![]() | | #81 | ![]() |
![]() Join Date: May 2009 Location: Browns Mills/NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 739
| Not Ranked : 0 score
__________________ A Kabar is just a paper weight until it's in the hand of a Marine. If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground. COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS NATOR PA | |
![]() | | #82 | ![]() |
![]() Join Date: Nov 2008 Location: Europe
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,476
| Not Ranked : 0 score @lex Could you post the graph itself iso a printscreen, its hard to read. AFR's look pretty high for a WOT run imo? |
![]() | | #83 | ![]() |
| The Following User Says Thank You to Lex For This Useful Post: | MPSdriver (11-09-2009) |
![]() | | #84 | ![]() |
![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4957 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
| Not Ranked : 0 score i was under the impression that platinum plugs were a no-no in boosted applications.... copper or iridium. and no one makes copper plugs that works for us (that i know of), so that kinda narrows it down.. i did run plat plugs for a short while while waiting to get some new step colder ones..worked fine for a few days |
![]() | | #85 | ![]() |
![]() Join Date: Jul 2009 Location: Vancouver, BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score I have built up a few engines in 25+ years of doing this hobby both import and domestic. I agree that a huge difference between the two rods of supposedly the same spec. This looks far beyond manufacturing tolerances and more like a redesign or different vendor suppying the rods and getting the spec wrong or altering it for other reasons. However, I'll repeat, a heavier rod, especially in a high rpm app, needs to be stronger to withstand the forces it's greater mass imposes. Something is up, here. Now, no rod is going to take for long the carnage I'm seeing evidence of here, we have shattered crown edges near the ring lands, signs of possible hydrolock, etc. I can't tell too much with this shitty comp but, these are showing signs of serious abuse and suggest that the recip assembly is being stressed light-years beyond design. There's an engineering safety margin built into all engine parts and cost has forced engineers to whittle away at that margin. So, cars with engines like my 5.0, which could easily take 50% more power than stock without breaking anything are gonzo like the dodo these days. |
![]() | | #86 | ![]() |
I will get more pics up - but the bottom of the piston is scraped up by contact with the crank while it was still attached to the bent rod. Essentially, something bent the rod first and rod broke afterwards. There is another rod (#4) that is also bent in this motor and was running like this for a while as well. So the question remains - what is causing the rod to bent in the first place. IMO the biggest cause is detonation or pre-ignition and excessive load at low engine speeds. Essentially excessive, uncontrolled cylinder pressure. I know oil hydrolock has been discussed but I find that hard to believe. Based on how easily the motor knocks stock and when hot (for example), I am not surprised it is so sensitive to knock when the boost is turned up. Remember that fuel starts to be injected and mix with air only after the intake valves have opened. There is no premixing that happens behind the intake valves in a port injected engine. | |
![]() | | #87 | ![]() |
Groans: 79
| Not Ranked : 0 score I'm still unsure if fuel which is not properly mixed and combusted, can pull heat out of the cylinder. Also, excessive, uncontrolled cylinder pressure would greatly increase temps. If the volume isn't increasing (slow rpm), but the pressure is (combustion), the temp must also. Or in an even worse scenario, volume is decreasing (with either detonation or spark advance of >50), with pressure increasing. I know light load KR isn't something to necessarily worry about, but it may be a valid indication of how high the temps may be getting. My stock timing maps were above 60 at it's lightest loads (idle) between like 1500-3500rpm (i'll have to verify by looking at a map, bu you get the idea). No wonder i see knock after sitting at a light for a couple minutes, then get on the gas and start to load the engine. Same probably goes for highway cruising. I also wanted to ask if anyone knew the rod length to stroke ratio for our motor. From what i've read, it gives a good indication of the likelihood of seized pistons with variations in crank alignment and probably bent rods.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com Last edited by djuosnteisn; 11-09-2009 at 01:48 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #88 | ![]() |
(Thread Starter) | Not Ranked : 0 score To tell you the truth, I don't see the classical scuffing associated with seized pistons due to piston expansion. They all seem to seize because they are crooked in the bore. To throw fuel on the fire - here's more about alcohol tendency for pre-ignition:
Last edited by Lex; 11-09-2009 at 02:25 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #89 | ![]() |
![]() Join Date: Jul 2009 Location: Sardinia, Ohio
Rep Power: 4726 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,721
| Not Ranked : 0 score Pre-ignition kills instantly......Detonation kills over time, and the higher the HP per displacement the shorter amount of time it will take detonation to show it's ugly head. |
![]() | | #90 | ![]() |
![]() Join Date: Mar 2008 Location: Oceanside, CA
Rep Power: 2852 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 676
Groans: 106
| Not Ranked : 0 score so are you saying meth is hurting us?
