 Old 10-29-2009, 11:06 PM   #41
Originally Posted by 18psiWhiteMS3 View Post
test them already lex. i'm getting tuned next week hehe
I wish this was my full time job
 Old 10-30-2009, 09:33 AM   #42
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Tension is usually the strongest force on a rod out of all the different cycles.
When its the compression stroke, the exploding combustion helps slow the piston head down and change direction. This takes the load off the road quite a bit.
When it's the intake stroke though, and there's no explosion, That's when the rod alone has to bear the entire force of reversing the piston direction from up to down. This is probably also why our rods let go during shifts, but i'm still confused why it's always low rpm shifts, not high rpm WOT shifts.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 10-30-2009, 09:57 AM   #43
slo4now's Avatar
Posts: 382   (View Stats)
slo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond reputeslo4now has a reputation beyond repute
Groaned at 24 Times in 6 Posts
I bet i can break one of these rods using my knee, that's how week
they look to me.
Still curious to see the results though, the rods still look cast to me.
slo4now is offline   Reply With Quote
 Old 10-30-2009, 10:28 AM   #44
The rods break after they have already been bent or twisted. Because they are forged, they are more prone to deforming before outright breaking when overloaded. Once they deform, it doesn't take much for them to further deform or for the piston to snag in the bore regardless of RPM.
It happens during shifts because there is a momentum change and because the crank is moved through the application/release of the clutch further offsetting how forces are applied to the rod. Our rods contact the crank counterweights on either side of the big end.
djuosnteisn (10-30-2009), Easter Bunny (12-11-2012), ms3077 (11-02-2009)
 Old 11-01-2009, 06:31 PM   #45
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
updates?
 Old 11-01-2009, 06:37 PM   #46
I will post them when they are available. In the meantime keep the torque and fueling in check and the shiny side up!
 Old 11-02-2009, 03:19 PM   #47
kgb
kgb's Avatar
Posts: 808   (View Stats)
kgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the world
Groans: 88
Lex, did you ever get an AP and if so, can you share your map if you made one? With all the knowledge you have shared, I would just like to compare that to the changes you would of made in ATR.
FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs
WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s
AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI
MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute
JAM SESSION........US Amps (in Series w/ Stock Amp) using
OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back)
RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors
- Acne Rear Bumper LED Reflectors
kgb is offline   Reply With Quote
 Old 11-02-2009, 03:28 PM   #48
I do have an AP and have great results with it - I can of course share my map and results but I believe most people here wouldn't want to run the settings I am.
This should be in a different thread however.
 Old 11-02-2009, 03:58 PM   #49
kgb
kgb's Avatar
Groans: 88
Thanks
 Old 11-07-2009, 06:32 PM   #50
clos561's Avatar
Posts: 1,172   (View Stats)
clos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the world
updates?
7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance
clos561 is offline   Reply With Quote
 Old 11-07-2009, 08:46 PM   #51
Got a little sidetracked on this. I will update when I find something.
In the meantime, I honestly don't think these destructive tests will tells us something we didn't already know.
 Old 11-07-2009, 09:02 PM   #52
18psiWhiteMS3
Lurkers
Posts: n/a
i think it will personally. i think our rods are much stronger then originally thought
 Old 11-07-2009, 10:33 PM   #53
Here's food for thought. Out of the stock rods I have, some are definitely stronger built than others. One is actually a 0.5 mm thicker down the entire shaft with much smoother surface finish. That makes quite a difference.
aaronc7 (11-08-2009), DaleNixon (11-10-2009), Easter Bunny (12-11-2012), SLOMS3 (11-07-2009)
 Old 11-07-2009, 10:42 PM   #54
18psiWhiteMS3
Lurkers
Posts: n/a
DJuosteisn i see you viewing this thread go to shoutbox asap
 Old 11-08-2009, 07:48 AM   #55
Captain
Groans: 79
lol, woops. I guess send me a pm if you need.
www.permtuning.com
 Old 11-08-2009, 09:19 AM   #56
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Now thats a huge deal for more than a few reasons, what is the weight difference between them?
That is not good at all.
2006 Mazdaspeed 6
 Old 11-08-2009, 09:40 AM   #57
Captain
Groans: 79
Has there been a correlation with build dates and failures? I remember the russians mentioning that they only had rod issues on earlier builds, but not in quite a while. I'll try to find the quote.
