![]() | | #41 | ![]() |
![]() | | #42 | ![]() |
Groans: 79
| Not Ranked : 0 score Tension is usually the strongest force on a rod out of all the different cycles. When its the compression stroke, the exploding combustion helps slow the piston head down and change direction. This takes the load off the road quite a bit. When it's the intake stroke though, and there's no explosion, That's when the rod alone has to bear the entire force of reversing the piston direction from up to down. This is probably also why our rods let go during shifts, but i'm still confused why it's always low rpm shifts, not high rpm WOT shifts.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
![]() | | #43 | ![]() |
![]() Join Date: Aug 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
Groaned at 24 Times in 6 Posts
| Not Ranked : 0 score I bet i can break one of these rods using my knee, that's how week they look to me. Still curious to see the results though, the rods still look cast to me. |
![]() | | #44 | ![]() |
It happens during shifts because there is a momentum change and because the crank is moved through the application/release of the clutch further offsetting how forces are applied to the rod. Our rods contact the crank counterweights on either side of the big end. | |
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
![]() | | #45 | ![]() |
| Lurkers
Posts: n/a
| updates? |
![]() | | #46 | ![]() |
(Thread Starter) | Not Ranked : 0 score I will post them when they are available. In the meantime keep the torque and fueling in check and the shiny side up! |
![]() | | #47 | ![]() |
![]() Join Date: Jun 2008 Location: New Port Richey, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,984
Groans: 88
| Not Ranked : 0 score Lex, did you ever get an AP and if so, can you share your map if you made one? With all the knowledge you have shared, I would just like to compare that to the changes you would of made in ATR.
__________________ FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute JAM SESSION........US Amps (in Series w/ Stock Amp) using OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back) RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors - Acne Rear Bumper LED Reflectors |
![]() | | #48 | ![]() |
This should be in a different thread however. | |
![]() | | #49 | ![]() |
Groans: 88
__________________ FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute JAM SESSION........US Amps (in Series w/ Stock Amp) using OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back) RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors - Acne Rear Bumper LED Reflectors Last edited by kgb; 11-08-2009 at 07:10 PM. | |
![]() | | #50 | ![]() |
![]() Join Date: Mar 2008 Location: In a house
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54
| Not Ranked : 0 score updates?
__________________ 7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance |
![]() | | #51 | ![]() |
(Thread Starter) | Not Ranked : 0 score Got a little sidetracked on this. I will update when I find something. In the meantime, I honestly don't think these destructive tests will tells us something we didn't already know. |
![]() | | #52 | ![]() |
| Lurkers
Posts: n/a
| i think it will personally. i think our rods are much stronger then originally thought |
![]() | | #53 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here's food for thought. Out of the stock rods I have, some are definitely stronger built than others. One is actually a 0.5 mm thicker down the entire shaft with much smoother surface finish. That makes quite a difference. |
| The Following 4 Users Say Thank You to Lex For This Useful Post: |
![]() | | #54 | ![]() |
| Lurkers
Posts: n/a
| DJuosteisn i see you viewing this thread go to shoutbox asap |
![]() | | #55 | ![]() |
Groans: 79
| Not Ranked : 0 score lol, woops. I guess send me a pm if you need.
![]() | | #56 | ![]() |
Rep Power: 7491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
That is not good at all.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG | |
![]() | | #57 | ![]() |
Groans: 79
| Not Ranked : 0 score Has there been a correlation with build dates and failures? I remember the russians mentioning that they only had rod issues on earlier builds, but not in quite a while. I'll try to find the quote. Here's one reference to a change in design. This was in regards to whether or not they were having rod issues.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com Last edited by djuosnteisn; 11-08-2009 at 09:49 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #58 | ![]() |
(Thread Starter) | Not Ranked : 0 score The beefier rod came out of an 07. I have seen 08.5 rods that are back to not being "beefy" The MS3 and MS6 rods are serialized differently (early versus later builds). The MS6 rods have a 3d bar bode on them probably used for matching weights of rods in each motor. The MS3 rods only have number/letter markings. I am not sure how to read these serialized numbers but it can be that they are incremental. I can grab the weight of the rods 06speed6 but I am inclined to think that the rods are matched by weight in a particular engine. |
| The Following User Says Thank You to Lex For This Useful Post: | 802MS3 (11-08-2009) |
![]() | | #59 | ![]() |
| Not Ranked : 0 score Its too bad that we cant get all 4 rods from an engine. Regardless, bigger and smaller rods are a big deal... I wonder if we could get the guys that have had blown engines to weigh their rods in grams and see if its the lighter rods that are breaking.
![]() | | #60 | ![]() |
![]() Join Date: Jul 2009 Location: Vancouver, BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score Generally, production line engines are only static-balanced, matched by weight, some not even that. A GM Malibu V6 likely isn't checked for balance at all, because the engine is mass-produced for low rpm and light loads, typically so, why balance the engine parts to the gram? Weight is only one factor in strength. Forging tends to produce normalised metal density over the rod more easily than casting, which can be good but, heavier doesn't always mean stronger. The change in reciprocating mass makes a heavier rod put more strain on the rotating assembly than a lighter rod. Aside from the above, you have the hardening issues that come with forging, since the surface is a machined one, there is often little strengthening of the surface steel through quenching or hammering. This massively affects the potential strength of the rod. Aligning and compressing the grain structure of the steel through work can make a light rod immensely strong. I can't say if these are factors here as I'd need to closely examine the rod and have deep insight into the manufacturing process. |
![]() | | #61 | ![]() |
| Not Ranked : 0 score Considering that these rods probably had the same or similar manufacturing processes, I would say weight is a direct indication of strength.
