 Old 03-15-2010, 11:37 PM   #1
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
Default switching to synthetic oil
at what mileage?
take off the pan to get the excess oil that doesn't drain?
install the baffle i sold?
i also have to switch to 5-40. same questions.
i hope those fragments of sentences were enough to get my point across...
:phillyb:
 Old 03-16-2010, 12:01 AM   #2
danesti's Avatar
Posts: 4,186   (View Stats)
danesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the world
Groans: 137
no more filthy boxes of oil for 7 bucks total from a mexican gas station?
first you cut your hair..
now this...
2012.
2008 STi
Intake
Turboback
AP
danesti is offline   Reply With Quote
The Following 3 Users Say Thank You to danesti For This Useful Post:
bykeryder4life (03-17-2010), phillyb (03-16-2010), SpeedSixxx (03-17-2010)
 Old 03-16-2010, 12:22 AM   #3
felt's Avatar
Posts: 1,504   (View Stats)
felt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the worldfelt is the leader of the world
Groans: 1,364
Groaned at 589 Times in 386 Posts
mexicans cant own a gas station in california. wtf nukkas.
felt is offline   Reply With Quote
The Following User Says NO Thank You to felt For This Un-useful Post:
 Old 03-16-2010, 12:24 AM   #4
phillyb's Avatar
Groans: 1,940
get the fuck outta here or gimme information
 Old 03-16-2010, 12:42 AM   #5
johnsin55's Avatar
Posts: 59   (View Stats)
johnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud of
Default Re: switching to sythetic oil
Id swap it out like a regular oil change, cruise around for a couple hundred miles or so then do one more change (including filter) and it should be more or less full synthetic by then... A little expensive but its easier then droppin the pan, which still would leave oil in the block anyways
Modified CP-E Xcel CAI with 3" ATP MAF housing--CP-E TIP--ATP GT2871R--CP-E FMIC--FORGE BPV--PTP Internals--COBB AP & DP--3" Vibrant Exhaust--SU Motor mounts rear and sides--Volk Te37 18"x7.5" +47
johnsin55 is offline   Reply With Quote
The Following User Says Thank You to johnsin55 For This Useful Post:
 Old 03-16-2010, 12:49 AM   #6
Doc
Doc's Avatar
Posts: 526   (View Stats)
Doc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the world
Groans: 35
Id just do a normal oil change.. then at 3500miles.. change it again and the filter.. that shit is too expensive to flush straight away.. its not going to hurt anything
Doc is offline   Reply With Quote
The Following 2 Users Say Thank You to Doc For This Useful Post:
phillyb (03-16-2010), Sacrilicious (03-16-2010)
 Old 03-16-2010, 02:45 AM   #7
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
MF wont pay for coolant and then wants to put synthetic oil in...........
Does not fuckin' compute!!!!!!
You want a mushroom tip...... I have a hookup
Suspension:
 Old 03-16-2010, 08:34 AM   #8
phillyb's Avatar
Groans: 1,940
i know what you mean.
i plan on doing a few fluid flushes...oil, coolant, and tranny fluid.
i plan on replacing with coolant or water with water wetter. i want to drain current water left in the system though.
and shut it...
 Old 03-16-2010, 08:53 AM   #9
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
just change the oil like you normally would...except with the synthetic. think of it as a "synthetic blend"...that's all they really do...=/
The Following User Says Thank You to Sacrilicious For This Useful Post:
 Old 03-16-2010, 09:43 AM   #10
darth vader's Avatar
Posts: 665   (View Stats)
This car beats the shyt out of oil, that for true, especially modded. Buy a good brand you like and change it out in the regular manner.
F*ck, I ran dino 15W40 Walmart-brand Tech 2000 oil in my blown drag car for 13 years, no problems. That car just got faster.
 Old 03-16-2010, 10:28 AM   #11
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
3500 miles, don't worry about dropping the oil pan, you can't have your baffle back & rotella 5w40.
The Following User Says Thank You to karl-hungus For This Useful Post:
 Old 03-16-2010, 10:33 AM   #12
phillyb's Avatar
Groans: 1,940
lol, i don't want the baffle back, but the thought did cross my mind.
 Old 03-16-2010, 11:02 AM   #13
johnnymsp3's Avatar
Posts: 12   (View Stats)
johnnymsp3 will become famous soon enoughjohnnymsp3 will become famous soon enough
No worries, just change it out. That's what I've done in the past with previous cars. After a few oil changes (assuming you continue to use synthetic) the old oil will flush out.
johnnymsp3 is offline   Reply With Quote
The Following User Says Thank You to johnnymsp3 For This Useful Post:
 Old 03-16-2010, 11:31 AM   #14
SPEEDRAC3R's Avatar
Posts: 399   (View Stats)
SPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the world
As above - just do an oil/filter change and refill with synthetic. I did mine at the first oil change.
