Testing a new Ignition Upgrade - Plasma System 1 Attachment(s) So from what it seems, it looks like our ignition system might get a upgrade. I been helping out a company testing a plasma type ignition system and from what the butt dyno tells me (and dashdaq logs) the car drives and feels better. I can tell there has been a increase is mileage and as well as power and the small traces of knock I would have haven't shown since I been testing the system. SPDi Spark is the company for the product - SPDi Spark . I was approached to help and figured that it might be a product that would help us, and so why not. However this is where I need more help from the forum. Short of dyno runs (hopefully I can get something worked out here soonish to get some dyno runs going), what else would be something to look for test for. I realize that buttdyno is subjective hence I am looking for what else to look for short of dyno runs and ignition timings (before and after). Hopefully while I have the system for the next while I can test/lookup whatever some of you gearheads want or think might be beneficial and help us learn more and prove if this works or does not work for us. Any thoughts? suggestions? ideas? ----------------------------------------------------------------------------------- I'll cut and paste some info from the website incase those that want to read some more without going to the website: Quote:
Subbed for curiosity. Give it a little tap, a tap tap tap-a-roo |
Hm...veeerry interesting. 60-100 runs are usually a good indicator of increased power if you have some before runs to compare to. What kind of gas mileage increase did you notice? I Tapped that |
How do they differentiate heat ranges? |
That read was a mind fuck Tapin it |
subbed for interest, looks like it will run in between stock parts, I am curious not only about heat range of the plugs (I would think you would want to go very cold as you can control spark quality now in another way) but also longevity of the plugs compared to OEM... |
Without. 10 bucks at 1.41 bucks a liter = 7.09 liters I got 73Kms With. 7.09 liters (costed 10.21, 1.44 bucks a liter) I got 77Kms Only a 4Km difference, could be the error factor/driving conditions (they were relatively the same) it was all done on highway at the same station/route to try and keep it the same but again its not really scientific, merely a quick test on my own. I would need more controled conditions. But if this is kinda prelude to what it COULD do, then I would estimate maybe ~30 kms more a tank. Not a huge difference but a difference none the less. Quote:
It has its own module box (bout the size of a hockey puck) and uses some sorta denso/motorcycle coils (I have 4 of them on the car, replacing each of the stock coils) and obviously its own wiring. Quote:
------------------------ What else do you guys want me to test? any idea's of what I could test? how to test? what would yeild some results that we we would be interested in? Again it feels like its working and doing something, but I need to figureout what else I can test to get some quantifyable results (dyno would be one way, but what else is there?). I just want to make sure if this is something that will help this platform, or something that really wont help. I assume Big Turbo guys with blowout or whatever might benefit from this more then anyone. However I think closest competitor to this would be the Kenne Bell Boost a Spark (even though both systems are different) thats where my mind immedately goes to. Also how would I go about testing spark time itself? Anything to specifically log? The DashDAQ doesnt have anything other then timing (even with the enhanced ford PIDs). What I am trying to figure is stock the ECU sends the signal to the coils, in this system it sends to the Module Box THEN to the Coils...does this introduce any sort of latency? in my mind it would? But is it enough to cause anything? I'll see if I can tag some of the bigger gear heads then me into this... @Lex; @Dano; @djuosnteisn; @MS3-a(sore)ASS-rex; Feel free to tag anyone else that might have some insight. |
2 Attachment(s) Heres 2 pics I got from their website. Might help some understand more. Heres one of the spark and one of the software. I attached them. |
cool stuff. subbed |
I got some beachfront property in Arizona that ill sell you if you think this snake oil works. |
Here's a good thread about it (I think, haven't finished it). SPDI plasma ignition - Turbobricks Forums And since they're in Canadia, maybe @Lex would be interested. |
I aint paying anything for this... Just testing to help out and see if this helps the platform. If it doesnt, it doesnt...if it does, it does. Hence I am asking what else can we test or would be a test to indicate if it does or doesnt work. Quote:
I am interested to see if this works. Hence I am asking the bigger gearheads here what could suffice that would prove or disprove this. |
Same car, same hard parts setup, the only thing that changes is the ignition system. Fully tune them on a dyno (fuel of your choice) until knock or MBT is reached. Watch what happens in the tune along with the power curve, BSFC, and emissions (probably can't get this, though) would tell us results. |
Yesterday a guy came on a local forum saying they have a similar product (Okada PlasmaDirect) available but only for EVO's and Subaru's for now. They didn't have any part# specific to our cars (only for Miata's and rotary powered Mazda's) and that guy pointed me to the HKS DLI2 TwinPower. Ok, so now what's supposed to be the difference between the two? One (HKS) controls the voltage and has a more accurate way of making that voltage available as much as possible and the other one is accomplishing about the same using better coils? |
Subbed As long as the price doesn't trump the HKS system |
DIY SPDi Kit | SPDi Spark DIY kit is 430 CAD, but you need to add coils and who knows what else, also note it will shut off if it gets to 100 Degrees C, likely not a problem but mounting it close to the coil packs might not be a good thing. curious and agree that same car, pre/post on a dyno would be a good thing, a long term test and eval on fuel use and plug wear would be another. |
I think its a great system if the system its replacing sucks, otherwise its a waste of money. I like to rate parts like this by cost vs power. If it added 2hp and cost $400 then it gives ya 1hp for every $200. Compaired to a downpipe that gives 30hp for $400ish, its gonna be last on almost everyones list. |
starscream, if you know pippy with the Evo X, you'll know that he also dyno tested this for SPDi on his Evo at APH and it did diddly squat. if you take the BS filter to their "technical" mumbo jumbo you'll see that you could achieve the same thing by indexing your spark plugs. |
It's been proven repeatedly that "plasma," plugs are snake oil. Why are we wasting your time? |
Thanks for the info though. I just want to get more info/results on this. Quote:
Again, not bashing, but honestly trying to get whatever informaiton I can get my hands on, and as well do whatever testing I can, and post results. So far Dyno and Exhaust Gas analysing is what most are asking for, but what else can I do? Any more info totally would help. |
Its nearly untestable because its effect is so small that is falls within the same range as the oem coil. |
I find it funny because people call the, spark plugs they don't actually spark they arc. So we should've calling them arc plugs. Since arcing is a form of a gas in a plasma state we already have a plasma ignition. Clever marketing but a silly product in my opinion. To be honest all you would have to do is upgrade the stock capacitor and you could do the same thing as this system. The part that I am concerned with is now that you are interrupting the stock signal you will start to affect the latency calculator done by the ECU so you may in fact loose power because of the improper timing. This isn't like extending a conductor which has no effect on latency. This is adding more control to something that works properly as it is which generally leads to problems. |
| All times are GMT -7. The time now is 08:01 AM. |
