asshole and have them flatbed tow your car in and watch them fix it.
And then, never go back. Ever. Again. To them or any other dealer.
It was also 5w 30.
Now I'm all fired up at Comic Con... Damn you, Geoff!
rfinkle2 and HawkeyeGeoff like this.
2012 Black Mica Mazdaspeed3 ~ NATOR BUILT ~ Hypnotic Tuned
* GTX3076R * COBB AccessPORT * HTP * CP-e TMIC * CP-e Exhaust Manifold * Autotech Internals * Forge V2 BOV * Speed Daddy Down Pipe *
* COBB Cat Back Exhaust * Saikou Michi OCC * Edge EGR Blockoff Plate * Corksport Lowering Springs * JBR 88 Duro RMM *
* JBR 80 Duro TMM * JBR 70 Duro PMM * Whiteline RSB * DamondMotorSports Short Shifter Plate * JBR Shifter Weight *
* Maisonvi Turbo Bolt * Custom Maisonvi/terMINATOR Shifter Knob You Are Jealous Of * Hawkeye Boost Gauge * Britz Couplers *
* NGK Plugs * Rally Armor Mud Flaps * Corksport Rear Bumper LED's *
Mommy Wagon:
2013 CX-9 Touring
LynzeC is offline   Reply With Quote
The Following 2 Users Say Thank You to LynzeC For This Useful Post:
Easter Bunny (11-23-2014), rfinkle2 (11-22-2014)
 Old 11-22-2014, 02:16 PM   #43
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Originally Posted by mituc View Post
How hard is to put in exactly 6 quarts or 5.7l of oil in an engine? Are they retarded? The engine may be fine with 5.8-5.85l of oil in it, as well as with only 5 (at this point it's at the minimum on the dipstick) if all you want is to get your kids to the school and back. But not ok even by far in a performance car driven accordingly. If there's any damage found to your engine get it replaced under warranty.
You'd be surprised how many times I see this.
The ms3 with a spin on comes from the factory with an n/a mazda 6 filter... I would imagine they use fill specs for the larger capacity filter.
That is my only semi-logical guess @ how they fuck this up over and over.
 Old 11-22-2014, 02:18 PM   #44
I Sparkle
LynzeC's Avatar
@rfinkle2; - Remember talking me off the ledge?
Mommy Wagon:
2013 CX-9 Touring
 Old 11-22-2014, 02:39 PM   #45
cletusb's Avatar
Posts: 488   (View Stats)
cletusb is the leader of the worldcletusb is the leader of the worldcletusb is the leader of the worldcletusb is the leader of the worldcletusb is the leader of the worldcletusb is the leader of the worldcletusb is the leader of the worldcletusb is the leader of the worldcletusb is the leader of the worldcletusb is the leader of the worldcletusb is the leader of the world
Could be worse, my dad's cx7 blew up because they drained and forgot to refill his oil.
Unfortunately he was getting a service the day he left on a road trip
cletusb is offline   Reply With Quote
 Old 11-23-2014, 07:42 AM   #46
fasteddie128's Avatar
Posts: 348   (View Stats)
fasteddie128 is the leader of the worldfasteddie128 is the leader of the worldfasteddie128 is the leader of the worldfasteddie128 is the leader of the worldfasteddie128 is the leader of the worldfasteddie128 is the leader of the worldfasteddie128 is the leader of the worldfasteddie128 is the leader of the worldfasteddie128 is the leader of the worldfasteddie128 is the leader of the worldfasteddie128 is the leader of the world
Quick update. Vehicle was cold when I checked it before. Checked again and it was still overfilled by the same margin as the OP. I ended up using a long hose and siphoned some oil out from where the dipstick goes. I removed a little less than a cup of oil and the dipstick now reads right at the full mark.
