Like Tree2Likes
 Old 06-13-2009, 10:38 AM   #1
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
Default Throttle Body By-Pass
Had about 30 mintues to work on the car today. Did a TB By-Pass.
You can use vacuum caps or just use one of the hoses you take off to cap the TB in/out ports. I used the vacuum caps supplied by PTP IM gasket. Took the TMIC off to get to it better and clearer pictures.
The hose coming from the metal pipe near the head is routed to the metal pipe below the head/on the block.
Re-routed to block pipe. There will be some radiator fluid that will spill out, just do it fast lol.
The other hose you removed can be reuse to cap off the TB on both in/out ports on the TB.
Caps I used to cap the TB in/out ports.
For people who live in colder climates need to put it back on during winter or just make a plumbing valve to open and close to the TB, sort of like a "Y" By-Pass with a diverter valve and you won't have to take it off and on all the time.
The Following 4 Users Say Thank You to bioevolve For This Useful Post:
Addikted To Boost (08-28-2009), BolvangaR (04-15-2010), JmkC (10-10-2009), skeeter149 (10-09-2009)
 Old 06-13-2009, 10:43 AM   #2
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
do you notice anything? or just did it for the hell of it?
The Following User Says Thank You to aaronc7 For This Useful Post:
bioevolve (06-13-2009)
 Old 06-13-2009, 10:46 AM   #3
Alittle Faster
bioevolve's Avatar
Just for the hell of it lol, nothing else to do to the car until some more parts come in lol.
I will do/check BAT logs later to see if it changed any.
 Old 06-13-2009, 10:57 AM   #4
aaronc7's Avatar
Groans: 370
cool, yeah same here I am thinking about doing it too!
The Following 3 Users Say Thank You to aaronc7 For This Useful Post:
bioevolve (06-13-2009), BolvangaR (04-15-2010), Chriscote (08-05-2011)
 Old 06-13-2009, 11:02 AM   #5
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
dont 4get the chicken wire
The Following 3 Users Say Thank You to rodrigo For This Useful Post:
bioevolve (06-13-2009), BolvangaR (04-15-2010), Tokay444 (06-06-2011)
 Old 06-13-2009, 11:26 AM   #6
Alittle Faster
bioevolve's Avatar
Go for it lol!
PTP didn't send me any yet lol. Might just go down to Lowes or Homedepot and get some mesh to put on lol, Nator style!
The Following 2 Users Say Thank You to bioevolve For This Useful Post:
Fobio (06-13-2009), phillyb (06-13-2009)
 Old 06-13-2009, 06:23 PM   #7
ptperformance's Avatar
Posts: 4,123   (View Stats)
ptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the world
Nator style, LOL.
ptperformance is offline   Reply With Quote
The Following 2 Users Say Thank You to ptperformance For This Useful Post:
glocK23 (06-14-2009), phillyb (06-13-2009)
 Old 06-13-2009, 07:59 PM   #8
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
i still really don't get this. you're taking coolant out of throttle body?
The Following 2 Users Say Thank You to phillyb For This Useful Post:
 Old 06-13-2009, 08:23 PM   #9
phantom6294's Avatar
Posts: 255   (View Stats)
phantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the world
As I understand it... many cars have coolant flowing through the throttle body to keep it warm/hot enough to not let 'gunk' build up around the throttle opening. The gunk is being pulled in via the PCV system. Without the coolant, this gunk would harden where it collects. So, if you have a good catch can, or don't mind cleaning the throttle body regularly, bypassing the coolant flow through the throttle body should help reduce air temps; BATs for us.
That's my understanding at least.
phantom6294 is offline   Reply With Quote
The Following 6 Users Say Thank You to phantom6294 For This Useful Post:
bioevolve (06-13-2009), BolvangaR (04-15-2010), davros (04-15-2015), Fobio (06-13-2009), Miltron (06-24-2014), phillyb (06-13-2009)
 Old 06-13-2009, 08:35 PM   #10
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
you are eliminating coolant flowing throughout some cavities of the throttle body by plugging some of the lines that feed it coolant. therefore making it cooler since the water temp after normal operating temps usually will be higher than the throttle body temp. The coolant flowing through there isn't to cool like inside the engine it serves another purpose, to heat.
bioevolve (06-13-2009), BolvangaR (04-15-2010), phillyb (06-14-2009)
 Old 06-13-2009, 08:56 PM   #11
Alittle Faster
bioevolve's Avatar
I have a catch can on. When the TT L/A IC comes in I will tap it's cold pipe and spray the meth in front of the TB to help clean it, right now the meth is spraying thru the PTP freezeplug in the IM. Still getting vapors and crap from the Valve cover hose, I might put another catch can there too.
