 Old 10-20-2009, 01:13 PM   #1
Default Stock rods needed for testing
I have been talking to an aftermarket rod manufacturer that is interested in developing a product for us, AND will take a look at the forces needed to bend the stock rods. We'll get a good idea this way (and comparing this test to other/aftermarket rods) how much torque we're safe for as far as the rods go.
Problem is I don't have enough whole rods for this.
So, I need some complete, unbent rods from people that have upgraded or blew up other cylinders. It is very important that the rods are not bent and that the caps and bolts are included
Please let me know if you have any you can send my way, I am looking for a couple.
The rods will be bent during the testing and will no longer be usable if that wasn't obvious.
Thanks!
The Following 25 Users Say Thank You to Lex For This Useful Post:
06Speed6 (10-20-2009), 802MS3 (10-20-2009), cld12pk2go (10-23-2009), djuosnteisn (10-20-2009), Easter Bunny (12-11-2012), flyrevs2 (10-27-2009), FreeFlyFreak (10-20-2009), Funky (11-20-2009), JmkC (10-24-2009), KayWhy (10-25-2009), kgb (10-20-2009), mazda.speed3 (10-20-2009), ms3077 (11-02-2009), Night Wolf (03-01-2010), NRSpeed (12-02-2009), nyghtryder (10-20-2009), RacingToaster (10-27-2009), speed23 (10-20-2009), SpeedSixxx (10-20-2009), superskaterxes (10-20-2009), Target:STi (10-20-2009), toprock (10-20-2009), tozfeekum (10-20-2009), UNKWN14569 (11-07-2009), xcoldricex (10-21-2009)
 Old 10-20-2009, 02:53 PM   #2
Target:STi's Avatar
Posts: 289   (View Stats)
Target:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the worldTarget:STi is the leader of the world
i'll see what i can do when i pick mine up. not sure if they were going to keep the block as a turn in or what but i'll ask. i wanted to keep my bent ones anyway to always remind me of what fun its been.
Formerly: TG 06 MS6- CAI, TMIC, TBE
Currently: RR 08 Evo X- SRI, UICP, TP, CBE, Tune
Target:STi is offline   Reply With Quote
 Old 10-20-2009, 02:55 PM   #3
Sounds good, let me know once you find out.
 Old 10-20-2009, 03:16 PM   #4
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Lex, a local guy here just blew recently i guess. One rod is broken, but the other's may be intact. Not sure if you'd want them, cause they are probably already structurally compromised, but i'll see if i can get them anyway. Maybe your company could do a material analysis on the compound or something.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 10-20-2009, 03:24 PM   #5
Would be great to have. Actually, if you can also get bearings and pistons from the motor would be nice to see what they look like. PM me with any more info about the blowup if you have it/can get it. The more info the better.
 Old 10-20-2009, 07:34 PM   #6
austin102085's Avatar
Posts: 1,195   (View Stats)
austin102085 is the leader of the worldaustin102085 is the leader of the worldaustin102085 is the leader of the worldaustin102085 is the leader of the worldaustin102085 is the leader of the worldaustin102085 is the leader of the worldaustin102085 is the leader of the worldaustin102085 is the leader of the worldaustin102085 is the leader of the worldaustin102085 is the leader of the worldaustin102085 is the leader of the world
Groans: 32
Groaned at 33 Times in 21 Posts
my engine just got torn apart. i have all 4 good rods. ill swing by the shop tomm. and pick um up. do you need them labled what cylinder they came out of?
2008.5 Mazdaspeed 3
Built Engine- CP Pistons 9.5:1/Pauter Rods -- Holset Big Turbo-- DNP Manifold w/ewg -- Tial 44mm EWG -- STRATIFIED EBCS
CP-E Catback Exhaust -- Custon Downpipe-- CUSTOM 3.25 MAF-- CP-E 4 inch Turbo Inlet, custom Proto-type Injector Seals
COBB AP CUSTOM TUNE-- COBB FMIC
Fuel Pump Internals -- Devils Own Meth Kit #7 -- Spin-on Oil Filter -- 3 Step Colder Plugs -- TWM Short Shift
Custom Center Gauge Pod -- Custom 1 Of A Kind MS3 Gauges -- Halo Lights -- Front Lip -- Emblem Less Grill -- Rice Gen1&2 Hood Hybrid
513whp MS3<-- for now (sold)
