Ticking sound from gearbox I changed RMM to a CP-e 'stage 2' last Saturday. Once done, I went out for some 'spirited' driving... just to test it out. I went full bore through the gears (from standstill) up to 130, remembered I was hungry so I went to the nearest drivethru junkfood place... it was then I heard a ticking sound from the gearbox area (well under there somewhere), disappeared when engaging the clutch, but still there on the first gear when driving away slowly. It was gone when I got back home though, and I haven't heard it since... did it fix itself??? If I would guess it sounded like a bad sync ring...? |
Thanks. I guess it could be gear clatter... see if I can recreate it, I guess it's time for more junkfood. |
| All times are GMT -7. The time now is 07:29 AM. |
