 Old 09-13-2008, 06:52 PM   #41
bykeryder4life's Avatar
Posts: 1,032   (View Stats)
bykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the world
Groans: 38
yes you need to get it honed even if its just a little if you plan on using your stock block. you cant just pull out the stock pistons and slide in the forged internals. the stock pistons have worn in with the cylinder walls when you broke in the car and putting in brand new ones without resurfacing the cylinders would not be smart for your build. Theres no easy or cheap way to do it... you have to do it all and do it all at the same time. I wouldnt lower my compression and run the stock tune....but I donno about that stuff too much so good luck man! excited to see the outcome.
bykeryder4life is offline   Reply With Quote
 Old 09-13-2008, 06:56 PM   #42
atomicms3's Avatar
Posts: 459   (View Stats)
atomicms3 is the leader of the worldatomicms3 is the leader of the worldatomicms3 is the leader of the worldatomicms3 is the leader of the worldatomicms3 is the leader of the worldatomicms3 is the leader of the worldatomicms3 is the leader of the worldatomicms3 is the leader of the worldatomicms3 is the leader of the worldatomicms3 is the leader of the worldatomicms3 is the leader of the world
Honing can usually be done anywhere, you don't need to bolt the block into a mill or anything.
2007 MS3 GT - 25k+ miles a year... what's a warranty?
atomicms3 is offline   Reply With Quote
 Old 09-13-2008, 07:40 PM   #43
Grim's Avatar
Posts: 2,395   (View Stats)
Grim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the world
well,i have a friend that runs a small aftermarket mazda3 parts company and he is going to help me pull the engine,he also has a hookup with none other,Dee karagiannis, i can send him my block to get built and honed for 1100.
Black 2003 Evo VIII-3in TBE,HKS 280's,ETS Intake,Halman pro MBC,Forge BOV,Precision 6262,4" Intercooler,AEM Meth injection,Manely S&R's.4G63 FTW!
Grim is offline   Reply With Quote
 Old 09-13-2008, 07:44 PM   #44
Groans: 38
sweeeet thats the way to go then
 Old 09-28-2008, 12:56 AM   #45
Speedie6's Avatar
Posts: 1,838   (View Stats)
Speedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the world
I had asked in another thread if there was a way to just do the rods from just the bottom without pulling the head. I was told no, and I'm sure that is right. But, I just thought I'd get some extra opinions.
Speedie6 is offline   Reply With Quote
 Old 09-28-2008, 07:19 AM   #46
CMESCOOT's Avatar
Posts: 429   (View Stats)
CMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the worldCMESCOOT is the leader of the world
If you're going to do the rods, you'll have to do pistons too. And the motor does have to be pulled. I just went through this mayhem about three weeks ago. Good luck!
http://active.com/donate/1soldier
Making the world a safer place one Taliban at a time.
Arias 8.8:1 Pistons - Pauter rods - Balance Shaft Delete - ARP Head Studs - Street Unit Rear Motor Mount - TurboXS Hybrid BOV - TurboXS Downpipe - - TurboXS FMIC - CP-E CAI - Custom Built/ported and polished Turbo and Wastegate - CP-E Engine Management - Upgraded high pressure fuel pump - PG Turbo Exhaust manifold - PG Dash mount gauge pod - Cooling Mist Progressive Methanol Injection - Apexi TT - VEI gauges (oil pressure, boost ) - Dashhawk -LaminX Fog lights - H&R Sport Springs - Cobb Rear Sway Bar - Tenzo DC-s wrapped in Nitto InVo's - TWM short throw shifter and bushings
CMESCOOT is offline   Reply With Quote
 Old 09-28-2008, 09:11 AM   #47
Speedie6's Avatar
Okay. Well, I guess I'm not going to rush into this.
 Old 09-28-2008, 11:22 AM   #48
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
You dont have to do pistons but you would be a complete idiot to pull the motor and not replace them. While you are at it, do some port matching to the head and intake while you are at it.
 Old 09-28-2008, 12:37 PM   #49
Speedie6's Avatar
There were two reasons I was considering just the rods. For one, I had hoped there might be some easy way to get to the rods from the bottom and not have to pull the head. It appears not. And for two, I've heard people having trouble getting it tuned right after replacing heads. That the aftermarket heads are high quality I'm sure, but, that it would be different than what the ECU is expecting.
But, given that to do it, you have to do it all, then, I guess I will do that some day. By then, maybe there will be more shops with build experience on the MZR.
Thinking about ordering these... ATE BALLER Mazdaspeed3/6 General Discussion 4 08-19-2008 10:41 AM
Thinking of running slicks ms3jake Drag Racing 0 08-14-2008 11:31 AM
Thinking about getting the E-Cutout again. bioevolve MazdaSpeed 3 - Engine, Transmission & Driveline 4 08-14-2008 08:59 AM
The thinking (or lack thereof) behind KITT F-150 Haltech Automotive News 0 07-30-2008 09:40 AM
Page generated in 0.29232 seconds with 25 queries