So if your oil is coming up to the bends on the dipstick you have almost a cup of extra oil. (roughly)
08 Speed 3 GT, Cosmic Blue
Installed - BNR s3, 3 BAR MAP, Cobb 3 Port EBCS, HTP 3" Intake, CS TMIC, CNT Catback Exhaust, Manzo TP, CS and JBR Hoses, TRZ RMM, Autotech HPFP Internals, Forge v1 BPV, Cobb AP v2, Nitto NT555 225/40/18 Tires, Block8Head Gauge Pod, Corksport Steering Wheel, NGK 6510, Step Colder Plugs, JBR Short Shifter, JBR Shift Bushings, Rallyarmor Flaps, Corn Tuned by Freek
Installing Next - EBC Yellow Stuff Pads, JBR VTA OCC
Next to Buy - Suspension stuff, Brake lines and Rotors, Relentless Manifold
fasteddie128 is offline   Reply With Quote
 Old 11-23-2014, 08:04 AM   #47
ALPINEST4RS's Avatar
Posts: 905   (View Stats)
ALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the worldALPINEST4RS is the leader of the world
Groaned at 8 Times in 3 Posts
I just skimmed this thread. In Mazda's book it states every disi takes 6.0 quarts regardless of model/year. Which is a guideline to check it after you fill it. Every car is different and none is the same.
6 quarts overfills my motor too. I usually run 5.7 quarts. That's safe for me.
OP don't sweat it. I've ran into my techs overfilling skyactiv' like it's nobody's business. I've actually ran tests with our reels at work too. The sky 2.5 takes 4.8 quarts. Our reels will vary from car to car with the same motor.
The dealership is in the wrong here. I check all oil levels after a oil change. People have became so lazy it irks me. How hard is it really ya know?
By the way, Mazda is lying to you. Overfilling a engine will damage it overtime. We all know that. My car was overfilled when I baught it. I immediately changed the oil. It did not damage the vehicle in any way so you are safe.
My suggestion is to DIY. Nobody cares but you and you only.
2011 MS3 COBB AP/Hypnotic Tuned/JBR 3.5in WP/CS Wiper Delete/EBAY DP/CS RMM/CS Lowering springs/Maisonvi shift bushings and knob/OBX Catback/AT Internals/Synapse DV/ CP-E TMIC/E30
ALPINEST4RS is offline   Reply With Quote
 Old 11-23-2014, 11:14 AM   #48
roguemazda's Avatar
Posts: 159   (View Stats)
roguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud ofroguemazda has much to be proud of
I had exactly the same thing but lucky enuff checked the oil level and made them change it to the correct level fucktards
roguemazda is offline   Reply With Quote
 Old 11-25-2014, 10:43 PM   #49
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Well, in this regard all cars are identical: they need 6 quarts/5.7 liters of oil when filling them with a new oil filter (which should be changed at every oil change anyway) and if you still have the balance shaft.
The only thing that may differ is how even is the car when you dump the oil and how much of it remains in the engine/sump.
Also keep in mind that the dipstick is a bit shorter and when the engine has the right (and maximum) amount of oil you may see the oil level 2-3mm above the max hole.
5.7 quarts instead of 6 is perfectly fine though and the engine will feel no difference in running with 5.7 versus 6.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 11-25-2014, 11:39 PM   #50
JgamB's Avatar
Posts: 2,566   (View Stats)
Some people don't want to spend $35 on a drain plug valve, but I think the http://www.qwikvalve.com/fumoto-f106sw-valve.html is well worth it. If you overfill, you can simply crack the valve open and drain a bit.
@nindoja; bought a "blown motor" speed6 that we drained no less than 10 quarts out of, with probably another quart inside the TB/IM/gunked in the head. It looked like an obvious double fill fubar, and the drain plug was rounded off. Once we drained the oil and replaced the .052 gapped plugs, the car fired right up.
 Old 11-26-2014, 10:04 AM   #51
rockshoxtora's Avatar
Posts: 76   (View Stats)
rockshoxtora is a splendid one to beholdrockshoxtora is a splendid one to beholdrockshoxtora is a splendid one to beholdrockshoxtora is a splendid one to beholdrockshoxtora is a splendid one to beholdrockshoxtora is a splendid one to beholdrockshoxtora is a splendid one to behold
I'm diggin' all the activity! Thanks for the contributions everyone.