 Old 06-14-2009, 12:09 AM   #12
phillyb's Avatar
Groans: 1,940
dope. thanks for the info. so for throttle body bypass, it's recommended to have a catch can elsewhere?
bioevolve (06-14-2009), BolvangaR (04-15-2010)
 Old 06-14-2009, 06:11 AM   #13
Alittle Faster
bioevolve's Avatar
I would still recommend catch for the PCV area still, just another one at the valve cover hose also. That is just my opinion thou, you don't have to.
The Following User Says Thank You to bioevolve For This Useful Post:
 Old 10-08-2009, 04:18 PM   #14
1mpg's Avatar
Posts: 37   (View Stats)
1mpg is a jewel in the rough1mpg is a jewel in the rough1mpg is a jewel in the rough
Groaned at 4 Times in 2 Posts
So how cold does it have to be to put the throttle body coolant plumbing back on? It get to about 25 some nights here in Gainesville, but I dont drive to work so I dont have to dtart my car till it warms up.
2008 Cosmic Blue MS3
Corksport TBE
Corksport FMIC
Turbosmart BOV
1-step colder Densos
Streetunit Rear Motor Mount
Eibach ProKit
Tenzo DC-5 v.2
Hankook Ventus V12 235/40/18
Hypertech tuned
1mpg is offline   Reply With Quote
The Following 2 Users Say Thank You to 1mpg For This Useful Post:
bioevolve (10-08-2009), BolvangaR (04-15-2010)
 Old 10-08-2009, 05:36 PM   #15
Alittle Faster
bioevolve's Avatar
I guess below freezing, but if you turn the car on when it warms up I wouldn't worry about it.
 Old 10-08-2009, 08:16 PM   #16
darth vader's Avatar
Posts: 665   (View Stats)
I don't know where EGR is plumbed on this car but, often it's near the TB and the coolant is there to actually cool off the TB housing, as well as warm it during cold start.
The Following 2 Users Say Thank You to darth vader For This Useful Post:
bioevolve (10-09-2009), BolvangaR (04-15-2010)
 Old 10-08-2009, 11:25 PM   #17
JmkC's Avatar
Posts: 871   (View Stats)
JmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the world
Groans: 109
Groaned at 6 Times in 6 Posts
i dont understand how it would be cooling it off. 190 degree coolant flowing through a throttle body that as cooler air already going through it only makes sense to me it keeps it hot. and i dont see why if it is freezing out that you need to heat it up?
JmkC is offline   Reply With Quote
The Following User Says Thank You to JmkC For This Useful Post:
 Old 10-09-2009, 04:39 AM   #18
Alittle Faster
bioevolve's Avatar
EGR is on the side of the TB closest to the head, other end to the side of the head closest to the inlet pipe/intake tube.
Coolant is only there to warm the TB. Unfreeze it if frozen.
You are right it's not for cooling. We have Throttle by wire, gears on in the mechanics side of the system are attached to the TB. Also to help keep the butterfly plate and the shaft that the butterfly plate is attached to. If they are frozen, obviously it would get stuck hence the heating of the TB to unfreeze it.
I'm not sure how low the temps need to be to freeze the gears and/or the butterfly plate/shaft.
JmkC (10-10-2009)
 Old 10-09-2009, 04:38 PM   #19
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
It is just a safety measure for colder climates, it would suck to have your TB stick while you are on the highway etc.
2006 Mazdaspeed 6
 Old 10-09-2009, 10:37 PM   #20
JmkC's Avatar
Groans: 109
but really what are the chances of it freezing? its right up tight close to the motor. even the intake manifold gets hot from motor..
The Following 2 Users Say Thank You to JmkC For This Useful Post:
bioevolve (10-10-2009), BolvangaR (04-15-2010)
 Old 10-10-2009, 01:13 AM   #21
You don't know much about airplanes I bet. Airflow through venturis, with the increase in airspeed of that flow, can actually ice the surfaces up and that's what sticks them. Not immensely likely anywhere short of the Yukon but, possible.
