![]() | | #1 | ![]() |
| Banned ![]() Join Date: Mar 2012 Location: Akron/Ohio
Rep Power: 0 ![]() ![]() ![]() Thanks: 9
(Thread Starter) | Not Ranked : 0 score My issue is when the car is decelerating 2nd to 1st, it won't go into gear until it is a low speed such as 5mph. And this is even with the clutch fully down or engaged. I read another thread with a similar issue and it was a broken syncro. If this is the case am I covered by power train warranty because the car has under 42K on it? |
![]() Join Date: Jan 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 975
Groans: 52
| Not Ranked : 0 score Don't go in first until you are under 5 MPH anyways.... Does it pop out if you engine brake in 1st or 2nd gear? (4000ish RPM and let off throttle, let car slow on its own)
__________________ Black Mica 2006 Speed6 GT | 62,000 Miles Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1 ms6db.com I'm Registered. Are You? |
| The Following User Says Thank You to jm211 For This Useful Post: | chuckms6 (12-25-2012) |
Groans: 793
| Not Ranked : 0 score There is no syncro for first gear. On ANY car, that I know of. And certainly not this one.
![]() | | #4 | ![]() |
![]() Join Date: May 2010 Location: Colorado Springs, CO 80915
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 921
| Not Ranked : 0 score Why the hell are you downshifting to 1st to begin with? You only put the car into 1st gear when your at a complete stop. Sent from my Motorola DynaTAC 8000X
__________________ 2010 Mazdaspeed 3 - Built Motor - GTX3071: SOLD 2012 Jeep Wrangler Unlimited Sport: Current DD |
![]() | | #5 | ![]() |
Groans: 793
| Not Ranked : 0 score I downshift to first all the time. You just have to rev match.
![]() | | #6 | ![]() |
![]() Join Date: May 2011 Location: Ft. Worth TEXAS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 89
| Not Ranked : 0 score This.. Bump the throttle and.it goes.in..
__________________ 07Speed3 TWM STS || Forge BPVv1 || Sure RMM || Cobb SRI || CNT DP || AP || Autotech || ITV22 || COBB/TR8L FMIC || JBR TB&IM TIG || HTP TIP || JBR PMM&TMM || JBR EGR DELETE || Cobb CBE || SONIC COs || Perm Plate & OCC || JBR OCC || PnP IM || DO Meth Inj. || |
![]() | | #7 | ![]() |
Groans: 111
When you downshift make sure you either do it quickly and do not remove your foot from the gas pedal completely. If you downshift this way from 3rs to 2nd or other upper gears the synchros will help with your poor shifting, but not from 2nd to 1st. There is no problem downshifting from 2nd to 1st even from 25mph (I never tried from more than that because it was not necessary) as long as you do it right.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
![]() | | #8 | ![]() |
Rep Power: 7491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
Downshifting to first is terrible for the syncros and will destroy the forks unless you rev match. Why would anyone need to downshift to first in a moving car, first is worthless for anything.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG | |
| The Following 2 Users Say Thank You to 06Speed6 For This Useful Post: | chuckms6 (12-25-2012), DISIindahead (12-25-2012) |
![]() | | #9 | ![]() |
Groans: 793
| Not Ranked : 0 score I didn't think any cars has syncros for first, but I guess I'll look into it. If you've ever driven rattle snake point, or forks of the credit road, you'd know why you need to downshift into first.
![]() | | #10 | ![]() |
Groans: 111
Or when you need to pass rapidly some very slow vehicle while going uphill and moving really slow behind it, with like 15mph or so. It also makes sense on tight technical and short circuits where you need to make tight turns, eventually to rotate the car using the handbrake and then accelerate quickly out of the turn. There are a lot of situations like these I encountered over the time, there may be more.
![]() | | #11 | ![]() |
Groans: 793
| Not Ranked : 0 score Apparently we do have triple cone synchros on the first three years.
| The Following User Says Thank You to Tokay444 For This Useful Post: | 06Speed6 (12-27-2012) |
![]() | | #12 | ![]() |
![]() Join Date: Dec 2009 Location: San Antonio, TX
Rep Power: 5051 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,143
Groans: 146
| Not Ranked : 0 score Were the synchros the only thing replaced? |
![]() | | #13 | ![]() |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
Groans: 52
| Not Ranked : 0 score post a copy of the service order for details or this is /thread |
| The Following User Says Thank You to Nitr0EngiE For This Useful Post: | pzr2874 (12-25-2012) |
![]() | | #14 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks for the answers and makes senses to me now |
| Syncro's shot!? | :: Gusto :: | MazdaSpeed 6 - Engine, Transmission & Driveline | 21 | 09-20-2011 09:20 PM |
| New MS6.... a few issues | Fatguy729 | MazdaSpeed 3/6 - ECU Computer Tuning | 11 | 08-31-2011 10:57 PM |
| RX8 issues | TRex | Wheels & Tires - BLACK | 9 | 08-21-2011 04:01 PM |
| CS CBE Issues | Airman3454 | Gen2 MS3 General Discussion | 7 | 06-16-2011 05:01 PM |