2009 MS3GT - JBR 3.0" Wide Path Full Intake System | CorkSport TMIC |NATOR'd Test Pipe | Autotech HPFP | COBB AP (freek PERM in process) | NGK LTR7IX-11 (6510) | SURE Anchors | Bilstein B8's | 35% Tint
SPEEDRAC3R is offline   Reply With Quote
 Old 03-16-2010, 11:43 AM   #15
phillyb's Avatar
Groans: 1,940
something odd...i get the impression that not all of you change the filter with each change...i find that odd.
 Old 03-16-2010, 11:53 AM   #16
fhaze's Avatar
Posts: 552   (View Stats)
fhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the worldfhaze is the leader of the world
phil..belated welcome back btw..
I bought my MS6 with 120 on the odo. Changed oil at 1200 with dino 5/30 and filter. Changed oil and filter again @ 3.5k with M1 5/30 and oem filter. I've been changing at 3-5k with OEM filter and M1 5/30. I'm just around 50k on the clock. Time for tranny fluids for me though.
I don't lose a drop during changes, and car runs like a top.
Goodbye 06MS6 you were a great car.
2011 STi Limited w/ NAV Plasma Blue Pearl, Escort 9500ix, Invidia Catted TBE 3" Q300 Ti Tip, Cobb CAI + Box, AP Stage 2+ 93, Kartboy SS w/ Bushings, Rally Armor Flaps.
303whp/330lbft Pro-Tuned @ EFI Logics
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens, and you go faster.”
--Mr. Clarkson
fhaze is offline   Reply With Quote
The Following User Says Thank You to fhaze For This Useful Post:
 Old 03-16-2010, 11:57 AM   #17
phillyb's Avatar
Groans: 1,940
yeah, i've always changed the filter every time i do an oil change, except for the one time i just couldn't get the fucking cartridge off.
i've been on 5-30 for 47k
finally switching to 5-40
The Following User Says Thank You to phillyb For This Useful Post:
danesti (03-16-2010)
 Old 03-16-2010, 05:48 PM   #18
danesti's Avatar
Groans: 137
eh.. dirty oil is better than no oil..
but in all seriousness the filter should be changed every oil change. unless you drive a ms3/6 and that fucker is impossible to get out without the proper tools.
spin on ftw.
2008 STi
Intake
Turboback
AP
The Following User Says Thank You to danesti For This Useful Post:
 Old 03-16-2010, 05:50 PM   #19
phillyb's Avatar
Groans: 1,940
you remember that?
trying to take the cartridge off with the channel locks???
hahaha
 Old 03-16-2010, 05:51 PM   #20
danesti's Avatar
Groans: 137
hahah yup.
minus the getting intoxicated part we suck at a lot of shit.
2008 STi
Intake
Turboback
AP
 Old 03-16-2010, 10:02 PM   #21
Doc
Doc's Avatar
Groans: 35
I oil change every 5000 kms, filter get changed every 10,000kms.
 Old 03-17-2010, 05:51 PM   #22
patrick failman
Groans: 74
spin on conversion is a pita but i feel good about running the big black filter. same flute size as the cartridge too.
The Following 2 Users Say Thank You to karl-hungus For This Useful Post:
phillyb (03-17-2010), SpeedSixxx (03-17-2010)
 Old 03-17-2010, 05:58 PM   #23
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
i'm clueless as to why you didnt use synthetic oil from the moment you got ur fail boat.
The Following User Says Thank You to SpeedSixxx For This Useful Post:
karl-hungus (03-17-2010)
 Old 03-17-2010, 06:05 PM   #24
phillyb's Avatar
Groans: 1,940
spin on is a pain in the ass?
that was a pretty easy, straightforward install to me. idk
 Old 03-17-2010, 06:15 PM   #25
patrick failman
Groans: 74
i didn't have a stubby 15mm wrench for the bolt on top of the oil cooler.
how many miles do you have and you're just shifting to synthetic? that has to be some kind of record. it's like buying the hooker breakfast at this point.
 Old 03-17-2010, 06:17 PM   #26
phillyb's Avatar
Groans: 1,940
47k
 Old 03-17-2010, 06:46 PM   #27
ANGRYEAGLE's Avatar
Posts: 133   (View Stats)
ANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant futureANGRYEAGLE has a brilliant future
Why the fuck won't my dealer put synthetic in mine then? He tells me no go for these cars. I mean he could be getting an extra $40 off of me every oil change. By the way my manual says change the oil every 5k.