If EGR is ANYWHERE near the TB, that's ~1300 degrees of exhaust heat hitting that TB. The 190 degree water takes most of that away, easily, being a better heat sink than the air that is now in those water passages.
 Old 10-16-2009, 08:38 PM   #22
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
Addikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the worldAddikted To Boost is the leader of the world
Groans: 157
Groaned at 29 Times in 16 Posts
bio, i recently undid my throttle body bypass so i could take my car in to the dealer to get my thermo replaced and i am just wondering if i put it back correctly. Is the hose at the very front (most forward) the input and the one towards the rear of the car is the exit that goes down to the little black pipe that is shown in your last pic? I think im gonna leave it hooked up for the winter and undo it again in the spring because it frequently gets down to single digits where i live. Sorry for the stupid question this seems like a common sense thing but i cannot remember how it was when i unhooked it.
09 MGM MS3
BNR S3 V2, Freek'd Corn Toon, Cobb AP V3, Cobb FMIC w/ JBR piping, JBR WP 3.5 silicone, Cobb EBCS, Turbo XS Catless DP and TP, CPE Nexus CBE, Autotechs, GFB Hybrid BPV, Damond Trilogy mounts (FTMFW), Bilstein B14 Coils, RX8 R3s
Addikted To Boost is offline   Reply With Quote
 Old 10-16-2009, 10:17 PM   #23
Alittle Faster
bioevolve's Avatar
Yes correct, if my memory serves me lol.
 Old 06-06-2011, 02:31 PM   #24
dkapetansky's Avatar
Posts: 171   (View Stats)
dkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond reputedkapetansky has a reputation beyond repute
Neutral  -1 score
Another way to block the coolant hoses is just to pinch them closed with clamps- see pictures. This way is really quick, simple, cheap ($5), effective, and reversible, if you decide you don't like the results, or if you want to reactivate the coolant flow for winter.
dkapetansky is offline   Reply With Quote
The Following User Says Thank You to dkapetansky For This Useful Post:
kgb (06-11-2011)
 Old 06-06-2011, 02:36 PM   #25
(With photos)
kgb (06-07-2011)
 Old 06-06-2011, 02:53 PM   #26
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
mods, can you please move this thread to the how-to section? rip, philly and bio.
 Old 08-05-2011, 06:38 PM   #27
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
How safe is this option being that the coolant is not being recirculated? Jw since it seems too easy to be true. I would think it needs to circulate. This is very similar to deleting the oil cooler on a previous car. The fluid still needs to flow and not just hit a wall. Discuss...
 Old 08-05-2011, 06:47 PM   #28
kgb
kgb's Avatar
Posts: 808   (View Stats)
kgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the world
Groans: 88
I will take a picture of mine but tomorrow but I just connected the lines that were going to the TP together. Been a month and my BATS are much lower, no issues.
SLOWHATCH likes this.
FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs
WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s
AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI
MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute
JAM SESSION........US Amps (in Series w/ Stock Amp) using
OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back)
RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors
- Acne Rear Bumper LED Reflectors
kgb is offline   Reply With Quote
The Following User Says Thank You to kgb For This Useful Post:
SLOWHATCH (08-06-2011)
 Old 08-05-2011, 08:28 PM   #29
I've been running this setup for 4 months now, and so far the only effect I've seen is lower BAT's. I'm not looking for trouble, and so far I haven't seen anything worrisome.
 Old 08-05-2011, 08:38 PM   #30
JBR
JBR's Avatar
Posts: 6,629   (View Stats)
Groans: 28
This is a great mod and works very well.
JBR is offline   Reply With Quote
 Old 08-06-2011, 06:12 PM   #31
kgb
kgb's Avatar
Groans: 88
Here are the pictures of the TP bypass along with the capping of the TP.
I bought a barb connector from Home Depot to connect the lines (forgot size but fits well!) I then wrapped with tape, then reused the clamps.
hose barb connector Sales, Buy hose barb connector Products from alibaba.com
Once heatsoaked, meth or FMIC are the only real options. This mod really works well for limited stop and go for me!
davros (04-15-2015)
 Old 08-06-2011, 07:29 PM   #32
SLOWHATCH's Avatar
Groans: 274
^^^You kinda beat me to it, but here is what I used. I just did this today and it was incredibly easy. According to my AP it made a noticeable difference in BAT's. I got the barb and clamps from autozone for less than $10, I already had the vaccum caps, but you can get those there also.
