 Old 07-23-2008, 11:01 AM   #41
samsel450r's Avatar
Posts: 350   (View Stats)
samsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the worldsamsel450r is the leader of the world
here what mine looked like and the repair... i dont think it will hold up but we will see.. i only used 1500psi epoxy....i used tape to get the mold...
1999 Formula WS6 1 of 175 Made
Built 347 - Built 347, ARP everything, milled AFR 205's, PatG cam, ls6 Intake, MTI TB, Jethot LT's, True duals, 9inch rear 3.73's, built t56, NX kit W/NANO and more!
samsel450r is offline   Reply With Quote
 Old 07-29-2008, 06:02 PM   #42
qwerty4550's Avatar
Posts: 62   (View Stats)
qwerty4550 has a spectacular aura aboutqwerty4550 has a spectacular aura about
Jack up the drivers side of the car, put the car in gear, try to move the front tire back and forth, if the engine moves alot, ure fucked. Mine wiggled ALOT, after i filled it I can't get it to move no matter how hard i try to spin the wheel
I did this and my engine moved back and forth a good amount. I then removed the battery tray and then tightened the bolt to 95 lbs/ft torque I believe and it does not rock back and forth any more.
The weird thing is that it makes a slight creaking noise right when I start to rotate the tire. Any thoughts on what this might be due to?
qwerty4550 is offline   Reply With Quote
 Old 10-20-2008, 03:17 PM   #43
badams118's Avatar
Posts: 821   (View Stats)
badams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the world
Groaned at 126 Times in 71 Posts
I've been hearing a creaking when I engage the clutch. It is even more obvious with passengers in the car. Is this a common symptom of this tranny mount problem?
badams118 is offline   Reply With Quote
 Old 10-25-2008, 07:19 AM   #44
fbpem1's Avatar
Posts: 1,159   (View Stats)
fbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the world
Groaned at 47 Times in 40 Posts
why jb weld? it turns brittle you should use something with a little bit of play in it. like window weld, thats what i used to fill mounts on some of my other cars, honda torque mounts i did all the time on all the ones i owned and that worked extremly well. I will do this next week with window weld and take some pictures and such.
fbpem1 is offline   Reply With Quote
tranny fluid change how to? bombdotcom MazdaSpeed 3 - Engine, Transmission & Driveline 4 05-01-2009 09:53 PM
mazda wont fix my tranny... bombdotcom MazdaSpeed 3 - Engine, Transmission & Driveline 18 07-11-2008 11:54 AM
when do i change the tranny fluid? skeeter149 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-21-2008 12:22 PM
Tranny fluid.. MT-90 GL4 or GL5? Friction Modifier? speed3 Mazdaspeed3/6 General Discussion 34 06-17-2008 08:07 AM
Page generated in 0.25870 seconds with 24 queries