__________________ 13.2@111 CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
http://jpnutritionandfitness.blogspot.com/ Sponsored By: CP-E | |
![]() | | #91 | ![]() |
| Not Ranked : 0 score Lex made the statement that meth is more prone to pre-ignition than gas, so if there is a pre-ignition source in the combustion chamber, then yes, the potential for a pre-ignition event is more likely when using meth or an alcohol based fuel. To me that is why it was so important to make sure that there is no way for oil to be induced into the combustion chamber, and use the coldest plugs that would be feasible to run the car on. |
![]() | | #92 | ![]() |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
| Not Ranked : 0 score it sounds like 100% meth might...
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
![]() | | #93 | ![]() |
Groans: 79
| Not Ranked : 0 score Meth is the only alcohol fuel out there. And i'm not sure whether or not Lex's quotes are in reference to "meth". For all we know it could be talking about e85. But i agree, if it does apply, it should be taken into consideration before squirting it into your engine. I believe if meth was horribly flawed in terms of pre-ignition, it probably wouldn't be such a popular solution in motorsports. But if indeed the above quotes refer also to methyl alcohol, and if indeed our cylinder temps are getting hotter than other engines, i could see it being a problem. Personally though, it's done wonders for my car, though i only run a 50/50 mix.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
![]() | | #94 | ![]() |
![]() Join Date: Jul 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
| Not Ranked : 0 score No. Lex mentioned that Methanol is more susceptible to detonation with PLATINUM tipped plugs. Our upgrade that a lot of people run (denso) are iridium tipped...so that doesn't really apply to us. But what IS possible hurting us when it comes to methanol, is the PTP Freeze Plug location. PTP claims it was equal spraying through all cylinders...and I beleive it when they did their testing when the intake manifold was off the car, but its a whole different ball game when you have pressurized air inside the manifold. And from Lex's findings, it seems that cylinder 1 and 4 are getting a lot less methanol then cylinders 2 and 3...thus...why cylinder 1 blew. From Lex's discoveries...Id suggest anyone with PTPs freeze plug nozzle to turn off their meth/run a more conservative tune. I know I turned off mine and added fuel so Im seeing mid/high 11s without Meth. Im going to see if I can get my methanol plug tapped into my cold pipe. p.s. the pictures of the pistons is from my car.
__________________ ![]() |
![]() | | #95 | ![]() |
(Thread Starter) | Not Ranked : 0 score Methanol alcohol is more prone to pre-ignition on a hot surface than gasoline. Of course this greatly depends on the amount of methanol present, hot surfaces present (spark plugs, piston tops, deposits), intake temperature etc. I'd stick to a 50/50 mix to simply cool intake charge. The graph below is self explanatory. It shows that alcohol fuels ignite at lower temperatures than gasoline. At the same TIME, alcohol has a much higher knock threshold. They are 2 different properties. |
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
![]() | | #96 | ![]() |
![]() Join Date: Sep 2009 Location: Austin, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 289
Groans: 40
| Not Ranked : 0 score We got to stop using as added fuel, and get the tune straight. |
![]() | | #97 | ![]() |
Rep Power: 7491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
| Not Ranked : 0 score bahaha ive been saying meth was crap for years. Vindication at last!
