![]() | | #41 | ![]() |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score so your over drive pinion is failing or broke in poorly After a quick review of the trans details, your guess is "almost" completely correct! The 5th and 6th gears in both the Speed3 & 6 trans have their own output shaft that drives the ring gear separately. This means that the trans has TWO output shafts that drive the ring gear, each shaft having a different pinion gear size and thusly a different final drive ratio as listed in the specs..... Here is an image of the trans. Note the Primary Shaft is the input from the clutch disc. The Secondary (output) Shaft #1 has 1-4th gears and the smaller final drive pinion running the ring gear when in gears 1-4. The Secondary (output) Shaft #2 has 5-6th gears and the larger final pinion running the ring gear in gears 5-6. Pretty simple actually....
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan Last edited by rigor; 07-09-2013 at 08:55 PM. |
![]() | | #42 | ![]() |
Groans: 40
| Not Ranked : 0 score the worst part is the 3 need replaced to fix it right. as they wear together, the 2 pinion gears and the ring gear, if you only replace one you think its loud now, it will be even louder
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
| The Following User Says Thank You to rigor For This Useful Post: | DuBz (07-09-2013) |
![]() | | #43 | ![]() |
![]() Join Date: Sep 2011 Location: Pearl River, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 328
(Thread Starter) | Not Ranked : 0 score @rigor; Is it possible to replace all 3 by dropping the trans and changing them out, or is it the equivalent of a rebuild?
__________________ GenWin Mazdaspeed 3: HTP 3", CP-E RMM: HKS SSQV : masonville knob, JBR SSP, bushings, RSB: COBB AP: STRATIFIED: Saikou Michi OCC: CP-E DP & FMIC: Autotech Internals: Koni FSD's: DO Meth A La WW tank style |
![]() | | #44 | ![]() |
Groans: 40
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan | |
![]() | | #45 | ![]() |
(Thread Starter) | Not Ranked : 0 score I haz done internals all by myself, how hard could rebuilding a transmission be?
| The Following User Says Thank You to DuBz For This Useful Post: | xantho99 (08-12-2013) |
![]() | | #46 | ![]() |
Groans: 40
| Not Ranked : 0 score if it was just syncros / gears, id say give it a try maybe, but the ring and pinions, are a different ball game, tuns of special tools required... one error and it's a bucket of shit unfortunately...
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan Last edited by rigor; 07-09-2013 at 10:27 PM. |
![]() | | #47 | ![]() |
(Thread Starter) | Not Ranked : 0 score haha I don't think I'd ever attempt something as heavy as that, as you can see by my trans fluid theory, I'm clearly both mentally and mechanically retarded.
![]() | | #48 | ![]() |
![]() Join Date: Apr 2010 Location: Des Plaines, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 234
Groaned at 53 Times in 17 Posts
At least we know most likely what the issue is. The only think that worries me is how save is it? Can you drive the car like this? And could it cause any additional damage? I still wonder why the noise started after an oil change? It did fix shifting(def smoother) but... | |
![]() | | #49 | ![]() |
Groans: 40
| Not Ranked : 0 score oil will make no diff on the whine
| The Following User Says Thank You to rigor For This Useful Post: | DuBz (07-10-2013) |
![]() | | #50 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm gonna agree with rigor, he seems to know his shit when it comes to transmissions. With this new knowledge he has graciously bestowed upon me, I can't see how taking out good gear oil and replacing it with garbage gear oil would help me at this point. If I feel like throwing away 70 bucks at the stealership, I'll let you know how it turns out.
| The Following User Says Thank You to DuBz For This Useful Post: | dead-zone (07-11-2013) |
![]() | | #51 | ![]() |
| Not Ranked : 0 score I agree with both of you. I on top of it, you already tried the friction modifier and that could of made some difference. Rigor, will this issue cause any further damage on the trans? What do you think? |
![]() | | #52 | ![]() |
Groans: 40
but if it gets louder check for metal, but if it is staying the same and no metal your good! a little brass looking stuff is ok that is syncro material, if you see this your being hard on the tranny, and it is going to start jumping out of gear eventually, the syncros are 2 piece and flimsy as hell! same with the shift forks i trashed one of these trannys in 17000 miles
![]() | | #53 | ![]() |
(Thread Starter) | Not Ranked : 0 score So after being relieved by this ring and pinion diagnosis I decided to get on the pedal (been babying it since I didn't know the source of the noise) and when I was getting up there in 5th and 6th the whine was insanely loud.......I know speed is a factor, but damn that shit was screaming, guess I'll have to drain a little and check for flakes/brass/dead hooker fragments.
| The Following User Says Thank You to DuBz For This Useful Post: | rigor (07-12-2013) |
![]() | | #54 | ![]() |
Groans: 40
| Not Ranked : 0 score they will sing, is it a high pitch ring?