Originally Posted by Yarrus View Post
Not at all...in 2007 we had a problems.
Here's one reference to a change in design. This was in regards to whether or not they were having rod issues.
www.permtuning.com
Last edited by djuosnteisn; 11-08-2009 at 09:49 AM. Reason: MSF Database - Automerged Doublepost
 Old 11-08-2009, 11:17 AM   #58
The beefier rod came out of an 07. I have seen 08.5 rods that are back to not being "beefy"
The MS3 and MS6 rods are serialized differently (early versus later builds). The MS6 rods have a 3d bar bode on them probably used for matching weights of rods in each motor.
The MS3 rods only have number/letter markings. I am not sure how to read these serialized numbers but it can be that they are incremental.
I can grab the weight of the rods 06speed6 but I am inclined to think that the rods are matched by weight in a particular engine.
802MS3 (11-08-2009)
 Old 11-08-2009, 01:02 PM   #59
Speeeeeed
06Speed6's Avatar
Its too bad that we cant get all 4 rods from an engine.
Regardless, bigger and smaller rods are a big deal...
I wonder if we could get the guys that have had blown engines to weigh their rods in grams and see if its the lighter rods that are breaking.
2006 Mazdaspeed 6
 Old 11-08-2009, 01:34 PM   #60
darth vader's Avatar
Posts: 665   (View Stats)
Generally, production line engines are only static-balanced, matched by weight, some not even that. A GM Malibu V6 likely isn't checked for balance at all, because the engine is mass-produced for low rpm and light loads, typically so, why balance the engine parts to the gram?
Weight is only one factor in strength. Forging tends to produce normalised metal density over the rod more easily than casting, which can be good but, heavier doesn't always mean stronger. The change in reciprocating mass makes a heavier rod put more strain on the rotating assembly than a lighter rod.
Aside from the above, you have the hardening issues that come with forging, since the surface is a machined one, there is often little strengthening of the surface steel through quenching or hammering. This massively affects the potential strength of the rod. Aligning and compressing the grain structure of the steel through work can make a light rod immensely strong. I can't say if these are factors here as I'd need to closely examine the rod and have deep insight into the manufacturing process.
 Old 11-08-2009, 01:40 PM   #61
Speeeeeed
06Speed6's Avatar
Considering that these rods probably had the same or similar manufacturing processes, I would say weight is a direct indication of strength.
2006 Mazdaspeed 6
 Old 11-08-2009, 02:53 PM   #62
I hope you're not missing my obvious point that a heavier rod NEEDS to be stronger to withstand the added force of it's own increased mass in reciprocation. You can make a lighter rod less strong and be totally fine, due to the decreased recip mass. It's really just a touch more complicated than "heavier = stronger".
 Old 11-08-2009, 03:04 PM   #63
18psiWhiteMS3
Lurkers
Posts: n/a
do u design engines?
 Old 11-08-2009, 04:49 PM   #64
Speeeeeed
06Speed6's Avatar
My understanding is that added beef in a non high rpm setup, with the same piston weight, with the same stroke, and with the same metalurgy, will always yield a stronger rod.
Obviously in a cart engine like you are talking about that doesnt apply.
2006 Mazdaspeed 6
 Old 11-08-2009, 05:52 PM   #65
Here is what I mean.
This rod is the "beefy" one.
This rod is like all the other ones I have measured (5 others) and it is 0.5mm thinner throughout its entire construction.
 Old 11-08-2009, 05:55 PM   #66
18psiWhiteMS3
Lurkers
Posts: n/a
pull that shit a part lex. i want to know what they can handle
 Old 11-08-2009, 06:00 PM   #67
Speeeeeed
06Speed6's Avatar
I cant really tell much from those pics except that they appear to have the same finish.
2006 Mazdaspeed 6
 Old 11-08-2009, 06:05 PM   #68
They CAN'T handle detonation. They CAN'T handle boost spikes, low fuel pressure, FFS, uneven meth distribution (the freeze plug idea is terrible), too much timing, too much heat, low oiling.
I can't think of any cars (that were not freak accidents) that have died at anything else but the hands of detonation.
Big pics for full detail
Exhitbit #1. This is what happens when you run meth in the centre of the IM. It only gets to cylinders 2, 3. In this picture you see cylinder 4 which got no meth which has a bent rod (notice the offset spray pattern from the injector on the piston). The piston next to it got all the meth and that's why it's so clean.