Ide bet if someone showed up with a meth tuned engine to Engine Masters they would be laughed out.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG | ||
![]() | | #98 | ![]() |
Groans: 44
| Not Ranked : 0 score from what I'm reading, anything but 100% meth should be fine...but what about the need to run a colder plug? with meth and higher pressures, wouldn't ITV24's be needed/necessary?
![]() | | #99 | ![]() |
Groans: 79
Water injection was huge in WWII, and allowed engines do some unbelievable shit. I'm a fan of a cool combustion chamber, and water does exactly that.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
| The Following User Says Thank You to djuosnteisn For This Useful Post: | phantom3 (11-10-2009) |
![]() | | #100 | ![]() |
| Not Ranked : 0 score Please do not confuse detonation with pre-ignition.....two totally different events that cause different outcomes on engine failures. Detonation is the spontaneous combustion of the end-gas (remaining fuel/air mixture) in the chamber. It always occurs after normal combustion is initiated by the spark plug. The initial combustion at the spark plug is followed by a normal combustion burn. For some reason, likely heat and pressure, the end gas in the chamber spontaneously combusts. The key point here is that detonation occurs after you have initiated the normal combustion with the spark plug. Pre-ignition is defined as the ignition of the mixture prior to the spark plug firing. Anytime something causes the mixture in the chamber to ignite prior to the spark plug event it is classified as pre-ignition. The two are completely different and abnormal phenomenon. Source: Detonation and Pre-Ignition by Allen W. Cline -------------------------------------------------------------------------------------------------------------------------------------------- Last edited by SilverDemon; 11-09-2009 at 07:12 PM. |
| The Following User Says Thank You to SilverDemon For This Useful Post: | Easter Bunny (12-11-2012) |
![]() | | #101 | ![]() |
Years ago I found meth injection to control knock in a gasoline engine to be almost laughable because of the ghetto way that people do it. People on here that use meth are people who dont realise that it has to be used as a standalone fuel or a specific ratio fuel that is injected into individual runners through a secondary port injection system. I know of no one on here that meters their meth injection to achieve a specific meth/gasoline ratio. Honestly if I came on here selling a "race" fuel injection system that controlled knock by injecting a waterfall of unmetered charcoal lighter fluid through a nozzle that is drilled into a boost tube or freeze plug I would get laughed off the forums, but the meth koolaid is strong here. Bottom line, if you want your car to not knock on pump gas, get a secondary race gas injection system or get a better tune and leave the windshield washer fluid for your windshield.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG Last edited by 06Speed6; 11-10-2009 at 05:39 AM. | ||
![]() | | #102 | ![]() |
| Eth/Meth Junkie ![]() Join Date: Mar 2008 Location: Columbus, OH
Rep Power: 2957 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,846
| Not Ranked : 0 score Guys one thing to keep in mind here is that Lex's meth data is when most of the fueling is provided with meth (M85). With meth injection, we are adding so small of a percentage of total fueling as to not likely apply to the concerns in the listed papers. It is good info, but I think we need to keep it in context. I am still strongly of the opinion that we get enormous benefits from the BAT cooling and higher octane from meth with respect to keeping the engine in one piece.
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
![]() | | #103 | ![]() |
Groans: 44
| Not Ranked : 0 score doing a quick MSDS search here for Canadians, I can safely say that all the windshield washer fluid from Canadian Tire, from MotoMaster to RainX to that NASCAR stuff has 0% glycol listed on the MSDS. All meth content is around 40 - 50%. a 1L bottle of Heet or meth hydrate (from Home Depot) added to 4L/1 gallon should make for a ~70% mix. and as long as this stuff is easily available, I don't see the need to run 100% meth...esp since I'm not tuning for it as fuel.