The Following 2 Users Say Thank You to SLOWHATCH For This Useful Post:
rfinkle2 (08-08-2011), SeeMeGovan (01-16-2014)
 Old 08-08-2011, 12:28 PM   #33
tooslow10's Avatar
Posts: 700   (View Stats)
tooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the worldtooslow10 is the leader of the world
@SLOWHATCH , when u did this, before u capped the tb inlet/outlet, did u allow the coolant to drain or just quick cap before it came out??
no more MS3 in the driveway
but there is an EcoBoost FX2 that will be hunting on the freeways soooon!!
TEAM LBN BEERS -- FYCN
TEAM MEAGHAN -- FYCN
tooslow10 is offline   Reply With Quote
 Old 08-08-2011, 12:58 PM   #34
wankular's Avatar
Posts: 4,343   (View Stats)
Could you just clamp the hoses with two pairs of vice grips near the TB so you wouldn't spill much? If I even look at my radiator hoses wrong it seems like I spill half a gallon.
2009 MS3 sport MGM
The Following User Says Thank You to wankular For This Useful Post:
SLOWHATCH (08-08-2011)
 Old 08-08-2011, 03:32 PM   #35
SLOWHATCH's Avatar
Groans: 274
I was actually expecting coolant to run out, I even had a cup in place to catch it, but nothing came out. I was parked on a flat surface (in garage). Kinda surprised me that nothing came out. I even waited a bit while I was getting everything together and nothing. Car was cold, so guessing it had all ran back out?
LOL. I think you will be ok on this one. But you can use the grips if you want, although if they are the reg size ones they will just be in the way. The hoses are pretty small. I would just undo the hose clamps at the tb, pull hoses and insert the barb, then connect the two hoses together and clamp everything down. Then cap the in/out on tb. Start the car and check for any leaks.
I would still have a small cup or something in place in case something does spill.
Last edited by SLOWHATCH; 08-08-2011 at 03:34 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to SLOWHATCH For This Useful Post:
wankular (08-08-2011)
 Old 08-08-2011, 03:37 PM   #36
wankular's Avatar
When people talk about "burping" the system, is that just the sequence of revving to get the air bubbles out? In the repair manual there are directions for this (hold at 2500 rpms for 30sec, etc...)
2009 MS3 sport MGM
 Old 08-08-2011, 03:53 PM   #37
SLOWHATCH's Avatar
Groans: 274
Some cars are different. My last car had a bleeder valve by the cap which was used to let out any air trapped in the system. This is usually only needed (to my knowledge) when draining and refilling the radiator.
I don't forsee this mod creating that issue, but anything is possible.
The sequence you mention, is that supposed to be done with the radiator overflow lid off?
 Old 08-08-2011, 03:57 PM   #38
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
I have only seen 1 person on the forum have a problem after doing this (and I believe it was resolved through "burping" lol.
You could always "burp" the system for safety, but the car will run really hot if there are air bubbles in the system (so you'll definitely know something is up if your engine coolant temps are higher than usual).
The Following 3 Users Say Thank You to rfinkle2 For This Useful Post:
Broxer (10-07-2011), kgb (08-08-2011), SLOWHATCH (08-08-2011)
 Old 08-08-2011, 04:48 PM   #39
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
What a blast from the past this thread is lol
NATOR PA
 Old 08-08-2011, 04:50 PM   #40
wankular's Avatar
Someone bump bio's liquid to air intercooler thread next!
2009 MS3 sport MGM
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/throttle-body-pass-30053/
WTB - Looking for an intercooler This thread Refback 08-05-2013 11:36 AM
2 fuel pumps and a throttle body straydoginc MazdaSpeed 3 - Engine, Transmission & Driveline 18 05-26-2009 10:18 AM
Lingenfelter releases info on engine packages, body kit for 2010 Camaro body kit Haltech Automotive News 0 05-04-2009 10:00 AM
So who wants a bigger throttle body? redrocketz MazdaSpeed 3 - Engine, Transmission & Driveline 16 04-09-2008 11:52 AM
Page generated in 0.58491 seconds with 40 queries