Exhibit #2. This is the same motor, cylinder #1 that blew. It had a bent rod for a while and it finally broke loose. Cylinder #1 also got little of the meth share.
This car was using FFS and experimenting with leaner A/F ratios using meth - except that poor #1, and #4 were not seeing much meth at all!
 Old 11-08-2009, 06:10 PM   #69
Pointing out difference in shaft width. Look at the calipers. They are opened and locked the same amount in both pictures.
06Speed6 (11-08-2009), speed23 (11-08-2009)
 Old 11-08-2009, 06:17 PM   #70
18psiWhiteMS3
Lurkers
Posts: n/a
lex is spraying meth in the intercooler pipe right before the throttle body the best?
 Old 11-08-2009, 06:18 PM   #71
Unless you do each runner yes, spray it where the full airstream can come into contact with it.
 Old 11-08-2009, 06:19 PM   #72
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
awesome pics!
yeah that freeze plug idea was terrible i cant believe so many liked the idea.
and yes 18psi thats probably the best idea other than one in each runner etc. if you have the nozzle far enough away from the IM then it should have time to mix pretty evenly thruout the air
The Following User Says Thank You to aaronc7 For This Useful Post:
Lex (11-08-2009)
 Old 11-08-2009, 06:56 PM   #73
Captain
Groans: 79
Great pics lex, worth the wait for the page to load, lol. Also good info as well.
www.permtuning.com
Lex (11-08-2009)
 Old 11-08-2009, 08:52 PM   #74
More food for thought:
From SAE international:
It was found that methanol fuel is more susceptible to pre-ignition compared to gasoline fuel ... Platinum tipped spark plugs were found to be highly susceptible to pre-ignition with methanol fuel.
Pre-ignition and detonation tendency increase with the increase of engine load, compression ratio, inlet air temperature, advancing the ignition timing and lowering the engine speed
 Old 11-08-2009, 09:29 PM   #75
bf360's Avatar
Posts: 2,069   (View Stats)
The discrepancies in size between the rods is most likely because of the forging process not everything will come out the exact same when forging.
 Old 11-09-2009, 04:29 AM   #76
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Link to document?
If i recall correctly, methanol has a much higher autoignition temp than gasoline so I would expect it to be less prone under similar circumstances.
 Old 11-09-2009, 07:45 AM   #77
Speeeeeed
06Speed6's Avatar
bahahah... Im not even going to say anything.
2006 Mazdaspeed 6
 Old 11-09-2009, 08:34 AM   #78
Link to document?
You are correct, gasoline has an autoignition temperature of 280 C whereas methyl alcohol has a temperature of 365 C. There is more to it than this however. I would suspect this to really become an issue when a large percentage of the fueling is done by methanol.
The abstract states:
The combustion pressure as well as a signal from the pre-ignition detector were analyzed. It was found that methanol fuel is more susceptible to pre-ignition compared to gasoline fuel. Large cycle-by-cycle variations are present with combustion by surface ignition at the time of pre-ignition.
Here is the link to the paper: Pre-Ignition Phemomena of Methanol Fuel (M85) By the Post-Ignition Technique
 Old 11-09-2009, 09:02 AM   #79
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
I just want to say I appreciate the info shared on the thread.
-- Mario Andretti --
 Old 11-09-2009, 09:03 AM   #80
Here's something else to avoid. This car blew as it was being loaded (foot to floor) from a low RPM. Bent rod but not through the block. It happened right as KR hit 6.0.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/stock-rods-needed-testing-40379/
Diskussion VTT / Pleuel / Motorstandfestigkeit - Seite 2 This thread Refback 06-16-2012 09:36 AM
weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this? labikesrcool MazdaSpeed 3/6 - Wheels & Tires 21 11-30-2015 03:32 PM
STOCK RODS AND PISTONS for sale quickspeed6 Mazdaspeed3/6 General Discussion 5 06-05-2009 01:53 PM
Testing MS3 Camshafts, Volunteer Needed CaptainKRM Mazdaspeed3/6 General Discussion 48 02-26-2009 12:08 PM
FYI: Carrillo Rods vs. Factory Rods JimmyMac MazdaSpeed 3 - Engine, Transmission & Driveline 45 02-20-2009 10:07 AM
Stock air box pic needed. HiggyMS3 Mazdaspeed3/6 General Discussion 6 09-20-2008 01:36 PM
Page generated in 0.56746 seconds with 31 queries
