![]() | | #81 | ![]() |
![]() Join Date: Feb 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
Groaned at 36 Times in 8 Posts
| Not Ranked : 0 score I would still like to see the other unknowns. |
![]() | | #82 | ![]() |
![]() Join Date: Nov 2008 Location: Palm Harbor, Fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
(Thread Starter) | Not Ranked : 0 score No more FP worries here, Just order MazdaSPEED3 HPFpump from CPE. Should be in tomorrow,installed by Saturday right before the tunning session. http://www.cp-e.com/2111.html?open=0,100 |
![]() | | #83 | ![]() |
![]() Join Date: Oct 2008 Location: Western Hemisphere
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
Groans: 91
| Not Ranked : 0 score How's the install on a fuel pump? Can an idiot do it?
__________________ Gay car #1: 2001 Miata (Gay White) Gay car #2: 2011 Mazda 2 (Gay Blue) |
![]() | | #84 | ![]() |
![]() Join Date: Jan 2009
| Not Ranked : 0 score Yes. And in under 45 minutes, from what I understand. |
![]() | | #85 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 19 Times in 2 Posts
| Not Ranked : 0 score |
![]() | | #86 | ![]() |
![]() Join Date: May 2008 Location: NOVA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
Groaned at 47 Times in 40 Posts
![]() | | #87 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
Groaned at 9 Times in 3 Posts
VERY EASY I hear. Solves fuel pressure issues instantly. If any of you have gotten that high rpm stutter or cut, it's fuel and the cpe pump will fix any issues up to 400 whp. For anyone with logging ability, check fuel pressure. If at anytime at high rpms, the fuel pressure drops off significantly, you are pushing the fuel delivery limits of the stock CDFP. Log on the coldest days. Fuel flow past 20 gph will result in a cut.
__________________ 2007 Cosmic Blue Mazdaspeed 3 GT Mods: Mazdaspeed Cold Air Intake, Mazdaspeed Cat-Back Exhaust, Defi BF Amber Boost Gauge in Driver's Vent Last edited by ASIC_BSEE; 01-20-2010 at 10:52 AM. | |||||
![]() | | #88 | ![]() |
| Not Ranked : 0 score I have a MSCAI as well. But, I wouldn't say it's the BEST design out there. Let's face it, the location of the MAF is a bit to be desired. The addition of the air straightener would solidify the point. However, I am pleased with the gains, sound, and overall appeal of the product. SRIs have plenty of cold air creeping in that it's a bit of a moot point. Also, with that snail generating so much heat, it's not as critical to scavenge cold air as it would be with an NA motor. But, I'm glad someone else out there doesn't feel the need to tee off on the MSCAI. |
![]() | | #89 | ![]() |
(Thread Starter) | Not Ranked : 0 score HPF Pump #0085 delivers a smoother power band. I haven't had the car on the dyno yet, still breaking in 900miles of the required 1000 miles. But the data logs don't tell lies its plan to see that the flow/pressure is able to handle engine loads better.... Last edited by tazman34685; 02-24-2009 at 07:19 PM. |
![]() | | #90 | ![]() |
Rep Power: 0 ![]() ![]() Thanks: 8
| Not Ranked : 0 score FBPEM1 am I right in understanding that you had verified that your pump was operating properly and that it has now changed and is not keeping up the pressure as it was? Is this due to more fuel demands because you have made changes to the engine or has the pump performance dropped without any other engine modifications? If you made changes then that is a smaller issue because you may be requiring more fuel. If a pump that was working properly is now not keeping up with the same demand from it then that is a much bigger issue. Ed. |
![]() | | #91 | ![]() |
![]() Join Date: Sep 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 145
Groans: 29
-Jeff at PG
__________________ All wagon, No traction | |
![]() | | #92 | ![]() |
| Not Ranked : 0 score Wassup61 that is not reassuring. From what I have read people are basically redesigning the pistons to provide more fuel - the basic pump is the same. Do we know that the problem that has occurred with these "fickle" pumps was due to a problem with the pump's piston? If we do not know that then you can have it happen again at any time even with a rebuilt pump - ie new piston design. Ed |
![]() | | #93 | ![]() |
Groans: 29
-Jeff at PG
![]() | | #94 | ![]() |
![]() Join Date: Mar 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 97
| Not Ranked : 0 score Good information. Has there been reports of people with bone stock cars with failed fuel pumps? |
![]() | | #95 | ![]() |
Groans: 29
Jeff at PG
![]() | | #96 | ![]() |
![]() Join Date: Sep 2008 Location: Phoenix, AZ
Rep Power: 1352 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 813
| Not Ranked : 0 score Pretty sure the TSB says manufactured before Nov 07, forget the VIN though. Check your date on the sticker on the driver side door panel.
__________________ Some things. |
![]() | | #97 | ![]() |
| Not Ranked : 0 score Oh, so this was a known problem fixed by Mazda? |
![]() | | #98 | ![]() |
| Not Ranked : 0 score The failing pumps yes. But after you add enough mods/power even the proper stock internals may not be able to flow efficiently under higher demands.
![]() | | #99 | ![]() |
| Not Ranked : 0 score Yeah I plan on staying stock for a bit, but I was planning on when I do mod to have a HPFP or internals done as one of the early mods. And I mean when, stupid newly installed lift is making it hard not to tare into this car. |
| ANOTHER VICTIM OF A BLOWN MOTOR | ev0nstispanka | MazdaSpeed 3 - Engine, Transmission & Driveline | 107 | 01-06-2009 11:52 PM |
| another blown engine | b-ron | MazdaSpeed 6 - Engine, Transmission & Driveline | 28 | 12-16-2008 08:29 AM |
| Motor Blown, Rod through block | cageyvet | MazdaSpeed 3 - Engine, Transmission & Driveline | 35 | 12-12-2008 03:31 PM |
| Blown Seal? | Rican219 | MazdaSpeed 6 - Engine, Transmission & Driveline | 8 | 04-19-2008 09:52 AM |
