![]() | | #1 | ![]() |
![]() Join Date: Nov 2009
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score I took it into Mazda the first chance I could, but they said that they wouldn't do anything unless they could duplicate the problem. It had cooled off by then and with it being so intermittent in the first place i was unable to make it happen on the drive with the tech so they didn't do anything. The car is bone stock, oil has always been changed by the dealer and it has only ever seen 91 octane gas. Any ideas? |
![]() Join Date: Mar 2008 Location: orange county
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,807
Groans: 137
| Not Ranked : 0 score a lot have experienced this. try not to put load on the car under 3k. people have stretched the ignition coils and had positive results from it (http://forum.mazda6club.com/index.php?showtopic=90286) as for now downshift and roll easier onto the throttle. or this one How To: Spark Plug Replacement - Mazda6 / Atenza
__________________ 2008 STi Intake Turboback AP Last edited by danesti; 11-07-2009 at 07:44 PM. Reason: MSF Database - Automerged Doublepost |
(Thread Starter) | Not Ranked : 0 score How is poor ignition causing detonation? It seems sort of weird for this to be common, if everyone's car does this below 3k there should be a lot of failures eventually. |
![]() | | #4 | ![]() |
![]() Join Date: Nov 2008 Location: Alexandria, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 413
Groans: 40
| Not Ranked : 0 score Stretching out the coils in your coil packs helps it have more solid contact when it lights, thus helping you reduce cylinder misfire.
__________________ CP-E SRI / Forge BPV / Corksport TP / Corksport CBE |
![]() | | #5 | ![]() |
![]() Join Date: Jul 2009 Location: Vancouver, BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score really, this car likes alot higher than 91 octane fuel, to be honest, especially when it gets hot. it's alot of static compression and boost. |
![]() | | #6 | ![]() |
(Thread Starter) | Not Ranked : 0 score It's not missfire, it's knock for sure. And I can't get anything higher than 91 in CA,.. |
![]() | | #7 | ![]() |
![]() Join Date: Aug 2009
Rep Power: 0 ![]() ![]() ![]() Thanks: 23
| Not Ranked : 0 score Welcome to the club. This is one of the problems mazda has yet to fix. And the worst part is, it's probably connected to the part throttle zoom zoom boom issue IMO....
__________________ 2006 Mazdaspeed6 33k miles - stock |
| weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this? | labikesrcool | MazdaSpeed 3/6 - Wheels & Tires | 21 | 11-30-2015 03:32 PM |