![]() | | #104 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 249
| Not Ranked : 0 score Anyone else notice that the rod that was getting meth/water (the one that didn't blow) is getting surface rust, but the one that didn't get meth/water (the one that blew) is clean? Thoughts?
![]() | | #105 | ![]() |
![]() Join Date: Oct 2008 Location: Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 761
Groans: 190
Groaned at 53 Times in 32 Posts
EDIT: As far as Meth is concerned, I've been saying for years to only run water. Maybe a little meth (-40* washer fluid) in the winter just so things don't freeze up.
__________________ My mission is to go fast. ![]() Currently Designing: The golden girdle of the gods The CF "fuck your face" IM | |
| The Following User Says Thank You to phantom3 For This Useful Post: | Superstretch18 (11-10-2009) |
![]() | | #106 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
Last, if the car leaned out, you will not see rods getting bent, the pistons will show signs of it first, then the rods will let go, not the other way around. If you can confirm that it was the WI point I will be more then willing to pull these items off the site and recall all of them as well with a full refund. Should be around 118 ish units that I have to recall (one would figure that if there were that many running out there, we would see more motors blown like this with similar failures to cyl's #'s 1 and 4, odd that we don't see that, but its even more odd that we are willing to make an assumption based 1/2 of the pistons, and less than 1/2 of the time taken to verify the problem). | ||
![]() | | #107 | ![]() |
(Thread Starter) | Not Ranked : 0 score The methanol flow is uneven. Whether motors will pop from it - that is unknown. AFCadet was leaning out specifically to rely on the methanol so he was pushing the envelope. Did the lack of methanol in cylinder 1 cause him to blow? Hard to say. One thing that you can take away from this is that by placing the nozzle there, the flow is not even to all cylinders. Placing a nozzle in each runner is different and a better design. However, if you only have one nozzle, place it at a point where all airflow is forced by it. Of course these products are sold as "install at your own risk" as are all aftermarket products. |
![]() | | #108 | ![]() |
So, know you are saying that the WI point may or may not have caused the issue? I will stick by my testing and my sales of 100's of these to customers without ever seeing an issue like this. Last, is there something your getting at by stating "all airflow"? Last time I checked "all the airflow" entered into the manifold, and all the airflow traveled up into the "W" designed runners. Cly pulses will determine how much each cyl requires but they all get what is being delivered to them, no matter where excluding DI nozzle placement. Just as long as your applying WI fluid under boost, there is not reason any cyl should be starved based on nozzle location. | |
![]() | | #109 | ![]() |
Groans: 79
| Not Ranked : 0 score DI = PI
![]() | | #110 | ![]() |
![]() | | #111 | ![]() |
![]() Join Date: Sep 2008 Location: Soledad, CA
Rep Power: 446 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 393
Groaned at 5 Times in 2 Posts
| Not Ranked : 0 score Here is my #3 piston and rod. How does it look?
__________________ Cobb AP, 504whp 492wtq |
![]() | | #112 | ![]() |
| Not Ranked : 0 score ...blurry.... |
![]() | | #113 | ![]() |
![]() Join Date: Nov 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score Hi Everyone, Tim here from Verocious. Dan told me there was interest to see some of the photos from a Speed3 failure analysis we are working on in the shop at the moment. I am the marketing manager, so I do not have any additional info or specifics, however, Dan will be commenting further later today as he is the one heading up this job. Tim |
| The Following 10 Users Say Thank You to Verocious For This Useful Post: | DaleNixon (12-01-2009), djuosnteisn (12-01-2009), Fobio (12-01-2009), FreeFlyFreak (12-01-2009), kgb (12-02-2009), Lex (12-01-2009), nyghtryder (12-01-2009), Realgib3 (12-01-2009), superskaterxes (12-01-2009), ungrave (01-19-2010) |
![]() | | #114 | ![]() |
(Thread Starter) | Not Ranked : 0 score That piston was riding right against the side of the bore for at least a little while to scuff it up like that before the rod broke. |
![]() | | #115 | ![]() |
Groans: 79
| Not Ranked : 0 score is that cylinder 3 or 2?