1993 RX7 FD build in progress!!!!!!
austin102085 is offline   Reply With Quote
The Following 14 Users Say Thank You to austin102085 For This Useful Post:
802MS3 (10-21-2009), Aetherfury (10-27-2009), djuosnteisn (10-20-2009), E4Performance (10-21-2009), Easter Bunny (12-11-2012), FearUndersteer (11-01-2009), FreeFlyFreak (10-20-2009), kgb (10-20-2009), Lex (10-20-2009), nyghtryder (10-20-2009), RayRayBauder (10-29-2009), Scatt Nasty (10-20-2009), superskaterxes (10-20-2009), tozfeekum (10-20-2009)
 Old 10-20-2009, 08:54 PM   #7
clos561's Avatar
Posts: 1,172   (View Stats)
clos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the world
this will be very nice to know, good shit lex
- how exactly are they going to test the rods
7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance
clos561 is offline   Reply With Quote
 Old 10-20-2009, 09:05 PM   #8
im sure they will put them through neumerous compression and torsion tests to basically test their static breaking point. the reason he probs needs alot of rods is because if youu test a sample of say 12 diff rods and they all break at x+/- 20ftlbs of torque, you have alot more realistic results then if you test 3 rods and they all break at x +-40ftlbs of torque.
 Old 10-20-2009, 09:13 PM   #9
clos561's Avatar
lol yea, sounds similar to the shit im learning in statistics. sample mean and standard deviation.
-how do they do the testing tho, they put the rods in a engine? or just pull on it with a special machine
 Old 10-20-2009, 09:15 PM   #10
actually they hire two gorillas (read gorillas need moneys too you know) and they pull on the rod from each end. then they test how strong the gorilla can pull on a scale and apply x logic to the rod.
lol they pull on it with a machine. we have all these machine at my school but i dont really have the access to use them cause they are more for acedemic purposes.
martyxattack (10-20-2009)
 Old 10-20-2009, 09:17 PM   #11
bf360's Avatar
Posts: 2,069   (View Stats)
I can also do tests on rod or pistons and i could pull a rod apart if someone wanted, also test metal hardness's etc
Tensile test a rod anyone?
 Old 10-20-2009, 09:38 PM   #12
Miembro
nighthawk358's Avatar
Posts: 725   (View Stats)
nighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the world
Groans: 27
Groaned at 6 Times in 6 Posts
i think the term is called young modulus where they search how much stress can the rod handle until it strains
2008.5 MS3 Metro Gray...slow
nighthawk358 is offline   Reply With Quote
The Following User Says Thank You to nighthawk358 For This Useful Post:
 Old 10-20-2009, 09:39 PM   #13
bf360's Avatar
yes youngs modulus of elasticity
 Old 10-20-2009, 10:47 PM   #14
OK, looks like I have all the rods I need for now. If I need more, will let you guys know.
We will see what these guys can do. I am very interested in what they find because they have terms of comparison with other stock rods and aftermarket ones. Without terms of comparison it's harder to tell what you're looking at even if a machine spits out some numbers.
bf360, if you can do some stress,strain,hardness tests on the rods that would be great. Let me know what you need.
djuosnteisn (10-21-2009), FreeFlyFreak (10-20-2009)
 Old 10-20-2009, 10:54 PM   #15
bf360's Avatar
yes i can do all three, just need the actual parts either rods or pistons and i can do the tests
The Following 2 Users Say Thank You to bf360 For This Useful Post:
06Speed6 (10-21-2009), Lex (10-20-2009)
 Old 10-20-2009, 11:04 PM   #16
Great, we need a few more rods guys. Get in touch with bf360 and send him a few.
bf360, if you have issues locating some rods let me know, I can send you a couple but I'd rather avoid the to and fro shipping and have someone send you some directly.
 Old 10-20-2009, 11:17 PM   #17
bf360's Avatar
ok cool anyone that has any just pm me, as soon as i get them i can do the tests that week
 Old 10-21-2009, 03:45 PM   #18
clos561's Avatar
bumping this, get these guys some rods!
 Old 10-21-2009, 03:58 PM   #19
E4Performance's Avatar
Posts: 690   (View Stats)
E4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the worldE4Performance is the leader of the world
Groaned at 69 Times in 65 Posts
seeing as pistons and cranks tend to not be issues for these motors, are they planning on creating a rod that will be compatible with the factory pistons and crank?
E4Performance is offline   Reply With Quote
 Old 10-21-2009, 04:57 PM   #20
i think overall this is something awesome to have done so we actually know what kinda punishment these rods can take but we also need to understand that rod failure due to sheer power is not whats causing motors to blow. this is something that we really need to push forward on as well. keep up the good work as well alex and billy.
bf360 (10-21-2009)
 Old 10-23-2009, 09:04 AM   #21
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Lex,
Awesome. Just awesome. Can't wait for the results.
