 Old 09-08-2019, 10:33 AM   #1
dharv4's Avatar
Posts: 63   (View Stats)
dharv4 has disabled reputation
Default Trans build?
Been a while since last thread. Put 100K on the my last (OVERBUILT$$$) engine. Now it's protesting my sometimes cavalier oil-level management with subtle, bottom-end, rattlings, unfortunately reminiscent of the spun-fried rod bearing variety, responsible for the demise of its predecessor! I recognized them immediately and have parked the car in the garage and purchased another engine. I'm going with a fully BBB, drop-in, long block and new tune this time but what about the trans? I've been so caught-up with engines over the years, I've forgotten about the trans! It's working very well with the current clutch but it has 200k now. It's the only thing that hasn't been replaced at least once! New trans from Mazda, re-build with gear set...or leave it alone till it breaks? Whats being done with the most success, nowadays? Thanks
dharv4 is offline   Reply With Quote
 Old 09-08-2019, 10:25 PM   #2
SSinstaller's Avatar
Posts: 3,985   (View Stats)
Groans: 60
Unless its giving you problems or you want taller gearing, nothing much to do with the transmission.. If you want to be 100% certian you could pull it apart and check the actual gearsets.
 Old 09-09-2019, 09:37 AM   #3
dharv4's Avatar
Thanks, Installer, for your thoughts. I've learned all lessons the hard ($$$) way so far with this car....my Mazdarati , and don't want to schooled again at this late date. Just snoopin' around to benefit from what others might have experienced.
Differences between a ms6 trans and a ms3 trans? alex_dewitt_ms3 MazdaSpeed 3 - Engine, Transmission & Driveline 6 07-28-2016 08:24 AM
Build my engine or built longblock? Built trans? Mustangkr500 Mazdaspeed3/6 General Discussion 24 07-22-2016 12:17 PM
trans pto rear diff build Matx MazdaSpeed 6 - Engine, Transmission & Driveline 5 08-24-2012 01:22 PM
Suggestions (ECU, trans, rear end, etc) for MZR build DarkPasseng3r Gen2 MS3 General Discussion 5 06-06-2012 04:54 PM
Page generated in 0.26217 seconds with 21 queries