![]() | | #55 | ![]() |
(Thread Starter) | Not Ranked : 0 score yes, absolutely high pitched, it does it in 2nd, 5th, and 6th only, and it used to go away when coasting but now it'll do it anytime I'm in those gears.
![]() | | #56 | ![]() |
Groans: 40
| Not Ranked : 0 score iit will damn near make your ears bleed, as long as it don't sound rough or uneven ,just nice smooth ear peircing ring, you should be fine, may need ear plugs though..... 2nd? mine is starting to whine to
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan Last edited by rigor; 07-12-2013 at 10:12 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #57 | ![]() |
Groans: 40
| Not Ranked : 0 score Hy-per Lube Oil Supplement | Oil Stabilizer | Oil Additive this is some bad ass shit good to 2200 deg compatible with synthetic / non synthetic i run it in my jeep definitely stop galling,i think im going to put some of this shit in mine, help it out a little lol, im not nice to mine
![]() | | #58 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm sure that BT isn't nice to it either I just may try this lube you speak of, you think it'll quiet it down?
![]() | | #59 | ![]() |
Groans: 40
| Not Ranked : 0 score it does add lots of film strength so it might some, id add a quart of it couldn't hurt, its hard to diagnose your problem from Oregon lol our tranny oil is thin for better mpg so this might help quiet it some
| The Following User Says Thank You to rigor For This Useful Post: | DuBz (07-13-2013) |
![]() | | #60 | ![]() |
![]() Join Date: Sep 2009 Location: Surburban Detroit Michigan
Rep Power: 2266 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,223
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score Just had mine looked at. Bad bearing in the secondary shaft. Drivable but going to need replacing. 150K beat to death miles. Might just trade it in. |
![]() | | #61 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm going to wrap this thread up and assume that I have a bad bearing like this guy^, mine just went 90K sooner. It seems like it's getting slightly louder every time I drive it, but that may just be my car psychosis kicking in. @rigor; that Hyper-lube molasses you recommended is the shit, I threw the whole Qt. in there and while it's continuing to keep my shifting buttery smooth, it didn't affect the noise at all, as you pretty much predicted. While I was draining some of the motorcraft I checked it out, there wasn't one flake or fragment of anything in there. However, it seems to be getting louder, and now I'm hearing it ever so slightly in 4th as well, but it is more uneven than 5th or 6th. I give up, I'm just gonna drive this bitch until it blows. @SPEED6 KILLAH; you MIGHT be hearing from me very soon. /thread
| The Following User Says Thank You to DuBz For This Useful Post: | rigor (08-12-2013) |
![]() | | #62 | ![]() |
Groans: 40
| Not Ranked : 0 score to bad i cant ride in it, i could pin point it better, good luck man hope all turns out good
| The Following User Says Thank You to rigor For This Useful Post: | DuBz (08-12-2013) |
![]() | | #63 | ![]() |
![]() Join Date: Aug 2011 Location: Murrieta, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,535
Groans: 60
__________________ 2011 MS3. Cobb AP V3, GTX3071, CPE LTR mani, Tial 44mm EWG, 3 bar MAP sensor and PnP harness, JBR WP intake, HTP battery tray with a 51 Optima Yellow battery, ITV22s, GFB BOV, Autotech internals, CPE injector seals and studs, VTCS delete, COBB FMIC, UR DP and TP, CNT CBE, JBR TIGs and Coolant bypass, JBR EGR delete, JBR RMM, PMM, and TMM, JBR OCC, PERM Plate, JBR RSB, JBR Rear Camber arms, 17X8 RPF1, TWM full replacement shifter with a PERM buttplug shift knob. Waiting to install:Built block, NJspeed PNP IM, Prosport boost and water temp gauges, coilovers and shit. | |
| Whine only in 5th and 6th gear? | Brian06460 | MazdaSpeed 3 - Engine, Transmission & Driveline | 9 | 01-03-2014 08:56 AM |
| PS Pump whine | Smoker6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 0 | 02-06-2012 08:50 PM |
| supercharger whine | turd burglar | MazdaSpeed 3/6 - Turbo Induction | 85 | 06-27-2011 01:07 PM |
| Transmission Whine | 8.5MS3 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 4 | 08-04-2009 01:31 PM |