![]() | | #116 | ![]() |
Groans: 44
| Not Ranked : 0 score which side? the same side getting wash down?
![]() | | #117 | ![]() |
(Thread Starter) | Not Ranked : 0 score I want to say the rod bent and rode the side of the bore until it finally broke but I will wait for the guys with the parts in hand to chime in. No, the washed down side is the exhaust side. This is at 90 degrees to that. Last edited by Lex; 12-01-2009 at 02:13 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to Lex For This Useful Post: | Fobio (12-02-2009) |
![]() | | #118 | ![]() |
| Not Ranked : 0 score The pic of the cylinder that has the scuffing on the timing chain side of the cylinder is #3, #2 (which is bent but not broken) has the same scuffing but not as severe so I would agree with Lex that the rod bent, rode the cylinder wall for a little while then broke. For some reason though rod #4 was in the worste condition of the rods that were left intact but that cylinder if I recall correctly did not have the scuffing on the timing chain side of the cylinder only the exhaust side. Is this scuffing on the timing chain side of the cylinder common with these motors? Has anyone claimed to have a vibrating clutch pedal right before throwing a rod? Lex, I checked with the customer and he said that it would be fine for me to send the rods out to you but he would like to keep the broken one as it is a pretty pricey paperweight. I should have a total of 7 rods to send over to you, 4 from a CX-7 donor motor and 3 out of the speed3. |
| The Following 3 Users Say Thank You to Verocious For This Useful Post: |
![]() | | #119 | ![]() |
| The Kamikaze King! ![]() Join Date: Jun 2008
Rep Power: 1829 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,794
Groans: 754
Lots of people have had the dreaded clutch vibes before blowing. Not everyone though, couldnt give a percentage. http://www.mazdaspeedforums.org/foru...lp-asap-25124/ http://www.mazdaspeedforums.org/foru...-speed3-23806/ I think its toast..... There she blows!!!! http://www.mazdaspeedforums.org/foru...e-thread-6113/
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 ![]() http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. Last edited by FreeFlyFreak; 12-01-2009 at 06:15 PM. | |
![]() | | #120 | ![]() |
![]() Join Date: Aug 2009 Location: Nor Cal
| Not Ranked : 0 score Damn, this is crazy stuff
__________________ 2007 Cosmic Blue Speed3 [ MS CAI w/Straightener] [Cobb AP] [ RPMC TI ] [ FORGE BPV ] [ SU RP ] [ PG FMIC ] [Denso Plugs] [Trz MM] [ TWM SS&Bushings ] [ Greddy TT ] [ Defi Boost Gauge ] Not going to install-Weapon R catch can. Piss on doing that install |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/stock-rods-needed-testing-40379/ | ||||
| Diskussion VTT / Pleuel / Motorstandfestigkeit - Seite 2 | This thread | Refback | 06-16-2012 09:36 AM | |
| weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this? | labikesrcool | MazdaSpeed 3/6 - Wheels & Tires | 21 | 11-30-2015 03:32 PM |
| STOCK RODS AND PISTONS for sale | quickspeed6 | Mazdaspeed3/6 General Discussion | 5 | 06-05-2009 01:53 PM |
| Testing MS3 Camshafts, Volunteer Needed | CaptainKRM | Mazdaspeed3/6 General Discussion | 48 | 02-26-2009 12:08 PM |
| FYI: Carrillo Rods vs. Factory Rods | JimmyMac | MazdaSpeed 3 - Engine, Transmission & Driveline | 45 | 02-20-2009 10:07 AM |
| Stock air box pic needed. | HiggyMS3 | Mazdaspeed3/6 General Discussion | 6 | 09-20-2008 01:36 PM |
