![]() | | #1 | ![]() |
![]() Join Date: May 2010 Location: Homestead, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,375
Groans: 112
(Thread Starter) | Not Ranked : 0 score Stock pistons with any upgraded rods...? Appearently K1 rods dont fit stock pistons (without machining) and I called Eagle and they said "Im not sure if they fit" So im just seeing if I can get any evidence of any aftermarket rod that fits with our stock pistons....
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost |
| Not Ranked : 0 score Call Carrillo - they have this option.
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
Groans: 112
(Thread Starter) | Not Ranked : 0 score Arent they like $1100? i could probably get aftermarket rods and pistons for that money.
![]() | | #4 | ![]() |
![]() Join Date: Dec 2008 Location: Tampa FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 984
Groans: 47
Groaned at 25 Times in 19 Posts
| Not Ranked : 0 score PM Stefan at eagle motorsports. tech/sale@EM he should have the information you are looking for.
__________________ From built & Big turbo to Miata Gheys |
![]() | | #5 | ![]() |
![]() Join Date: Sep 2008 Location: Toronto, Ontario, Canada
Rep Power: 2202 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,767
| Not Ranked : 0 score Carrillo A Beams are in the high $900s, low $1000s. H beams are about $300 more.
__________________ '07 CWP MS3 Forged. |
| The Following User Says Thank You to BlueStreak For This Useful Post: | PapaSmurf (12-01-2011) |
![]() | | #6 | ![]() |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
Groans: 24
Expensive, but worth it if you want to build for the future IMHO.
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() | |
| The Following User Says Thank You to Alpha For This Useful Post: | BlueStreak (12-01-2011) |
![]() | | #7 | ![]() |
| Must Have Teh 10's! ![]() ![]() Join Date: Mar 2008 Location: Columbia, MD
Rep Power: 10779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,334
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner |
![]() | | #8 | ![]() |
| Not Ranked : 0 score The machining on the Carrillo rods is worth it. This is a game of tolerances and good components imo are well worth it.
| The Following User Says Thank You to Lex For This Useful Post: | Alpha (12-01-2011) |
![]() | | #9 | ![]() |
![]() Join Date: Mar 2010 Location: Colorado Springs, CO, USA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,160
Groans: 201
Groaned at 164 Times in 103 Posts
| Not Ranked : 0 score Don't the Pauter rods work with stock pistons?
__________________ Stealth01 2006 Mazdaspeed6 GT Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG Read my stories: https://www.smashwords.com/books/view/55318 |
![]() | | #10 | ![]() |
Groans: 47
| Not Ranked : 0 score I think you can special order them, I know protege garage stocked them a while back but that company is pretty much dead.
![]() | | #11 | ![]() |
Rep Power: 7491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
| Not Ranked : 0 score I thought k1, pauter, and carrillo all made stock pin rods.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG |
| The Following User Says Thank You to 06Speed6 For This Useful Post: | superskaterxes (12-02-2011) |
![]() | | #12 | ![]() |
![]() Join Date: Jul 2008 Location: Tucson, AZ
Rep Power: 740 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 517
Groaned at 6 Times in 6 Posts
| Not Ranked : 0 score HI have the k1 rods and stock pistons on my car. Technically yes they do fit, however, the connecting rod where the wrist pin goes through is squared off, whereas the stock piston has a triangulated/tapered shape, so machining is required. My machinist did this + weighing them for $10/piston. Did this on a rebuild, car is currently down due to a fuel sensor going AWOL, but car runs fine. I have video, but its only a small snippet
__________________ JDMFresh.com 1990 Mazda Miata NASA Time Trials/Time Attack, Global Time Attack A miata may be gay, but its probably faster than your car around a track. That's pretty gay. |
| The Following 4 Users Say Thank You to jroc For This Useful Post: |
![]() | | #13 | ![]() |
![]() | | #14 | ![]() |
| 2zz mr-s ![]() Join Date: Nov 2010 Location: katy, tx
Rep Power: 3483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 239
| Not Ranked : 0 score im shot peening and cyro'in stock rods
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
![]() | | #15 | ![]() |
| The Following User Says Thank You to Lex For This Useful Post: | 06Speed6 (12-23-2011) |
![]() | | #16 | ![]() |
Groans: 112
(Thread Starter) | Not Ranked : 0 score I'm just going with aftermarket pistons, will set my build back a little longer but mine as well do it while it's out. Tapafucku!
![]() | | #17 | ![]() |
![]() Join Date: Jul 2008 Location: Ottawa, ON Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,005
| Not Ranked : 0 score Exactly what I was thinking, you've already got it all apart, why not pay the piper and get the pistons as well? |
| The Following User Says Thank You to theurgy For This Useful Post: | PapaSmurf (12-02-2011) |
![]() | | #18 | ![]() |
| Banned ![]() Join Date: Nov 2010 Location: Tampa, FL
Groaned at 28 Times in 11 Posts
| Not Ranked : 0 score ![]() |
![]() | | #19 | ![]() |
![]() Join Date: Jun 2012 Location: Montreal, QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 927
| Not Ranked : 0 score Can anyone gives me some measures of the stock rod small end (taper)? Need this to machine my Eagle rods before I take the engine apart (this is my DD, cant put the car aside for too long)
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement |
| K1 Rods with Stock Pistons | Cwhite | MazdaSpeed 3 - Engine, Transmission & Driveline | 16 | 12-19-2010 03:19 PM |