 Old 10-27-2009, 08:46 AM   #22
clos561's Avatar
any updates on progress? have you guys started doing the testing?
 Old 10-27-2009, 08:52 AM   #23
Not yet, will post results when they are available here.
djuosnteisn (10-27-2009)
 Old 10-27-2009, 10:29 AM   #24
RacingToaster's Avatar
Posts: 426   (View Stats)
RacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the world
Groans: 40
Lex and bf360 way to go guys, keep it up
RacingToaster is offline   Reply With Quote
 Old 10-27-2009, 11:07 AM   #25
bf360's Avatar
i still need anything no one has contacted me with any parts
 Old 10-27-2009, 07:15 PM   #26
I will see what I have left over and might have something to send you. I live in Canada and shipping to/from the US is really slow.
 Old 10-27-2009, 07:19 PM   #27
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
Im not home to send anymore out
Lex i thought you were in washington? what is this about canada?
 Old 10-27-2009, 07:23 PM   #28
I live close to the border. I have stuff shipped to WA and drive over to pick stuff up. It's a bit of a hassle because I can only do this at certain times etc.
 Old 10-28-2009, 11:37 AM   #29
Race Roots's Avatar
Posts: 885   (View Stats)
Race Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the worldRace Roots is the leader of the world
Groaned at 18 Times in 18 Posts
bump! In for the results
Race Roots is offline   Reply With Quote
 Old 10-28-2009, 11:47 AM   #30
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
this thread is getting my adrenaline pumping. i want results!!!!!!!!!!!1
 Old 10-28-2009, 12:32 PM   #31
You know what they say, you show me yours and I'll show you mine
phantom3 (11-09-2009), psychophyr (10-29-2009)
 Old 10-29-2009, 10:56 AM   #32
psychophyr's Avatar
Posts: 770   (View Stats)
psychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the world
LOL nice friendly burn
psychophyr is offline   Reply With Quote
 Old 10-29-2009, 11:52 AM   #33
Race Roots's Avatar
 Old 10-29-2009, 01:47 PM   #34
Groans: 32
LEX. im still trying to get my stuff back from the shop as soon as i do ill send it to ya. sorry its taking so long.
2008.5 Mazdaspeed 3
 Old 10-29-2009, 07:52 PM   #35
18psiWhiteMS3
Lurkers
Posts: n/a
someone send Bf360 some. he can test them also right away
 Old 10-29-2009, 08:23 PM   #36
bf360's Avatar
I am pretty sure i cant do tension tests of the rods, i do not think the tester has enough power to pull them apart i can do pretty much anything else
 Old 10-29-2009, 08:41 PM   #37
well considering the rods never really have any tensile forces acting on them (save for pulling the weight of the piston down) i think this is ok.
 Old 10-29-2009, 08:50 PM   #38
bf360's Avatar
The point of the tension test is to determine the strength of the rod not necessarily only how it reacts to tension
 Old 10-29-2009, 09:17 PM   #39
Actually tension on the rods goes up with the square of the RPM. So it is equally important to compression. The oscillation between tension and compression is what fatigues the rod.
djuosnteisn (10-30-2009), FearUndersteer (11-01-2009)
 Old 10-29-2009, 09:18 PM   #40
18psiWhiteMS3
Lurkers
Posts: n/a
test them already lex. i'm getting tuned next week hehe
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/stock-rods-needed-testing-40379/
Diskussion VTT / Pleuel / Motorstandfestigkeit - Seite 2 This thread Refback 06-16-2012 09:36 AM
weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this? labikesrcool MazdaSpeed 3/6 - Wheels & Tires 21 11-30-2015 03:32 PM
STOCK RODS AND PISTONS for sale quickspeed6 Mazdaspeed3/6 General Discussion 5 06-05-2009 01:53 PM
Testing MS3 Camshafts, Volunteer Needed CaptainKRM Mazdaspeed3/6 General Discussion 48 02-26-2009 12:08 PM
FYI: Carrillo Rods vs. Factory Rods JimmyMac MazdaSpeed 3 - Engine, Transmission & Driveline 45 02-20-2009 10:07 AM
Stock air box pic needed. HiggyMS3 Mazdaspeed3/6 General Discussion 6 09-20-2008 01:36 PM
Page generated in 0.55075 seconds with 34 queries