![]() | | #62 | ![]() |
| Not Ranked : 0 score I hope you're not missing my obvious point that a heavier rod NEEDS to be stronger to withstand the added force of it's own increased mass in reciprocation. You can make a lighter rod less strong and be totally fine, due to the decreased recip mass. It's really just a touch more complicated than "heavier = stronger". |
![]() | | #63 | ![]() |
| Lurkers
Posts: n/a
| do u design engines? |
![]() | | #64 | ![]() |
| Not Ranked : 0 score My understanding is that added beef in a non high rpm setup, with the same piston weight, with the same stroke, and with the same metalurgy, will always yield a stronger rod. Obviously in a cart engine like you are talking about that doesnt apply.
![]() | | #65 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here is what I mean. This rod is the "beefy" one. ![]() This rod is like all the other ones I have measured (5 others) and it is 0.5mm thinner throughout its entire construction. |
![]() | | #66 | ![]() |
| Lurkers
Posts: n/a
| pull that shit a part lex. i want to know what they can handle |
![]() | | #67 | ![]() |
| Not Ranked : 0 score I cant really tell much from those pics except that they appear to have the same finish.
![]() | | #68 | ![]() |
(Thread Starter) | Not Ranked : 0 score They CAN'T handle detonation. They CAN'T handle boost spikes, low fuel pressure, FFS, uneven meth distribution (the freeze plug idea is terrible), too much timing, too much heat, low oiling. I can't think of any cars (that were not freak accidents) that have died at anything else but the hands of detonation. Big pics for full detail Exhitbit #1. This is what happens when you run meth in the centre of the IM. It only gets to cylinders 2, 3. In this picture you see cylinder 4 which got no meth which has a bent rod (notice the offset spray pattern from the injector on the piston). The piston next to it got all the meth and that's why it's so clean. ![]() Exhibit #2. This is the same motor, cylinder #1 that blew. It had a bent rod for a while and it finally broke loose. Cylinder #1 also got little of the meth share. ![]() This car was using FFS and experimenting with leaner A/F ratios using meth - except that poor #1, and #4 were not seeing much meth at all! |
![]() | | #69 | ![]() |
![]() | | #70 | ![]() |
| Lurkers
Posts: n/a
| lex is spraying meth in the intercooler pipe right before the throttle body the best? |
![]() | | #71 | ![]() |
![]() | | #72 | ![]() |
![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4957 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
| Not Ranked : 0 score awesome pics! yeah that freeze plug idea was terrible i cant believe so many liked the idea. and yes 18psi thats probably the best idea other than one in each runner etc. if you have the nozzle far enough away from the IM then it should have time to mix pretty evenly thruout the air |
| The Following User Says Thank You to aaronc7 For This Useful Post: | Lex (11-08-2009) |
![]() | | #73 | ![]() |
Groans: 79
| Not Ranked : 0 score Great pics lex, worth the wait for the page to load, lol. Also good info as well.
| The Following User Says Thank You to djuosnteisn For This Useful Post: | Lex (11-08-2009) |
![]() | | #74 | ![]() |
(Thread Starter) | Not Ranked : 0 score More food for thought: From SAE international: It was found that methanol fuel is more susceptible to pre-ignition compared to gasoline fuel ... Platinum tipped spark plugs were found to be highly susceptible to pre-ignition with methanol fuel. Pre-ignition and detonation tendency increase with the increase of engine load, compression ratio, inlet air temperature, advancing the ignition timing and lowering the engine speed |
![]() | | #75 | ![]() |
![]() Join Date: Aug 2008 Location: jersey
Rep Power: 609 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 388
| Not Ranked : 0 score The discrepancies in size between the rods is most likely because of the forging process not everything will come out the exact same when forging. |
![]() | | #76 | ![]() |
| Eth/Meth Junkie ![]() Join Date: Mar 2008 Location: Columbus, OH
Rep Power: 2957 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,846
If i recall correctly, methanol has a much higher autoignition temp than gasoline so I would expect it to be less prone under similar circumstances.
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
![]() | | #77 | ![]() |
![]() | | #78 | ![]() |
The abstract states:
![]() | | #79 | ![]() |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
| Not Ranked : 0 score I just want to say I appreciate the info shared on the thread.
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
![]() | | #80 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here's something else to avoid. This car blew as it was being loaded (foot to floor) from a low RPM. Bent rod but not through the block. It happened right as KR hit 6.0. |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/stock-rods-needed-testing-40379/ | ||||
| Diskussion VTT / Pleuel / Motorstandfestigkeit - Seite 2 | This thread | Refback | 06-16-2012 09:36 AM | |
| weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this? | labikesrcool | MazdaSpeed 3/6 - Wheels & Tires | 21 | 11-30-2015 03:32 PM |
| STOCK RODS AND PISTONS for sale | quickspeed6 | Mazdaspeed3/6 General Discussion | 5 | 06-05-2009 01:53 PM |
| Testing MS3 Camshafts, Volunteer Needed | CaptainKRM | Mazdaspeed3/6 General Discussion | 48 | 02-26-2009 12:08 PM |
| FYI: Carrillo Rods vs. Factory Rods | JimmyMac | MazdaSpeed 3 - Engine, Transmission & Driveline | 45 | 02-20-2009 10:07 AM |
| Stock air box pic needed. | HiggyMS3 | Mazdaspeed3/6 General Discussion | 6 | 09-20-2008 01:36 PM |