The car seems to working fine since I've had the dealership top it off to the right levels.
I plan to pull the plugs and seafoam this weekend. I think the plugs may be gunked up a little. I say this not because I have regular symptoms, but because I did find oil in the intake behind the PCV hose (I think that's the right hose).
As aforementioned, I did experience what I believe to have been some ignition issues.
Anything else I should try cleaning while I'm in there?
And I apologize I haven't done this sooner. Some dick hit my rear driver door in the parking lot of my office. I've been dealing with insurance and repair shops lately...
rockshoxtora is offline   Reply With Quote
 Old 11-26-2014, 10:17 AM   #52
I let the car sit overnight and it still took 5.7 quarts. including filter. I only put the plug back in when its dripping and there is no oil stream. On a hoist, at work.
If I put 6 exact quarts in like the ms3 document states. its overfilled above the max line.
The proper way to check oil is to let it sit too. It will usually rise after you let the oil drain into the pan.
I check mine immediately after shutting the car off and its overfilled above max. 5.7quarts takes care of that and if i let the car sit with 5.7quarts in it and drain for 10min its above max.. still
The Following 2 Users Say Thank You to ALPINEST4RS For This Useful Post:
Nliiitend1 (11-26-2014), pzr2874 (11-26-2014)
 Old 11-26-2014, 03:07 PM   #53
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
I've been filling at 5.25-5.4 quarts for 5 years. Pull an oil pan and all their infinite glory.... There is still a quart left behind after a night sitting to drain. Not questioning your ability.... just sayin is all
 Old 11-26-2014, 04:08 PM   #54
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
mr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the worldmr.speedy3 is the leader of the world
Man, I use about 7.5qts... race car problems.
Join AZ Nator already!
Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet!
mr.speedy3 is offline   Reply With Quote
The Following User Says Thank You to mr.speedy3 For This Useful Post:
Easter Bunny (11-27-2014)
 Old 11-26-2014, 10:54 PM   #55
mituc's Avatar
Groans: 111
If you put the car on jack stands you need to lift the front a bit higher.
 Old 11-28-2014, 08:06 AM   #56
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
...even with my car on ramps and draining overnight, it won't take a full 6 quarts.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
ALPINEST4RS (11-28-2014)
 Old 01-12-2015, 08:21 PM   #57
Here's what the plugs looked like!
Pretty mucked up. Cleaned 'em (made sure to avoid the iridium tip) and regapped .030 for good measure (they were all already gapped right around there from teh factory).
Car seems to be running fine now. No issues since I've done this.
Lesson learned. Do your own damn oil changes...
 Old 01-12-2015, 08:35 PM   #58
Police - Grammarhead
Vansquish's Avatar
Groans: 1,911
The plugs should be gapped at 0.024"-0.027", per Mazda's updated specs for the MZR DISI.
Edit: fixed gap specs.
 Old 01-12-2015, 08:36 PM   #59
The plugs should be gapped at 0.025"-0.028", per Mazda's updated specs for the MZR DISI.
Source?? Could this explain my hard shift/WOT hesitation?
 Old 01-12-2015, 08:44 PM   #60
Vansquish's Avatar
Groans: 1,911
I was actually going from memory. The correct specs for the engine are 0.024"-0.027."
2010 Mazda CX-7 | Owner's Manual - Page 498
It's hard to say if it's the cause of any problems without data logs to show what's happening.
Overfilled oil from fuel dillution?? blkspd3 Mazdaspeed3/6 General Discussion 4 12-29-2013 01:46 AM
Could my transmission be overfilled from the factory? J.Dy 2010 MS3 - Engine, Transmission & Driveline 1 10-21-2012 06:16 AM
overfilled oil snOhio Gen2 MS3 General Discussion 20 10-10-2011 06:15 PM
somewhere besides the stealership.. JAGspeed6 Mazdaspeed3/6 General Discussion 9 08-04-2011 11:09 AM
Page generated in 0.42259 seconds with 34 queries