ANGRYEAGLE is offline   Reply With Quote
 Old 03-17-2010, 06:48 PM   #28
phillyb's Avatar
Groans: 1,940
i do not have a good answer for this.
the only thing i can really come up with is $$$$$$$$$
 Old 03-17-2010, 07:11 PM   #29
patrick failman
Groans: 74
The Following 3 Users Say Thank You to karl-hungus For This Useful Post:
bykeryder4life (03-17-2010), FreeFlyFreak (03-17-2010), SpeedSixxx (03-17-2010)
 Old 03-17-2010, 07:12 PM   #30
bykeryder4life's Avatar
Posts: 1,032   (View Stats)
bykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the world
Groans: 38
philly, switch it to synth oil like a normal oil change and get an oil wrench tool from mazda to get the cartridge off properly every time. I think I paid like 25 bucks for the tool. torque it correctly next time fool! id also recommend you get a fresh oil drain plug washer if you dont change it out each time, synthetic oil is more "slippery" for lack of a better term, and can cause oil leaks to start appearing if you have always ran regular oil and are just switching.
bykeryder4life is offline   Reply With Quote
 Old 03-17-2010, 07:19 PM   #31
I'm a caveman
gtlaw's Avatar
Posts: 758   (View Stats)
gtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the worldgtlaw is the leader of the world
Groans: 68
the manual also says to use conventional oil. mazda has had something against synthetic oil for a long time now
2015 MUSTANG GTPP
gtlaw is offline   Reply With Quote
 Old 03-17-2010, 07:54 PM   #32
Groans: 38
fuck mazda dealers
The Following User Says Thank You to bykeryder4life For This Useful Post:
 Old 03-17-2010, 08:51 PM   #33
SpeedSixxx's Avatar
Groans: 778
dude....synthetic is what you should use.
all modern cars use it, why would we be any different?
and...do this, look at your oil at 3k and see how nasty and black it is with no viscosity left.
then look at it at 5k when you change it yourself and see how it feels like chalk.
I try and change my oil at 2500 miles if I can but i'll go 4k if i'm broke.
 Old 03-17-2010, 09:05 PM   #34
SpeedSixxx's Avatar
Groans: 778
=) I understand, too bad you don't have the autozone hook up like me.
40 bills and I get 8 qrts of oil, filter and whatever else I can fit in the bag.
u send me some medical budd and i'll send you some synthetic oil and filter. even trade
 Old 03-17-2010, 10:40 PM   #35
R.MS3's Avatar
Posts: 987   (View Stats)
Have any of you tried the new Pennzoil Ultra?
I saw this new oil right next to the Platinum that i usually buy at Walmart. I said WTH and bought it, even though it came to about $36, compared to the $28 for the Platinum, 6qts.
After using this oil for about 150 miles, it seems my PT KR have gone down a lot, getting mostly 0.4 or 0.7. It's supposed to clean a lot of the gunk in there and anything to keep KR at bay is welcomed. Not calling any miracle here but it's strange not seeing the KR warning on my DH coming up every so often.
Might be worth a try for some of you.
R.MS3 is offline   Reply With Quote
 Old 03-17-2010, 10:53 PM   #36
SpeedSixxx's Avatar
Groans: 778
use valvoline syn or thier new V race oil
 Old 03-17-2010, 10:54 PM   #37
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
American Forum = American Units = Miles ninja!
lol
The Following 3 Users Say Thank You to hnda etr For This Useful Post:
Doc (03-18-2010), karl-hungus (03-18-2010), SpeedSixxx (03-17-2010)
 Old 03-17-2010, 10:55 PM   #38
SpeedSixxx's Avatar
Groans: 778
lol
THANK YOU
 Old 03-18-2010, 12:01 AM   #39
Doc
Doc's Avatar
Groans: 35
Sorry if this confuses some people here
Convert km to miles - Conversion of Measurement Units
Hope this helps...lol
 Old 03-18-2010, 12:02 AM   #40
phillyb's Avatar
Groans: 1,940
hahahahah
Doc (03-18-2010)
ipod switching unit doggs31 MazdaSpeed 3/6 - Car Audio & Electronics 0 09-29-2009 05:08 AM
Switching to MBC cpolly69 MazdaSpeed 3/6 - Turbo Induction 10 09-20-2009 06:43 PM
BMW switching to turbocharged M cars Haltech Automotive News 0 11-27-2008 07:50 AM
Page generated in 0.54134 seconds with 37 queries
